Thanks @Aragorn, I did as you described.
If /bin
is just a symbolic link to /usr/bin
why do /etc/shells
have both shells under /bin
and under /usr/bin
@Mirdarthos, this is the output from the last freeze:
Dec 21 11:13:14 sam-pc kernel: nvidia: loading out-of-tree module taints kernel.
Dec 21 11:13:14 sam-pc kernel: nvidia: module license 'NVIDIA' taints kernel.
Dec 21 11:13:14 sam-pc kernel: Disabling lock debugging due to kernel taint
Dec 21 11:13:14 sam-pc kernel: nvidia: module license taints kernel.
Dec 21 11:13:14 sam-pc kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 550.135 Thu Nov 14 00:09:29 UTC 2024
Dec 21 11:13:14 sam-pc kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Dec 21 11:13:14 sam-pc kernel: nvme nvme0: missing or invalid SUBNQN field.
Dec 21 11:13:14 sam-pc kernel: usb: port power management may be unreliable
Dec 21 11:13:14 sam-pc kernel: EXT4-fs (nvme0n1p3): warning: maximal mount count reached, running e2fsck is recommended
Dec 21 11:13:14 sam-pc kernel: systemd[1]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
Dec 21 11:13:15 sam-pc kernel: ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\GSA1.SMBI) (20230628/utaddress-204)
Dec 21 11:13:15 sam-pc kernel: kvm_amd: SVM disabled (by BIOS) in MSR_VM_CR on CPU 10
Dec 21 11:13:16 sam-pc kernel: nvidia-gpu 0000:07:00.3: i2c timeout error e0000000
Dec 21 11:13:16 sam-pc kernel: ucsi_ccg 5-0008: i2c_transfer failed -110
Dec 21 11:13:16 sam-pc kernel: ucsi_ccg 5-0008: ucsi_ccg_init failed - -110
Dec 21 11:13:16 sam-pc kernel: ucsi_ccg: probe of 5-0008 failed with error -110
Dec 21 11:13:19 sam-pc (uetoothd)[1007]: bluetooth.service: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Dec 21 11:13:19 sam-pc bluetoothd[1007]: src/plugin.c:init_plugin() System does not support bap plugin
Dec 21 11:13:19 sam-pc bluetoothd[1007]: src/plugin.c:init_plugin() System does not support bass plugin
Dec 21 11:13:19 sam-pc bluetoothd[1007]: src/plugin.c:init_plugin() System does not support mcp plugin
Dec 21 11:13:19 sam-pc bluetoothd[1007]: src/plugin.c:init_plugin() System does not support vcp plugin
Dec 21 11:13:19 sam-pc bluetoothd[1007]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Dec 21 11:13:19 sam-pc bluetoothd[1007]: src/plugin.c:init_plugin() System does not support micp plugin
Dec 21 11:13:19 sam-pc bluetoothd[1007]: src/plugin.c:init_plugin() System does not support ccp plugin
Dec 21 11:13:19 sam-pc bluetoothd[1007]: src/plugin.c:init_plugin() System does not support csip plugin
Dec 21 11:13:19 sam-pc bluetoothd[1007]: src/plugin.c:init_plugin() System does not support asha plugin
Dec 21 11:13:19 sam-pc bluetoothd[1007]: src/device.c:device_set_wake_support() Unable to set wake_support without RPA resolution
Dec 21 11:13:20 sam-pc dbus-broker-launch[1003]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Dec 21 11:13:20 sam-pc dbus-broker-launch[1210]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Dec 21 11:13:20 sam-pc dbus-broker-launch[1210]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service'
Dec 21 11:13:20 sam-pc dbus-broker-launch[1210]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Dec 21 11:13:20 sam-pc dbus-broker-launch[1210]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Dec 21 11:13:21 sam-pc sddm-greeter-qt6[1206]: Could not locate KSvg image set "breath2-dark" in "plasma/desktoptheme/" using search path QList("/var/lib/sddm/.local/share", "/var/lib/flatpak/exports/share", "/usr/local/share", "/usr/share")
Dec 21 11:13:21 sam-pc sddm-greeter-qt6[1206]: Could not locate plasma theme "breath2-dark" in plasma/desktoptheme/ using search path QList("/var/lib/sddm/.local/share", "/var/lib/flatpak/exports/share", "/usr/local/share", "/usr/share")
Dec 21 11:13:24 sam-pc dbus-broker-launch[1003]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Dec 21 11:13:26 sam-pc rpc.idmapd[1240]: Setting log level to 0
