Computer freezes sometimes, REISUB doesn't work
My computer freezes sometimes. I do not know the reason for it.
Background info
I have previously used Ubuntu 20.04 and I had the same type of problem. I then got my PC to a repair shop to have it checked. There were no hardware defects nor problems. They didn’t do any driver checks. Some time after that I installed Manjaro 22.1.2 and finally everything worked perfectly. A period after that I upgraded the system using sudo pacman -Syu and about 500+ upgrades were installed. My computer froze approx a few hours after post system upgrade and restart.
I had Timeshift for backups so there were no problems. However Manjaro is a rolling release so I can’t wait forever to upgrade it.
When a freeze happens I can’t use REISUB. I have confirmed that REISUB work. What I get from cat /etc/sysctl.d/99sysctl.conf is kernel.sysrq=1. My PC’s blinking lamp doesn’t blink when the system freezes. I can’t make the CAPS button’s lamp turn on if the system is frozen. If I had cmus to play music the sound would just stop. So unfortunately I need power the PC down by pressing the power button long enough for it to shut down.
I have tried to upgrade only files that clearly wasn’t system related ones (e.g. Firefox), it worked but it was only 11+ packages of 500+. I tried for a partial upgrade despite it being warned against. I excluded linux packages in IgnoreGroup and IgnonrePkg in /etc/pacman.conf. I used different combination of:
IgnorePkg   = linux linux-headers linux-api-headers manjaro-release
IgnoreGroup = linux manjaro-release
I switched linux and manjaro-release and edited them away sometimes to check if the option crashed against each other. It still crashed.
I rolled back and waited a few days to see if there was a faulty package or something that made my system unstable. I upgraded everything using sudo pacman -Syyu. It seemed to work and I made sure to keep everything up to date then a couple of days after that I got the same kind of system freeze.
Now when this crash happened today last reboot I had open Palemoon, a couple of folders, Gwenview and cmus in Terminal.
Information.
Inxi -v7azy
sudo inxi -v7azy         ✔
[sudo] password for jonatan:
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
        LANGUAGE = "",
        LC_ALL = (unset),
        LC_ADDRESS = "fi_FI.UTF-8",
        LC_IDENTIFICATION = "fi_FI.UTF-8",
        LC_MEASUREMENT = "C",
        LC_MONETARY = "en_FI.UTF-8",
        LC_NAME = "fi_FI.UTF-8",
        LC_NUMERIC = "fi_FI.UTF-8",
        LC_PAPER = "fi_FI.UTF-8",
        LC_TELEPHONE = "fi_FI.UTF-8",
        LC_TIME = "fi_FI.UTF-8",
        LANG = "en_GB.UTF-8"
    are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("en_GB.UTF-8").
  Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=41b3fad3-ccb6-4bf6-b6f8-4d53e439f254 rw quiet
    cryptdevice=UUID=15ee6e27-c5df-49a2-9177-67672878e17f:luks-15ee6e27-c5df-49a2-9177-67672878e17f
    root=/dev/mapper/luks-15ee6e27-c5df-49a2-9177-67672878e17f splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_wayland dm: SDDM
  Type: Desktop Mobo: MSI model: X370 KRAIT GAMING (MS-7A33) v: 1.0
    serial: <filter> UEFI: American Megatrends v: 1.H0 date: 01/21/2019
  System RAM: available: 15.57 GiB used: 4.62 GiB (29.7%)
  Array-1: capacity: 256 GiB note: check slots: 4 EC: None
    max-module-size: 64 GiB note: est.
  Device-1: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 8 GiB speed: spec: 2400 MT/s actual: 1200 MT/s volts: curr: 1.2
    min: 1.2 max: 1.2 width (bits): data: 64 total: 64 manufacturer: Kingston
    part-no: KF3200C16D4/8GX serial: <filter>
  Device-2: DIMM 1 type: no module installed
  Device-3: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-4: DIMM 1 type: no module installed
  Info: model: AMD Ryzen 5 1600X socket: AM4 bits: 64 type: MT MCP arch: Zen
    level: v3 note: check built: 2017-19 process: GF 14nm family: 0x17 (23)
    model-id: 1 stepping: 1 microcode: 0x8001137
    L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
    desc: 2x8 MiB
  Speed (MHz): avg: 2316 high: 3600 min/max: 2200/3600 boost: enabled
    base/boost: 3600/4100 scaling: driver: acpi-cpufreq governor: schedutil
    volts: 1.4 V ext-clock: 100 MHz cores: 1: 2200 2: 3600 3: 2200 4: 2200
    5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
    bogomips: 86425
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
    cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
    flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
    lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
    sep sev sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a
    ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
    v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
    xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    disabled, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
    vendor: Micro-Star MSI driver: amdgpu v: kernel arch: GCN-4
    code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
    speed: 8 GT/s lanes: 16 ports: active: HDMI-A-2 empty: DP-1, DP-2,
    DVI-D-1, HDMI-A-1 bus-ID: 26:00.0 chip-ID: 1002:67df class-ID: 0300
    temp: 53.0 C
  Display: server: X.Org v: 23.1.1 with: Xwayland v: 23.1.1
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :1 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
    s-diag: 583mm (22.95")
  Monitor-1: HDMI-A-2 model: BenQ GC2870 serial: <filter> built: 2017
    res: 1920x1080 hz: 60 dpi: 79 gamma: 1.2 size: 620x340mm (24.41x13.39")
    diag: 708mm (27.9") ratio: 16:9 modes: max: 1920x1080 min: 720x400
  API: OpenGL v: 4.6 Mesa 23.0.4 renderer: AMD Radeon RX 580 Series
    (polaris10 LLVM 15.0.7 DRM 3.49 6.1.31-2-MANJARO) direct-render: Yes
  Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 26:00.1
    chip-ID: 1002:aaf0 class-ID: 0403
  Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
    bus-ID: 28:00.3 chip-ID: 1022:1457 class-ID: 0403
  API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.70 status: n/a (root, process) with: wireplumber
    status: active tools: pw-cli,wpctl
  Server-3: PulseAudio v: 16.1 status: active (root, process)
    with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: f000 bus-ID: 21:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp33s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-1: luks-15ee6e27-c5df-49a2-9177-67672878e17f maj-min: 254:0
    type: LUKS dm: dm-0 size: 1.82 TiB
  Components:
  p-1: sda2 maj-min: 8:2 size: 1.82 TiB
  Local Storage: total: 5.46 TiB used: 514.09 GiB (9.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
    family: BarraCuda 3.5 (SMR) size: 1.82 TiB block-size: physical: 4096 B
    logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 7200
    serial: <filter> fw-rev: 0001 temp: 41 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 2434h+51m+16.827s cycles: 419
    read: 1.65 TiB written: 2.14 TiB Pre-Fail: attribute: Spin_Retry_Count
    value: 100 worst: 100 threshold: 97
  ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000DM004-2CV104
    family: BarraCuda 3.5 (SMR) size: 3.64 TiB block-size: physical: 4096 B
    logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 5425
    serial: <filter> fw-rev: 0001 temp: 36 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 7706h+58m+05.315s cycles: 1195
    read: 9.88 TiB written: 893.56 GiB Pre-Fail: attribute: Spin_Retry_Count
  ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 169.5 GiB (9.3%)
    fs: ext4 block-size: 4096 B dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-15ee6e27-c5df-49a2-9177-67672878e17f label: N/A
    uuid: 41b3fad3-ccb6-4bf6-b6f8-4d53e439f254
    used: 448 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
    label: N/A uuid: FEF2-17E7
  ID-3: /run/timeshift/5345/backup raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
    used: 344.59 GiB (18.8%) fs: ext4 block-size: 4096 B dev: /dev/sdb1
    maj-min: 8:17 label: 2TBtop uuid: fc918111-f99a-47fc-a959-47207c36f4ff
  ID-1: /dev/sdb2 maj-min: 8:18 size: 1.82 TiB fs: ext4 label: 2TB_bottom
    uuid: 693a6ad4-1456-4c9a-bbcb-ef742d3bc7fa
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 14 rev: 2.0
  Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-3:2 info: Logitech USB Keyboard type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 90mA chip-ID: 046d:c34b class-ID: 0300
  Device-2: 5-4:3 info: USB GAMING MOUSE type: mouse,keyboard
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 30fa:1130 class-ID: 0301
  Hub-6: 6-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 47.0 C mobo: N/A gpu: amdgpu temp: 53.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 185
  Processes: 326 Uptime: 2h 3m wakeups: 0 Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
  Packages: 1580 pm: pacman pkgs: 1574 libs: 483 tools: pamac,yay pm: flatpak
  pkgs: 6 Shell: Zsh (sudo) v: 5.9 default: Bash v: 5.1.16 running-in: konsole
  inxi: 3.3.27
Journalctl. Today when the latest crash happened.
Journalctl
journalctl --boot=-1 --priority=3 --catalog --no-pager         ✔  1m 41s 
May 03 17:25:07 jonatan-ms7a33 kernel: kvm: support for 'kvm_amd' disabled by bios
Jun 13 09:50:03 jonatan-ms7a33 pulseaudio[1345]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Jun 13 09:51:02 jonatan-ms7a33 konsole[1525]: kf.xmlgui: Shortcut for action  "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Jun 13 09:51:02 jonatan-ms7a33 konsole[1525]: kf.xmlgui: Shortcut for action  "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Jun 13 09:52:04 jonatan-ms7a33 konsole[2086]: kf.xmlgui: Shortcut for action  "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Jun 13 09:52:04 jonatan-ms7a33 konsole[2086]: kf.xmlgui: Shortcut for action  "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Jun 13 10:29:52 jonatan-ms7a33 gwenview[3299]: QWaylandShmBuffer: mmap failed (Invalid argument)
Jun 13 10:29:53 jonatan-ms7a33 gwenview[3299]: QWaylandShmBuffer: mmap failed (Invalid argument)
Jun 13 10:29:54 jonatan-ms7a33 gwenview[3299]: QWaylandShmBuffer: mmap failed (Invalid argument)
Jun 13 10:29:56 jonatan-ms7a33 gwenview[3299]: QWaylandShmBuffer: mmap failed (Invalid argument)
Jun 13 10:29:58 jonatan-ms7a33 gwenview[3299]: QWaylandShmBuffer: mmap failed (Invalid argument)
Jun 13 10:30:01 jonatan-ms7a33 gwenview[3299]: QWaylandShmBuffer: mmap failed (Invalid argument)
Jun 13 10:30:04 jonatan-ms7a33 gwenview[3299]: QWaylandShmBuffer: mmap failed (Invalid argument)
Jun 13 10:30:12 jonatan-ms7a33 gwenview[3299]: QWaylandShmBuffer: mmap failed (Invalid argument)
Jun 13 10:30:14 jonatan-ms7a33 gwenview[3299]: QWaylandShmBuffer: mmap failed (Invalid argument)
Jun 13 10:30:23 jonatan-ms7a33 gwenview[3299]: QWaylandShmBuffer: mmap failed (Invalid argument)
Jun 13 10:30:25 jonatan-ms7a33 gwenview[3299]: QWaylandShmBuffer: mmap failed (Invalid argument)
Jun 13 10:31:18 jonatan-ms7a33 gwenview[3299]: QWaylandShmBuffer: mmap failed (Invalid argument)
Jun 13 18:32:14 jonatan-ms7a33 gwenview[8780]: QWaylandShmBuffer: mmap failed (Invalid argument)
Jun 13 18:32:16 jonatan-ms7a33 gwenview[8780]: QWaylandShmBuffer: mmap failed (Invalid argument)
Jun 13 18:33:41 jonatan-ms7a33 gwenview[8780]: QWaylandShmBuffer: mmap failed (Invalid argument)
Jun 13 18:34:16 jonatan-ms7a33 gwenview[8780]: QWaylandShmBuffer: mmap failed (Invalid argument)
Jun 13 18:34:41 jonatan-ms7a33 gwenview[8866]: QWaylandShmBuffer: mmap failed (Invalid argument)
Jun 13 18:34:42 jonatan-ms7a33 gwenview[8866]: QWaylandShmBuffer: mmap failed (Invalid argument)
Jun 13 18:35:27 jonatan-ms7a33 gwenview[8866]: QWaylandShmBuffer: mmap failed (Invalid argument)
Jun 13 18:36:00 jonatan-ms7a33 gwenview[8866]: QWaylandShmBuffer: mmap failed (Invalid argument)
Jun 13 18:36:23 jonatan-ms7a33 gwenview[8866]: QWaylandShmBuffer: mmap failed (Invalid argument)
Jun 13 18:36:35 jonatan-ms7a33 gwenview[8866]: QWaylandShmBuffer: mmap failed (Invalid argument)
Jun 13 18:37:03 jonatan-ms7a33 gwenview[8780]: QWaylandShmBuffer: mmap failed (Invalid argument)
Jun 13 18:37:04 jonatan-ms7a33 gwenview[8780]: QWaylandShmBuffer: mmap failed (Invalid argument)
Jun 13 18:37:36 jonatan-ms7a33 konsole[9084]: kf.xmlgui: Shortcut for action  "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Jun 13 18:37:36 jonatan-ms7a33 konsole[9084]: kf.xmlgui: Shortcut for action  "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Jun 13 18:39:17 jonatan-ms7a33 gwenview[8866]: QWaylandShmBuffer: mmap failed (Invalid argument)
Jun 13 18:39:18 jonatan-ms7a33 gwenview[8866]: QWaylandShmBuffer: mmap failed (Invalid argument)
Jun 13 18:40:24 jonatan-ms7a33 gwenview[8780]: QWaylandShmBuffer: mmap failed (Invalid argument)
Jun 13 18:40:25 jonatan-ms7a33 gwenview[8780]: QWaylandShmBuffer: mmap failed (Invalid argument)
Sudo Dmesg --level emerg,alert,crit,err,warn. Today when the latest crash happened.
dmesg
sudo dmesg --level emerg,alert,crit,err,warn         ✔
[    0.000000] ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20220331/tbfadt-615)
[    0.425948] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.426025] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.426135] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.426229] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.426330] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.426426] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.426487] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.426567] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.426633] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.426725] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.426799] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.426889] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    3.233727] ata5: failed to resume link (SControl 0)
[    4.460859] usb: port power management may be unreliable
[   66.357547] vboxdrv: loading out-of-tree module taints kernel.
[   66.555565] VBoxNetAdp: Successfully started.
[   66.604491] VBoxNetFlt: Successfully started.
[   67.684808] systemd-journald[456]: File /var/log/journal/341864a718924dd7a41a6ae2ed424948/system.journal corrupted or uncleanly shut down, renaming and replacing.
[   69.676525] kvm: support for 'kvm_amd' disabled by bios
[   72.143566] amdgpu: SRAT table not found
[   98.307178] systemd-journald[456]: File /var/log/journal/341864a718924dd7a41a6ae2ed424948/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[  176.126917] [UFW BLOCK] IN=enp33s0 OUT= MAC=01:00:5e:00:00:01:54:e6:fc:d1:2f:c0:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[  301.124640] [UFW BLOCK] IN=enp33s0 OUT= MAC=01:00:5e:00:00:01:54:e6:fc:d1:2f:c0:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[  426.122462] [UFW BLOCK] IN=enp33s0 OUT= MAC=01:00:5e:00:00:01:54:e6:fc:d1:2f:c0:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[  551.120691] [UFW BLOCK] IN=enp33s0 OUT= MAC=01:00:5e:00:00:01:54:e6:fc:d1:2f:c0:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[  676.118528] [UFW BLOCK] IN=enp33s0 OUT= MAC=01:00:5e:00:00:01:54:e6:fc:d1:2f:c0:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[  801.116419] [UFW BLOCK] IN=enp33s0 OUT= MAC=01:00:5e:00:00:01:54:e6:fc:d1:2f:c0:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[  926.113646] [UFW BLOCK] IN=enp33s0 OUT= MAC=01:00:5e:00:00:01:54:e6:fc:d1:2f:c0:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1051.111342] [UFW BLOCK] IN=enp33s0 OUT= MAC=01:00:5e:00:00:01:54:e6:fc:d1:2f:c0:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1176.109362] [UFW BLOCK] IN=enp33s0 OUT= MAC=01:00:5e:00:00:01:54:e6:fc:d1:2f:c0:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1301.106875] [UFW BLOCK] IN=enp33s0 OUT= MAC=01:00:5e:00:00:01:54:e6:fc:d1:2f:c0:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1426.104714] [UFW BLOCK] IN=enp33s0 OUT= MAC=01:00:5e:00:00:01:54:e6:fc:d1:2f:c0:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1551.102638] [UFW BLOCK] IN=enp33s0 OUT= MAC=01:00:5e:00:00:01:54:e6:fc:d1:2f:c0:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
When I finally decided to keep my system upgraded I saved the logs if I would need it.
sudo pacman -Syyu
sudo pacman -Syyu         ✔
 core                                     143.6 KiB   825 KiB/s 00:00 [#######################################] 100%
 extra                                   1636.7 KiB  4.99 MiB/s 00:00 [#######################################] 100%
 community                                  7.0 MiB  3.88 MiB/s 00:02 [#######################################] 100%
 multilib                                 145.2 KiB  2.53 MiB/s 00:00 [#######################################] 100%
resolving dependencies...
