After a stuck update, I finally decide to re-install manjaro. Went fairly well. Now there is an annoyance. Every time I want to restart manjaro the computer bios hangs on the detection of the manjaro drive. I have 4 drives) I have to restart the computer manually each time and then it goes. This is a new behavior.
I have windows and mint installed on the same computer and both reboot without issue.
Host: Manjarogigabyte Kernel: 6.2.8-1-MANJARO arch: x86_64 bits: 64
Desktop: Xfce v: 4.18.1 Distro: Manjaro Linux
Type: Desktop Mobo: Gigabyte model: GA-970A-D3 v: x.x
serial: <superuser required> BIOS: Award v: F12 date: 09/03/2013
Info: 6-core model: AMD FX-6300 bits: 64 type: MT MCP cache: L2: 6 MiB
Speed (MHz): avg: 1400 min/max: 1400/3500 cores: 1: 1400 2: 1400 3: 1400
4: 1400 5: 1400 6: 1400
Device-1: NVIDIA GM107 [GeForce GTX 750 Ti] driver: nvidia v: 530.41.03
Device-2: Logitech Webcam C110 type: USB driver: snd-usb-audio,uvcvideo
Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: nvidia gpu: nvidia
resolution: 1920x1080~60Hz
API: OpenGL Message: Unable to show GL data. Required tool glxinfo
missing.
Device-1: AMD SBx00 Azalia driver: snd_hda_intel
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX]
Device-3: Logitech Webcam C110 type: USB driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.2.8-1-MANJARO status: kernel-api
Server-1: PulseAudio v: 16.1 status: active
driver: r8169
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: 90:2b:34:98:ef:6c
Local Storage: total: 1.6 TiB used: 564.66 GiB (34.4%)
ID-1: /dev/nvme0n1 vendor: A-Data model: SX8200PNP size: 238.47 GiB
ID-2: /dev/sda vendor: TeamGroup model: T-FORCE 250GB size: 232.89 GiB
ID-3: /dev/sdb vendor: Seagate model: SSD size: 238.47 GiB
ID-4: /dev/sdc vendor: Western Digital model: WD10EZEX-22RKKA0
ID-1: / size: 36.37 GiB used: 17.25 GiB (47.4%) fs: ext4 dev: /dev/sdb2
ID-1: swap-1 type: partition size: 3.72 GiB used: 0 KiB (0.0%)
dev: /dev/sdb1
System Temperatures: cpu: 17.0 C mobo: N/A gpu: nvidia temp: 28 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 33%
Processes: 229 Uptime: 27m Memory: 7.74 GiB used: 2.54 GiB (32.9%)
Shell: Bash inxi: 3.3.26