Dec 21 11:13:26 sam-pc rpc.idmapd[1240]: libnfsidmap: Unable to determine the NFSv4 domain; Using 'localdomain' as the NFSv4 domain which means UIDs will be mapped to the 'Nobody-User' user defined in /etc/idmapd.conf
Dec 21 11:13:26 sam-pc rpc.statd[1243]: Flags: TI-RPC
Dec 21 11:13:27 sam-pc kernel: kauditd_printk_skb: 158 callbacks suppressed
Dec 21 11:20:27 sam-pc sddm-greeter-qt6[1206]: failed to create compose table
Dec 21 11:20:34 sam-pc sddm-greeter-qt6[1206]: file:///usr/share/sddm/themes/breeze/Main.qml:230:17 Parameter "username" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
Dec 21 11:20:34 sam-pc sddm-helper[1687]: gkr-pam: unable to locate daemon control file
Dec 21 11:20:35 sam-pc dbus-broker-launch[1714]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Dec 21 11:20:35 sam-pc dbus-broker-launch[1714]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service'
Dec 21 11:20:35 sam-pc dbus-broker-launch[1714]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Dec 21 11:20:35 sam-pc dbus-broker-launch[1714]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Dec 21 11:20:35 sam-pc xdg-desktop-por[1761]: Choosing gtk.portal for org.freedesktop.impl.portal.Lockdown as a last-resort fallback
Dec 21 11:20:35 sam-pc xdg-desktop-por[1761]: The preferred method to match portal implementations to desktop environments is to use the portals.conf(5) configuration file
Dec 21 11:20:36 sam-pc baloo_file[1756]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.34'
Dec 21 11:20:36 sam-pc baloo_file[1756]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.36'
Dec 21 11:20:36 sam-pc kwalletd6[1719]: kf.wallet.kwalletd: Wallet failed to get opened by PAM, error code is -9
Dec 21 11:20:36 sam-pc kded6[1814]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
Dec 21 11:20:36 sam-pc kded6[1814]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
Dec 21 11:20:37 sam-pc org_kde_powerdevil[1894]: Failed to create wl_display (No such file or directory)
Dec 21 11:20:37 sam-pc kernel: [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000700] Failed to grab modeset ownership
Dec 21 11:20:38 sam-pc kconf_update[1953]: kf.config.kconf_update: /usr/share/kconf_update/ark.upd defined Version=5 but Version=6 was expected
Dec 21 11:20:38 sam-pc kconf_update[1953]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
Dec 21 11:20:38 sam-pc kconf_update[1953]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_detailsmodesettings.upd defined Version=5 but Version=6 was expected
Dec 21 11:20:38 sam-pc kconf_update[1953]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_directorysizemode.upd defined Version=5 but Version=6 was expected
Dec 21 11:20:38 sam-pc kconf_update[1953]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
Dec 21 11:20:38 sam-pc kconf_update[1953]: kf.config.kconf_update: /usr/share/kconf_update/konsole.upd defined Version=5 but Version=6 was expected
Dec 21 11:20:38 sam-pc kconf_update[1953]: kf.config.kconf_update: /usr/share/kconf_update/okular.upd defined Version=5 but Version=6 was expected
Dec 21 11:20:38 sam-pc org_kde_powerdevil[1894]: busno=1, Feature 0xdd should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Dec 21 11:20:38 sam-pc org_kde_powerdevil[1894]: busno=1, Feature 0x41 should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Dec 21 11:20:38 sam-pc org_kde_powerdevil[1894]: busno=1, Feature 0x00 should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Dec 21 11:20:38 sam-pc org_kde_powerdevil[1894]: busno=1, All features that should not exist detected. Monitor does not indicate unsupported
Dec 21 11:20:39 sam-pc kded6[1814]: kf.bluezqt: PendingCall Error: "The name is not activatable"
Dec 21 11:20:39 sam-pc bluetoothd[1007]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
Dec 21 11:20:39 sam-pc kded6[1814]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_09_00.4.analog-stereo.monitor"
Dec 21 11:20:39 sam-pc dbus-broker-launch[1003]: Activation request for 'org.freedesktop.Avahi' failed: The systemd unit 'dbus-org.freedesktop.Avahi.service' could not be found.
