Well it keeps happening faster now so here is the journalctl part 1 since it was to large for 1 message.
aug 04 18:51:41 z97mds3h kernel: ACPI Warning: SystemIO range 0x0000000000001828-0x000000000000182F conflicts with OpRegion 0x0000000000001800-0x000000000000187F (\PMIO) (20211217/utaddress-204)
aug 04 18:51:41 z97mds3h kernel: ACPI Warning: SystemIO range 0x0000000000001C40-0x0000000000001C4F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20211217/utaddress-204)
aug 04 18:51:41 z97mds3h kernel: ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20211217/utaddress-204)
aug 04 18:51:41 z97mds3h kernel: ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20211217/utaddress-204)
aug 04 18:51:41 z97mds3h kernel: ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20211217/utaddress-204)
aug 04 18:51:41 z97mds3h kernel: ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20211217/utaddress-204)
aug 04 18:51:41 z97mds3h kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
aug 04 18:51:42 z97mds3h kernel: at24 0-0051: supply vcc not found, using dummy regulator
aug 04 18:51:42 z97mds3h kernel: at24 0-0053: supply vcc not found, using dummy regulator
aug 04 18:51:42 z97mds3h kernel: r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
aug 04 18:51:42 z97mds3h kernel: nvidia: loading out-of-tree module taints kernel.
aug 04 18:51:42 z97mds3h kernel: nvidia: module license 'NVIDIA' taints kernel.
aug 04 18:51:42 z97mds3h kernel: Disabling lock debugging due to kernel taint
aug 04 18:51:42 z97mds3h kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 515.57 Wed Jun 22 22:44:07 UTC 2022
aug 04 18:51:43 z97mds3h kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
aug 04 18:51:44 z97mds3h kernel: kauditd_printk_skb: 126 callbacks suppressed
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (--) Log file renamed from "/var/log/Xorg.pid-659.log" to "/var/log/Xorg.0.log"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: X.Org X Server 1.21.1.4
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: X Protocol Version 11, Revision 0
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: Current Operating System: Linux z97mds3h 5.18.14-1-MANJARO #1 SMP PREEMPT_DYNAMIC Sun Jul 24 09:00:58 UTC 2022 x86_64
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64 root=UUID=a29c54a8-ea4b-4aee-9575-18fcf74b37f2 rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: Current version of pixman: 0.40.0
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: Before reporting problems, check http://wiki.x.org
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: to make sure that you have the latest version.
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: Markers: (--) probed, (**) from config file, (==) default setting,
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (++) from command line, (!!) notice, (II) informational,
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (==) Log file: "/var/log/Xorg.0.log", Time: Thu Aug 4 18:51:44 2022
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (==) Using config directory: "/etc/X11/xorg.conf.d"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (==) ServerLayout "layout"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (==) No screen section available. Using defaults.
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (**) |-->Screen "Default Screen Section" (0)
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (**) | |-->Monitor "<default monitor>"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (==) No monitor specified for screen "Default Screen Section".
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: Using a default monitor configuration.
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (==) Automatically adding devices
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (==) Automatically enabling devices
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (==) Automatically adding GPU devices
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (==) Automatically binding GPU devices
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (==) Max clients allowed: 256, resource mask: 0x1fffff
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (WW) The directory "/usr/share/fonts/misc" does not exist.
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: Entry deleted from font path.
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (WW) The directory "/usr/share/fonts/OTF" does not exist.
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (WW) The directory "/usr/share/fonts/Type1" does not exist.
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (WW) The directory "/usr/share/fonts/100dpi" does not exist.
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (WW) The directory "/usr/share/fonts/75dpi" does not exist.
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (==) FontPath set to:
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: /usr/share/fonts/TTF
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (==) ModulePath set to "/usr/lib/xorg/modules"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) The server relies on udev to provide the list of input devices.
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: If no devices become available, reconfigure udev or disable AutoAddDevices.
