Computer refuses to wake after sleep
Hello! I’m quite new to forum posts, so please forgive me if I don’t have everything down just yet. I’ve looked around the forum, but nothing seems to describe my particular issue, and solutions haven’t helped.
When I put my computer into sleep (suspend-to-RAM), it shuts the case and peripherals down, and if I try to wake it, it refuses to wake up. My peripherals and case come on, but my displays don’t turn on, and the computer takes no inputs.
Since I’ve seen journalctl mentioned in some places, here’s the output of journalctl | grep sleep for the latest sleep event I tried.
Mar 18 18:56:29 soleil ModemManager[794]: <msg> [sleep-monitor-systemd] system is about to suspend
Mar 18 18:56:29 soleil NetworkManager[730]: <info>  [1742342189.4274] manager: sleep: sleep requested (sleeping: no  enabled: yes)
Mar 18 18:56:29 soleil NetworkManager[730]: <info>  [1742342189.4275] device (enp4s0): state change: unavailable -> unmanaged (reason 'unmanaged-sleeping', managed-type: 'full')
Mar 18 18:56:29 soleil NetworkManager[730]: <info>  [1742342189.4368] device (p2p-dev-wlp3s0): state change: disconnected -> unmanaged (reason 'unmanaged-sleeping', managed-type: 'full')
Mar 18 18:56:29 soleil NetworkManager[730]: <info>  [1742342189.4372] device (wlp3s0): state change: activated -> deactivating (reason 'sleeping', managed-type: 'full')
Mar 18 18:56:29 soleil NetworkManager[730]: <info>  [1742342189.7137] device (wlp3s0): state change: deactivating -> disconnected (reason 'sleeping', managed-type: 'full')
Mar 18 18:56:29 soleil NetworkManager[730]: <info>  [1742342189.8358] device (wlp3s0): state change: disconnected -> unmanaged (reason 'unmanaged-sleeping', managed-type: 'full')
Mar 18 18:56:30 soleil systemd-sleep[1486]: User sessions remain unfrozen on explicit request ($SYSTEMD_SLEEP_FREEZE_USER_SESSIONS=0).
Mar 18 18:56:30 soleil systemd-sleep[1486]: This is not recommended, and might result in unexpected behavior, particularly
Mar 18 18:56:30 soleil systemd-sleep[1486]: in suspend-then-hibernate operations or setups with encrypted home directories.
Mar 18 18:56:30 soleil systemd-sleep[1486]: Performing sleep operation 'suspend'...
Mar 18 18:56:47 soleil kernel: ACPI: PM: Preparing to enter system sleep state S3
Mar 18 18:56:47 soleil kernel: ACPI: PM: Waking up from system sleep state S3
Mar 18 18:56:47 soleil systemd-sleep[1486]: System returned from sleep operation 'suspend'.
Mar 18 18:58:38 soleil org_kde_powerdevil[1094]: [  1094] is_sysfs_reliable_for_busno(0) returned false and session_type = X11. Using X11 to determine if display is asleep
Mar 18 18:58:38 soleil org_kde_powerdevil[1094]: [  1094] is_sysfs_reliable_for_busno(1) returned false and session_type = X11. Using X11 to determine if display is asleep
Mar 18 18:58:38 soleil org_kde_powerdevil[1094]: [  1094] is_sysfs_reliable_for_busno(2) returned false and session_type = X11. Using X11 to determine if display is asleep
Mar 18 18:58:38 soleil org_kde_powerdevil[1094]:    last_checked_asleep:       false
Mar 18 18:58:38 soleil org_kde_powerdevil[1094]: [  1094] is_sysfs_reliable_for_busno(3) returned false and session_type = X11. Using X11 to determine if display is asleep
Mar 18 18:58:39 soleil org_kde_powerdevil[1094]: [  1094] is_sysfs_reliable_for_busno(4) returned false and session_type = X11. Using X11 to determine if display is asleep
Mar 18 18:58:39 soleil org_kde_powerdevil[1094]: [  1094] is_sysfs_reliable_for_busno(3) returned false and session_type = X11. Using X11 to determine if display is asleep
I’m not fully sure what the issue is. I noticed that it’s telling me “User sessions remain unfrozen on explicit request” and that it isn’t recommended (my system is encrypted), but I’m not quite sure how to fix that? It also seems like org_kde_powerdevil is struggling with my displays, but that’s more of a guess than anything. Any ideas? I’m willing to try anything.
Seemingly relevant specs:
KDE Plasma Version: 6.3.3
GPU: NVIDIA GeForce RTX 3060
GPU Drivers: Proprietary linux612-nvidia 550.144.03-9
The following should help; in particular the links given.
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Be prepared to provide more information and outputs from other commands whenever asked.
Required reading
Resources