warning: dependency cycle detected:
warning: libcamera-ipa will be installed before its libcamera dependency
Packages (512) a52dec-0.8.0-1  adwaita-cursors-44.0-1  adwaita-icon-theme-44.0-1  alsa-lib-1.2.9-1
               alsa-ucm-conf-1.2.9-1  alsa-utils-1.2.9-1  aom-3.6.1-1  apparmor-3.1.3-2  appstream-0.16.2-1
               appstream-qt-0.16.2-1  argon2-20190702-5  at-spi2-core-2.48.2-1  attica-5.106.0-1
               audiocd-kio-23.04.1-1  audit-3.1.1-1  avahi-0.8+22+gfd482a7-4  baloo-5.106.0-1
               baloo-widgets-23.04.1-1  benchmark-1.8.0-1  binutils-2.40-5  bluedevil-1:5.27.5-1
               bluez-qt-5.106.0-1  bogofilter-1.2.5-8  boost-libs-1.81.0-6  botan-3.0.0-1  breeze-5.27.5-1
               breeze-gtk-5.27.5-1  breeze-icons-5.106.0-1  brotli-1.0.9-12  btrfs-progs-6.3-2
               ca-certificates-mozilla-3.89.1-1  cblas-3.11.0-2  clang-15.0.7-9  compiler-rt-15.0.7-2
               cryptsetup-2.6.1-3.4  cups-1:2.4.2-7  cups-filters-1.28.17-3  curl-8.1.0-1  dav1d-1.2.0-1
               dbus-python-1.2.18-5  dhclient-4.4.3.P1-2  dhcpcd-10.0.1-1  dolphin-23.04.1-1.1
               dolphin-plugins-23.04.1-1  double-conversion-3.3.0-1  ethtool-1:6.3-1  exfatprogs-1.2.1-1
               ffmpeg-2:6.0-6  ffmpegthumbs-23.04.1-1  filelight-23.04.1-1  firefox-114.0-1
               firefox-i18n-en-gb-114.0-1  firefox-i18n-en-us-114.0-1  firefox-i18n-fi-114.0-1
               frameworkintegration-5.106.0-1  fwupd-1.9.1-1  gawk-5.2.2-1  gcc-13.1.1-1  gcc-libs-13.1.1-1
               gcr-3.41.1-4  glib2-2.76.2-1  glibc-2.37-3  glslang-12.1.0-2  gnome-desktop-1:44.0-1
               gnome-desktop-common-1:44.0-1  gnome-online-accounts-3.48.0-2
               gnome-video-effects-1:0.5.0+r18+g5f4c801-1  gobject-introspection-runtime-1.76.1-3
               goocanvas-3.0.0-4  gpgme-1.20.0-3  gpm-1.20.7.r38.ge82d1a6-5  graphviz-8.0.5-2  grep-3.11-1
               gsl-2.7.1-3  gst-libav-1.22.2-1  gst-plugins-bad-1.22.2-1  gst-plugins-bad-libs-1.22.2-1
               gst-plugins-base-1.22.2-1  gst-plugins-base-libs-1.22.2-1  gst-plugins-good-1.22.2-1
               gst-plugins-ugly-1.22.2-1  gstreamer-1.22.2-1  gtk-update-icon-cache-1:4.10.3-2  gtk4-1:4.10.3-2
               gufw-22.04-2  gvfs-1.50.4-3  harfbuzz-7.3.0-1  harfbuzz-icu-7.3.0-1  hwdata-0.370-1
               imagemagick-7.1.1.9-1  imath-3.1.7-2  imlib2-1.11.1-1  iproute2-6.3.0-2  iso-codes-4.15.0-1
               iw-5.19-2  jemalloc-1:5.3.0-2  jxrlib-0.2.4-2  kaccounts-integration-23.04.1-1
               kaccounts-providers-23.04.1-1  kactivities-5.106.0-1  kactivities-stats-5.106.0-1
               kactivitymanagerd-5.27.5-1  kamera-23.04.1-1  karchive-5.106.0-1  kate-23.04.1-1  kauth-5.106.0-1
               kbd-2.5.1-2  kbookmarks-5.106.0-1  kcmutils-5.106.0-1  kcodecs-5.106.0-1  kcompletion-5.106.0-1
               kconfig-5.106.0-1  kconfigwidgets-5.106.0-1  kcontacts-1:5.106.0-1  kcoreaddons-5.106.0-1
               kcrash-5.106.0-1  kdbusaddons-5.106.0-1  kde-cli-tools-5.27.5.1-1  kde-gtk-config-5.27.5-1
               kdeclarative-5.106.0-1  kdeconnect-23.04.1-1  kdecoration-5.27.5-1  kded-5.106.0-1
               kdegraphics-mobipocket-23.04.1-1  kdegraphics-thumbnailers-23.04.1-1  kdelibs4support-5.106.0-1
               kdenetwork-filesharing-23.04.1-1  kdeplasma-addons-5.27.5-1  kdesu-5.106.0-1  kdialog-23.04.1-1
               kdnssd-5.106.0-1  kdoctools-5.106.0-1  keditbookmarks-23.04.1-1  kemoticons-5.106.0-1
               keyutils-1.6.3-2  kfilemetadata-5.106.0-1  kfind-23.04.1-1  kgamma5-5.27.5-1  kglobalaccel-5.106.0-1
               kguiaddons-5.106.0-1  khelpcenter-23.04.1-1  kholidays-1:5.106.0-1  khotkeys-5.27.5-1
               khtml-5.106.0-1  ki18n-5.106.0-1  kiconthemes-5.106.0-1  kidletime-5.106.0-1
               kimageformats-5.106.0-1  kinfocenter-5.27.5-1  kinit-5.106.0-1  kio-5.106.0-1  kio-extras-23.04.1-1
               kirigami2-5.106.0-1  kitemmodels-5.106.0-1  kitemviews-5.106.0-1  kjobwidgets-5.106.0-1
               kjs-5.106.0-1  kmenuedit-5.27.5-1  knetwalk-23.04.1-1  knewstuff-5.106.0-1  knotifications-5.106.0-1
               knotifyconfig-5.106.0-1  konsole-23.04.1-1  kpackage-5.106.0-1  kparts-5.106.0-1  kpeople-5.106.0-1
               kpipewire-5.27.5-1  kplotting-5.106.0-1  kpmcore-23.04.1-1  kpty-5.106.0-1  kquickcharts-5.106.0-1
               krunner-5.106.0-1  ksanecore-23.04.1-1  kscreen-5.27.5-1  kscreenlocker-5.27.5-1  kservice-5.106.0-1
               ksshaskpass-5.27.5-1  ksystemlog-23.04.1-1  ksystemstats-5.27.5-1  ktexteditor-5.106.0-1
               ktextwidgets-5.106.0-1  kunitconversion-5.106.0-1  kwallet-5.106.0-1  kwallet-pam-5.27.5-1
               kwalletmanager-23.04.1-1  kwayland-5.106.0-1  kwayland-integration-5.27.5-1
               kwidgetsaddons-5.106.0-1  kwin-5.27.5-2  kwindowsystem-5.106.0-1  kwrited-5.27.5-1
               kxmlgui-5.106.0-1  layer-shell-qt-5.27.5-1  ldb-2:2.7.2-2  lensfun-1:0.3.3-2  less-1:633-1
               lib32-alsa-lib-1.2.9-1  lib32-at-spi2-core-2.48.2-1  lib32-curl-8.1.0-1  lib32-gcc-libs-13.1.1-1
               lib32-glib2-2.76.2-1  lib32-glibc-2.37-3  lib32-harfbuzz-7.3.0-1  lib32-imlib2-1.11.1-1
               lib32-libcap-2.69-1  lib32-libcurl-compat-8.1.0-1  lib32-libcurl-gnutls-8.1.0-1
               lib32-libdecor-0.1.1-1  lib32-libgpg-error-1.47-1  lib32-libva-2.18.0-1  lib32-libxfixes-6.0.1-1
               lib32-libxft-2.3.8-1  lib32-libxi-1.8.1-1  lib32-libxkbcommon-1.5.0-1
               lib32-libxkbcommon-x11-1.5.0-1  lib32-libxml2-2.10.4-4  lib32-libxt-1.3.0-1
               lib32-mangohud-0.6.9.1-2  lib32-mesa-demos-9.0.0-1  lib32-nss-3.89.1-1  lib32-pam-1.5.3-1
               lib32-sqlite-3.41.2-1  lib32-systemd-253.4-1  lib32-vkd3d-1.7.1-1  lib32-xz-5.4.3-1
               libaccounts-glib-1.26-2  libblockdev-2.28-2  libbpf-1.2.0-1  libbytesize-2.7-2  libcamera-0.0.5-1
               libcamera-ipa-0.0.5-1  libcap-2.69-1  libcap-ng-0.8.3-2  libcheese-44.0.1-1  libcups-1:2.4.2-7
               libcurl-compat-8.1.0-1  libcurl-gnutls-8.1.0-1  libevdev-1.13.1-1  libftdi-1.5-5  libgdata-0.18.1-3
               libgexiv2-0.14.0-4  libgirepository-1.76.1-3  libgoa-3.48.0-2  libheif-1.16.1-2  libibus-1.5.28-4
               libieee1284-0.2.11-15  libimobiledevice-1.3.0-8  libixion-0.17.0-5  libkcddb-23.04.1-1
               libkcompactdisc-23.04.1-1  libkdcraw-23.04.1-1  libkdegames-23.04.1-1  libkexiv2-23.04.1-1
               libksane-23.04.1-1  libkscreen-5.27.5-1  libksysguard-5.27.5-1  libmalcontent-0.11.1-2
               libmwaw-0.3.22-1  libnewt-0.52.23-2  libnghttp2-1.53.0-1  libopenmpt-0.7.1-1  liborcus-0.17.2-5
               libpackagekit-glib-1.2.6-2  libpipewire-1:0.3.70-2  libplist-2.3.0-1  libproxy-0.4.18-3
               libpwquality-1.4.5-2  libreoffice-still-7.4.7-2  libreoffice-still-en-gb-7.4.7-1
               libreoffice-still-fi-7.4.7-1  libseccomp-2.5.4-2  libsmbios-2.4.3-6  libsoup3-3.4.2-1
               libspeechd-0.11.4-2  libssh-0.10.5-1  libteam-1.31-8  libtool-2.4.7+4+g1ec8fa28-3  libtpms-0.9.6-1
               libunrar-1:6.2.7-1  libupnp-1.14.17-1  libusbmuxd-2.0.2-2  libwacom-2.7.0-1  libwbclient-4.18.2-2
               libwmf-0.2.13-1  libwpg-0.3.4-1  libwps-0.4.14-1  libxi-1.8.1-1  libxml2-2.10.4-4  libxslt-1.1.37-3
               libytnef-1:2.1.1-1  lilv-0.24.20-2  linux-api-headers-6.3-1  linux515-5.15.114-2
               linux515-virtualbox-host-modules-7.0.8-11  linux61-6.1.31-2
               linux61-virtualbox-host-modules-7.0.8-10  llvm-15.0.7-3  llvm-libs-15.0.7-3  lua-5.4.6-1
               luajit-2.1.0.beta3.r471.g224129a8-1  lutris-0.5.13-6  man-pages-fi-4.18.1-1  mangohud-0.6.9.1-2
               mangohud-common-0.6.9.1-2  manjaro-application-utility-1.3.3-9  manjaro-kde-settings-20230529-1
               manjaro-release-23.0.0pre-1  memtest86+-6.20-1  memtest86+-efi-6.20-1  milou-5.27.5-1
               minetest-common-5.7.0-1  modemmanager-qt-5.106.0-1  mpfr-4.2.0.p7-2  net-snmp-5.9.1-6  nettle-3.9-1
               networkmanager-qt-5.106.0-1  nftables-1:1.0.7-2  noto-fonts-20230501-1  nss-3.89.1-1
               openconnect-1:9.10-1  opendht-1:2.5.5-1  openresolv-3.13.1-1  openvpn-2.6.4-1  oxygen-5.27.5-1
               oxygen-icons-1:5.106.0-1  oxygen-sounds-5.27.5-1  packagekit-1.2.6-2
               pacman-mirrors-4.23.2+3+g4148c3d-1  pam-1.5.3-1  pamac-cli-10.5.1-2  pamac-gtk-10.5.1-2
               partitionmanager-23.04.1-1  pciutils-3.10.0-1  perl-5.36.1-1  perl-uri-5.18-1  pipewire-1:0.3.70-2
               plasma-browser-integration-5.27.5-1  plasma-desktop-5.27.5-1  plasma-framework-5.106.0-1
               plasma-integration-5.27.5-1  plasma-nm-5.27.5-1  plasma-pa-5.27.5-1  plasma-systemmonitor-5.27.5-1
               plasma-thunderbolt-5.27.5-1  plasma-wayland-session-5.27.5-1  plasma-workspace-5.27.5-1
               plasma-workspace-wallpapers-5.27.5-1  plymouth-kcm-5.27.5-1  polkit-kde-agent-5.27.5-1
               poppler-23.05.0-1  poppler-glib-23.05.0-1  poppler-qt5-23.05.0-1  postgresql-libs-15.3-1
               powerdevil-5.27.5-3  print-manager-23.04.1-1  prison-5.106.0-1  protobuf-21.12-2  purpose-5.106.0-1
               pyside6-6.5.0-2  python-3.11.3-1  python-apsw-3.41.2.0-1  python-async-timeout-4.0.2-3
               python-attrs-22.2.0-3  python-beautifulsoup4-4.12.2-1  python-brotli-1.0.9-12
               python-brotlicffi-1.0.9.2-4  python-cairo-1.23.0-4  python-capng-0.8.3-2  python-cchardet-2.1.7-5
               python-certifi-2022.12.07-3  python-cffi-1.15.1-3  python-chardet-5.1.0-3  python-configobj-5.0.8-4
               python-cryptography-40.0.2-1  python-css-parser-1.0.9-1  python-cssselect-1.2.0-3
               python-dateutil-2.8.2-5  python-distro-1.8.0-3  python-dnspython-1:2.3.0-3  python-docopt-0.6.2-12
               python-evdev-1.6.1-2  python-feedparser-6.0.10-3  python-future-0.18.3-1  python-gobject-3.44.1-3
               python-html2text-2020.1.16-9  python-html5-parser-0.4.11-1  python-html5lib-1.1-12
               python-idna-3.4-3  python-ifaddr-0.2.0-2  python-inflate64-0.3.1-2  python-jeepney-0.8.0-2
               python-keyutils-0.6-9  python-lxml-4.9.2-3  python-manjaro-sdk-0.9-2  python-markdown-3.4.3-2
               python-mechanize-1:0.4.8-2  python-moddb-0.8.1-1  python-msgpack-1.0.5-1
               python-multivolumefile-0.2.3-6  python-netifaces-0.11.0-4  python-npyscreen-4.10.5-8
               python-packaging-23.1-1  python-pdftotext-2.2.2-4  python-pefile-2023.2.7-1  python-pexpect-4.8.0-7
               python-pillow-9.5.0-2  python-pip-23.1.2-1  python-ply-3.11-12  python-psutil-5.9.5-1
               python-ptyprocess-0.7.0-5  python-py7zr-0.20.5-2  python-pybcj-1.0.1-2  python-pychm-0.8.6-7
               python-pycparser-2.21-5  python-pycryptodome-3.17.0-2  python-pycryptodomex-3.12.0-2
               python-pycups-2.0.1-6  python-pycurl-7.45.2-3  python-pygments-2.15.1-1  python-pyppmd-1.0.0-2
               python-pyqt5-5.15.9-2  python-pyqt5-sip-12.12.1-2  python-pyqt6-6.5.0-2  python-pyqt6-sip-13.5.1-2
               python-pyqt6-webengine-6.5.0-2  python-pyrate-limiter-2.10.0-1  python-pysmbc-1.0.23-4
               python-pyxdg-0.28-2  python-pyzstd-0.15.7-2  python-regex-2023.5.5-1  python-reportlab-3.6.12-3
               python-requests-2.28.2-4  python-sgmllib3k-1.0.0-5  python-six-1.16.0-8  python-soupsieve-2.4.1-1
               python-sqlalchemy1.3-1.3.24-6  python-systemd-235-2  python-texttable-1.6.7-2  python-toolz-0.12.0-3
               python-typing_extensions-4.5.0-4  python-unrardll-0.1.7-1  python-urllib3-1.26.15-1
               python-webencodings-0.5.1-10  python-websockets-10.4-3  python-wheel-0.40.0-3  python-yaml-6.0-3
               python-zeroconf-0.39.4-2  qca-qt5-2.3.6-2  qqc2-desktop-style-5.106.0-1
               qt5-declarative-5.15.9+kde+r25-1  qt5-quickcontrols2-5.15.9+kde+r6-1  qt5-svg-5.15.9+kde+r8-1
               samba-4.18.2-2  sddm-kcm-5.27.5-1  sdl2-2.26.5-2  shiboken6-6.5.0-2
               signon-kwallet-extension-23.04.1-1  smbclient-4.18.2-2  snapd-2.59.4-1  sof-firmware-2.2.5-1
               solid-5.106.0-1  sonnet-5.106.0-1  spectacle-23.04.1-1  speech-dispatcher-0.11.4-2  sqlite-3.42.0-1
               svt-av1-1.5.0-1  syndication-5.106.0-1  syntax-highlighting-5.106.0-1
               system-config-printer-1.5.18-2  systemd-253.4-1  systemd-libs-253.4-1  systemd-sysvcompat-253.4-1
               systemsettings-5.27.5-1  talloc-2.4.0-3  tdb-1.4.8-2  terminator-2.1.3-3  tevent-1:0.14.1-2
               thin-provisioning-tools-1.0.4-1  threadweaver-5.106.0-1  tpm2-tss-4.0.1-1  tracker3-3.5.2-1
               tzdata-2023c-2  udiskie-2.4.2-2  ufw-0.36.2-1  unrar-1:6.2.7-1  upower-1.90.0-4  usbmuxd-1.1.1-3
               util-linux-2.38.1-4  util-linux-libs-2.38.1-4  virtualbox-7.0.8-2  virtualbox-ext-vnc-7.0.8-2
               virtualbox-sdk-7.0.8-2  vkd3d-1.7.1-1  volume_key-0.3.12-8  vulkan-headers-1:1.3.248-1
               webkit2gtk-2.40.1-2  webkit2gtk-4.1-2.40.1-2  wine-8.8-1  wine-gecko-2.47.4-1
               wireless-regdb-2023.05.03-1  xapp-2.4.3-2  xcb-proto-1.15.2-3  xdg-desktop-portal-1.16.0-3
               xdg-desktop-portal-kde-5.27.5-1  xf86-video-ati-1:22.0.0-1  xorg-setxkbmap-1.3.4-1
               xorg-xdpyinfo-1.3.4-1  xz-5.4.3-1  yakuake-23.04.1-1  zbar-0.23.90-2  zenity-3.44.1-1
               zsh-theme-powerlevel10k-1.18.0-1
Total Download Size:     67.64 MiB
Total Installed Size:  5581.53 MiB
Net Upgrade Size:        83.76 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
 firefox-114.0-1-x86_64                    64.9 MiB  3.82 MiB/s 00:17 [#######################################] 100%
 lutris-0.5.13-6-any                     1043.6 KiB  4.63 MiB/s 00:00 [#######################################] 100%
 firefox-i18n-fi-114.0-1-any              497.9 KiB  3.83 MiB/s 00:00 [#######################################] 100%
 firefox-i18n-en-gb-114.0-1-any           481.0 KiB  3.70 MiB/s 00:00 [#######################################] 100%
 firefox-i18n-en-us-114.0-1-any           444.7 KiB  3.84 MiB/s 00:00 [#######################################] 100%
 python-toolz-0.12.0-3-any                143.0 KiB  2.79 MiB/s 00:00 [#######################################] 100%
 python-moddb-0.8.1-1-any                 120.0 KiB  3.17 MiB/s 00:00 [#######################################] 100%
 python-pyrate-limiter-2.10.0-1-any        30.4 KiB  1127 KiB/s 00:00 [#######################################] 100%
 Total (8/8)                               67.6 MiB  3.76 MiB/s 00:18 [#######################################] 100%
(512/512) checking keys in keyring                                    [#######################################] 100%
(512/512) checking package integrity                                  [#######################################] 100%
(512/512) loading package files                                       [#######################################] 100%
(512/512) checking for file conflicts                                 [#######################################] 100%
(512/512) checking available disk space                               [#######################################] 100%
(1/3) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(2/3) Removing linux initcpios...
