Computer freezing about twice a week
How often does your computer(Manjaro) lock up or freeze when the pointer thing stops moving and no keys seem to function? I have a new install on a new laptop. It freezes about twice a week now so I am wondering if my computer is sick or does Linux/Manjaro just jam occasionally? Is the only thing to do SHUTDOWN at the power button?
You could provide your hardware info so that we can help you diagnose the problem.
inxi -Fazy
  Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=48ec2f38-4c7b-40a2-b527-f15b7def8683 rw quiet
  cryptdevice=UUID=b4e78388-282f-47d5-943a-a6b04f0b7707:luks-b4e78388-282f-47d5-943a-a6b04f0b7707
  root=/dev/mapper/luks-b4e78388-282f-47d5-943a-a6b04f0b7707 apparmor=1
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
  Type: Laptop System: Razer
  product: Blade 15 Advanced Model (Early 2020) - RZ09-033 v: 5.04
  Mobo: Razer model: CH551 v: 4 serial: <superuser required> UEFI: Razer
  v: 1.08 date: 02/17/2021
  ID-1: BAT0 charge: 82.7 Wh (100.0%) condition: 82.7/80.2 Wh (103.1%)
  volts: 17.5 min: 15.4 model: Razer Blade type: Unknown serial: <filter>
  status: Full
  Info: 8-Core model: Intel Core i7-10875H bits: 64 type: MT MCP
  arch: Comet Lake family: 6 model-id: A5 (165) stepping: 2 microcode: EA
  cache: L1: 512 KiB L2: 2 MiB L3: 16 MiB
  flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  bogomips: 73625
  Speed: 907 MHz min/max: 800/5100 MHz Core speeds (MHz): 1: 800 2: 878 3: 805
  4: 949 5: 801 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800
  14: 800 15: 800 16: 800
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Razer USA
  driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
  Device-2: NVIDIA TU104M [GeForce RTX 2080 SUPER Mobile / Max-Q]
  vendor: Razer USA driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm
  bus-ID: 01:00.0 chip-ID: 10de:1e93 class-ID: 0300
  Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
  bus-ID: 1-7:2 chip-ID: 13d3:56d5 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org 1.21.1.1 compositor: xfwm4 v: 4.16.1 driver:
  loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
  display-ID: :0.0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP-1 res: 1920x1080 hz: 300 dpi: 142 size: 344x193mm (13.5x7.6")
  diag: 394mm (15.5")
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.5
  direct render: Yes
  Device-1: Intel Comet Lake PCH cAVS vendor: Razer USA driver: snd_hda_intel
  chip-ID: 8086:06c8 class-ID: 0403
  Device-2: NVIDIA TU104 HD Audio vendor: Razer USA driver: snd_hda_intel
  v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f8 class-ID: 0403
  Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.40 running: no
  Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
  bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
  bus-ID: 1-14:4 chip-ID: 8087:0026 class-ID: e001
  Local Storage: total: 953.87 GiB used: 29.07 GiB (3.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB1T0HBLR-00A00
  size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 type: SSD serial: <filter> rev: EXF7201Q temp: 39.9 C scheme: GPT
  ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%)
  used: 29.07 GiB (3.1%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
  mapped: luks-b4e78388-282f-47d5-943a-a6b04f0b7707
  used: 440 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 27.8 C pch: 45.0 C mobo: N/A
  Processes: 341 Uptime: 20h 3m wakeups: 5 Memory: 15.49 GiB
  used: 2.95 GiB (19.0%) Init: systemd v: 249 tool: systemctl Compilers:
  gcc: N/A Packages: 1107 pacman: 1103 lib: 312 flatpak: 0 snap: 4 Shell: Bash
  v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.09
You’re using a kernel that is no longer supported.
This is interesting news
I downloaded from Manjaro.org 2 weeks ago.
Tip: When pasting terminal output on Discourse forums, one can either…
  • Use the Preformatted text </> toolbar button.