Dec 21 11:20:39 sam-pc geoclue[1969]: Failed to connect to avahi service: Daemon not running
Dec 21 11:20:40 sam-pc kded6[1814]: kscreen.kded: PowerDevil SuspendSession action not available!
Dec 21 11:20:40 sam-pc backlighthelper[2013]: org.kde.powerdevil: no kernel backlight interface found
Dec 21 11:20:40 sam-pc org_kde_powerdevil[1894]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Dec 21 11:20:40 sam-pc org_kde_powerdevil[1894]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Dec 21 11:20:40 sam-pc plasmashell[1875]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth":
file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:201:9
Dec 21 11:20:40 sam-pc org_kde_powerdevil[1894]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Dec 21 11:20:40 sam-pc plasmashell[1875]: Toolbox not loading, toolbox package is either invalid or disabled.
Dec 21 11:20:43 sam-pc qbittorrent[2063]: The legacy data directory '/home/sam/.local/share/data/qBittorrent' is used. It is recommended to move its content to '/home/sam/.local/share/qBittorrent'
Dec 21 11:20:44 sam-pc kdeconnectd[2057]: 2024-12-21T11:20:44 qt.bluetooth.bluez: Bluetooth device is powered off
Dec 21 11:20:45 sam-pc qbittorrent[2063]: The legacy data directory '/home/sam/.local/share/data/qBittorrent' is used. It is recommended to move its content to '/home/sam/.local/share/qBittorrent'
Dec 21 11:20:45 sam-pc plasmashell[1875]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:50:9: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
Dec 21 11:20:45 sam-pc plasmashell[1875]: qt.dbus.integration: Could not connect "org.cups.cupsd.Notifier" to PrinterFinishingsChanged(QString, QString, QString, uint, QString, bool) :
Dec 21 11:20:45 sam-pc systemd[1693]: app-dropbox@autostart.service: Main process exited, code=killed, status=9/KILL
Dec 21 11:20:46 sam-pc plasmashell[1875]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Dec 21 11:20:47 sam-pc plasmashell[1875]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Dec 21 11:20:47 sam-pc plasmashell[1875]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_09_00.4.analog-stereo.monitor"
Dec 21 11:20:47 sam-pc kwin_x11[1815]: kwin_core: Failed to focus 0x3e00003 (error 8)
Dec 21 11:21:37 sam-pc upowerd[1799]: g_udev_device_get_sysfs_path: assertion 'G_UDEV_IS_DEVICE (device)' failed
Dec 21 11:21:37 sam-pc upowerd[1799]: g_udev_client_query_by_sysfs_path: assertion 'sysfs_path != NULL' failed
Dec 21 11:22:49 sam-pc systemsettings[4375]: qrc:/kcm/kcm_regionandlang/AdvancedLanguageSelectPage.qml:172:9: QML ListView: Binding loop detected for property "cacheBuffer":
qrc:/kcm/kcm_regionandlang/AdvancedLanguageSelectPage.qml:177:13
Dec 21 11:25:01 sam-pc kernel: sd 10:0:0:0: [sda] No Caching mode page found
Dec 21 11:25:01 sam-pc kernel: sd 10:0:0:0: [sda] Assuming drive cache: write through
Dec 21 11:25:02 sam-pc plasmashell[1875]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/FullRepresentation.qml:94:5: QML ScrollView: Binding loop detected for property "contentWidth":
file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/FullRepresentation.qml:98:9
Dec 21 11:25:02 sam-pc plasmashell[1875]: qrc:/qt/qml/org/kde/plasma/components/ScrollView.qml:53:29: QML ScrollBar: Binding loop detected for property "visible":
qrc:/qt/qml/org/kde/plasma/components/ScrollBar.qml:24:5
Dec 21 11:34:01 sam-pc plasmashell[1875]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/DeviceItem.qml:128: TypeError: Cannot read property 'defaultActionIcon' of undefined
Dec 21 11:34:01 sam-pc plasmashell[1875]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/DeviceItem.qml:129: TypeError: Cannot read property 'defaultActionText' of undefined
Dec 21 11:35:48 sam-pc plasmashell[1875]: qt.svg: Skipping a nested svg element, because SVG Document must not contain nested svg elements in Svg Tiny 1.2
Dec 21 11:36:16 sam-pc plasmashell[1875]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Dec 21 11:36:16 sam-pc kwin_x11[1815]: kwin_core: Failed to focus 0x680002f (error 8)
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml:12:1: QML ConfigTimers: Created graphical object was not placed in the graphics scene.