(3/3) Remove Firefox Distribution Settings
(  1/512) upgrading linux-api-headers                                 [#######################################] 100%
(  2/512) upgrading tzdata                                            [#######################################] 100%
(  3/512) upgrading glibc                                             [#######################################] 100%
Generating locales...
  en_GB.UTF-8... done
  en_US.UTF-8... done
  fi_FI.UTF-8... done
Generation complete.
(  4/512) upgrading a52dec                                            [#######################################] 100%
(  5/512) upgrading adwaita-cursors                                   [#######################################] 100%
(  6/512) upgrading util-linux-libs                                   [#######################################] 100%
New optional dependencies for util-linux-libs
    python: python bindings to libmount [installed]
(  7/512) upgrading gcc-libs                                          [#######################################] 100%
(  8/512) upgrading glib2                                             [#######################################] 100%
(  9/512) upgrading xz                                                [#######################################] 100%
( 10/512) upgrading libxml2                                           [#######################################] 100%
( 11/512) upgrading brotli                                            [#######################################] 100%
( 12/512) upgrading harfbuzz                                          [#######################################] 100%
( 13/512) upgrading xcb-proto                                         [#######################################] 100%
( 14/512) upgrading gtk-update-icon-cache                             [#######################################] 100%
( 15/512) upgrading adwaita-icon-theme                                [#######################################] 100%
( 16/512) upgrading alsa-ucm-conf                                     [#######################################] 100%
( 17/512) upgrading alsa-lib                                          [#######################################] 100%
( 18/512) upgrading hwdata                                            [#######################################] 100%
( 19/512) upgrading pciutils                                          [#######################################] 100%
( 20/512) upgrading alsa-utils                                        [#######################################] 100%
New optional dependencies for alsa-utils
    bash: for alsa-info.sh and alsabat-test.sh [installed]
( 21/512) upgrading aom                                               [#######################################] 100%
( 22/512) upgrading libcap-ng                                         [#######################################] 100%
( 23/512) upgrading keyutils                                          [#######################################] 100%
( 24/512) upgrading audit                                             [#######################################] 100%
New optional dependencies for audit
    libldap: for audispd-zos-remote [installed]
    sh: for augenrules [installed]
( 25/512) upgrading pam                                               [#######################################] 100%
( 26/512) upgrading python                                            [#######################################] 100%
( 27/512) upgrading apparmor                                          [#######################################] 100%
( 28/512) upgrading libnghttp2                                        [#######################################] 100%
( 29/512) upgrading libcap                                            [#######################################] 100%
( 30/512) upgrading systemd-libs                                      [#######################################] 100%
( 31/512) upgrading ca-certificates-mozilla                           [#######################################] 100%
( 32/512) upgrading curl                                              [#######################################] 100%
( 33/512) upgrading appstream                                         [#######################################] 100%
( 34/512) upgrading sqlite                                            [#######################################] 100%
( 35/512) upgrading avahi                                             [#######################################] 100%
( 36/512) upgrading nettle                                            [#######################################] 100%
( 37/512) upgrading libcups                                           [#######################################] 100%
( 38/512) upgrading double-conversion                                 [#######################################] 100%
( 39/512) upgrading libxi                                             [#######################################] 100%
( 40/512) upgrading libproxy                                          [#######################################] 100%
( 41/512) upgrading llvm-libs                                         [#######################################] 100%
( 42/512) upgrading libseccomp                                        [#######################################] 100%
( 43/512) upgrading argon2                                            [#######################################] 100%
( 44/512) upgrading cryptsetup                                        [#######################################] 100%
( 45/512) upgrading kbd                                               [#######################################] 100%
( 46/512) upgrading util-linux                                        [#######################################] 100%
( 47/512) upgrading systemd                                           [#######################################] 100%
New optional dependencies for systemd
    libmicrohttpd: systemd-journal-gatewayd and systemd-journal-remote
    libp11-kit: support PKCS#11 [installed]
    python: Unified Kernel Image with ukify [installed]
    systemd-ukify: combine kernel and initrd into a signed Unified Kernel Image
( 48/512) upgrading libevdev                                          [#######################################] 100%
( 49/512) upgrading libwacom                                          [#######################################] 100%
( 50/512) upgrading appstream-qt                                      [#######################################] 100%
( 51/512) upgrading at-spi2-core                                      [#######################################] 100%
( 52/512) upgrading attica                                            [#######################################] 100%
( 53/512) upgrading libplist                                          [#######################################] 100%
( 54/512) upgrading libusbmuxd                                        [#######################################] 100%
( 55/512) upgrading libimobiledevice                                  [#######################################] 100%
( 56/512) upgrading usbmuxd                                           [#######################################] 100%
( 57/512) upgrading upower                                            [#######################################] 100%
( 58/512) upgrading btrfs-progs                                       [#######################################] 100%
( 59/512) upgrading mpfr                                              [#######################################] 100%
( 60/512) upgrading libbytesize                                       [#######################################] 100%
( 61/512) upgrading lib32-glibc                                       [#######################################] 100%
( 62/512) upgrading lib32-gcc-libs                                    [#######################################] 100%
( 63/512) upgrading lib32-pam                                         [#######################################] 100%
( 64/512) upgrading lib32-libcap                                      [#######################################] 100%
( 65/512) upgrading tpm2-tss                                          [#######################################] 100%
( 66/512) upgrading gpgme                                             [#######################################] 100%
( 67/512) upgrading nss                                               [#######################################] 100%
( 68/512) upgrading volume_key                                        [#######################################] 100%
New optional dependencies for volume_key
    python-volume_key: for Python bindings
( 69/512) upgrading thin-provisioning-tools                           [#######################################] 100%
( 70/512) upgrading libblockdev                                       [#######################################] 100%
( 71/512) upgrading solid                                             [#######################################] 100%
( 72/512) upgrading kcoreaddons                                       [#######################################] 100%
( 73/512) upgrading kwidgetsaddons                                    [#######################################] 100%
( 74/512) upgrading kjobwidgets                                       [#######################################] 100%
( 75/512) upgrading kdbusaddons                                       [#######################################] 100%
( 76/512) upgrading kconfig                                           [#######################################] 100%
( 77/512) upgrading kwindowsystem                                     [#######################################] 100%
( 78/512) upgrading kcrash                                            [#######################################] 100%
( 79/512) upgrading kglobalaccel                                      [#######################################] 100%
( 80/512) upgrading qt5-svg                                           [#######################################] 100%
( 81/512) upgrading kauth                                             [#######################################] 100%
( 82/512) upgrading kcodecs                                           [#######################################] 100%
( 83/512) upgrading qt5-declarative                                   [#######################################] 100%
( 84/512) upgrading kguiaddons                                        [#######################################] 100%
( 85/512) upgrading iso-codes                                         [#######################################] 100%
( 86/512) upgrading ki18n                                             [#######################################] 100%
( 87/512) upgrading kconfigwidgets                                    [#######################################] 100%
( 88/512) upgrading karchive                                          [#######################################] 100%
( 89/512) upgrading kiconthemes                                       [#######################################] 100%
( 90/512) upgrading kitemviews                                        [#######################################] 100%
( 91/512) upgrading kxmlgui                                           [#######################################] 100%
( 92/512) upgrading kbookmarks                                        [#######################################] 100%
( 93/512) upgrading libxslt                                           [#######################################] 100%
( 94/512) upgrading tdb                                               [#######################################] 100%
( 95/512) upgrading libtool                                           [#######################################] 100%
( 96/512) upgrading gstreamer                                         [#######################################] 100%
( 97/512) upgrading gst-plugins-base-libs                             [#######################################] 100%
( 98/512) upgrading gst-plugins-base                                  [#######################################] 100%
( 99/512) upgrading knotifications                                    [#######################################] 100%
(100/512) upgrading kservice                                          [#######################################] 100%
(101/512) upgrading qca-qt5                                           [#######################################] 100%
(102/512) upgrading kwallet                                           [#######################################] 100%
(103/512) upgrading kcompletion                                       [#######################################] 100%
(104/512) upgrading sonnet                                            [#######################################] 100%
(105/512) upgrading ktextwidgets                                      [#######################################] 100%
(106/512) upgrading kded                                              [#######################################] 100%
(107/512) upgrading kio                                               [#######################################] 100%
(108/512) upgrading kpackage                                          [#######################################] 100%
(109/512) upgrading kdeclarative                                      [#######################################] 100%
(110/512) upgrading kcmutils                                          [#######################################] 100%
(111/512) upgrading libkcddb                                          [#######################################] 100%
(112/512) upgrading libkcompactdisc                                   [#######################################] 100%
(113/512) upgrading audiocd-kio                                       [#######################################] 100%
(114/512) upgrading poppler                                           [#######################################] 100%
(115/512) upgrading poppler-qt5                                       [#######################################] 100%
(116/512) upgrading dav1d                                             [#######################################] 100%
(117/512) upgrading libopenmpt                                        [#######################################] 100%
(118/512) upgrading libssh                                            [#######################################] 100%
(119/512) upgrading sdl2                                              [#######################################] 100%
(120/512) upgrading svt-av1                                           [#######################################] 100%
(121/512) upgrading imath                                             [#######################################] 100%
(122/512) upgrading perl                                              [#######################################] 100%
(123/512) upgrading ffmpeg                                            [#######################################] 100%
(124/512) upgrading kfilemetadata                                     [#######################################] 100%
(125/512) upgrading kidletime                                         [#######################################] 100%
(126/512) upgrading baloo                                             [#######################################] 100%
(127/512) upgrading baloo-widgets                                     [#######################################] 100%
(128/512) upgrading benchmark                                         [#######################################] 100%
(129/512) upgrading binutils                                          [#######################################] 100%
(130/512) upgrading bluez-qt                                          [#######################################] 100%
(131/512) upgrading bluedevil                                         [#######################################] 100%
(132/512) installing cblas                                            [#######################################] 100%
(133/512) upgrading gsl                                               [#######################################] 100%
(134/512) upgrading bogofilter                                        [#######################################] 100%
(135/512) upgrading boost-libs                                        [#######################################] 100%
(136/512) upgrading botan                                             [#######################################] 100%
(137/512) upgrading syndication                                       [#######################################] 100%
(138/512) upgrading knewstuff                                         [#######################################] 100%
(139/512) upgrading frameworkintegration                              [#######################################] 100%
(140/512) upgrading kdecoration                                       [#######################################] 100%
(141/512) upgrading breeze-icons                                      [#######################################] 100%
(142/512) upgrading kwayland                                          [#######################################] 100%
(143/512) upgrading qt5-quickcontrols2                                [#######################################] 100%
(144/512) upgrading kirigami2                                         [#######################################] 100%
(145/512) upgrading breeze                                            [#######################################] 100%
(146/512) upgrading breeze-gtk                                        [#######################################] 100%
(147/512) upgrading gcc                                               [#######################################] 100%
(148/512) upgrading compiler-rt                                       [#######################################] 100%
(149/512) upgrading clang                                             [#######################################] 100%
(150/512) upgrading cups-filters                                      [#######################################] 100%
(151/512) upgrading cups                                              [#######################################] 100%
(152/512) upgrading dbus-python                                       [#######################################] 100%
(153/512) upgrading libbpf                                            [#######################################] 100%