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) Module ABI versions:
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: X.Org ANSI C Emulation: 0.4
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: X.Org Video Driver: 25.2
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: X.Org XInput driver : 24.4
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: X.Org Server Extension : 10.0
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (++) using VT number 1
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) xfree86: Adding drm device (/dev/dri/card1)
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card1
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 14 paused 0
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) xfree86: Adding drm device (/dev/dri/card0)
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 15 paused 0
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (--) PCI: (0@0:2:0) 8086:0412:1458:d000 rev 6, Mem @ 0xf7400000/4194304, 0xd0000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (--) PCI:*(1@0:0:0) 10de:13c2:1462:3171 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) LoadModule: "glx"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) Module glx: vendor="X.Org Foundation"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: compiled for 1.21.1.4, module version = 1.0.0
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: ABI class: X.Org Server Extension, version 10.0
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) Applying OutputClass "nvidia" to /dev/dri/card1
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: loading driver: nvidia
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) Applying OutputClass "intel" to /dev/dri/card0
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: loading driver: modesetting
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (==) Matched nvidia as autoconfigured driver 0
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (==) Matched nouveau as autoconfigured driver 1
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (==) Matched nv as autoconfigured driver 2
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (==) Matched modesetting as autoconfigured driver 3
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (==) Matched fbdev as autoconfigured driver 4
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (==) Matched vesa as autoconfigured driver 5
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (==) Assigned the driver to the xf86ConfigLayout
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) LoadModule: "nvidia"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) Module nvidia: vendor="NVIDIA Corporation"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: compiled for 1.6.99.901, module version = 1.0.0
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: Module class: X.Org Video Driver
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) LoadModule: "nouveau"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (WW) Warning, couldn't open module nouveau
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (EE) Failed to load module "nouveau" (module does not exist, 0)
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) LoadModule: "nv"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (WW) Warning, couldn't open module nv
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (EE) Failed to load module "nv" (module does not exist, 0)
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) LoadModule: "modesetting"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) Module modesetting: vendor="X.Org Foundation"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: compiled for 1.21.1.4, module version = 1.21.1
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: ABI class: X.Org Video Driver, version 25.2
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) LoadModule: "fbdev"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (WW) Warning, couldn't open module fbdev
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (EE) Failed to load module "fbdev" (module does not exist, 0)
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) LoadModule: "vesa"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (WW) Warning, couldn't open module vesa
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (EE) Failed to load module "vesa" (module does not exist, 0)
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) NVIDIA dlloader X Driver 515.57 Wed Jun 22 22:37:27 UTC 2022
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) modesetting: Driver for Modesetting Kernel Drivers: kms
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) systemd-logind: releasing fd for 226:1
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) Loading sub module "fb"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) LoadModule: "fb"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) Module "fb" already built-in
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) Loading sub module "wfb"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) LoadModule: "wfb"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) Loading /usr/lib/xorg/modules/libwfb.so
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) Module wfb: vendor="X.Org Foundation"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: ABI class: X.Org ANSI C Emulation, version 0.4
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) Loading sub module "ramdac"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) LoadModule: "ramdac"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) Module "ramdac" already built-in
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (WW) Falling back to old probe method for modesetting
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) modeset(G0): using drv /dev/dri/card0
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) NVIDIA(0): Creating default Display subsection in Screen section
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: "Default Screen Section" for depth/fbbpp 24/32
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (==) NVIDIA(0): RGB weight 888
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (==) NVIDIA(0): Default visual is TrueColor
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "AllowNVIDIAGpuScreens"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) Applying OutputClass "nvidia" options to /dev/dri/card1
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (**) NVIDIA(0): Enabling 2D acceleration
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) Loading sub module "glxserver_nvidia"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) LoadModule: "glxserver_nvidia"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: Module class: X.Org Server Extension
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) NVIDIA GLX Module 515.57 Wed Jun 22 22:33:44 UTC 2022
aug 04 18:51:44 z97mds3h /usr/lib/gdm-x-session[659]: (II) NVIDIA: The X server supports PRIME Render Offload.
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(0): CRT-0
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(0): DFP-0
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(0): DFP-1 (boot)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(0): DFP-2
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(0): DFP-3
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(0): DFP-4
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(0): DFP-5
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(0): DFP-6
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(0): DFP-7
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) NVIDIA(0): NVIDIA GPU NVIDIA GeForce GTX 970 (GM204-A) at PCI:1:0:0
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) NVIDIA(0): (GPU-0)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(0): Memory: 4194304 kBytes
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(0): VideoBIOS: 84.04.36.00.73
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) NVIDIA(0): Detected PCI Express Link width: 16X
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): CRT-0: disconnected
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-0: disconnected
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): Philips 247E4 (DFP-1): connected
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): Philips 247E4 (DFP-1): Internal TMDS
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): Philips 247E4 (DFP-1): 600.0 MHz maximum pixel clock
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-2: disconnected
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-3: disconnected
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-4: disconnected
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-5: disconnected
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-6: disconnected
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-7: disconnected
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (==) NVIDIA(0):
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (==) NVIDIA(0): will be used as the requested mode.
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) NVIDIA(0): Validated MetaModes:
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) NVIDIA(0): "DFP-1:nvidia-auto-select"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(0): DPI set to (93, 94); computed from "UseEdidDpi" X config
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(0): option
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (==) modeset(G0): RGB weight 888
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (==) modeset(G0): Default visual is TrueColor
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Loading sub module "glamoregl"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) LoadModule: "glamoregl"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Loading /usr/lib/xorg/modules/libglamoregl.so
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Module glamoregl: vendor="X.Org Foundation"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: compiled for 1.21.1.4, module version = 1.0.1
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: ABI class: X.Org ANSI C Emulation, version 0.4
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) modeset(G0): glamor X acceleration enabled on Mesa Intel(R) HD Graphics 4600 (HSW GT2)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) modeset(G0): glamor initialized
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) modeset(G0): Output VGA-1-1 has no monitor section
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) modeset(G0): Output HDMI-1-1 has no monitor section
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) modeset(G0): Output HDMI-1-2 has no monitor section
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) modeset(G0): EDID for output VGA-1-1
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) modeset(G0): EDID for output HDMI-1-1
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) modeset(G0): EDID for output HDMI-1-2
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (==) modeset(G0): DPI set to (96, 96)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Loading sub module "fb"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) LoadModule: "fb"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Module "fb" already built-in
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) NVIDIA: Reserving 6144.00 MB of virtual memory for indirect memory
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) NVIDIA: access.