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_conditionalSwitchDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_customFont
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_customFontDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_dailyTimerDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_detectWorkraveConfigurationChangesDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_fontColor
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_fontColorDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_iconEnabled
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_iconEnabledDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_iconHeightPercentage
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_iconHeightPercentageDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_idleTimeSwitchDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_labelEnabled
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_labelEnabledDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_microTimerDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_nonIdleTimeSwitchDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_periodicalSwitchDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_periodicalSwitchIntervalDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_progressBarEnabled
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_progressBarEnabledDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_progressBarHeightPercentage
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_progressBarHeightPercentageDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_progressBarNormalBackground
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_progressBarNormalBackgroundDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_progressBarNormalForeground
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_progressBarNormalForegroundDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_progressBarOverdueBackground
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_progressBarOverdueBackgroundDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_progressBarRestingElapsedForeground
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_progressBarRestingElapsedForegroundDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_progressBarRestingForeground
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_progressBarRestingForegroundDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_restTimerDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_showMinusSign
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_showMinusSignDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_showOnlyTheMostSignificantTimerPart
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_showOnlyTheMostSignificantTimerPartDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_showTimeUnits
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_showTimeUnitsDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_singleTimerModeDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_timeDifferenceSwitchDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_timeDifferenceSwitchDifferenceDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_timersExtraHeight
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_timersExtraHeightDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_timersExtraWidth
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_timersExtraWidthDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_timersOrientationDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_timersSpacing
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_timersSpacingDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_updateIntervalDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_useCustomFont
Dec 21 11:36:23 sam-pc plasmashell[1875]: file:///home/sam/.local/share/plasma/plasmoids/org.kde.workraveApplet/contents/ui/config/ConfigTimers.qml: Setting initial properties failed: ConfigTimers does not have a property called cfg_useCustomFontDefault