(154/512) upgrading iproute2                                          [#######################################] 100%
(155/512) upgrading dhclient                                          [#######################################] 100%
(156/512) upgrading dhcpcd                                            [#######################################] 100%
(157/512) upgrading kdnssd                                            [#######################################] 100%
(158/512) upgrading talloc                                            [#######################################] 100%
(159/512) upgrading tevent                                            [#######################################] 100%
(160/512) upgrading ldb                                               [#######################################] 100%
(161/512) upgrading libwbclient                                       [#######################################] 100%
(162/512) upgrading smbclient                                         [#######################################] 100%
(163/512) upgrading libkexiv2                                         [#######################################] 100%
(164/512) upgrading syntax-highlighting                               [#######################################] 100%
(165/512) upgrading kio-extras                                        [#######################################] 100%
(166/512) upgrading kparts                                            [#######################################] 100%
(167/512) upgrading kactivities                                       [#######################################] 100%
(168/512) upgrading dolphin                                           [#######################################] 100%
(169/512) upgrading dolphin-plugins                                   [#######################################] 100%
(170/512) upgrading ethtool                                           [#######################################] 100%
(171/512) upgrading exfatprogs                                        [#######################################] 100%
(172/512) upgrading ffmpegthumbs                                      [#######################################] 100%
(173/512) upgrading qqc2-desktop-style                                [#######################################] 100%
(174/512) upgrading kquickcharts                                      [#######################################] 100%
(175/512) upgrading filelight                                         [#######################################] 100%
(176/512) upgrading noto-fonts                                        [#######################################] 100%
(177/512) upgrading libsoup3                                          [#######################################] 100%
(178/512) upgrading tracker3                                          [#######################################] 100%
(179/512) upgrading firefox                                           [#######################################] 100%
(180/512) upgrading firefox-i18n-en-gb                                [#######################################] 100%
(181/512) upgrading firefox-i18n-en-us                                [#######################################] 100%
(182/512) upgrading firefox-i18n-fi                                   [#######################################] 100%
(183/512) upgrading libsmbios                                         [#######################################] 100%
(184/512) upgrading libftdi                                           [#######################################] 100%
(185/512) upgrading protobuf                                          [#######################################] 100%
(186/512) upgrading fwupd                                             [#######################################] 100%
(187/512) upgrading gawk                                              [#######################################] 100%
(188/512) upgrading gcr                                               [#######################################] 100%
(189/512) upgrading glslang                                           [#######################################] 100%
(190/512) upgrading gnome-desktop-common                              [#######################################] 100%
(191/512) upgrading gnome-desktop                                     [#######################################] 100%
(192/512) upgrading gst-plugins-bad-libs                              [#######################################] 100%
(193/512) upgrading harfbuzz-icu                                      [#######################################] 100%
(194/512) upgrading webkit2gtk-4.1                                    [#######################################] 100%
(195/512) installing libgoa                                           [#######################################] 100%
(196/512) upgrading gnome-online-accounts                             [#######################################] 100%
(197/512) upgrading lilv                                              [#######################################] 100%
(198/512) upgrading imagemagick                                       [#######################################] 100%
(199/512) upgrading zbar                                              [#######################################] 100%
(200/512) upgrading libpipewire                                       [#######################################] 100%
(201/512) upgrading gst-plugins-bad                                   [#######################################] 100%
(202/512) upgrading gpm                                               [#######################################] 100%
(203/512) upgrading imlib2                                            [#######################################] 100%
(204/512) upgrading gst-plugins-good                                  [#######################################] 100%
(205/512) upgrading gnome-video-effects                               [#######################################] 100%
(206/512) upgrading libgirepository                                   [#######################################] 100%
(207/512) upgrading gobject-introspection-runtime                     [#######################################] 100%
(208/512) upgrading goocanvas                                         [#######################################] 100%
(209/512) upgrading libheif                                           [#######################################] 100%
New optional dependencies for libheif
    rav1e: rav1e encoder [installed]
    svt-av1: svt-av1 encoder [installed]
(210/512) upgrading graphviz                                          [#######################################] 100%
New optional dependencies for graphviz
    qt6-base: gvedit [installed]
(211/512) upgrading grep                                              [#######################################] 100%
(212/512) upgrading gst-libav                                         [#######################################] 100%
(213/512) upgrading gst-plugins-ugly                                  [#######################################] 100%
(214/512) upgrading gtk4                                              [#######################################] 100%
(215/512) upgrading python-gobject                                    [#######################################] 100%
(216/512) upgrading ufw                                               [#######################################] 100%
(217/512) upgrading webkit2gtk                                        [#######################################] 100%
(218/512) upgrading gufw                                              [#######################################] 100%
(219/512) upgrading gvfs                                              [#######################################] 100%
(220/512) upgrading iw                                                [#######################################] 100%
(221/512) upgrading jemalloc                                          [#######################################] 100%
(222/512) upgrading jxrlib                                            [#######################################] 100%
(223/512) upgrading signon-kwallet-extension                          [#######################################] 100%
(224/512) upgrading libaccounts-glib                                  [#######################################] 100%
(225/512) upgrading kaccounts-integration                             [#######################################] 100%
(226/512) upgrading kaccounts-providers                               [#######################################] 100%
(227/512) upgrading kactivities-stats                                 [#######################################] 100%
(228/512) upgrading kactivitymanagerd                                 [#######################################] 100%
(229/512) upgrading kamera                                            [#######################################] 100%
(230/512) upgrading ktexteditor                                       [#######################################] 100%
(231/512) upgrading kate                                              [#######################################] 100%
(232/512) upgrading kcontacts                                         [#######################################] 100%
(233/512) upgrading kpty                                              [#######################################] 100%
(234/512) upgrading kdesu                                             [#######################################] 100%
(235/512) upgrading kde-cli-tools                                     [#######################################] 100%
(236/512) upgrading kde-gtk-config                                    [#######################################] 100%
(237/512) upgrading modemmanager-qt                                   [#######################################] 100%
(238/512) upgrading kpeople                                           [#######################################] 100%
(239/512) upgrading kdeconnect                                        [#######################################] 100%
(240/512) upgrading kdegraphics-mobipocket                            [#######################################] 100%
(241/512) upgrading libkdcraw                                         [#######################################] 100%
(242/512) upgrading kdegraphics-thumbnailers                          [#######################################] 100%
(243/512) upgrading kunitconversion                                   [#######################################] 100%
(244/512) upgrading kitemmodels                                       [#######################################] 100%
(245/512) upgrading kemoticons                                        [#######################################] 100%
(246/512) upgrading kdelibs4support                                   [#######################################] 100%
(247/512) upgrading samba                                             [#######################################] 100%
(248/512) upgrading kdenetwork-filesharing                            [#######################################] 100%
(249/512) upgrading knotifyconfig                                     [#######################################] 100%
(250/512) upgrading libksysguard                                      [#######################################] 100%
(251/512) upgrading ksystemstats                                      [#######################################] 100%
(252/512) upgrading kholidays                                         [#######################################] 100%
(253/512) upgrading plasma-framework                                  [#######################################] 100%
(254/512) upgrading threadweaver                                      [#######################################] 100%
(255/512) upgrading krunner                                           [#######################################] 100%
(256/512) upgrading milou                                             [#######################################] 100%
(257/512) upgrading prison                                            [#######################################] 100%
(258/512) upgrading layer-shell-qt                                    [#######################################] 100%
(259/512) upgrading libkscreen                                        [#######################################] 100%
(260/512) upgrading kscreenlocker                                     [#######################################] 100%
(261/512) upgrading libcamera-ipa                                     [#######################################] 100%
(262/512) upgrading libcamera                                         [#######################################] 100%
(263/512) upgrading pipewire                                          [#######################################] 100%
(264/512) upgrading lua                                               [#######################################] 100%
(265/512) upgrading kwin                                              [#######################################] 100%
(266/512) upgrading plasma-integration                                [#######################################] 100%
(267/512) upgrading kpipewire                                         [#######################################] 100%
(268/512) upgrading oxygen-sounds                                     [#######################################] 100%
(269/512) upgrading plasma-workspace                                  [#######################################] 100%
(270/512) upgrading kdeplasma-addons                                  [#######################################] 100%
(271/512) upgrading kdialog                                           [#######################################] 100%
(272/512) upgrading kdoctools                                         [#######################################] 100%
(273/512) upgrading keditbookmarks                                    [#######################################] 100%
(274/512) upgrading kfind                                             [#######################################] 100%
(275/512) upgrading systemsettings                                    [#######################################] 100%
(276/512) upgrading kgamma5                                           [#######################################] 100%
(277/512) upgrading kjs                                               [#######################################] 100%
(278/512) upgrading khtml                                             [#######################################] 100%
(279/512) upgrading khelpcenter                                       [#######################################] 100%
(280/512) upgrading khotkeys                                          [#######################################] 100%
(281/512) upgrading kimageformats                                     [#######################################] 100%
(282/512) upgrading xorg-xdpyinfo                                     [#######################################] 100%
(283/512) upgrading kinfocenter                                       [#######################################] 100%
(284/512) upgrading kinit                                             [#######################################] 100%
(285/512) upgrading kmenuedit                                         [#######################################] 100%
(286/512) upgrading libkdegames                                       [#######################################] 100%
(287/512) upgrading knetwalk                                          [#######################################] 100%
(288/512) upgrading konsole                                           [#######################################] 100%
(289/512) upgrading kplotting                                         [#######################################] 100%
(290/512) upgrading kpmcore                                           [#######################################] 100%
(291/512) upgrading libieee1284                                       [#######################################] 100%
(292/512) upgrading net-snmp                                          [#######################################] 100%
(293/512) upgrading poppler-glib                                      [#######################################] 100%
(294/512) upgrading ksanecore                                         [#######################################] 100%
(295/512) upgrading kscreen                                           [#######################################] 100%
(296/512) upgrading ksshaskpass                                       [#######################################] 100%
(297/512) upgrading ksystemlog                                        [#######################################] 100%
(298/512) upgrading kwallet-pam                                       [#######################################] 100%
(299/512) upgrading kwalletmanager                                    [#######################################] 100%
(300/512) upgrading kwayland-integration                              [#######################################] 100%
(301/512) upgrading kwrited                                           [#######################################] 100%
(302/512) upgrading lensfun                                           [#######################################] 100%
(303/512) upgrading less                                              [#######################################] 100%
(304/512) upgrading lib32-alsa-lib                                    [#######################################] 100%
(305/512) upgrading lib32-glib2                                       [#######################################] 100%
(306/512) upgrading lib32-xz                                          [#######################################] 100%
(307/512) upgrading lib32-libxml2                                     [#######################################] 100%
(308/512) upgrading lib32-libgpg-error                                [#######################################] 100%
(309/512) upgrading lib32-systemd                                     [#######################################] 100%
(310/512) upgrading lib32-libxfixes                                   [#######################################] 100%
(311/512) upgrading lib32-libxi                                       [#######################################] 100%
(312/512) upgrading lib32-at-spi2-core                                [#######################################] 100%
(313/512) upgrading lib32-curl                                        [#######################################] 100%