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) NVIDIA(0): configuration option may not be set correctly. When the
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) NVIDIA(0): Config Options in the README.
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) NVIDIA(0): Setting mode "DFP-1:nvidia-auto-select"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (==) NVIDIA(0): Disabling shared memory pixmaps
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (==) NVIDIA(0): Backing store enabled
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (==) NVIDIA(0): Silken mouse enabled
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (==) NVIDIA(0): DPMS enabled
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Loading sub module "dri2"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) LoadModule: "dri2"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Module "dri2" already built-in
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) NVIDIA(0): [DRI2] Setup complete
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (==) modeset(G0): Backing store enabled
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (==) modeset(G0): Silken mouse enabled
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (==) modeset(G0): DPMS enabled
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) modeset(G0): [DRI2] Setup complete
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) modeset(G0): [DRI2] DRI driver: crocus
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) modeset(G0): [DRI2] VDPAU driver: va_gl
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) modeset(G0): Disable reverse prime offload mode for i915.
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension Generic Event Extension
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension SHAPE
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension MIT-SHM
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension XInputExtension
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension XTEST
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension BIG-REQUESTS
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension SYNC
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension XKEYBOARD
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension XC-MISC
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension SECURITY
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension XFIXES
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension RENDER
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension RANDR
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension COMPOSITE
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension DAMAGE
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension MIT-SCREEN-SAVER
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension DOUBLE-BUFFER
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension RECORD
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension DPMS
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension Present
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension DRI3
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension X-Resource
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension XVideo
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension XVideo-MotionCompensation
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension GLX
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Indirect GLX disabled.
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) GLX: Another vendor is already registered for screen 0
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension XFree86-VidModeExtension
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension XFree86-DGA
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension XFree86-DRI
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension DRI2
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension NV-GLX
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension NV-CONTROL
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Initializing extension XINERAMA
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) modeset(G0): Damage tracking initialized
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device Power Button (/dev/input/event2)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Power Button: Applying InputClass "evdev keyboard catchall"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Power Button: Applying InputClass "libinput keyboard catchall"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Power Button: Applying InputClass "system-keyboard"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) LoadModule: "libinput"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Module libinput: vendor="X.Org Foundation"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: compiled for 1.21.1.3, module version = 1.2.1
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: Module class: X.Org XInput Driver
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: ABI class: X.Org XInput driver, version 24.4
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Using input driver 'libinput' for 'Power Button'
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 51 paused 0
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Power Button: always reports core events
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "Device" "/dev/input/event2"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event2 - Power Button: is tagged by udev as: Keyboard
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event2 - Power Button: device is a keyboard
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event2 - Power Button: device removed
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "xkb_layout" "us"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device Video Bus (/dev/input/event4)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Video Bus: Applying InputClass "evdev keyboard catchall"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Video Bus: Applying InputClass "libinput keyboard catchall"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Video Bus: Applying InputClass "system-keyboard"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Using input driver 'libinput' for 'Video Bus'
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 54 paused 0
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Video Bus: always reports core events
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "Device" "/dev/input/event4"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event4 - Video Bus: is tagged by udev as: Keyboard
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event4 - Video Bus: device is a keyboard
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event4 - Video Bus: device removed
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input26/event4"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device Power Button (/dev/input/event0)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 55 paused 0
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "Device" "/dev/input/event0"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event0 - Power Button: is tagged by udev as: Keyboard
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event0 - Power Button: device is a keyboard
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event0 - Power Button: device removed
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Sleep Button: Applying InputClass "system-keyboard"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Using input driver 'libinput' for 'Sleep Button'
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 56 paused 0
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Sleep Button: always reports core events
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "Device" "/dev/input/event1"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event1 - Sleep Button: is tagged by udev as: Keyboard
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event1 - Sleep Button: device is a keyboard
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event1 - Sleep Button: device removed
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event12)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) No input driver specified, ignoring this device.
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) This device may have been added with another device file.