Dec 21 11:36:23 sam-pc plasmashell[1875]: qrc:/qt/qml/org/kde/kirigami/dialogs/PromptDialog.qml:135: TypeError: Cannot read property 'Success' of undefined
Dec 21 11:36:23 sam-pc plasmashell[1875]: qrc:/qt/qml/org/kde/kirigami/dialogs/PromptDialog.qml:97: TypeError: Cannot read property 'None' of undefined
Dec 21 11:36:40 sam-pc systemd-coredump[18898]: Process 1875 (plasmashell) of user 1000 dumped core.
Stack trace of thread 1875:
#0 0x00007f95a7278974 _ZNK6Plasma5Theme5colorENS0_9ColorRoleENS0_10ColorGroupE (libPlasma.so.6 + 0x3d974)
#1 0x00007f9594981980 n/a (KirigamiPlasmaStyle.so + 0x4980)
#2 0x00007f95a49b1b29 n/a (libQt6Core.so.6 + 0x1b1b29)
#3 0x00007f95a49b1b29 n/a (libQt6Core.so.6 + 0x1b1b29)
#4 0x00007f95a49b1b29 n/a (libQt6Core.so.6 + 0x1b1b29)
#5 0x00007f95a49bab35 _ZN6QTimer10timerEventEP11QTimerEvent (libQt6Core.so.6 + 0x1bab35)
#6 0x00007f95a49a2d49 _ZN7QObject5eventEP6QEvent (libQt6Core.so.6 + 0x1a2d49)
#7 0x00007f95a6afe78a _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt6Widgets.so.6 + 0xfe78a)
#8 0x00007f95a4957ac8 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt6Core.so.6 + 0x157ac8)
#9 0x00007f95a4ad6b1f _ZN14QTimerInfoList14activateTimersEv (libQt6Core.so.6 + 0x2d6b1f)
#10 0x00007f95a4bc4f09 n/a (libQt6Core.so.6 + 0x3c4f09)
#11 0x00007f95a355f559 n/a (libglib-2.0.so.0 + 0x5d559)
#12 0x00007f95a35c2257 n/a (libglib-2.0.so.0 + 0xc0257)
#13 0x00007f95a355ea55 g_main_context_iteration (libglib-2.0.so.0 + 0x5ca55)
#14 0x00007f95a4bc22fd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3c22fd)
#15 0x00007f95a4961ee6 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x161ee6)
#16 0x00007f95a4958f4f _ZN16QCoreApplication4execEv (libQt6Core.so.6 + 0x158f4f)
#17 0x000055c83f94b17f n/a (plasmashell + 0x2817f)
#18 0x00007f95a4234e08 n/a (libc.so.6 + 0x25e08)
#19 0x00007f95a4234ecc __libc_start_main (libc.so.6 + 0x25ecc)
#20 0x000055c83f94b695 n/a (plasmashell + 0x28695)
Stack trace of thread 2042:
#0 0x00007f95a431abb0 ppoll (libc.so.6 + 0x10bbb0)
#1 0x00007f95a35c2327 n/a (libglib-2.0.so.0 + 0xc0327)
#2 0x00007f95a355ea55 g_main_context_iteration (libglib-2.0.so.0 + 0x5ca55)
#3 0x00007f95a4bc22fd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3c22fd)
#4 0x00007f95a4961ee6 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x161ee6)
#5 0x00007f95a4a58082 _ZN7QThread3runEv (libQt6Core.so.6 + 0x258082)
#6 0x00007f95a4ad90cd n/a (libQt6Core.so.6 + 0x2d90cd)
#7 0x00007f95a42a339d n/a (libc.so.6 + 0x9439d)
#8 0x00007f95a432849c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 2141:
#0 0x00007f95a429fa19 n/a (libc.so.6 + 0x90a19)
#1 0x00007f95a42a2479 pthread_cond_wait (libc.so.6 + 0x93479)
#2 0x00007f95a4ade440 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt6Core.so.6 + 0x2de440)
#3 0x00007f95a644452a n/a (libQt6Quick.so.6 + 0x44452a)
#4 0x00007f95a4ad90cd n/a (libQt6Core.so.6 + 0x2d90cd)
#5 0x00007f95a42a339d n/a (libc.so.6 + 0x9439d)
#6 0x00007f95a432849c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 2175:
#0 0x00007f95a431a63d __poll (libc.so.6 + 0x10b63d)
#1 0x00007f9596a141d7 n/a (libnvidia-glcore.so.550.135 + 0xa141d7)
#2 0x00007f95969f5974 n/a (libnvidia-glcore.so.550.135 + 0x9f5974)
#3 0x00007f95a42a339d n/a (libc.so.6 + 0x9439d)
#4 0x00007f95a432849c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 2217:
Stack trace of thread 2356:
Stack trace of thread 4293:
Stack trace of thread 2352:
#5 0x00007f95a4a57f22 _ZN7QThread4execEv (libQt6Core.so.6 + 0x257f22)
#6 0x00007f95a637e538 n/a (libQt6Quick.so.6 + 0x37e538)
#7 0x00007f95a4ad90cd n/a (libQt6Core.so.6 + 0x2d90cd)
#8 0x00007f95a42a339d n/a (libc.so.6 + 0x9439d)
#9 0x00007f95a432849c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 2386:
Stack trace of thread 4291:
Stack trace of thread 1881:
#6 0x00007f95a4f735ae n/a (libQt6DBus.so.6 + 0x2e5ae)
Stack trace of thread 4289:
Stack trace of thread 4298:
Stack trace of thread 17384:
Stack trace of thread 2289:
#6 0x00007f956e91a8b0 _ZN15KCupsConnection3runEv (libkcupslib.so.6.2.4 + 0x2c8b0)
Stack trace of thread 15319:
#1 0x00007f95a4ad1213 _Z12qt_safe_pollP6pollfdm14QDeadlineTimer (libQt6Core.so.6 + 0x2d1213)