(314/512) upgrading lib32-harfbuzz                                    [#######################################] 100%
(315/512) upgrading lib32-imlib2                                      [#######################################] 100%
(316/512) upgrading lib32-libcurl-compat                              [#######################################] 100%
(317/512) upgrading lib32-libcurl-gnutls                              [#######################################] 100%
(318/512) upgrading lib32-libva                                       [#######################################] 100%
(319/512) upgrading lib32-libxft                                      [#######################################] 100%
(320/512) upgrading lib32-libxt                                       [#######################################] 100%
(321/512) upgrading mangohud-common                                   [#######################################] 100%
(322/512) upgrading lib32-mangohud                                    [#######################################] 100%
(323/512) installing lib32-libdecor                                   [#######################################] 100%
(324/512) installing lib32-libxkbcommon                               [#######################################] 100%
(325/512) installing lib32-libxkbcommon-x11                           [#######################################] 100%
(326/512) upgrading lib32-mesa-demos                                  [#######################################] 100%
(327/512) upgrading lib32-sqlite                                      [#######################################] 100%
(328/512) upgrading lib32-nss                                         [#######################################] 100%
(329/512) upgrading lib32-vkd3d                                       [#######################################] 100%
(330/512) upgrading libcheese                                         [#######################################] 100%
(331/512) upgrading libcurl-compat                                    [#######################################] 100%
(332/512) upgrading libcurl-gnutls                                    [#######################################] 100%
(333/512) upgrading libgdata                                          [#######################################] 100%
(334/512) upgrading libgexiv2                                         [#######################################] 100%
(335/512) upgrading libibus                                           [#######################################] 100%
(336/512) upgrading libixion                                          [#######################################] 100%
(337/512) upgrading libksane                                          [#######################################] 100%
(338/512) upgrading libmalcontent                                     [#######################################] 100%
(339/512) upgrading libmwaw                                           [#######################################] 100%
(340/512) upgrading libnewt                                           [#######################################] 100%
(341/512) upgrading liborcus                                          [#######################################] 100%
(342/512) upgrading libpackagekit-glib                                [#######################################] 100%
(343/512) upgrading libpwquality                                      [#######################################] 100%
(344/512) upgrading libwps                                            [#######################################] 100%
(345/512) upgrading libwpg                                            [#######################################] 100%
(346/512) upgrading libreoffice-still                                 [#######################################] 100%
(347/512) upgrading libreoffice-still-en-gb                           [#######################################] 100%
(348/512) upgrading libreoffice-still-fi                              [#######################################] 100%
(349/512) upgrading libspeechd                                        [#######################################] 100%
(350/512) upgrading libteam                                           [#######################################] 100%
(351/512) upgrading libtpms                                           [#######################################] 100%
(352/512) upgrading libunrar                                          [#######################################] 100%
(353/512) upgrading libupnp                                           [#######################################] 100%
(354/512) upgrading libwmf                                            [#######################################] 100%
(355/512) upgrading libytnef                                          [#######################################] 100%
(356/512) upgrading linux515                                          [#######################################] 100%
(357/512) upgrading linux515-virtualbox-host-modules                  [#######################################] 100%
In order to use the new version, reload all virtualbox modules manually.
(358/512) upgrading linux61                                           [#######################################] 100%
(359/512) upgrading linux61-virtualbox-host-modules                   [#######################################] 100%
(360/512) upgrading llvm                                              [#######################################] 100%
(361/512) upgrading luajit                                            [#######################################] 100%
(362/512) upgrading python-cairo                                      [#######################################] 100%
(363/512) upgrading python-certifi                                    [#######################################] 100%
(364/512) upgrading python-distro                                     [#######################################] 100%
(365/512) upgrading python-lxml                                       [#######################################] 100%
(366/512) upgrading python-soupsieve                                  [#######################################] 100%
(367/512) upgrading python-beautifulsoup4                             [#######################################] 100%
(368/512) installing python-pyrate-limiter                            [#######################################] 100%
Optional dependencies for python-pyrate-limiter
    python-filelock: concurrent sqlite backend
    python-redis: redis backend
(369/512) upgrading python-urllib3                                    [#######################################] 100%
New optional dependencies for python-urllib3
    python-certifi: security support [installed]
    python-cryptography: security support [installed]
(370/512) upgrading python-chardet                                    [#######################################] 100%
(371/512) upgrading python-idna                                       [#######################################] 100%
(372/512) upgrading python-requests                                   [#######################################] 100%
(373/512) installing python-toolz                                     [#######################################] 100%
(374/512) installing python-moddb                                     [#######################################] 100%
(375/512) upgrading python-pillow                                     [#######################################] 100%
(376/512) upgrading python-yaml                                       [#######################################] 100%
(377/512) upgrading xdg-desktop-portal-kde                            [#######################################] 100%
(378/512) upgrading xdg-desktop-portal                                [#######################################] 100%
(379/512) upgrading lutris                                            [#######################################] 100%
New optional dependencies for lutris
    python-protobuf: BattleNet integration
(380/512) upgrading man-pages-fi                                      [#######################################] 100%
(381/512) upgrading mangohud                                          [#######################################] 100%
(382/512) upgrading python-npyscreen                                  [#######################################] 100%
(383/512) upgrading pacman-mirrors                                    [#######################################] 100%
(384/512) upgrading pamac-cli                                         [#######################################] 100%
(385/512) upgrading pamac-gtk                                         [#######################################] 100%
(386/512) upgrading manjaro-application-utility                       [#######################################] 100%
(387/512) upgrading manjaro-kde-settings                              [#######################################] 100%
(388/512) upgrading manjaro-release                                   [#######################################] 100%
(389/512) upgrading memtest86+                                        [#######################################] 100%
(390/512) upgrading memtest86+-efi                                    [#######################################] 100%
(391/512) upgrading minetest-common                                   [#######################################] 100%
(392/512) upgrading networkmanager-qt                                 [#######################################] 100%
(393/512) upgrading nftables                                          [#######################################] 100%
(394/512) upgrading openconnect                                       [#######################################] 100%
(395/512) upgrading opendht                                           [#######################################] 100%
(396/512) upgrading openresolv                                        [#######################################] 100%
(397/512) upgrading openvpn                                           [#######################################] 100%
(398/512) upgrading oxygen                                            [#######################################] 100%
(399/512) upgrading oxygen-icons                                      [#######################################] 100%
(400/512) upgrading packagekit                                        [#######################################] 100%
(401/512) upgrading partitionmanager                                  [#######################################] 100%
(402/512) upgrading perl-uri                                          [#######################################] 100%
(403/512) upgrading purpose                                           [#######################################] 100%
(404/512) upgrading plasma-browser-integration                        [#######################################] 100%
(405/512) upgrading polkit-kde-agent                                  [#######################################] 100%
(406/512) upgrading powerdevil                                        [#######################################] 100%
(407/512) upgrading plasma-desktop                                    [#######################################] 100%
(408/512) upgrading plasma-nm                                         [#######################################] 100%
(409/512) upgrading plasma-pa                                         [#######################################] 100%
(410/512) upgrading plasma-systemmonitor                              [#######################################] 100%
(411/512) upgrading plasma-thunderbolt                                [#######################################] 100%
(412/512) upgrading xorg-setxkbmap                                    [#######################################] 100%
(413/512) upgrading plasma-wayland-session                            [#######################################] 100%
(414/512) upgrading plasma-workspace-wallpapers                       [#######################################] 100%
(415/512) upgrading plymouth-kcm                                      [#######################################] 100%
(416/512) upgrading postgresql-libs                                   [#######################################] 100%
(417/512) upgrading print-manager                                     [#######################################] 100%
(418/512) upgrading vulkan-headers                                    [#######################################] 100%
(419/512) upgrading shiboken6                                         [#######################################] 100%
(420/512) upgrading pyside6                                           [#######################################] 100%
(421/512) upgrading python-apsw                                       [#######################################] 100%
(422/512) upgrading python-typing_extensions                          [#######################################] 100%
(423/512) upgrading python-async-timeout                              [#######################################] 100%
(424/512) upgrading python-attrs                                      [#######################################] 100%
(425/512) upgrading python-brotli                                     [#######################################] 100%
(426/512) upgrading python-ply                                        [#######################################] 100%
(427/512) upgrading python-pycparser                                  [#######################################] 100%
(428/512) upgrading python-cffi                                       [#######################################] 100%
(429/512) upgrading python-brotlicffi                                 [#######################################] 100%
(430/512) upgrading python-capng                                      [#######################################] 100%
(431/512) upgrading python-cchardet                                   [#######################################] 100%
(432/512) upgrading python-six                                        [#######################################] 100%
(433/512) upgrading python-configobj                                  [#######################################] 100%
(434/512) upgrading python-cryptography                               [#######################################] 100%
(435/512) upgrading python-css-parser                                 [#######################################] 100%
(436/512) upgrading python-cssselect                                  [#######################################] 100%
(437/512) upgrading python-dateutil                                   [#######################################] 100%
(438/512) upgrading python-dnspython                                  [#######################################] 100%
(439/512) upgrading python-docopt                                     [#######################################] 100%
(440/512) upgrading python-evdev                                      [#######################################] 100%
(441/512) upgrading python-sgmllib3k                                  [#######################################] 100%
(442/512) upgrading python-feedparser                                 [#######################################] 100%
(443/512) upgrading python-future                                     [#######################################] 100%
(444/512) upgrading python-html2text                                  [#######################################] 100%
(445/512) upgrading python-html5-parser                               [#######################################] 100%
(446/512) upgrading python-webencodings                               [#######################################] 100%
(447/512) upgrading python-html5lib                                   [#######################################] 100%
(448/512) upgrading python-ifaddr                                     [#######################################] 100%
(449/512) upgrading python-inflate64                                  [#######################################] 100%
(450/512) upgrading python-jeepney                                    [#######################################] 100%
(451/512) upgrading python-keyutils                                   [#######################################] 100%
(452/512) upgrading python-systemd                                    [#######################################] 100%
(453/512) upgrading python-manjaro-sdk                                [#######################################] 100%
(454/512) upgrading python-markdown                                   [#######################################] 100%
(455/512) upgrading python-mechanize                                  [#######################################] 100%
(456/512) upgrading python-msgpack                                    [#######################################] 100%
(457/512) upgrading python-multivolumefile                            [#######################################] 100%
(458/512) upgrading python-netifaces                                  [#######################################] 100%
(459/512) upgrading python-packaging                                  [#######################################] 100%
(460/512) upgrading python-pdftotext                                  [#######################################] 100%
(461/512) upgrading python-pefile                                     [#######################################] 100%
(462/512) upgrading python-ptyprocess                                 [#######################################] 100%
(463/512) upgrading python-pexpect                                    [#######################################] 100%
(464/512) upgrading python-wheel                                      [#######################################] 100%
(465/512) upgrading python-pip                                        [#######################################] 100%
(466/512) upgrading python-psutil                                     [#######################################] 100%
(467/512) upgrading python-pybcj                                      [#######################################] 100%
(468/512) upgrading python-pycryptodomex                              [#######################################] 100%
(469/512) upgrading python-pyppmd                                     [#######################################] 100%
(470/512) upgrading python-pyzstd                                     [#######################################] 100%