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event13)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event15)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event16)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event19)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event20)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event23)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=3 (/dev/input/event5)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=7 (/dev/input/event6)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=8 (/dev/input/event24)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=9 (/dev/input/event25)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=10 (/dev/input/event26)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device Logitech G604 (/dev/input/event27)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Logitech G604 : Applying InputClass "evdev pointer catchall"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Logitech G604 : Applying InputClass "evdev keyboard catchall"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Logitech G604 : Applying InputClass "libinput pointer catchall"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Logitech G604 : Applying InputClass "libinput keyboard catchall"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Logitech G604 : Applying InputClass "system-keyboard"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Using input driver 'libinput' for 'Logitech G604 '
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) systemd-logind: got fd for /dev/input/event27 13:91 fd 57 paused 0
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Logitech G604 : always reports core events
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "Device" "/dev/input/event27"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event27 - Logitech G604 : is tagged by udev as: Keyboard Mouse
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event27 - Logitech G604 : device is a pointer
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event27 - Logitech G604 : device is a keyboard
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event27 - Logitech G604 : device removed
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) libinput: Logitech G604 : needs a virtual subdevice
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.2/0003:046D:C539.0003/0003:046D:4085.0007/input/input37/event27"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) XINPUT: Adding extended input device "Logitech G604 " (type: MOUSE, id 10)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "AccelerationScheme" "none"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Logitech G604 : (accel) selected scheme none/0
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Logitech G604 : (accel) acceleration factor: 2.000
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Logitech G604 : (accel) acceleration threshold: 4
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device Logitech G604 (/dev/input/mouse0)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device DATACOMP SteelS쀁̄Љ̒DATA (/dev/input/event7)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) DATACOMP SteelS쀁̄Љ̒DATA: Applying InputClass "evdev keyboard catchall"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) DATACOMP SteelS쀁̄Љ̒DATA: Applying InputClass "libinput keyboard catchall"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) DATACOMP SteelS쀁̄Љ̒DATA: Applying InputClass "system-keyboard"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Using input driver 'libinput' for 'DATACOMP SteelS쀁̄Љ̒DATA'
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 58 paused 0
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) DATACOMP SteelS쀁̄Љ̒DATA: always reports core events
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "Device" "/dev/input/event7"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event7 - DATACOMP SteelS쀁̄Љ̒DATA: is tagged by udev as: Keyboard
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event7 - DATACOMP SteelS쀁̄Љ̒DATA: device is a keyboard
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event7 - DATACOMP SteelS쀁̄Љ̒DATA: device removed
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4:1.0/0003:04B4:0101.0004/input/input8/event7"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) XINPUT: Adding extended input device "DATACOMP SteelS쀁̄Љ̒DATA" (type: KEYBOARD, id 11)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device DATACOMP SteelS쀁̄Љ̒DATA Consumer Control (/dev/input/event9)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) DATACOMP SteelS쀁̄Љ̒DATA Consumer Control: Applying InputClass "evdev keyboard catchall"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) DATACOMP SteelS쀁̄Љ̒DATA Consumer Control: Applying InputClass "libinput keyboard catchall"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) DATACOMP SteelS쀁̄Љ̒DATA Consumer Control: Applying InputClass "system-keyboard"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Using input driver 'libinput' for 'DATACOMP SteelS쀁̄Љ̒DATA Consumer Control'
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 59 paused 0
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) DATACOMP SteelS쀁̄Љ̒DATA Consumer Control: always reports core events
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "Device" "/dev/input/event9"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event9 - DATACOMP SteelS쀁̄Љ̒DATA Consumer Control: is tagged by udev as: Keyboard
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event9 - DATACOMP SteelS쀁̄Љ̒DATA Consumer Control: device is a keyboard
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event9 - DATACOMP SteelS쀁̄Љ̒DATA Consumer Control: device removed
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4:1.1/0003:04B4:0101.0005/input/input10/event9"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) XINPUT: Adding extended input device "DATACOMP SteelS쀁̄Љ̒DATA Consumer Control" (type: KEYBOARD, id 12)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device DATACOMP SteelS쀁̄Љ̒DATA System Control (/dev/input/event8)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) DATACOMP SteelS쀁̄Љ̒DATA System Control: Applying InputClass "evdev keyboard catchall"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) DATACOMP SteelS쀁̄Љ̒DATA System Control: Applying InputClass "libinput keyboard catchall"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) DATACOMP SteelS쀁̄Љ̒DATA System Control: Applying InputClass "system-keyboard"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Using input driver 'libinput' for 'DATACOMP SteelS쀁̄Љ̒DATA System Control'
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 60 paused 0
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) DATACOMP SteelS쀁̄Љ̒DATA System Control: always reports core events
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "Device" "/dev/input/event8"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event8 - DATACOMP SteelS쀁̄Љ̒DATA System Control: is tagged by udev as: Keyboard
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event8 - DATACOMP SteelS쀁̄Љ̒DATA System Control: device is a keyboard
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event8 - DATACOMP SteelS쀁̄Љ̒DATA System Control: device removed