#2 0x00007f95a415ef03 n/a (libQt6Network.so.6 + 0x12cf03)
#3 0x00007f95a40e2a19 n/a (libQt6Network.so.6 + 0xb0a19)
#4 0x00007f95a40df9de _ZN15QAbstractSocket16waitForReadyReadEi (libQt6Network.so.6 + 0xad9de)
#5 0x00007f95a3ac42fa n/a (libKF6KIOCore.so.6 + 0x3e2fa)
#6 0x00007f95a3bad3fd n/a (libKF6KIOCore.so.6 + 0x1273fd)
#7 0x00007f95a3b8af84 n/a (libKF6KIOCore.so.6 + 0x104f84)
#8 0x00007f95a4ad90cd n/a (libQt6Core.so.6 + 0x2d90cd)
#9 0x00007f95a42a339d n/a (libc.so.6 + 0x9439d)
#10 0x00007f95a432849c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 17364:
Stack trace of thread 4307:
Stack trace of thread 2297:
#1 0x00007f956df86a78 n/a (libpulse.so.0 + 0x32a78)
#2 0x00007f956df70654 pa_mainloop_poll (libpulse.so.0 + 0x1c654)
#3 0x00007f956df7a7c5 pa_mainloop_iterate (libpulse.so.0 + 0x267c5)
#4 0x00007f956df7a891 pa_mainloop_run (libpulse.so.0 + 0x26891)
#5 0x00007f956df8bbd4 n/a (libpulse.so.0 + 0x37bd4)
#6 0x00007f956df3134f n/a (libpulsecommon-17.0.so + 0x5d34f)
Stack trace of thread 7578:
Stack trace of thread 17369:
Stack trace of thread 17371:
Stack trace of thread 4300:
Stack trace of thread 4237:
Stack trace of thread 17372:
Stack trace of thread 4294:
Stack trace of thread 4288:
Stack trace of thread 17366:
Stack trace of thread 4301:
Stack trace of thread 4304:
Stack trace of thread 17379:
#3 0x00007f95a4bc2322 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3c2322)
Stack trace of thread 17375:
Stack trace of thread 4299:
Stack trace of thread 17377:
Stack trace of thread 4302:
Stack trace of thread 17382:
Stack trace of thread 7576:
Stack trace of thread 4303:
Stack trace of thread 1882:
#1 0x00007f95a73f720b n/a (libxcb.so.1 + 0xd20b)
#2 0x00007f95a73f8f3d xcb_wait_for_event (libxcb.so.1 + 0xef3d)
#3 0x00007f959e56dd19 n/a (libQt6XcbQpa.so.6 + 0x4ed19)
Stack trace of thread 17551:
#1 0x00007f95a42a27e2 pthread_cond_timedwait (libc.so.6 + 0x937e2)
#2 0x00007f95a4ade3c8 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt6Core.so.6 + 0x2de3c8)
#3 0x00007f95a4adfad5 n/a (libQt6Core.so.6 + 0x2dfad5)
Stack trace of thread 4290:
Stack trace of thread 17385:
Stack trace of thread 4310:
Stack trace of thread 4308:
Stack trace of thread 17368:
Stack trace of thread 4305:
Stack trace of thread 17386:
Stack trace of thread 4309:
Stack trace of thread 18892:
Stack trace of thread 18321:
Stack trace of thread 4292:
Stack trace of thread 15318:
Stack trace of thread 15320:
Stack trace of thread 17380:
Stack trace of thread 17383:
Stack trace of thread 17381:
Stack trace of thread 4296:
Stack trace of thread 17367:
Stack trace of thread 17378:
Stack trace of thread 4306:
Stack trace of thread 17374:
Stack trace of thread 4295:
Stack trace of thread 5203:
Stack trace of thread 17553:
Dec 21 11:36:40 sam-pc systemd[1693]: plasma-plasmashell.service: Main process exited, code=dumped, status=11/SEGV
Dec 21 11:36:40 sam-pc systemd[1693]: plasma-plasmashell.service: Failed with result 'core-dump'.
Dec 21 11:36:41 sam-pc plasmashell[18968]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth":
Dec 21 11:36:41 sam-pc plasmashell[18968]: Toolbox not loading, toolbox package is either invalid or disabled.
Dec 21 11:36:42 sam-pc plasmashell[18968]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:50:9: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
Dec 21 11:36:42 sam-pc plasmashell[18968]: qt.dbus.integration: Could not connect "org.cups.cupsd.Notifier" to PrinterFinishingsChanged(QString, QString, QString, uint, QString, bool) :
Dec 21 11:36:43 sam-pc plasmashell[18968]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:50:9: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
Dec 21 11:36:43 sam-pc plasmashell[18968]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Dec 21 11:36:44 sam-pc plasmashell[18968]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Dec 21 11:36:44 sam-pc plasmashell[18968]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_09_00.4.analog-stereo.monitor"
Dec 21 11:37:41 sam-pc systemd[1693]: dbus-:1.2-org.kde.KSplash@0.service: Failed with result 'exit-code'.