(471/512) upgrading python-texttable                                  [#######################################] 100%
(472/512) upgrading python-py7zr                                      [#######################################] 100%
(473/512) upgrading python-pychm                                      [#######################################] 100%
(474/512) upgrading python-pycryptodome                               [#######################################] 100%
(475/512) upgrading python-pycups                                     [#######################################] 100%
(476/512) upgrading python-pycurl                                     [#######################################] 100%
(477/512) upgrading python-pygments                                   [#######################################] 100%
(478/512) upgrading python-pyqt5-sip                                  [#######################################] 100%
(479/512) upgrading python-pyqt5                                      [#######################################] 100%
(480/512) upgrading python-pyqt6-sip                                  [#######################################] 100%
(481/512) upgrading python-pyqt6                                      [#######################################] 100%
(482/512) upgrading python-pyqt6-webengine                            [#######################################] 100%
(483/512) upgrading python-pysmbc                                     [#######################################] 100%
(484/512) upgrading python-pyxdg                                      [#######################################] 100%
(485/512) upgrading python-regex                                      [#######################################] 100%
(486/512) upgrading python-reportlab                                  [#######################################] 100%
(487/512) upgrading python-sqlalchemy1.3                              [#######################################] 100%
(488/512) upgrading python-unrardll                                   [#######################################] 100%
(489/512) upgrading python-websockets                                 [#######################################] 100%
(490/512) upgrading python-zeroconf                                   [#######################################] 100%
(491/512) upgrading sddm-kcm                                          [#######################################] 100%
(492/512) upgrading snapd                                             [#######################################] 100%
(493/512) upgrading sof-firmware                                      [#######################################] 100%
(494/512) upgrading spectacle                                         [#######################################] 100%
(495/512) upgrading speech-dispatcher                                 [#######################################] 100%
(496/512) upgrading system-config-printer                             [#######################################] 100%
(497/512) upgrading systemd-sysvcompat                                [#######################################] 100%
(498/512) upgrading terminator                                        [#######################################] 100%
(499/512) upgrading udiskie                                           [#######################################] 100%
(500/512) upgrading unrar                                             [#######################################] 100%
(501/512) upgrading virtualbox                                        [#######################################] 100%
0%...10%...20%...30%...40%...50%...60%...70%...80%...90%...100%
(502/512) upgrading virtualbox-ext-vnc                                [#######################################] 100%
bsdtar: Failed to set default locale
(503/512) upgrading virtualbox-sdk                                    [#######################################] 100%
(504/512) upgrading vkd3d                                             [#######################################] 100%
(505/512) upgrading wine                                              [#######################################] 100%
(506/512) upgrading wine-gecko                                        [#######################################] 100%
(507/512) upgrading wireless-regdb                                    [#######################################] 100%
(508/512) upgrading xapp                                              [#######################################] 100%
(509/512) upgrading xf86-video-ati                                    [#######################################] 100%
(510/512) upgrading yakuake                                           [#######################################] 100%
(511/512) upgrading zenity                                            [#######################################] 100%
(512/512) upgrading zsh-theme-powerlevel10k                           [#######################################] 100%
( 1/33) Creating system user accounts...
( 2/33) Registering binary formats...
( 3/33) Updating journal message catalog...
( 4/33) Reloading system manager configuration...
( 5/33) Updating udev hardware database...
( 6/33) Applying kernel sysctl settings...
( 7/33) Creating temporary files...
( 8/33) Reloading device manager configuration...
( 9/33) Arming ConditionNeedsUpdate...
(10/33) Updating the MIME type database...
(11/33) Rebuilding certificate stores...
(12/33) Updating module dependencies...
(13/33) Restarting cronie for libc upgrade...
(14/33) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
  -> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img --microcode /boot/amd-ucode.img
==> Starting build: '5.15.114-2-MANJARO'
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
  -> Running build hook: [plymouth]
  -> Running build hook: [encrypt]
  -> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: '/boot/initramfs-5.15-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
  -> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect --microcode /boot/amd-ucode.img
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-5.15-x86_64-fallback.img'
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'default'
  -> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64.img --microcode /boot/amd-ucode.img
==> Starting build: '6.1.31-2-MANJARO'
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.1-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'fallback'
  -> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64-fallback.img -S autodetect --microcode /boot/amd-ucode.img
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.1-x86_64-fallback.img'
(15/33) Refreshing PackageKit...
(16/33) Updating the appstream cache...
? Metadata cache was updated successfully.
(17/33) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
(18/33) Reloading system bus configuration...
(19/33) Warn about old perl modules
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
        LANGUAGE = "",
        LC_ALL = (unset),
        LC_ADDRESS = "fi_FI.UTF-8",
        LC_NAME = "fi_FI.UTF-8",
        LC_MONETARY = "en_FI.UTF-8",
        LC_PAPER = "fi_FI.UTF-8",
        LC_IDENTIFICATION = "fi_FI.UTF-8",
        LC_TELEPHONE = "fi_FI.UTF-8",
        LC_MEASUREMENT = "C",
        LC_TIME = "fi_FI.UTF-8",
        LC_NUMERIC = "fi_FI.UTF-8",
        LANG = "en_GB.UTF-8"
    are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("en_GB.UTF-8").
(20/33) Copy Firefox Distribution Settings
(21/33) Updating fontconfig cache...
(22/33) Updating 32-bit fontconfig cache...
(23/33) Probing GDK-Pixbuf loader modules...
(24/33) Updating GIO module cache...
(25/33) Compiling GSettings XML schema files...
(26/33) Updating icon theme caches...
(27/33) Updating GTK4 module cache...
(28/33) Reloading GVFS config...
(29/33) Hiding redundant menu entries
(30/33) Configuring pacman-mirrors ...
::INFO => Mirror status: https://repo.manjaro.org/status.json
hint: use `pacman-mirrors` to generate and update your pacman mirrorlist.
(31/33) Updating the info directory file...
(32/33) Updating the desktop file MIME type cache...
(33/33) Updating X fontdir indices...
I also saved from what version of packages I upgraded to what version. When I saved this I had yet to comment IgnorePkg and IgnoreGroup. Do note that this is only from the big update. Not the small ones I performed to make sure that the system was up to date later.
pacman -Qu
pacman -Qu
a52dec 0.7.4-12 -> 0.8.0-1
adwaita-cursors 43-2 -> 44.0-1
adwaita-icon-theme 43-2 -> 44.0-1
alsa-lib 1.2.8-1 -> 1.2.9-1
alsa-ucm-conf 1.2.8-1 -> 1.2.9-1
alsa-utils 1.2.8-1 -> 1.2.9-1
aom 3.6.0-1 -> 3.6.1-1
apparmor 3.1.3-1 -> 3.1.3-2
appstream 0.16.1-2 -> 0.16.2-1
appstream-qt 0.16.1-2 -> 0.16.2-1
argon2 20190702-4 -> 20190702-5
at-spi2-core 2.48.0-2 -> 2.48.2-1
attica 5.105.0-1 -> 5.106.0-1
audiocd-kio 23.04.0-1 -> 23.04.1-1
audit 3.1-1 -> 3.1.1-1
avahi 0.8+22+gfd482a7-3 -> 0.8+22+gfd482a7-4
baloo 5.105.0-1 -> 5.106.0-1
baloo-widgets 23.04.0-1 -> 23.04.1-1
benchmark 1.7.1-1 -> 1.8.0-1
binutils 2.40-4 -> 2.40-5
bluedevil 1:5.27.4-1 -> 1:5.27.5-1
bluez-qt 5.105.0-1 -> 5.106.0-1
bogofilter 1.2.5-7 -> 1.2.5-8
boost-libs 1.81.0-3 -> 1.81.0-6
botan 2.19.3-1 -> 3.0.0-1
breeze 5.27.4-1 -> 5.27.5-1
breeze-gtk 5.27.4-2.1 -> 5.27.5-1
breeze-icons 5.105.0-1 -> 5.106.0-1
brotli 1.0.9-10 -> 1.0.9-12
btrfs-progs 6.2.2-1 -> 6.3-2
ca-certificates-mozilla 3.89-1 -> 3.89.1-1
clang 15.0.7-2 -> 15.0.7-9
compiler-rt 15.0.7-1 -> 15.0.7-2
cryptsetup 2.6.1-3.3 -> 2.6.1-3.4
cups 1:2.4.2-6 -> 1:2.4.2-7
cups-filters 1.28.17-2 -> 1.28.17-3
curl 8.0.1-1 -> 8.1.0-1
dav1d 1.1.0-1 -> 1.2.0-1
dbus-python 1.2.18-4 -> 1.2.18-5
dhclient 4.4.3.P1-1 -> 4.4.3.P1-2
dhcpcd 9.4.1-1 -> 10.0.1-1
dolphin 23.04.0-2 -> 23.04.1-1.1
dolphin-plugins 23.04.0-1 -> 23.04.1-1
double-conversion 3.2.1-1 -> 3.3.0-1
ethtool 1:6.2-1 -> 1:6.3-1
exfatprogs 1.2.0-1 -> 1.2.1-1
ffmpeg 2:6.0-5 -> 2:6.0-6
ffmpegthumbs 23.04.0-1 -> 23.04.1-1
filelight 23.04.0-1 -> 23.04.1-1
firefox 113.0.1-1 -> 114.0-1
firefox-i18n-en-gb 113.0.1-1 -> 114.0-1
firefox-i18n-en-us 113.0.1-1 -> 114.0-1
firefox-i18n-fi 113.0.1-1 -> 114.0-1
frameworkintegration 5.105.0-1 -> 5.106.0-1
fwupd 1.8.14-1 -> 1.9.1-1
gawk 5.2.1-2 -> 5.2.2-1
gcc 12.2.1-2 -> 13.1.1-1
gcc-libs 12.2.1-2 -> 13.1.1-1
gcr 3.41.1-3 -> 3.41.1-4
glib2 2.76.1-1 -> 2.76.2-1
glibc 2.37-2 -> 2.37-3
glslang 12.1.0-1 -> 12.1.0-2
gnome-desktop 1:43.2-1 -> 1:44.0-1
gnome-desktop-common 1:43.2-1 -> 1:44.0-1
gnome-online-accounts 3.46.0-1 -> 3.48.0-2
gnome-video-effects 0.5.0+4+g9554041-2 -> 1:0.5.0+r18+g5f4c801-1
gobject-introspection-runtime 1.76.1-1 -> 1.76.1-3
goocanvas 3.0.0-3 -> 3.0.0-4
gpgme 1.20.0-1 -> 1.20.0-3
gpm 1.20.7.r38.ge82d1a6-4 -> 1.20.7.r38.ge82d1a6-5
graphviz 8.0.3-1 -> 8.0.5-2
grep 3.10-1 -> 3.11-1
gsl 2.7.1-1 -> 2.7.1-3
gst-libav 1.22.1-2 -> 1.22.2-1
gst-plugins-bad 1.22.1-2 -> 1.22.2-1
gst-plugins-bad-libs 1.22.1-2 -> 1.22.2-1
gst-plugins-base 1.22.1-2 -> 1.22.2-1
gst-plugins-base-libs 1.22.1-2 -> 1.22.2-1
gst-plugins-good 1.22.1-2 -> 1.22.2-1
gst-plugins-ugly 1.22.1-2 -> 1.22.2-1
gstreamer 1.22.1-2 -> 1.22.2-1
gtk-update-icon-cache 1:4.10.3-1 -> 1:4.10.3-2
gtk4 1:4.10.3-1 -> 1:4.10.3-2
gufw 22.04-1 -> 22.04-2
gvfs 1.50.4-1 -> 1.50.4-3
harfbuzz 7.1.0-1 -> 7.3.0-1
harfbuzz-icu 7.1.0-1 -> 7.3.0-1
hwdata 0.369-1 -> 0.370-1
imagemagick 7.1.1.8-1 -> 7.1.1.9-1
imath 3.1.7-1 -> 3.1.7-2
imlib2 1.11.0-1 -> 1.11.1-1
iproute2 6.2.0-2 -> 6.3.0-2
iso-codes 4.13.0-1 -> 4.15.0-1
iw 5.19-1 -> 5.19-2
jemalloc 1:5.3.0-1 -> 1:5.3.0-2
jxrlib 0.2.4-1 -> 0.2.4-2
kaccounts-integration 23.04.0-1 -> 23.04.1-1
kaccounts-providers 23.04.0-1 -> 23.04.1-1
kactivities 5.105.0-1 -> 5.106.0-1
kactivities-stats 5.105.0-1 -> 5.106.0-1
kactivitymanagerd 5.27.4-1 -> 5.27.5-1
kamera 23.04.0-1 -> 23.04.1-1
karchive 5.105.0-1 -> 5.106.0-1
kate 23.04.0-1 -> 23.04.1-1
kauth 5.105.0-1 -> 5.106.0-1
kbd 2.5.1-1 -> 2.5.1-2
kbookmarks 5.105.0-1 -> 5.106.0-1
kcmutils 5.105.0-1 -> 5.106.0-1
kcodecs 5.105.0-1 -> 5.106.0-1
kcompletion 5.105.0-1 -> 5.106.0-1
kconfig 5.105.0-1 -> 5.106.0-1
kconfigwidgets 5.105.0-1 -> 5.106.0-1
kcontacts 1:5.105.0-1 -> 1:5.106.0-1
kcoreaddons 5.105.0-1 -> 5.106.0-1
kcrash 5.105.0-1 -> 5.106.0-1
kdbusaddons 5.105.0-1 -> 5.106.0-1
kde-cli-tools 5.27.4-1 -> 5.27.5.1-1
kde-gtk-config 5.27.4-1 -> 5.27.5-1
kdeclarative 5.105.0-1 -> 5.106.0-1
kdeconnect 23.04.0-1 -> 23.04.1-1
kdecoration 5.27.4-1 -> 5.27.5-1
kded 5.105.0-1 -> 5.106.0-1
kdegraphics-mobipocket 23.04.0-1 -> 23.04.1-1
kdegraphics-thumbnailers 23.04.0-1 -> 23.04.1-1
kdelibs4support 5.105.0-1 -> 5.106.0-1
kdenetwork-filesharing 23.04.0-1 -> 23.04.1-1
kdeplasma-addons 5.27.4-1 -> 5.27.5-1
kdesu 5.105.0-1 -> 5.106.0-1
kdialog 23.04.0-1 -> 23.04.1-1
kdnssd 5.105.0-1 -> 5.106.0-1
kdoctools 5.105.0-1 -> 5.106.0-1
keditbookmarks 23.04.0-1 -> 23.04.1-1
kemoticons 5.105.0-1 -> 5.106.0-1
keyutils 1.6.3-1 -> 1.6.3-2
kfilemetadata 5.105.0-1 -> 5.106.0-1
kfind 23.04.0-1 -> 23.04.1-1
kgamma5 5.27.4-1 -> 5.27.5-1
kglobalaccel 5.105.0-1 -> 5.106.0-1
kguiaddons 5.105.0-1 -> 5.106.0-1
khelpcenter 23.04.0-1 -> 23.04.1-1
kholidays 1:5.105.0-1 -> 1:5.106.0-1
khotkeys 5.27.4-1 -> 5.27.5-1
khtml 5.105.0-1 -> 5.106.0-1
ki18n 5.105.0-1 -> 5.106.0-1
kiconthemes 5.105.0-1 -> 5.106.0-1
kidletime 5.105.0-1 -> 5.106.0-1
kimageformats 5.105.0-1 -> 5.106.0-1
kinfocenter 5.27.4-1 -> 5.27.5-1
kinit 5.105.0-1 -> 5.106.0-1
kio 5.105.0-1 -> 5.106.0-1
kio-extras 23.04.0-1 -> 23.04.1-1
kirigami2 5.105.0-1 -> 5.106.0-1
kitemmodels 5.105.0-1 -> 5.106.0-1
kitemviews 5.105.0-1 -> 5.106.0-1
kjobwidgets 5.105.0-1 -> 5.106.0-1
kjs 5.105.0-1 -> 5.106.0-1
kmenuedit 5.27.4-1 -> 5.27.5-1
knetwalk 23.04.0-1 -> 23.04.1-1
knewstuff 5.105.0-1 -> 5.106.0-1
knotifications 5.105.0-1 -> 5.106.0-1
knotifyconfig 5.105.0-1 -> 5.106.0-1
konsole 23.04.0-1 -> 23.04.1-1
kpackage 5.105.0-1 -> 5.106.0-1
kparts 5.105.0-1 -> 5.106.0-1
kpeople 5.105.0-1 -> 5.106.0-1
kpipewire 5.27.4-1 -> 5.27.5-1
kplotting 5.105.0-1 -> 5.106.0-1
kpmcore 23.04.0-1 -> 23.04.1-1
kpty 5.105.0-1 -> 5.106.0-1
kquickcharts 5.105.0-1 -> 5.106.0-1
krunner 5.105.0-1 -> 5.106.0-1
ksanecore 23.04.0-1 -> 23.04.1-1
kscreen 5.27.4-1 -> 5.27.5-1
kscreenlocker 5.27.4-1 -> 5.27.5-1
kservice 5.105.0-1 -> 5.106.0-1
ksshaskpass 5.27.4-1 -> 5.27.5-1
ksystemlog 23.04.0-1 -> 23.04.1-1
ksystemstats 5.27.4-1 -> 5.27.5-1
ktexteditor 5.105.0-1 -> 5.106.0-1
ktextwidgets 5.105.0-1 -> 5.106.0-1
kunitconversion 5.105.0-1 -> 5.106.0-1
kwallet 5.105.0-1 -> 5.106.0-1
kwallet-pam 5.27.4-1 -> 5.27.5-1
kwalletmanager 23.04.0-1 -> 23.04.1-1
kwayland 5.105.0-1 -> 5.106.0-1
kwayland-integration 5.27.4-1 -> 5.27.5-1
kwidgetsaddons 5.105.0-1 -> 5.106.0-1
kwin 5.27.4.1-1 -> 5.27.5-2
kwindowsystem 5.105.0-1 -> 5.106.0-1
kwrited 5.27.4-1 -> 5.27.5-1
kxmlgui 5.105.0-1 -> 5.106.0-1
layer-shell-qt 5.27.4-1 -> 5.27.5-1
ldb 2:2.7.2-1 -> 2:2.7.2-2
lensfun 1:0.3.3-1 -> 1:0.3.3-2
less 1:608-2 -> 1:633-1
lib32-alsa-lib 1.2.8-1 -> 1.2.9-1
lib32-at-spi2-core 2.48.0-2 -> 2.48.2-1
lib32-curl 8.0.1-1 -> 8.1.0-1
lib32-gcc-libs 12.2.1-2 -> 13.1.1-1
lib32-glib2 2.76.1-1 -> 2.76.2-1
lib32-glibc 2.37-2 -> 2.37-3
lib32-harfbuzz 7.1.0-1 -> 7.3.0-1
lib32-imlib2 1.11.0-1 -> 1.11.1-1
lib32-libcap 2.68-1 -> 2.69-1
lib32-libcurl-compat 8.0.1-1 -> 8.1.0-1
lib32-libcurl-gnutls 8.0.1-1 -> 8.1.0-1
lib32-libgpg-error 1.46-1 -> 1.47-1
lib32-libva 2.17.0-1 -> 2.18.0-1
lib32-libxfixes 6.0.0-2 -> 6.0.1-1
lib32-libxft 2.3.7-1 -> 2.3.8-1
lib32-libxi 1.8-2 -> 1.8.1-1
lib32-libxml2 2.10.4-2 -> 2.10.4-4
lib32-libxt 1.2.1-1 -> 1.3.0-1
lib32-mangohud 0.6.9.1-1 -> 0.6.9.1-2
lib32-mesa-demos 8.5.0-1 -> 9.0.0-1
lib32-nss 3.89-1 -> 3.89.1-1
lib32-pam 1.5.2-1 -> 1.5.3-1
lib32-sqlite 3.41.1-1 -> 3.41.2-1
lib32-systemd 252.10-2 -> 253.4-1
lib32-vkd3d 1.6-1 -> 1.7.1-1
lib32-xz 5.4.2-1 -> 5.4.3-1
libaccounts-glib 1.26-1 -> 1.26-2
libblockdev 2.28-1 -> 2.28-2
libbpf 1.1.0-1 -> 1.2.0-1
libbytesize 2.7-1 -> 2.7-2
libcamera 0.0.4-4 -> 0.0.5-1
libcamera-ipa 0.0.4-4 -> 0.0.5-1
libcap-ng 0.8.3-1 -> 0.8.3-2
libcheese 43.0-1 -> 44.0.1-1
libcups 1:2.4.2-6 -> 1:2.4.2-7
libevdev 1.13.0-1 -> 1.13.1-1
libftdi 1.5-4 -> 1.5-5
libgdata 0.18.1-2 -> 0.18.1-3
libgexiv2 0.14.0-3 -> 0.14.0-4
libgirepository 1.76.1-1 -> 1.76.1-3
libheif 1.15.2-1 -> 1.16.1-2
libibus 1.5.28-3 -> 1.5.28-4
libieee1284 0.2.11-14 -> 0.2.11-15
libimobiledevice 1.3.0-6 -> 1.3.0-8
libixion 0.17.0-4 -> 0.17.0-5
libkcddb 23.04.0-1 -> 23.04.1-1
libkcompactdisc 23.04.0-1 -> 23.04.1-1
libkdcraw 23.04.0-1 -> 23.04.1-1
libkdegames 23.04.0-1 -> 23.04.1-1
libkexiv2 23.04.0-1 -> 23.04.1-1
libksane 23.04.0-1 -> 23.04.1-1
libkscreen 5.27.4-1 -> 5.27.5-1
libksysguard 5.27.4-1 -> 5.27.5-1
libmalcontent 0.11.1-1 -> 0.11.1-2
libmwaw 0.3.21-3 -> 0.3.22-1
libnewt 0.52.23-1 -> 0.52.23-2
libnghttp2 1.52.0-2 -> 1.53.0-1
libopenmpt 0.6.10-1 -> 0.7.1-1
liborcus 0.17.2-4 -> 0.17.2-5
libpackagekit-glib 1.2.6-1 -> 1.2.6-2
libpipewire 1:0.3.70-1 -> 1:0.3.70-2
libplist 2.2.0-6 -> 2.3.0-1
libproxy 0.4.18-2 -> 0.4.18-3
libpwquality 1.4.5-1 -> 1.4.5-2
libreoffice-still 7.4.6-1 -> 7.4.7-2
libreoffice-still-en-gb 7.4.6-1 -> 7.4.7-1
libreoffice-still-fi 7.4.6-1 -> 7.4.7-1
libseccomp 2.5.4-1 -> 2.5.4-2
libsmbios 2.4.3-5 -> 2.4.3-6
libsoup3 3.4.1-1 -> 3.4.2-1
libspeechd 0.11.4-1 -> 0.11.4-2
libssh 0.10.4-3 -> 0.10.5-1
libteam 1.31-7 -> 1.31-8
libtool 2.4.7+4+g1ec8fa28-2 -> 2.4.7+4+g1ec8fa28-3
libtpms 0.9.5-2 -> 0.9.6-1
libunrar 1:6.2.6-1 -> 1:6.2.7-1
libupnp 1.14.16-1 -> 1.14.17-1
libusbmuxd 2.0.2-1 -> 2.0.2-2
libwacom 2.6.0-2 -> 2.7.0-1
libwbclient 4.18.2-1 -> 4.18.2-2
libwmf 0.2.12-3 -> 0.2.13-1
libwpg 0.3.3-4 -> 0.3.4-1
libwps 0.4.13-1 -> 0.4.14-1
libxi 1.8-3 -> 1.8.1-1
libxslt 1.1.37-2 -> 1.1.37-3
libytnef 1:2.0-2 -> 1:2.1.1-1
lilv 0.24.20-1 -> 0.24.20-2
linux-api-headers 6.1.9-1 -> 6.3-1 [ignored]
linux515 5.15.114-1 -> 5.15.114-2
linux515-virtualbox-host-modules 7.0.8-9 -> 7.0.8-11
linux61 6.1.31-1 -> 6.1.31-2
linux61-virtualbox-host-modules 7.0.8-9 -> 7.0.8-10
llvm 15.0.7-2 -> 15.0.7-3
llvm-libs 15.0.7-2 -> 15.0.7-3
lua 5.4.4-4 -> 5.4.6-1
luajit 2.1.0.beta3.r471.g505e2c03-1 -> 2.1.0.beta3.r471.g224129a8-1
lutris 0.5.12-3 -> 0.5.13-6
man-pages-fi 4.18.0-1 -> 4.18.1-1
mangohud-common 0.6.9.1-1 -> 0.6.9.1-2
manjaro-application-utility 1.3.3-7 -> 1.3.3-9
manjaro-kde-settings 20230505-2 -> 20230529-1
manjaro-release 22.1.3-1 -> 23.0.0pre-1
memtest86+ 6.10-1 -> 6.20-1
memtest86+-efi 6.10-1 -> 6.20-1
milou 5.27.4-1 -> 5.27.5-1
minetest-common 5.6.1-2 -> 5.7.0-1
modemmanager-qt 5.105.0-1 -> 5.106.0-1
mpfr 4.2.0-3 -> 4.2.0.p7-2
net-snmp 5.9.1-5 -> 5.9.1-6
nettle 3.8.1-1 -> 3.9-1
networkmanager-qt 5.105.0-1 -> 5.106.0-1
nftables 1:1.0.7-1 -> 1:1.0.7-2
noto-fonts 20230401-1 -> 20230501-1
openconnect 1:9.01-2 -> 1:9.10-1
opendht 1:2.5.2-1 -> 1:2.5.5-1
openresolv 3.13.0-1 -> 3.13.1-1