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4:1.1/0003:04B4:0101.0005/input/input9/event8"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) XINPUT: Adding extended input device "DATACOMP SteelS쀁̄Љ̒DATA System Control" (type: KEYBOARD, id 13)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device Kingston HyperX SoloCast Consumer Control (/dev/input/event10)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Kingston HyperX SoloCast Consumer Control: Applying InputClass "evdev keyboard catchall"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Kingston HyperX SoloCast Consumer Control: Applying InputClass "libinput keyboard catchall"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Kingston HyperX SoloCast Consumer Control: Applying InputClass "system-keyboard"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Using input driver 'libinput' for 'Kingston HyperX SoloCast Consumer Control'
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 61 paused 0
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Kingston HyperX SoloCast Consumer Control: always reports core events
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "Device" "/dev/input/event10"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event10 - Kingston HyperX SoloCast Consumer Control: is tagged by udev as: Keyboard
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event10 - Kingston HyperX SoloCast Consumer Control: device is a keyboard
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event10 - Kingston HyperX SoloCast Consumer Control: device removed
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) libinput: Kingston HyperX SoloCast Consumer Control: needs a virtual subdevice
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-7/3-7:1.2/0003:0951:170F.0006/input/input11/event10"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) XINPUT: Adding extended input device "Kingston HyperX SoloCast Consumer Control" (type: MOUSE, id 14)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Kingston HyperX SoloCast Consumer Control: (accel) selected scheme none/0
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Kingston HyperX SoloCast Consumer Control: (accel) acceleration factor: 2.000
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Kingston HyperX SoloCast Consumer Control: (accel) acceleration threshold: 4
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device Kingston HyperX SoloCast (/dev/input/event11)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Kingston HyperX SoloCast: Applying InputClass "evdev keyboard catchall"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Kingston HyperX SoloCast: Applying InputClass "libinput keyboard catchall"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Kingston HyperX SoloCast: Applying InputClass "system-keyboard"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) Using input driver 'libinput' for 'Kingston HyperX SoloCast'
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 62 paused 0
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Kingston HyperX SoloCast: always reports core events
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "Device" "/dev/input/event11"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event11 - Kingston HyperX SoloCast: is tagged by udev as: Keyboard
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event11 - Kingston HyperX SoloCast: device is a keyboard
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) event11 - Kingston HyperX SoloCast: device removed
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-7/3-7:1.2/0003:0951:170F.0006/input/input12/event11"
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) XINPUT: Adding extended input device "Kingston HyperX SoloCast" (type: KEYBOARD, id 15)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event14)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event17)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event18)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event21)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event22)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) config/udev: Adding input device PC Speaker (/dev/input/event3)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) systemd-logind: returning pre-existing fd for /dev/input/event27 13:91
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) libinput: Logitech G604 : is a virtual subdevice
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) XINPUT: Adding extended input device "Logitech G604 " (type: KEYBOARD, id 16)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) systemd-logind: returning pre-existing fd for /dev/input/event10 13:74
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) libinput: Kingston HyperX SoloCast Consumer Control: is a virtual subdevice
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[659]: (II) XINPUT: Adding extended input device "Kingston HyperX SoloCast Consumer Control" (type: KEYBOARD, id 17)
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[669]: dbus-daemon[669]: [session uid=120 pid=669] Activating service name='org.a11y.Bus' requested by ':1.0' (uid=120 pid=674 comm="/usr/lib/gnome-session-check-accelerated")
aug 04 18:51:45 z97mds3h /usr/lib/gdm-x-session[669]: dbus-daemon[669]: [session uid=120 pid=669] Successfully activated service 'org.a11y.Bus'
aug 04 18:51:46 z97mds3h gnome-session-binary[670]: GLib-GIO-CRITICAL: g_bus_get_sync: assertion 'error == NULL || *error == NULL' failed
aug 04 18:51:46 z97mds3h gnome-session-binary[670]: WARNING: Could not parse desktop file orca-autostart.desktop or it references a not found TryExec binary
aug 04 18:51:46 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): CRT-0: disconnected
aug 04 18:51:46 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
aug 04 18:51:46 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-0: disconnected
aug 04 18:51:46 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
aug 04 18:51:46 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
aug 04 18:51:46 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): Philips 247E4 (DFP-1): connected
aug 04 18:51:46 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): Philips 247E4 (DFP-1): Internal TMDS
aug 04 18:51:46 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): Philips 247E4 (DFP-1): 600.0 MHz maximum pixel clock
aug 04 18:51:46 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-2: disconnected
aug 04 18:51:46 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
aug 04 18:51:46 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
aug 04 18:51:46 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-3: disconnected
aug 04 18:51:46 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
aug 04 18:51:46 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
aug 04 18:51:46 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-4: disconnected
aug 04 18:51:46 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
aug 04 18:51:46 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
aug 04 18:51:46 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-5: disconnected
aug 04 18:51:46 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
aug 04 18:51:46 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
aug 04 18:51:46 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-6: disconnected
aug 04 18:51:46 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
aug 04 18:51:46 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
aug 04 18:51:46 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-7: disconnected
aug 04 18:51:46 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
aug 04 18:51:46 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
aug 04 18:51:46 z97mds3h gnome-shell[687]: ATK Bridge is disabled but a11y has already been enabled.
