Hi,
I recently upgraded my nvidia driver to the 460 beta drivers because they contained a fix for an issue I was experiencing. While the fix is working, it seems like my system can no longer suspend anymore. When I suspend via the suspend button, sudo systemctl suspend
, or pm-suspend
, my PC starts powering down and it sounds like the discs spin down but then instantly spin up again and I appear back on my desktop.
From my journalctl log of when I suspended my device, it appears that something either fails to suspend or wakes the system back up:
Jan 02 18:24:33 PC kernel: sd 5:0:0:0: [sdd] Synchronizing SCSI cache
Jan 02 18:24:33 PC kernel: sd 3:0:0:0: [sdb] Synchronizing SCSI cache
Jan 02 18:24:33 PC kernel: sd 0:0:0:0: [sda] Stopping disk
Jan 02 18:24:33 PC kernel: sd 5:0:0:0: [sdd] Stopping disk
Jan 02 18:24:33 PC kernel: sd 4:0:0:0: [sdc] Stopping disk
Jan 02 18:24:33 PC kernel: sd 3:0:0:0: [sdb] Stopping disk
Jan 02 18:24:33 PC kernel: PM: Some devices failed to suspend, or early wake event detected
Jan 02 18:24:33 PC kernel: sd 0:0:0:0: [sda] Starting disk
Jan 02 18:24:33 PC kernel: sd 3:0:0:0: [sdb] Starting disk
Jan 02 18:24:33 PC kernel: sd 5:0:0:0: [sdd] Starting disk
Jan 02 18:24:33 PC kernel: sd 4:0:0:0: [sdc] Starting disk
Jan 02 18:24:33 PC kernel: parport_pc 00:01: activated
Jan 02 18:24:33 PC kernel: serial 00:02: activated
Jan 02 18:24:33 PC kernel: acpi LNXPOWER:16: Turning OFF
I installed this beta drive from the nvidia-beta-dkms
package from the AUR and the driver version is 460.27.04. I know that this is most likely a nvidia issue and not caused by Manjaro but wanted to see if anyone may have an idea on a way to fix it.
Specs:
KDE Plasma Version: 5.20.4
KDE Frameworks Version: 5.77.0
Qt Version: 5.15.2
Kernel Version: 5.10.4-1-MANJARO
OS Type: 64-bit
Processors: 8 × Intel® Core™ i7-6700K CPU @ 4.00GHz
Memory: 15.6 GiB of RAM
Graphics Processor: GeForce GTX 1080 Ti/PCIe/SSE2
Thanks.