openvpn 2.6.3-1 -> 2.6.4-1
oxygen 5.27.4-1 -> 5.27.5-1
oxygen-icons 1:5.105.0-1 -> 1:5.106.0-1
oxygen-sounds 5.27.4-1 -> 5.27.5-1
packagekit 1.2.6-1 -> 1.2.6-2
pacman-mirrors 4.23.2+2+g2f58b3c-3 -> 4.23.2+3+g4148c3d-1
pam 1.5.2-2 -> 1.5.3-1
pamac-cli 10.5.1-1 -> 10.5.1-2
pamac-gtk 10.5.1-1 -> 10.5.1-2
partitionmanager 23.04.0-1 -> 23.04.1-1
pciutils 3.9.0-2 -> 3.10.0-1
perl 5.36.0-3 -> 5.36.1-1
perl-uri 5.17-1 -> 5.18-1
plasma-browser-integration 5.27.4-1 -> 5.27.5-1
plasma-desktop 5.27.4-1 -> 5.27.5-1
plasma-framework 5.105.0-1 -> 5.106.0-1
plasma-integration 5.27.4-1 -> 5.27.5-1
plasma-nm 5.27.4-1 -> 5.27.5-1
plasma-pa 5.27.4-1 -> 5.27.5-1
plasma-systemmonitor 5.27.4-1 -> 5.27.5-1
plasma-thunderbolt 5.27.4-1 -> 5.27.5-1
plasma-wayland-session 5.27.4.1-1 -> 5.27.5-1
plasma-workspace 5.27.4.1-1 -> 5.27.5-1
plasma-workspace-wallpapers 5.27.4.1-1 -> 5.27.5-1
plymouth-kcm 5.27.4.1-1 -> 5.27.5-1
polkit-kde-agent 5.27.4.1-1 -> 5.27.5-1
poppler 23.03.0-1 -> 23.05.0-1
poppler-glib 23.03.0-1 -> 23.05.0-1
poppler-qt5 23.03.0-1 -> 23.05.0-1
postgresql-libs 15.2-1 -> 15.3-1
powerdevil 5.27.4.1-1 -> 5.27.5-3
print-manager 23.04.0-1 -> 23.04.1-1
prison 5.105.0-1 -> 5.106.0-1
protobuf 21.12-1 -> 21.12-2
purpose 5.105.0-1 -> 5.106.0-1
pyside6 6.5.0-1 -> 6.5.0-2
python 3.10.10-1 -> 3.11.3-1
python-apsw 3.40.0.0-1 -> 3.41.2.0-1
python-async-timeout 4.0.2-1 -> 4.0.2-3
python-attrs 22.2.0-1 -> 22.2.0-3
python-beautifulsoup4 4.11.2-1 -> 4.12.2-1
python-brotli 1.0.9-10 -> 1.0.9-12
python-brotlicffi 1.0.9.2-3 -> 1.0.9.2-4
python-cairo 1.23.0-3 -> 1.23.0-4
python-capng 0.8.3-1 -> 0.8.3-2
python-cchardet 2.1.7-4 -> 2.1.7-5
python-certifi 2022.12.07-1 -> 2022.12.07-3
python-cffi 1.15.1-1 -> 1.15.1-3
python-chardet 5.1.0-1 -> 5.1.0-3
python-configobj 5.0.6.r110.g3e2f4cc-3 -> 5.0.8-4
python-cryptography 40.0.1-1 -> 40.0.2-1
python-css-parser 1.0.8-1 -> 1.0.9-1
python-cssselect 1.2.0-1 -> 1.2.0-3
python-dateutil 2.8.2-4 -> 2.8.2-5
python-distro 1.8.0-2 -> 1.8.0-3
python-dnspython 1:2.3.0-1 -> 1:2.3.0-3
python-docopt 0.6.2-11 -> 0.6.2-12
python-evdev 1.6.1-1 -> 1.6.1-2
python-feedparser 6.0.10-2 -> 6.0.10-3
python-future 0.18.2-7 -> 0.18.3-1
python-gobject 3.44.1-1 -> 3.44.1-3
python-html2text 2020.1.16-8 -> 2020.1.16-9
python-html5-parser 0.4.10-4 -> 0.4.11-1
python-html5lib 1.1-11 -> 1.1-12
python-idna 3.4-1 -> 3.4-3
python-ifaddr 0.2.0-1 -> 0.2.0-2
python-inflate64 0.3.1-1 -> 0.3.1-2
python-jeepney 0.8.0-1 -> 0.8.0-2
python-keyutils 0.6-8 -> 0.6-9
python-lxml 4.9.2-1 -> 4.9.2-3
python-manjaro-sdk 0.9-1 -> 0.9-2
python-markdown 3.4.3-1 -> 3.4.3-2
python-mechanize 1:0.4.8-1 -> 1:0.4.8-2
python-msgpack 1.0.4-1 -> 1.0.5-1
python-multivolumefile 0.2.3-5 -> 0.2.3-6
python-netifaces 0.11.0-3 -> 0.11.0-4
python-npyscreen 4.10.5-7 -> 4.10.5-8
python-packaging 23.0-1 -> 23.1-1
python-pdftotext 2.2.2-3 -> 2.2.2-4
python-pefile 2022.5.30-1 -> 2023.2.7-1
python-pexpect 4.8.0-6 -> 4.8.0-7
python-pillow 9.4.0-2 -> 9.5.0-2
python-pip 23.0.1-1 -> 23.1.2-1
python-ply 3.11-10 -> 3.11-12
python-psutil 5.9.4-1 -> 5.9.5-1
python-ptyprocess 0.7.0-4 -> 0.7.0-5
python-py7zr 0.20.5-1 -> 0.20.5-2
python-pybcj 1.0.1-1 -> 1.0.1-2
python-pychm 0.8.6-6 -> 0.8.6-7
python-pycparser 2.21-3 -> 2.21-5
python-pycryptodome 3.17.0-1 -> 3.17.0-2
python-pycryptodomex 3.12.0-1 -> 3.12.0-2
python-pycups 2.0.1-5 -> 2.0.1-6
python-pycurl 7.45.2-1 -> 7.45.2-3
python-pygments 2.14.0-2 -> 2.15.1-1
python-pyppmd 1.0.0-1 -> 1.0.0-2
python-pyqt5 5.15.9-1 -> 5.15.9-2
python-pyqt5-sip 12.12.1-1 -> 12.12.1-2
python-pyqt6 6.5.0-1 -> 6.5.0-2
python-pyqt6-sip 13.5.1-1 -> 13.5.1-2
python-pyqt6-webengine 6.5.0-1 -> 6.5.0-2
python-pysmbc 1.0.23-3 -> 1.0.23-4
python-pyxdg 0.28-1 -> 0.28-2
python-pyzstd 0.15.7-1 -> 0.15.7-2
python-regex 2023.3.23-1 -> 2023.5.5-1
python-reportlab 3.6.12-2 -> 3.6.12-3
python-requests 2.28.2-1 -> 2.28.2-4
python-sgmllib3k 1.0.0-4 -> 1.0.0-5
python-six 1.16.0-6 -> 1.16.0-8
python-soupsieve 2.4-1 -> 2.4.1-1
python-sqlalchemy1.3 1.3.24-5 -> 1.3.24-6
python-systemd 235-1 -> 235-2
python-texttable 1.6.7-1 -> 1.6.7-2
python-typing_extensions 4.5.0-1 -> 4.5.0-4
python-unrardll 0.1.5-3 -> 0.1.7-1
python-urllib3 1.26.13-1 -> 1.26.15-1
python-webencodings 0.5.1-9 -> 0.5.1-10
python-websockets 10.4-1 -> 10.4-3
python-wheel 0.40.0-1 -> 0.40.0-3
python-yaml 6.0-1 -> 6.0-3
python-zeroconf 0.39.4-1 -> 0.39.4-2
qca-qt5 2.3.5-2 -> 2.3.6-2
qqc2-desktop-style 5.105.0-1 -> 5.106.0-1
qt5-declarative 5.15.9+kde+r24-1 -> 5.15.9+kde+r25-1
qt5-quickcontrols2 5.15.9+kde+r5-1 -> 5.15.9+kde+r6-1
qt5-svg 5.15.9+kde+r7-1 -> 5.15.9+kde+r8-1
samba 4.18.2-1 -> 4.18.2-2
sddm-kcm 5.27.4.1-1 -> 5.27.5-1
sdl2 2.26.5-1 -> 2.26.5-2
shiboken6 6.5.0-1 -> 6.5.0-2
signon-kwallet-extension 23.04.0-1 -> 23.04.1-1
smbclient 4.18.2-1 -> 4.18.2-2
snapd 2.59.1-1 -> 2.59.4-1
sof-firmware 2.2.4-1 -> 2.2.5-1
solid 5.105.0-1 -> 5.106.0-1
sonnet 5.105.0-1 -> 5.106.0-1
spectacle 23.04.0-1 -> 23.04.1-1
speech-dispatcher 0.11.4-1 -> 0.11.4-2
sqlite 3.41.2-1 -> 3.42.0-1
svt-av1 1.4.1-1 -> 1.5.0-1
syndication 5.105.0-1 -> 5.106.0-1
syntax-highlighting 5.105.0-1 -> 5.106.0-1
system-config-printer 1.5.18-1 -> 1.5.18-2
systemd-libs 252.10-2 -> 253.4-1
systemd-sysvcompat 252.10-2 -> 253.4-1
systemsettings 5.27.4.1-1 -> 5.27.5-1
talloc 2.4.0-2 -> 2.4.0-3
tdb 1.4.8-1 -> 1.4.8-2
terminator 2.1.3-1 -> 2.1.3-3
tevent 1:0.14.1-1 -> 1:0.14.1-2
thin-provisioning-tools 1.0.3-1 -> 1.0.4-1
threadweaver 5.105.0-1 -> 5.106.0-1
tpm2-tss 3.2.0-3 -> 4.0.1-1
tracker3 3.5.0-1 -> 3.5.2-1
tzdata 2023c-1 -> 2023c-2
udiskie 2.4.2-1 -> 2.4.2-2
ufw 0.36.1-3 -> 0.36.2-1
upower 1.90.0-3 -> 1.90.0-4
usbmuxd 1.1.1-2 -> 1.1.1-3
util-linux 2.38.1-3 -> 2.38.1-4
util-linux-libs 2.38.1-3 -> 2.38.1-4
virtualbox 7.0.8-1 -> 7.0.8-2
virtualbox-ext-vnc 7.0.8-1 -> 7.0.8-2
virtualbox-sdk 7.0.8-1 -> 7.0.8-2
volume_key 0.3.12-7 -> 0.3.12-8
vulkan-headers 1:1.3.246-1 -> 1:1.3.248-1
webkit2gtk 2.40.1-1 -> 2.40.1-2
webkit2gtk-4.1 2.40.1-1 -> 2.40.1-2
wine 8.6-1 -> 8.8-1
wine-gecko 2.47.3-1 -> 2.47.4-1
wireless-regdb 2023.02.13-1 -> 2023.05.03-1
xapp 2.4.3-1 -> 2.4.3-2
xcb-proto 1.15.2-2 -> 1.15.2-3
xdg-desktop-portal 1.16.0-1 -> 1.16.0-3
xdg-desktop-portal-kde 5.27.4.1-1 -> 5.27.5-1
xf86-video-ati 1:19.1.0.r15.g7a6a34af-1 -> 1:22.0.0-1
xorg-setxkbmap 1.3.3-2 -> 1.3.4-1
xorg-xdpyinfo 1.3.3-4 -> 1.3.4-1
yakuake 23.04.0-1 -> 23.04.1-1
zbar 0.23.90-1 -> 0.23.90-2
zenity 3.44.0-3 -> 3.44.1-1
zsh-theme-powerlevel10k 1.17.0+23+g1cff2249-1 -> 1.18.0-1
You have done a full sync? without the mentioned Ignores in pacman.conf?
If so - :+1: as a partial sync state - for various reasons - is unsupported :slight_smile:
It is difficult to say why your system freezes - there is nothing in your logs which says problem.
One is tempted to suggest running memtest+ on the system - to rule out faulty memory.
A little swap is always preferable over no swap at all.
The reason for this is the systems ability to swap out pages not in use and use memory as cache for pages which are actively used.
Another reason is situations where you exhaust your system - and with no swap OOM killer kicks in with unpredicatable results.
Don’t take my word for it - just take a look at the search for Linux system - why swap is preferred over no swap - SearXNG at sx.nix.dk
Some notes - nothing severe - just observations
You appear to have VirtualBox installed - but your firmware’s kvm extensions is disabled - if your freezes occurs while running a VM - perhaps enabling kvm in firmware would be beneficial?
You nic is RTL81xx and your driver is r8169 - perhaps you could get 1000Mbps by using the r8168 driver from the repo.
Thank you for your reply.
I made sure I don’t have IgnorePkg uncommented. I used sudo cat /etc/pacman.conf to check.
#IgnorePkg   = linux linux-headers linux-api-headers manjaro-release
#IgnorePkg   = manjaro-release
#IgnoreGroup =
I made sure I had everything up to date.
sudo pacman -Syu         1 ✘
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
 there is nothing to do
I looked up on swap as per your advice and it sounded good to create a swapfile. I decided to use 4GB swap to my 16GB RAM because generally I don’t use hibernation.
I used these commands.
sudo dd if=/dev/zero of=/swapfile1 bs=1M count=4096 status=progress
sudo chown root:root /swapfile1
sudo chmod 600 /swapfile1
sudo mkswap /swapfile1
sudo swapon /swapfile1
sudo cp /etc/fstab /etc/fstab.back-preSWAP
sudo bash -c "echo /swapfile1 none swap defaults 0 0 >> /etc/fstab"
I controlled that it fitted nicely in my fstab file with sudo cat /etc/fstab
I created a comment to help me remember.
# Swapfile 1st 4G
Then I used free -h to check if I swap showed.
free -h         ✔
               total        used        free      shared  buff/cache   available
Mem:            15Gi       1.1Gi        13Gi        35Mi       1.2Gi        14Gi
Swap:          4.0Gi          0B       4.0Gi
It did but it wasn’t used. I restarted the PC but it still wasn’t used. I tested different versions from the Internet if there was a difference.
ps -A | grep kswap         ✔
    110 ?        00:00:00 kswapd0
free -l         ✔  17s 
Mem:           15939        2263       11573         118        2101       13228
Low:           15939        4365       11573
High:              0           0           0
Swap:           4095           0        4095
I will stress test swap if it wasn’t used because it didn’t need to or if I something wrong when I am not writing this.
I have not used virtual machines as of yet on Manjaro so that’s why it wasn’t on. I enabled SVM mode in my BIOS settings. About a hour later the system froze again. REISUB didn’t work. I’m hesitant to name it here since its a SVM problem and not necessary my original problems but, anyway, on my previous OS freezes happened as shortest between each freeze when I had enabled SVM mode in BIOS. It might look like its also so on Manjaro but Its hard to know which problem is which.
SVM mode in BIOS became disabled after the freeze.
Is it useful if I will enable SVM mode more often to see if I will get anything from journalctl and dmesg after the freeze? Is it any particular command I should try for if they might be related?
I got new journalctl again since its a new freeze. I had up Palemoon, Firefox, folders and a couple of terminal tabs.
journalctl
journalctl --boot=-1 --priority=3 --catalog --no-pager
Jun 14 16:30:27 jonatan-ms7a33 konsole[1405]: kf.xmlgui: Shortcut for action  "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Jun 14 16:30:27 jonatan-ms7a33 konsole[1405]: kf.xmlgui: Shortcut for action  "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Jun 14 16:30:29 jonatan-ms7a33 pulseaudio[1352]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Jun 14 16:40:51 jonatan-ms7a33 konsole[2289]: kf.xmlgui: Shortcut for action  "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Jun 14 16:40:51 jonatan-ms7a33 konsole[2289]: kf.xmlgui: Shortcut for action  "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Again for the latest freeze sudo dmesg --level emerg,alert,crit,err,warn
dmesg
[    0.000000] ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20220331/tbfadt-615)
[    0.428032] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.428124] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.428219] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.428302] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.428371] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.428448] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.428525] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.428601] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.428681] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.428781] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.428854] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.428924] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    3.739207] usb: port power management may be unreliable
[   59.615657] vboxdrv: loading out-of-tree module taints kernel.
[   59.720870] VBoxNetAdp: Successfully started.
[   59.722459] VBoxNetFlt: Successfully started.
[   60.860655] systemd-journald[454]: File /var/log/journal/341864a718924dd7a41a6ae2ed424948/system.journal corrupted or uncleanly shut down, renaming and replacing.
[   64.702642] amdgpu: SRAT table not found
[   86.612729] [UFW BLOCK] IN=enp33s0 OUT= MAC=4c:cc:6a:f9:64:7a:54:e6:fc:d1:2f:c0:08:00 SRC=104.26.7.10 DST=192.168.1.101 LEN=91 TOS=0x00 PREC=0x00 TTL=59 ID=58206 DF PROTO=TCP SPT=443 DPT=49050 WINDOW=8 RES=0x00 ACK PSH URGP=0
[  100.434837] [UFW BLOCK] IN=enp33s0 OUT= MAC=01:00:5e:00:00:01:54:e6:fc:d1:2f:c0:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[  225.432761] [UFW BLOCK] IN=enp33s0 OUT= MAC=01:00:5e:00:00:01:54:e6:fc:d1:2f:c0:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[  350.430318] [UFW BLOCK] IN=enp33s0 OUT= MAC=01:00:5e:00:00:01:54:e6:fc:d1:2f:c0:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[  475.427537] [UFW BLOCK] IN=enp33s0 OUT= MAC=01:00:5e:00:00:01:54:e6:fc:d1:2f:c0:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[  600.425751] [UFW BLOCK] IN=enp33s0 OUT= MAC=01:00:5e:00:00:01:54:e6:fc:d1:2f:c0:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[  725.422951] [UFW BLOCK] IN=enp33s0 OUT= MAC=01:00:5e:00:00:01:54:e6:fc:d1:2f:c0:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[  850.420597] [UFW BLOCK] IN=enp33s0 OUT= MAC=01:00:5e:00:00:01:54:e6:fc:d1:2f:c0:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[  975.418206] [UFW BLOCK] IN=enp33s0 OUT= MAC=01:00:5e:00:00:01:54:e6:fc:d1:2f:c0:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1100.415783] [UFW BLOCK] IN=enp33s0 OUT= MAC=01:00:5e:00:00:01:54:e6:fc:d1:2f:c0:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1225.413321] [UFW BLOCK] IN=enp33s0 OUT= MAC=01:00:5e:00:00:01:54:e6:fc:d1:2f:c0:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1350.410474] [UFW BLOCK] IN=enp33s0 OUT= MAC=01:00:5e:00:00:01:54:e6:fc:d1:2f:c0:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1475.408085] [UFW BLOCK] IN=enp33s0 OUT= MAC=01:00:5e:00:00:01:54:e6:fc:d1:2f:c0:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
What do you mean? Where did you mean when you say the repo?
If the firmware change settings on it’s own - it could be a hardware issue - which brings me back to
If your system is working as per the NIC kernel support - please ignore the comment - the background for my observation related to your network card - linux kernel has built-in support for r8169 - but some systems work better with the driver packaged in $KERNEL-r8168 - where $KERNEL refers to your current kernel as reported by
mhwd-kernel -li
Computer freezes sometimes, REISUB doesn’t work
I had experienced the similar problem a few months ago. It rarely happened.
After my investigation, my old mainboard was a bit defective.
I tried to replace it with a new mainboard. So far I have no problem.
I went to BIOS settings and checked just in case. It turns out the freeze didn’t turn SVM mode off. Please excuse me. I’m so used to how Ubuntu 20.04 used to behave that I am talking nonsense.
I will run a memtest+ tonight. I feel that it shouldn’t be that since I did get my PC’s hardware checked.
I don’t understand. I have working Internet.
mhwd-kernel -li         ✔
Currently running: 6.1.31-2-MANJARO (linux61)
   * linux515
   * linux61
Even so - if this happened when you were using Ubuntu too - firmware - usually - does not change settings on it’s own - and it points even more to a hardware failure.
A thought just sroke - perhaps your issue roots in insufficent cooling of CPU - perhaps clogged radiator ribs or a worn out fan.
I have no idea - there is a firmware entry allowing you to reset the firmware to it’s default values.
It may be a power management related issue - I really have no idea.
I remember correctly:
  • Journal log showed no error, because any error message could not be written in my disk when my computer was frozen.
  • REISUB didn’t respond at all, but I am sure that my keyboard actually worked. Why?
  • I tried long-pressing the shutdown-button of PC manually. That didn’t work. Why?
  • I tried to press the reboot-button of PC, that worked, but it didn’t reboot. I had to reboot again, that worked, but no error in journal log.
That’s why I thought, my mainboard was faulty.
linux-aarhus, some of your explanations are hard to understand.
Controlled that swap was being used when I had up many idle browser tabs.
free -h         ✔  24s 
Mem:            15Gi       5.5Gi       5.9Gi       538Mi       4.2Gi       9.2Gi
Swap:          4.0Gi        11Mi       4.0Gi
Glad that I didn’t mess it up!
I have decided to try to clean up my CPU fans if there is an overheating issue. However I don’t have the tools for that so it will be put it aside until I get them. Until then I will see if swap reduced the freezes or if it didn’t.
I will try to remember to check the temperature in BIOS if the sudden freeze happens.
Just in case there is a misunderstanding. In Ubuntu 20.04 the SVM mode in BIOS settings used to switch back to disabled after a freeze happened. Now with Manjaro it didn’t switch my SVM mode off. It remained enabled even after the freeze. I’m still somewhat in a disbelief of that so I will check that often.
Why would I want to reset BIOS firmware? I think I did flash it a couple of years ago, or at least I have a memory being extremely nervous when I was about to start doing it anyway.
I checked 'https://outervision.com/power-supply-calculator' in the basic tab to get a rough estimate and I have about 150W extra over the recommended. However I don’t see how much I actually use with that tool.
My computer is 7 years old aka its 7 years since someone cleaned it. Do you think its possible that my components did get damaged because of excessive dust?
I did ignore this problem when I used Ubuntu 20.04 for about 1 year before this because I didn’t find a solution on my own. I changed HDD just in case persistent hard resets (1-2 times per day each day for a year) could do damage to a hard drive. It didn’t help to reinstall Ubuntu just in case someone wonders. Could this have done damage even to other components? Do I need to renew the thermal paste?
Cheers! I am quite happy that I am getting help. :smiley:
The difference between your and my case seems to be that my PC can be shutdown by pressing the shutdown button manually for 5-10 seconds. It’s not a large difference but I’m hopeful its not that.
Unfortunate I can’t check the restart button since I don’t have one.
I tried memtest86 my PC. When I had changed the startup disk priority and restarted the PC I came to a black screen that said that it couldn’t find my hard drive. I found out later that there were some problems with doing memtest on a hard drive with Manjaro’s full system encryption.