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[669]: dbus-daemon[669]: [session uid=120 pid=669] Activating service name='org.freedesktop.impl.portal.PermissionStore' requested by ':1.5' (uid=120 pid=687 comm="/usr/bin/gnome-shell")
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[669]: dbus-daemon[669]: [session uid=120 pid=669] Successfully activated service 'org.freedesktop.impl.portal.PermissionStore'
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[705]: The XKEYBOARD keymap compiler (xkbcomp) reports:
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[705]: > Warning: Symbol map for key <RALT> redefined
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[705]: > Using last definition for conflicting fields
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[705]: Errors from xkbcomp are not fatal to the X server
aug 04 18:51:47 z97mds3h geoclue[722]: Failed to connect to avahi service: Daemon not running
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[669]: dbus-daemon[669]: [session uid=120 pid=669] Activating service name='org.gnome.Shell.Notifications' requested by ':1.5' (uid=120 pid=687 comm="/usr/bin/gnome-shell")
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[681]: dbus-daemon[681]: Activating service name='org.a11y.atspi.Registry' requested by ':1.1' (uid=120 pid=687 comm="/usr/bin/gnome-shell")
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[753]: The XKEYBOARD keymap compiler (xkbcomp) reports:
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[753]: > Warning: Symbol map for key <RALT> redefined
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[753]: > Using last definition for conflicting fields
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[753]: Errors from xkbcomp are not fatal to the X server
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[681]: dbus-daemon[681]: Successfully activated service 'org.a11y.atspi.Registry'
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): CRT-0: disconnected
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[669]: dbus-daemon[669]: [session uid=120 pid=669] Successfully activated service 'org.gnome.Shell.Notifications'
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-0: disconnected
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): Philips 247E4 (DFP-1): connected
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): Philips 247E4 (DFP-1): Internal TMDS
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): Philips 247E4 (DFP-1): 600.0 MHz maximum pixel clock
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-2: disconnected
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-3: disconnected
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-4: disconnected
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-5: disconnected
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-6: disconnected
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-7: disconnected
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
aug 04 18:51:47 z97mds3h org.gnome.Shell.desktop[687]: Window manager warning: Failed to parse saved session file: Openen van bestand ‘/var/lib/gdm/.config/mutter/sessions/107bf37f50c0b3d28f16596319063030000000006700000.ms’ is mislukt: Bestand of map bestaat niet
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[780]: The XKEYBOARD keymap compiler (xkbcomp) reports:
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[780]: > Warning: Symbol map for key <RALT> redefined
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[780]: > Using last definition for conflicting fields
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[780]: Errors from xkbcomp are not fatal to the X server
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[669]: dbus-daemon[669]: [session uid=120 pid=669] Activating service name='org.gtk.vfs.Daemon' requested by ':1.14' (uid=120 pid=770 comm="ibus-daemon --panel disable --xim")
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[669]: dbus-daemon[669]: [session uid=120 pid=669] Activating service name='org.gnome.ScreenSaver' requested by ':1.10' (uid=120 pid=763 comm="/usr/lib/gsd-usb-protection")
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[669]: dbus-daemon[669]: [session uid=120 pid=669] Activating service name='org.freedesktop.systemd1' requested by ':1.9' (uid=120 pid=760 comm="/usr/lib/gsd-sharing")
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[838]: The XKEYBOARD keymap compiler (xkbcomp) reports:
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[838]: > Warning: Symbol map for key <RALT> redefined
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[838]: > Using last definition for conflicting fields
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[838]: Errors from xkbcomp are not fatal to the X server
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[669]: dbus-daemon[669]: [session uid=120 pid=669] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
aug 04 18:51:47 z97mds3h gsd-sharing[760]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[669]: dbus-daemon[669]: [session uid=120 pid=669] Successfully activated service 'org.gnome.ScreenSaver'
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[669]: dbus-daemon[669]: [session uid=120 pid=669] Successfully activated service 'org.gtk.vfs.Daemon'
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[921]: The XKEYBOARD keymap compiler (xkbcomp) reports:
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[921]: > Warning: Symbol map for key <RALT> redefined
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[921]: > Using last definition for conflicting fields
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[921]: Errors from xkbcomp are not fatal to the X server
aug 04 18:51:47 z97mds3h gsd-usb-protect[763]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[927]: The XKEYBOARD keymap compiler (xkbcomp) reports:
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[927]: > Warning: Symbol map for key <RALT> redefined
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[927]: > Using last definition for conflicting fields
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[927]: Errors from xkbcomp are not fatal to the X server
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[669]: dbus-daemon[669]: [session uid=120 pid=669] Activating service name='org.freedesktop.portal.IBus' requested by ':1.14' (uid=120 pid=770 comm="ibus-daemon --panel disable --xim")
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[669]: dbus-daemon[669]: [session uid=120 pid=669] Successfully activated service 'org.freedesktop.portal.IBus'
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[948]: The XKEYBOARD keymap compiler (xkbcomp) reports:
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[948]: > Warning: Symbol map for key <RALT> redefined
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[948]: > Using last definition for conflicting fields
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[948]: Errors from xkbcomp are not fatal to the X server
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[953]: The XKEYBOARD keymap compiler (xkbcomp) reports:
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[953]: > Warning: Symbol map for key <RALT> redefined
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[953]: > Using last definition for conflicting fields
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[953]: Errors from xkbcomp are not fatal to the X server
aug 04 18:51:47 z97mds3h gsd-media-keys[787]: Failed to grab accelerator for keybinding settings:hibernate