  • Add three backticks ` above and below the text (Markdown):
    type or paste code here
  • Use HTML:
    <pre><code>
    </pre></code>
I’ve done it for you this time. :wink:
Interesting. First i’ve got the same problem with Manjaro unstable, then reinstalled to Manjaro stable annnnd got the same stutter > total lock up (desktop apps suddenly crashes, can not save opened files, everything lags, after counted seconds it freezes and the only thing to do is to turn off by pressing power button. even tty won’t change by pressing ctrl+alt+f2). Dualboot on win works fine.
In my jornalctl log there were many “kernel: BUG: kernel NULL pointer dereference, address:” messages. I’ve installed unsupported nvidia driver (470) for my video card, so just uninstalled everything with “nvidia” and installed again default (390). Well, it seems that helps, cause now for 3-4 hours i get no stutter and freezing.
I really don’t know if it’s the same problem, but my suggestion would be to reinstall with mhwd your Nvidia driver to see if that helps.
Some logs of my configuration.
inxi -Fazy         ✔
  Kernel: 5.15.6-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=fab39fb6-a7b6-4384-8c02-55d5352d2d9b rw quiet apparmor=1
  security=apparmor udev.log_priority=3 nowatchdog amdgpu.dc=0
  Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
  Type: Laptop System: LENOVO product: 20EFS01B09 v: ThinkPad W541
  Mobo: LENOVO model: 20EFS01B09 v: SDK0E50510 WIN
  serial: <superuser required> UEFI: LENOVO v: GNET94WW (2.42 )
  date: 06/02/2021
  ID-1: BAT0 charge: 30.4 Wh (100.0%) condition: 30.4/99.5 Wh (30.6%)
  volts: 12.0 min: 11.1 model: LGC 45N1153 type: Li-ion serial: <filter>
  status: Full
  Info: Quad Core model: Intel Core i7-4810MQ bits: 64 type: MT MCP
  arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache:
  L1: 256 KiB L2: 1024 KiB L3: 6 MiB
  bogomips: 44713
  Speed: 2956 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 3345 2: 2385
  3: 2788 4: 2506 5: 2850 6: 3309 7: 2395 8: 3266
  Type: l1tf
  Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo
  driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0416 class-ID: 0300
  Device-2: NVIDIA GK106GLM [Quadro K2100M] vendor: Lenovo driver: nvidia
  v: 390.144 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:11fc
  class-ID: 0300
  Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
  loaded: intel unloaded: nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2880x1620 s-dpi: 96 s-size: 762x428mm (30.0x16.9")
  s-diag: 874mm (34.4")
  Monitor-1: eDP1 res: 2880x1620 hz: 60 dpi: 215 size: 340x190mm (13.4x7.5")
  diag: 389mm (15.3")
  OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
  v: 4.5 Mesa 21.2.5 compat-v: 3.0 direct render: Yes
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
  vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:03.0
  chip-ID: 8086:0c0c class-ID: 0403
  Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo
  driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
  class-ID: 0403
  Device-3: NVIDIA GK106 HDMI Audio vendor: Lenovo driver: snd_hda_intel
  v: kernel bus-ID: 01:00.1 chip-ID: 10de:0e0b class-ID: 0403
  Sound Server-1: ALSA v: k5.15.6-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.40 running: yes
  Device-1: Intel Ethernet I217-LM vendor: Lenovo driver: e1000e v: kernel
  port: 5080 bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
  IF: enp0s25 state: down mac: <filter>
  Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel bus-ID: 03:00.0
  chip-ID: 8086:08b2 class-ID: 0280
  bus-ID: 3-11:5 chip-ID: 8087:07dc class-ID: e001
  Local Storage: total: 1.49 TiB used: 713.01 GiB (46.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZ7LN512HCHP-000L1
  size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  type: SSD serial: <filter> rev: 4L0Q scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: KingSpec model: NT-128 size: 119.24 GiB
  block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
  serial: <filter> rev: 872 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: HGST (Hitachi) model: HTS541010A9E680
  type: HDD rpm: 5400 serial: <filter> rev: A7G0 scheme: GPT
  ID-1: / raw-size: 118.95 GiB size: 116.52 GiB (97.96%)
  used: 43.02 GiB (36.9%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18
  used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
  Kernel: swappiness: 10 (default 60) cache-pressure: 50 (default 100)
  ID-1: swap-1 type: file size: 6 GiB used: 0 KiB (0.0%) priority: -2
  file: /data/swapfile
  System Temperatures: cpu: 63.0 C mobo: N/A
  Fan Speeds (RPM): fan-1: 2376
  Processes: 282 Uptime: 2h 51m wakeups: 2 Memory: 31.23 GiB
  used: 5.69 GiB (18.2%) Init: systemd v: 249 tool: systemctl Compilers:
  gcc: 11.1.0 Packages: pacman: 1602 lib: 440 flatpak: 0 snap: 0 Shell: Zsh
  v: 5.8 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.09
Part of old journalctl log with “kernel BUG”:
gruod. 14 09:54:16 abacus kernel: nvidia: module license 'NVIDIA' taints kernel.