However I did go to a PC shop to check stuff like that just about 1 month before this. When I asked about the if they checked HDD, GPU and RAM. They did. They presumably also checked the motherboard but I didn’t ask about it. I had Ubuntu 20.04 installed on it, but they said whatever my issues is it must be a software issue. There were no hardware issues. I will be checking with them again to see what tests they did and what components they checked. Maybe its a business secret which tests?
I got a new crash so I’ll be posting the same kinds of logs again. Unsure if I should make a new post or if its better etiquette to just continue with this one. It seems to crash more after I turned on SVM mode. I’ll be turning it off to see if its just bias speaking or not.
journalctl
Jun 15 10:51:24 jonatan-ms7a33 pulseaudio[1373]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Jun 15 11:10:15 jonatan-ms7a33 konsole[1713]: kf.xmlgui: Shortcut for action  "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Jun 15 11:10:15 jonatan-ms7a33 konsole[1713]: kf.xmlgui: Shortcut for action  "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Jun 15 11:34:43 jonatan-ms7a33 kernel: kernel tried to execute NX-protected page - exploit attempt? (uid: 1000)
dmesg
[    0.429828] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.429911] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.430017] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.430106] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.430176] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.430266] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.430343] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.430446] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.430553] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.430648] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.430745] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.430846] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    3.738199] usb: port power management may be unreliable
[   61.514600] vboxdrv: loading out-of-tree module taints kernel.
[   61.636908] VBoxNetAdp: Successfully started.
[   61.639653] VBoxNetFlt: Successfully started.
[   62.881535] systemd-journald[457]: File /var/log/journal/341864a718924dd7a41a6ae2ed424948/system.journal corrupted or uncleanly shut down, renaming and replacing.
[   66.766861] amdgpu: SRAT table not found
[   90.664984] [UFW BLOCK] IN=enp33s0 OUT= MAC=01:00:5e:00:00:01:54:e6:fc:d1:2f:c0:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[  215.662593] [UFW BLOCK] IN=enp33s0 OUT= MAC=01:00:5e:00:00:01:54:e6:fc:d1:2f:c0:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
I ran a inxi -v7azy to check if there were any big differences now after I had done swap.
inxi -v7azy
  Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=41b3fad3-ccb6-4bf6-b6f8-4d53e439f254 rw quiet
    cryptdevice=UUID=15ee6e27-c5df-49a2-9177-67672878e17f:luks-15ee6e27-c5df-49a2-9177-67672878e17f
    root=/dev/mapper/luks-15ee6e27-c5df-49a2-9177-67672878e17f splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_wayland dm: SDDM
  Type: Desktop Mobo: MSI model: X370 KRAIT GAMING (MS-7A33) v: 1.0
    serial: <filter> UEFI: American Megatrends v: 1.H0 date: 01/21/2019
  System RAM: available: 15.57 GiB used: 1.85 GiB (11.9%)
  Array-1: capacity: 256 GiB note: check slots: 4 EC: None
    max-module-size: 64 GiB note: est.
  Device-1: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 8 GiB speed: spec: 2400 MT/s actual: 1200 MT/s volts: curr: 1.2
    min: 1.2 max: 1.2 width (bits): data: 64 total: 64 manufacturer: Kingston
    part-no: KF3200C16D4/8GX serial: <filter>
  Device-2: DIMM 1 type: no module installed
  Device-3: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-4: DIMM 1 type: no module installed
  Info: model: AMD Ryzen 5 1600X socket: AM4 bits: 64 type: MT MCP arch: Zen
    level: v3 note: check built: 2017-19 process: GF 14nm family: 0x17 (23)
    model-id: 1 stepping: 1 microcode: 0x8001137
    L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
    desc: 2x8 MiB
  Speed (MHz): avg: 2433 high: 3600 min/max: 2200/3600 boost: enabled
    base/boost: 3600/4100 scaling: driver: acpi-cpufreq governor: schedutil
    volts: 1.4 V ext-clock: 100 MHz cores: 1: 3600 2: 2200 3: 2200 4: 2200
    5: 2200 6: 2200 7: 3600 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
    bogomips: 86425
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
    cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
    flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
    lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
    sep sev sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a
    ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
    v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
    xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    disabled, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
    vendor: Micro-Star MSI driver: amdgpu v: kernel arch: GCN-4
    code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 1
    speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
    active: HDMI-A-2 empty: DP-1, DP-2, DVI-D-1, HDMI-A-1 bus-ID: 26:00.0
    chip-ID: 1002:67df class-ID: 0300 temp: 44.0 C
  Display: server: X.Org v: 23.1.1 with: Xwayland v: 23.1.1
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :1 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
    s-diag: 583mm (22.95")
  Monitor-1: HDMI-A-2 model: BenQ GC2870 serial: <filter> built: 2017
    res: 1920x1080 hz: 60 dpi: 79 gamma: 1.2 size: 620x340mm (24.41x13.39")
    diag: 708mm (27.9") ratio: 16:9 modes: max: 1920x1080 min: 720x400
  API: OpenGL v: 4.6 Mesa 23.0.4 renderer: AMD Radeon RX 580 Series
    (polaris10 LLVM 15.0.7 DRM 3.49 6.1.31-2-MANJARO) direct-render: Yes
  Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 26:00.1
    chip-ID: 1002:aaf0 class-ID: 0403
  Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
    bus-ID: 28:00.3 chip-ID: 1022:1457 class-ID: 0403
  API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.70 status: n/a (root, process) with: wireplumber
    status: active tools: pw-cli,wpctl
  Server-3: PulseAudio v: 16.1 status: active (root, process)
    with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: f000 bus-ID: 21:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp33s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-1: luks-15ee6e27-c5df-49a2-9177-67672878e17f maj-min: 254:0
    type: LUKS dm: dm-0 size: 1.82 TiB
  Components:
  p-1: sda2 maj-min: 8:2 size: 1.82 TiB
  Local Storage: total: 5.46 TiB used: 519.42 GiB (9.3%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
    family: BarraCuda 3.5 (SMR) size: 1.82 TiB block-size: physical: 4096 B
    logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 7200
    serial: <filter> fw-rev: 0001 temp: 40 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 2451h+28m+24.636s cycles: 426
    read: 1.67 TiB written: 2.15 TiB Pre-Fail: attribute: Spin_Retry_Count
    value: 100 worst: 100 threshold: 97
  ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000DM004-2CV104
    family: BarraCuda 3.5 (SMR) size: 3.64 TiB block-size: physical: 4096 B
    logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 5425
    serial: <filter> fw-rev: 0001 temp: 36 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 7723h+35m+11.512s cycles: 1202
    read: 9.88 TiB written: 894.73 GiB Pre-Fail: attribute: Spin_Retry_Count
  ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 174.63 GiB (9.5%)
    fs: ext4 block-size: 4096 B dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-15ee6e27-c5df-49a2-9177-67672878e17f label: N/A
    uuid: 41b3fad3-ccb6-4bf6-b6f8-4d53e439f254
    used: 448 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
    label: N/A uuid: FEF2-17E7
  ID-3: /mnt/fc918111-f99a-47fc-a959-47207c36f4ff raw-size: 1.82 TiB
    size: 1.79 TiB (98.37%) used: 344.79 GiB (18.8%) fs: ext4 block-size: 4096 B
    dev: /dev/sdb1 maj-min: 8:17 label: 2TBtop
    uuid: fc918111-f99a-47fc-a959-47207c36f4ff
  ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile1
  ID-1: /dev/sdb2 maj-min: 8:18 size: 1.82 TiB fs: ext4 label: 2TB_bottom
    uuid: 693a6ad4-1456-4c9a-bbcb-ef742d3bc7fa
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 14 rev: 2.0
  Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-3:2 info: Logitech USB Keyboard type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 90mA chip-ID: 046d:c34b class-ID: 0300
  Device-2: 5-4:3 info: USB GAMING MOUSE type: mouse,keyboard
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 30fa:1130 class-ID: 0301
  Hub-6: 6-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 43.5 C mobo: N/A gpu: amdgpu temp: 44.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 202
  Processes: 316 Uptime: 5m wakeups: 0 Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1580
  pm: pacman pkgs: 1574 libs: 483 tools: pamac,yay pm: flatpak pkgs: 6
  Shell: Zsh (sudo) v: 5.9 default: Bash v: 5.1.16 running-in: konsole
  inxi: 3.3.27
It is next to impossible to know what is causing your issues.
What I have understood so far - facts extracted from the thread
  • the issue is occurring randomly
  • it occurs more often under pressure
  • there is no logs because kernel locks completely
  • kernel hotkeys REISUB is locked
  • the issue is not related to Manjaro specifically
  • the issue is persistent across different Linux distributions
  • last OS was Ubuntu 20.04
While - evidently - it is a severe kernel panic when even kernel hotkeys lock up - so - my last idea is to test the latest stable kernel - linux63
sudo mhwd-kernel -i linux63
If that kernel locks up the same way - there is a couple of reasons why I think it is hardware
  • kernel panic - total and complete kernel lockup
  • lock up happens using different distributions
  • lock up happens no matter the kernel
Yes. It looks right those bullet points you have there.
linux63 (or Linux 6.3.5-2) is the latest stable despite that the one I’m using Linux 6.1.31-2 has a LTS tag a recommended tag? Strange. Still, I will try it.
I did
sudo mhwd-kernel -i linux63         ✔
[sudo] password for jonatan:
 core        143.6 KiB   365 KiB/s 00:00 [#######################################################################################] 100%
 extra        1636.8 KiB  2.57 MiB/s 00:01 [#######################################################################################] 100%
 community        7.0 MiB  4.73 MiB/s 00:01 [#######################################################################################] 100%
 multilib        145.5 KiB   338 KiB/s 00:00 [#######################################################################################] 100%
resolving dependencies...
Packages (2) linux63-6.3.5-2  linux63-virtualbox-host-modules-7.0.8-11
Total Download Size:   148.65 MiB
Total Installed Size:  153.21 MiB
:: Retrieving packages...
 linux63-virtualbox-host-modules-7.0.8-11-x86_64        308.8 KiB   707 KiB/s 00:00 [#######################################################################################] 100%
 linux63-6.3.5-2-x86_64        148.3 MiB  10.4 MiB/s 00:14 [#######################################################################################] 100%
 Total (2/2)        148.6 MiB  10.4 MiB/s 00:14 [#######################################################################################] 100%
(2/2) checking keys in keyring        [#######################################################################################] 100%
(2/2) checking package integrity        [#######################################################################################] 100%
(2/2) loading package files        [#######################################################################################] 100%
(2/2) checking for file conflicts        [#######################################################################################] 100%
(2/2) checking available disk space        [#######################################################################################] 100%
(1/2) installing linux63        [#######################################################################################] 100%
Optional dependencies for linux63
    wireless-regdb: to set the correct wireless channels of your country [installed]
(2/2) installing linux63-virtualbox-host-modules        [#######################################################################################] 100%
===> You must load vboxdrv module before starting VirtualBox:
===> # modprobe vboxdrv
(1/5) Arming ConditionNeedsUpdate...
(2/5) Updating module dependencies...
(3/5) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux63.preset: 'default'
  -> -k /boot/vmlinuz-6.3-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.3-x86_64.img --microcode /boot/amd-ucode.img
==> Starting build: '6.3.5-2-MANJARO'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.3-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux63.preset: 'fallback'
  -> -k /boot/vmlinuz-6.3-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.3-x86_64-fallback.img -S autodetect --microcode /boot/amd-ucode.img
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.3-x86_64-fallback.img'
(4/5) Refreshing PackageKit...
(5/5) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-6.3-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-6.3-x86_64.img
Found initrd fallback image: /boot/initramfs-6.3-x86_64-fallback.img
done
It froze again and when I booted up my PC I had the Linux 6.3.5-2 running. I’ll be back on how it goes on that front.
I began looking into temperature and computer sensors if there is a overheating problem due to dust buildup. I can’t determinate if there is a high temperature or if its just normal. Everyone on old topics about it seems to have their own opinion on the matter.
I checked how my temperature values with: sensors
200+ Firefox tabs, Zoom and Palemoon 10+ tabs.
sensors
nct6795-isa-0a20
Adapter: ISA adapter
Vcore:                 544.00 mV (min =  +0.00 V, max =  +1.74 V)
in1:                     1.02 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
AVCC:                    3.44 V  (min =  +2.98 V, max =  +3.63 V)
+3.3V:                   3.31 V  (min =  +2.98 V, max =  +3.63 V)
in4:                     1.01 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
in5:                   160.00 mV (min =  +0.00 V, max =  +0.00 V)  ALARM
in6:                   696.00 mV (min =  +0.00 V, max =  +0.00 V)  ALARM
3VSB:                    3.42 V  (min =  +2.98 V, max =  +3.63 V)
Vbat:                    3.39 V  (min =  +2.70 V, max =  +3.63 V)
in9:                     1.83 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
in10:                    0.00 V  (min =  +0.00 V, max =  +0.00 V)
in11:                  480.00 mV (min =  +0.00 V, max =  +0.00 V)  ALARM
in12:                  896.00 mV (min =  +0.00 V, max =  +0.00 V)  ALARM
in13:                  600.00 mV (min =  +0.00 V, max =  +0.00 V)  ALARM
in14:                    1.51 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
fan1:                     0 RPM  (min =    0 RPM)
fan2:                   862 RPM  (min =    0 RPM)
fan3:                     0 RPM  (min =    0 RPM)
fan4:                     0 RPM  (min =    0 RPM)
fan5:                     0 RPM  (min =    0 RPM)
fan6:                   933 RPM  (min =    0 RPM)
SYSTIN:                 +44.0°C  (high =  +0.0°C, hyst =  +0.0°C)  ALARM  sensor = CPU diode
CPUTIN:                 +40.0°C  (high = +113.0°C, hyst = +88.0°C)  sensor = thermistor
AUXTIN0:                +43.0°C  (high = +113.0°C, hyst = +88.0°C)  sensor = thermistor
AUXTIN1:               -128.0°C    sensor = thermistor
AUXTIN2:                +59.0°C    sensor = thermistor
AUXTIN3:                 -1.0°C    sensor = thermistor
SMBUSMASTER 0:          +59.0°C
PCH_CHIP_CPU_MAX_TEMP:   +0.0°C
PCH_CHIP_TEMP:           +0.0°C
PCH_CPU_TEMP:            +0.0°C
TSI0_TEMP:              +59.0°C
intrusion0:            ALARM
intrusion1:            ALARM
beep_enable:           disabled
k10temp-pci-00c3
Adapter: PCI adapter
Tctl:         +59.0°C
Tdie:         +39.0°C
amdgpu-pci-2600
vddgfx:      725.00 mV
fan1:         213 RPM  (min =    0 RPM, max = 4500 RPM)
edge:         +52.0°C  (crit = +94.0°C, hyst = -273.1°C)
PPT:           6.14 W  (cap = 135.00 W)
And another time with about 250 Firefox tabs, 30 Palemoon tabs up.
Sensors
nct6795-isa-0a20
Vcore:                 552.00 mV (min =  +0.00 V, max =  +1.74 V)
in11:                  488.00 mV (min =  +0.00 V, max =  +0.00 V)  ALARM
fan2:                   864 RPM  (min =    0 RPM)
fan6:                   949 RPM  (min =    0 RPM)
CPUTIN:                 +41.0°C  (high = +113.0°C, hyst = +88.0°C)  sensor = thermistor
SMBUSMASTER 0:          +60.0°C
TSI0_TEMP:              +60.0°C
intrusion0:            ALARM
intrusion1:            ALARM
k10temp-pci-00c3
Tctl:         +59.9°C
Tdie:         +39.9°C
amdgpu-pci-2600
vddgfx:      725.00 mV
fan1:         198 RPM  (min =    0 RPM, max = 4500 RPM)
edge:         +53.0°C  (crit = +94.0°C, hyst = -273.1°C)
Do the PC cool down fast when not in use? When a freeze has already happened once it goes through a second freeze sooner if it has already happened earlier same session.
It also freezes on linux63. Do you think it might be a motherboard issue like Zesko thought?
This topic seems to be answered as far as it can go. Do I pick your post as a solution because it’s you who has helped me all this time and it was you that made your reasoning clear on why you think this is a hardware issue?
Everyone, thanks for the help. Cheers!
It is impossible to deduct from a forum conversation - but I think it is a probability.
A mainboard is a complex construction with a lot of joint connections which is soldered. Even composite components like a CPU - I don’t know the inner joints of a CPU - but I imagine is a maze of connection points and software - hence the need for microcode (amd and intel) to mitigate flaws discovered after production has been released.
The following observation is highly speculative as it is - by nature - difficult to verify - so just stay with my thought.
If a soldered connection cracks it may still provide a connection when in cold state - but when in warm or hot state - due to thermodynamic laws - there is a subject expansion on heating and a subject crimp on cooling off. The phenoma is most evident with large constructions like a bridge.
Such crack will cause randon disconnection of the joint point thus causing inexplainable issues with the system.
Explaining how and why such incident happens is left to imagination - I can think of a lot - e.g. like how you get icecubes from the drawer by twisting the drawer carefully to make the cubes crack loose.