aug 04 18:51:47 z97mds3h gsd-media-keys[787]: Failed to grab accelerator for keybinding settings:playback-random
aug 04 18:51:47 z97mds3h gsd-media-keys[787]: Failed to grab accelerator for keybinding settings:rotate-video-lock
aug 04 18:51:47 z97mds3h gsd-media-keys[787]: Failed to grab accelerator for keybinding settings:playback-repeat
aug 04 18:51:47 z97mds3h colord-sane[944]: io/hpmud/pp.c 627: unable to read device-id ret=-1
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[959]: The XKEYBOARD keymap compiler (xkbcomp) reports:
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[959]: > Warning: Symbol map for key <RALT> redefined
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[959]: > Using last definition for conflicting fields
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[959]: Errors from xkbcomp are not fatal to the X server
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[960]: The XKEYBOARD keymap compiler (xkbcomp) reports:
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[960]: > Warning: Symbol map for key <RALT> redefined
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[960]: > Using last definition for conflicting fields
aug 04 18:51:47 z97mds3h /usr/lib/gdm-x-session[960]: Errors from xkbcomp are not fatal to the X server
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[961]: The XKEYBOARD keymap compiler (xkbcomp) reports:
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[961]: > Warning: Symbol map for key <RALT> redefined
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[961]: > Using last definition for conflicting fields
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[961]: Errors from xkbcomp are not fatal to the X server
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[962]: The XKEYBOARD keymap compiler (xkbcomp) reports:
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[962]: > Warning: Symbol map for key <RALT> redefined
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[962]: > Using last definition for conflicting fields
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[962]: Errors from xkbcomp are not fatal to the X server
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[963]: The XKEYBOARD keymap compiler (xkbcomp) reports:
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[963]: > Warning: Symbol map for key <RALT> redefined
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[963]: > Using last definition for conflicting fields
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[963]: Errors from xkbcomp are not fatal to the X server
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): CRT-0: disconnected
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-0: disconnected
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): Philips 247E4 (DFP-1): connected
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): Philips 247E4 (DFP-1): Internal TMDS
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): Philips 247E4 (DFP-1): 600.0 MHz maximum pixel clock
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-2: disconnected
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-3: disconnected
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-4: disconnected
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-4: 960.0 MHz maximum pixel clock
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-5: disconnected
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-6: disconnected
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-7: disconnected
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
aug 04 18:51:48 z97mds3h /usr/lib/gdm-x-session[659]: (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
aug 04 18:51:49 z97mds3h /usr/lib/gdm-x-session[669]: dbus-daemon[669]: [session uid=120 pid=669] Activating service name='org.freedesktop.systemd1' requested by ':1.9' (uid=120 pid=760 comm="/usr/lib/gsd-sharing")
aug 04 18:51:49 z97mds3h /usr/lib/gdm-x-session[669]: dbus-daemon[669]: [session uid=120 pid=669] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
aug 04 18:51:49 z97mds3h gsd-sharing[760]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
aug 04 18:51:54 z97mds3h kernel: kauditd_printk_skb: 7 callbacks suppressed
aug 04 18:51:57 z97mds3h gdm-password][991]: gkr-pam: unable to locate daemon control file
aug 04 18:51:57 z97mds3h systemd-xdg-autostart-generator[1012]: /home/jtebeling/.config/autostart/auto:1: Assignment outside of section. Ignoring.
aug 04 18:51:58 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "fd" "51"
aug 04 18:51:58 z97mds3h /usr/lib/gdm-x-session[659]: (II) event2 - Power Button: device removed
aug 04 18:51:58 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "fd" "54"
aug 04 18:51:58 z97mds3h /usr/lib/gdm-x-session[659]: (II) event4 - Video Bus: device removed
aug 04 18:51:58 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "fd" "55"
aug 04 18:51:58 z97mds3h /usr/lib/gdm-x-session[659]: (II) event0 - Power Button: device removed
aug 04 18:51:58 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "fd" "56"
aug 04 18:51:58 z97mds3h /usr/lib/gdm-x-session[659]: (II) event1 - Sleep Button: device removed
aug 04 18:51:58 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "fd" "57"
aug 04 18:51:58 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "fd" "58"
aug 04 18:51:58 z97mds3h /usr/lib/gdm-x-session[659]: (II) event7 - DATACOMP SteelS쀁̄Љ̒DATA: device removed
aug 04 18:51:58 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "fd" "59"
aug 04 18:51:58 z97mds3h /usr/lib/gdm-x-session[659]: (II) event9 - DATACOMP SteelS쀁̄Љ̒DATA Consumer Control: device removed
aug 04 18:51:58 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "fd" "60"
aug 04 18:51:58 z97mds3h /usr/lib/gdm-x-session[659]: (II) event8 - DATACOMP SteelS쀁̄Љ̒DATA System Control: device removed
aug 04 18:51:58 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "fd" "61"
aug 04 18:51:58 z97mds3h /usr/lib/gdm-x-session[659]: (**) Option "fd" "62"
aug 04 18:51:58 z97mds3h /usr/lib/gdm-x-session[659]: (II) event11 - Kingston HyperX SoloCast: device removed
aug 04 18:51:58 z97mds3h /usr/lib/gdm-x-session[659]: (II) event27 - Logitech G604 : device removed
aug 04 18:51:58 z97mds3h /usr/lib/gdm-x-session[659]: (II) event10 - Kingston HyperX SoloCast Consumer Control: device removed
aug 04 18:51:58 z97mds3h pipewire-media-session[717]: ms.mod.default-profile: device 'alsa_card.pci-0000_01_00.1': can't restore profile: No such device
aug 04 18:52:01 z97mds3h kernel: i915 0000:00:02.0: [drm] *ERROR* Unclaimed access detected prior to suspending
aug 04 18:52:14 z97mds3h kernel: kauditd_printk_skb: 7 callbacks suppressed
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[659]: (II) systemd-logind: got pause for 13:72
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[659]: (II) systemd-logind: got pause for 13:91
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[659]: (II) systemd-logind: got pause for 13:75
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[659]: (II) systemd-logind: got pause for 13:64
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[659]: (II) systemd-logind: got pause for 13:68
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[659]: (II) systemd-logind: got pause for 13:65
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[659]: (II) systemd-logind: got pause for 13:73
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[659]: (II) systemd-logind: got pause for 13:74
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[659]: (II) systemd-logind: got pause for 13:71