gruod. 14 09:54:16 abacus kernel: Disabling lock debugging due to kernel taint
gruod. 14 09:54:16 abacus kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 509
gruod. 14 09:54:16 abacus kernel: nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
gruod. 14 09:54:17 abacus kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  470.86  Tue Oct 26 21:55:45 UTC 2021
gruod. 14 09:54:18 abacus rtkit-daemon[6160]: Supervising 7 threads of 3 processes of 1 users.
gruod. 14 09:54:18 abacus rtkit-daemon[6160]: Successfully made thread 9192 of process 7302 owned by '1000' RT at priority 10.
gruod. 14 09:54:18 abacus rtkit-daemon[6160]: Supervising 8 threads of 4 processes of 1 users.
gruod. 14 09:54:19 abacus kernel: BUG: kernel NULL pointer dereference, address: 00000000000002a8
gruod. 14 09:54:19 abacus kernel: #PF: supervisor read access in kernel mode
gruod. 14 09:54:19 abacus kernel: #PF: error_code(0x0000) - not-present page
gruod. 14 09:54:19 abacus kernel: PGD 0 P4D 0
gruod. 14 09:54:19 abacus kernel: Oops: 0000 [#1] PREEMPT SMP PTI
gruod. 14 09:54:19 abacus kernel: CPU: 6 PID: 9097 Comm: cat Tainted: P        W  OE     5.15.6-2-MANJARO #1 3a19d45d1162f23d4faca02dd20d7e24f26326df
gruod. 14 09:54:19 abacus kernel: Hardware name: LENOVO 20EFS01B09/20EFS01B09, BIOS GNET94WW (2.42 ) 06/02/2021
gruod. 14 09:54:19 abacus kernel: RIP: 0010:_nv000704rm+0x146/0x1c0 [nvidia]
gruod. 14 09:54:19 abacus kernel: Code: ff be 00 00 08 00 bf 02 00 00 00 e8 c4 f8 6e ff 85 c0 75 73 4d 85 e4 74 7e 49 8b bc 24 a0 00 00 00 b9 02 00 00 00 31 d2 31 f6 <48> 8b 87 a8 02 00 00 e8 de ea 04 e2 89 45 0c e8 56 fa 6e ff 8b 45
gruod. 14 09:54:19 abacus kernel: RSP: 0018:ffff9ae903457b78 EFLAGS: 00010246
gruod. 14 09:54:19 abacus kernel: RAX: 0000000000000000 RBX: ffff8d9300ec9800 RCX: 0000000000000002
gruod. 14 09:54:19 abacus kernel: RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000000
gruod. 14 09:54:19 abacus kernel: RBP: ffff8d934c07aff0 R08: 0000000000000000 R09: 0000000000000000
gruod. 14 09:54:19 abacus kernel: R10: 0000000000000000 R11: 0000000000000000 R12: ffff8d9369720008
gruod. 14 09:54:19 abacus kernel: R13: ffff8d9300ec982d R14: ffff9ae903457c80 R15: ffff8d9300ec9800
gruod. 14 09:54:19 abacus kernel: FS:  00007fdf49a2e600(0000) GS:ffff8d99de380000(0000) knlGS:0000000000000000
gruod. 14 09:54:19 abacus kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
gruod. 14 09:54:19 abacus kernel: CR2: 00000000000002a8 CR3: 00000001e11ca001 CR4: 00000000001706e0
gruod. 14 09:54:19 abacus kernel: Call Trace:
gruod. 14 09:54:19 abacus kernel:  <TASK>
gruod. 14 09:54:19 abacus kernel:  ? rm_get_gpu_uuid+0x98/0x150 [nvidia 44b75a4103686940da5cf78362a1ec7c406e7a9b]
gruod. 14 09:54:19 abacus kernel:  ? vsnprintf+0x3ab/0x560