Dec 21 12:38:04 sam-pc systemd-coredump[72778]: Process 18968 (plasmashell) of user 1000 dumped core.
Stack trace of thread 18968:
#0 0x00007f5c11276974 _ZNK6Plasma5Theme5colorENS0_9ColorRoleENS0_10ColorGroupE (libPlasma.so.6 + 0x3d974)
#1 0x00007f5bf3f67980 n/a (KirigamiPlasmaStyle.so + 0x4980)
#2 0x00007f5c0e9b1b29 n/a (libQt6Core.so.6 + 0x1b1b29)
#3 0x00007f5c0e9b1b29 n/a (libQt6Core.so.6 + 0x1b1b29)
#4 0x00007f5c0e9b1b29 n/a (libQt6Core.so.6 + 0x1b1b29)
#5 0x00007f5c0e9bab35 _ZN6QTimer10timerEventEP11QTimerEvent (libQt6Core.so.6 + 0x1bab35)
#6 0x00007f5c0e9a2d49 _ZN7QObject5eventEP6QEvent (libQt6Core.so.6 + 0x1a2d49)
#7 0x00007f5c10afe78a _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt6Widgets.so.6 + 0xfe78a)
#8 0x00007f5c0e957ac8 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt6Core.so.6 + 0x157ac8)
#9 0x00007f5c0ead6b1f _ZN14QTimerInfoList14activateTimersEv (libQt6Core.so.6 + 0x2d6b1f)
#10 0x00007f5c0ebc4f41 n/a (libQt6Core.so.6 + 0x3c4f41)
#11 0x00007f5c0d55f559 n/a (libglib-2.0.so.0 + 0x5d559)
#12 0x00007f5c0d5c2257 n/a (libglib-2.0.so.0 + 0xc0257)
#13 0x00007f5c0d55ea55 g_main_context_iteration (libglib-2.0.so.0 + 0x5ca55)
#14 0x00007f5c0ebc22fd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3c22fd)
#15 0x00007f5c0e961ee6 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x161ee6)
#16 0x00007f5c0e958f4f _ZN16QCoreApplication4execEv (libQt6Core.so.6 + 0x158f4f)
#17 0x000055ce7704f17f n/a (plasmashell + 0x2817f)
#18 0x00007f5c0e234e08 n/a (libc.so.6 + 0x25e08)
#19 0x00007f5c0e234ecc __libc_start_main (libc.so.6 + 0x25ecc)
#20 0x000055ce7704f695 n/a (plasmashell + 0x28695)
Stack trace of thread 18978:
#0 0x00007f5c0e31abb0 ppoll (libc.so.6 + 0x10bbb0)
#1 0x00007f5c0d5c2327 n/a (libglib-2.0.so.0 + 0xc0327)
#2 0x00007f5c0d55ea55 g_main_context_iteration (libglib-2.0.so.0 + 0x5ca55)
#3 0x00007f5c0ebc22fd _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3c22fd)
#4 0x00007f5c0e961ee6 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x161ee6)
#5 0x00007f5c0ea58082 _ZN7QThread3runEv (libQt6Core.so.6 + 0x258082)
#6 0x00007f5c0ead90cd n/a (libQt6Core.so.6 + 0x2d90cd)
#7 0x00007f5c0e2a339d n/a (libc.so.6 + 0x9439d)
#8 0x00007f5c0e32849c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 18970:
#0 0x00007f5c0e31a63d __poll (libc.so.6 + 0x10b63d)
#1 0x00007f5c113f520b n/a (libxcb.so.1 + 0xd20b)
#2 0x00007f5c113f6f3d xcb_wait_for_event (libxcb.so.1 + 0xef3d)
#3 0x00007f5c0856bd19 n/a (libQt6XcbQpa.so.6 + 0x4ed19)
#4 0x00007f5c0ead90cd n/a (libQt6Core.so.6 + 0x2d90cd)
#5 0x00007f5c0e2a339d n/a (libc.so.6 + 0x9439d)
#6 0x00007f5c0e32849c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 19005:
#5 0x00007f5c0ea57f22 _ZN7QThread4execEv (libQt6Core.so.6 + 0x257f22)
#6 0x00007f5bcd66f8b0 _ZN15KCupsConnection3runEv (libkcupslib.so.6.2.4 + 0x2c8b0)
#7 0x00007f5c0ead90cd n/a (libQt6Core.so.6 + 0x2d90cd)
#8 0x00007f5c0e2a339d n/a (libc.so.6 + 0x9439d)
#9 0x00007f5c0e32849c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 72768:
#0 0x00007f5c0e29fa19 n/a (libc.so.6 + 0x90a19)
#1 0x00007f5c0e2a27e2 pthread_cond_timedwait (libc.so.6 + 0x937e2)