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[659]: (II) systemd-logind: got pause for 13:66
aug 04 18:52:24 z97mds3h gsd-media-keys[787]: Unable to get default source
aug 04 18:52:24 z97mds3h gsd-media-keys[787]: Unable to get default sink
aug 04 18:52:24 z97mds3h gsd-media-keys[787]: gvc_mixer_card_get_index: assertion 'GVC_IS_MIXER_CARD (card)' failed
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: _XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: _XSERVTransMakeAllCOTSServerListeners: server already running
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (--) Log file renamed from "/var/log/Xorg.pid-1038.log" to "/var/log/Xorg.1.log"
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: X.Org X Server 1.21.1.4
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: X Protocol Version 11, Revision 0
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: Current Operating System: Linux z97mds3h 5.18.14-1-MANJARO #1 SMP PREEMPT_DYNAMIC Sun Jul 24 09:00:58 UTC 2022 x86_64
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64 root=UUID=a29c54a8-ea4b-4aee-9575-18fcf74b37f2 rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: Current version of pixman: 0.40.0
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: Before reporting problems, check http://wiki.x.org
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: to make sure that you have the latest version.
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: Markers: (--) probed, (**) from config file, (==) default setting,
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (++) from command line, (!!) notice, (II) informational,
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (==) Log file: "/var/log/Xorg.1.log", Time: Thu Aug 4 18:52:24 2022
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (==) Using config directory: "/etc/X11/xorg.conf.d"
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (==) ServerLayout "layout"
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (==) No screen section available. Using defaults.
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (**) |-->Screen "Default Screen Section" (0)
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (**) | |-->Monitor "<default monitor>"
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (==) No monitor specified for screen "Default Screen Section".
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: Using a default monitor configuration.
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (==) Automatically adding devices
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (==) Automatically enabling devices
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (==) Automatically adding GPU devices
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (==) Automatically binding GPU devices
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (==) Max clients allowed: 256, resource mask: 0x1fffff
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (WW) The directory "/usr/share/fonts/misc" does not exist.
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: Entry deleted from font path.
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (WW) The directory "/usr/share/fonts/OTF" does not exist.
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (WW) The directory "/usr/share/fonts/Type1" does not exist.
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (WW) The directory "/usr/share/fonts/100dpi" does not exist.
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (WW) The directory "/usr/share/fonts/75dpi" does not exist.
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (==) FontPath set to:
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: /usr/share/fonts/TTF
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (==) ModulePath set to "/usr/lib/xorg/modules"
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (II) The server relies on udev to provide the list of input devices.
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: If no devices become available, reconfigure udev or disable AutoAddDevices.
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (II) Module ABI versions:
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: X.Org ANSI C Emulation: 0.4
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: X.Org Video Driver: 25.2
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: X.Org XInput driver : 24.4
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: X.Org Server Extension : 10.0
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (++) using VT number 2
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (II) systemd-logind: took control of session /org/freedesktop/login1/session/_33
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (II) xfree86: Adding drm device (/dev/dri/card1)
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card1
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 15 paused 0
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (II) xfree86: Adding drm device (/dev/dri/card0)
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 16 paused 0
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (--) PCI: (0@0:2:0) 8086:0412:1458:d000 rev 6, Mem @ 0xf7400000/4194304, 0xd0000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (--) PCI:*(1@0:0:0) 10de:13c2:1462:3171 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (II) LoadModule: "glx"
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (II) Module glx: vendor="X.Org Foundation"
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: compiled for 1.21.1.4, module version = 1.0.0
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: ABI class: X.Org Server Extension, version 10.0
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (II) Applying OutputClass "nvidia" to /dev/dri/card1
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: loading driver: nvidia
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (II) Applying OutputClass "intel" to /dev/dri/card0
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: loading driver: modesetting
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (==) Matched nvidia as autoconfigured driver 0
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (==) Matched nouveau as autoconfigured driver 1
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (==) Matched nv as autoconfigured driver 2
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (==) Matched modesetting as autoconfigured driver 3
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (==) Matched fbdev as autoconfigured driver 4
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (==) Matched vesa as autoconfigured driver 5
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (==) Assigned the driver to the xf86ConfigLayout
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (II) LoadModule: "nvidia"
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (II) Module nvidia: vendor="NVIDIA Corporation"
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: compiled for 1.6.99.901, module version = 1.0.0
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: Module class: X.Org Video Driver
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (II) LoadModule: "nouveau"
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (WW) Warning, couldn't open module nouveau
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (EE) Failed to load module "nouveau" (module does not exist, 0)
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (II) LoadModule: "nv"
aug 04 18:52:24 z97mds3h /usr/lib/gdm-x-session[1038]: (WW) Warning, couldn't open module nv