gruod. 14 09:54:19 abacus kernel:  ? nv_procfs_read_gpu_info+0x127/0x300 [nvidia 44b75a4103686940da5cf78362a1ec7c406e7a9b]
gruod. 14 09:54:19 abacus kernel:  ? seq_read_iter+0x12e/0x4c0
gruod. 14 09:54:19 abacus kernel:  ? seq_read+0x12a/0x180
gruod. 14 09:54:19 abacus kernel:  ? proc_reg_read+0x55/0xa0
gruod. 14 09:54:19 abacus kernel:  ? vfs_read+0x63/0x1a0
gruod. 14 09:54:19 abacus kernel:  ? vfs_read+0x95/0x1a0
gruod. 14 09:54:19 abacus kernel:  ? ksys_read+0x67/0xf0
gruod. 14 09:54:19 abacus kernel:  ? do_syscall_64+0x5c/0x90
gruod. 14 09:54:19 abacus kernel:  ? handle_mm_fault+0xd5/0x2c0
gruod. 14 09:54:19 abacus kernel:  ? do_user_addr_fault+0x20b/0x6b0
gruod. 14 09:54:19 abacus kernel:  ? exc_page_fault+0x72/0x180
gruod. 14 09:54:19 abacus kernel:  ? entry_SYSCALL_64_after_hwframe+0x44/0xae
gruod. 14 09:54:19 abacus kernel:  </TASK>
gruod. 14 09:54:19 abacus kernel: Modules linked in: nvidia(POE) ccm rfcomm ip6t_REJECT nf_reject_ipv6 ipt_REJECT nf_reject_ipv4 xt_multiport xt_cgroup xt_mark xt_owner xt_tcpudp cmac algif_hash algif_skcipher af_alg bnep btusb btrtl btbcm btintel ip6table_raw iptable_raw bluetooth intel_rapl_msr ip6table_mangle iptable_mangle rmi_smbus rmi_core joydev mousedev ip6table_nat iptable_nat nf_nat ecdh_generic nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c ip6table_filter ip6_tables iptable_filter intel_rapl_common qrtr ns squashfs loop x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel bbswitch(OE) kvm iwlmvm iTCO_wdt intel_spi_platform think_lmi intel_spi irqbypass spi_nor crct10dif_pclmul intel_pmc_bxt at24 mei_wdt mei_hdcp iTCO_vendor_support mtd wmi_bmof snd_ctl_led firmware_attributes_class crc32_pclmul snd_hda_codec_realtek mac80211 ghash_clmulni_intel aesni_intel snd_hda_codec_generic libarc4 snd_hda_codec_hdmi crypto_simd cryptd rapl iwlwifi intel_cstate snd_hda_intel snd_intel_dspcfg
gruod. 14 09:54:19 abacus kernel:  snd_intel_sdw_acpi intel_uncore vfat snd_hda_codec fat thinkpad_acpi pcspkr i915 snd_hda_core psmouse cfg80211 i2c_i801 ledtrig_audio snd_hwdep platform_profile i2c_smbus lpc_ich snd_pcm mei_me rfkill mei e1000e snd_timer ttm tpm_tis intel_gtt wmi tpm_tis_core snd tpm soundcore video mac_hid rng_core uinput ipmi_devintf ipmi_msghandler sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 usbhid serio_raw atkbd libps2 sdhci_pci cqhci sdhci crc32c_intel i8042 mmc_core xhci_pci serio
gruod. 14 09:54:19 abacus kernel: ---[ end trace 6b2c23d4ae562dce ]---
gruod. 14 09:54:19 abacus rtkit-daemon[6160]: Supervising 8 threads of 4 processes of 1 users.
gruod. 14 09:54:20 abacus rtkit-daemon[6160]: Supervising 8 threads of 4 processes of 1 users.
gruod. 14 09:54:22 abacus systemd[1]: systemd-timedated.service: Deactivated successfully.