#2 0x00007f5c0eade3c8 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt6Core.so.6 + 0x2de3c8)
#3 0x00007f5c0eadfad5 n/a (libQt6Core.so.6 + 0x2dfad5)
Stack trace of thread 19008:
#1 0x00007f5bcccdba78 n/a (libpulse.so.0 + 0x32a78)
#2 0x00007f5bcccc5654 pa_mainloop_poll (libpulse.so.0 + 0x1c654)
#3 0x00007f5bccccf7c5 pa_mainloop_iterate (libpulse.so.0 + 0x267c5)
#4 0x00007f5bccccf891 pa_mainloop_run (libpulse.so.0 + 0x26891)
#5 0x00007f5bccce0bd4 n/a (libpulse.so.0 + 0x37bd4)
#6 0x00007f5bccc8634f n/a (libpulsecommon-17.0.so + 0x5d34f)
Stack trace of thread 18991:
#1 0x00007f5c054141d7 n/a (libnvidia-glcore.so.550.135 + 0xa141d7)
#2 0x00007f5c053f5974 n/a (libnvidia-glcore.so.550.135 + 0x9f5974)
#3 0x00007f5c0e2a339d n/a (libc.so.6 + 0x9439d)
#4 0x00007f5c0e32849c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 18995:
#6 0x00007f5c1037e538 n/a (libQt6Quick.so.6 + 0x37e538)
Stack trace of thread 18969:
#6 0x00007f5c0ef735ae n/a (libQt6DBus.so.6 + 0x2e5ae)
Stack trace of thread 19039:
#1 0x00007f5c0e2a2479 pthread_cond_wait (libc.so.6 + 0x93479)
#2 0x00007f5c0eade440 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt6Core.so.6 + 0x2de440)
#3 0x00007f5c1044452a n/a (libQt6Quick.so.6 + 0x44452a)
Stack trace of thread 18985:
Stack trace of thread 18993:
Stack trace of thread 72771:
Stack trace of thread 72769:
Stack trace of thread 72767:
Stack trace of thread 19060:
Stack trace of thread 72766:
Stack trace of thread 72770:
Stack trace of thread 38645:
Dec 21 12:38:04 sam-pc systemd[1693]: plasma-plasmashell.service: Main process exited, code=dumped, status=11/SEGV
Dec 21 12:38:04 sam-pc systemd[1693]: plasma-plasmashell.service: Failed with result 'core-dump'.
Dec 21 12:38:05 sam-pc plasmashell[72801]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth":
Dec 21 12:38:05 sam-pc plasmashell[72801]: Toolbox not loading, toolbox package is either invalid or disabled.
Dec 21 12:38:06 sam-pc plasmashell[72801]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:50:9: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
Dec 21 12:38:06 sam-pc plasmashell[72801]: qt.dbus.integration: Could not connect "org.cups.cupsd.Notifier" to PrinterFinishingsChanged(QString, QString, QString, uint, QString, bool) :
Dec 21 12:38:07 sam-pc plasmashell[72801]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:50:9: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
Dec 21 12:38:07 sam-pc plasmashell[72801]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Dec 21 12:38:08 sam-pc plasmashell[72801]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Dec 21 12:38:08 sam-pc plasmashell[72801]: org.kde.pulseaudio: No object for name "alsa_output.pci-0000_09_00.4.analog-stereo.monitor"
Dec 21 12:39:05 sam-pc systemd[1693]: dbus-:1.2-org.kde.KSplash@1.service: Failed with result 'exit-code'.
Dec 21 12:43:13 sam-pc plasmashell[72801]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/FullRepresentation.qml:37:13: QML PlasmoidHeading: Binding loop detected for property "leftInset":
qrc:/qt/qml/org/kde/plasma/extras/PlasmoidHeading.qml:33:5
