Computer Crashes without Warning?
The computer crashes about once per day randomly, and for seemingly no reason. This behavious is somewhat correlated with idle (The hardware idle power current BIOS is set to conventional, and not “idle low” BTW), but not entirely and can and does sometimes crash right in the middle of doing something.
Running dmesg | grep “Hardware Error”:
[    1.570321] mce: [Hardware Error]: Machine check events logged
[    1.570322] mce: [Hardware Error]: CPU 19: Machine Check: 0 Bank 5: baa0000000090150
[    1.570326] mce: [Hardware Error]: TSC 0 MISC d012000100000000 SYND 4d000020 IPID 500b000000000
[    1.570329] mce: [Hardware Error]: PROCESSOR 2:a20f10 TIME 1662931101 SOCKET 0 APIC 7 microcode a201016
Full Hardware:
  Kernel: 5.19.1-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.19-x86_64
    root=UUID=f11386cf-342d-47ac-84e6-484b7b2f377d rw rootflags=subvol=@
    radeon.modeset=1 nvdia-drm.modeset=1 quiet
    cryptdevice=UUID=059df4b4-5be4-44d6-a23a-de81135eb5b4:luks-disk
    root=/dev/mapper/luks-disk apparmor=1 security=apparmor
    resume=/dev/mapper/luks-swap udev.log_priority=3
  Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: ASUSTeK model: PRIME X570-PRO v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 4021
    date: 08/09/2021
  RAM: total: 62.71 GiB used: 20.12 GiB (32.1%)
  RAM Report: permissions: Unable to run dmidecode. Root privileges
    required.
  Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3 gen: 4
    level: v3 built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
    model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
  Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
    L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
    L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 3023 high: 4162 min/max: 2200/5083 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3411 2: 2878
    3: 2200 4: 2878 5: 3603 6: 2200 7: 2880 8: 2878 9: 3599 10: 2880 11: 2880
    12: 2879 13: 3679 14: 2879 15: 2200 16: 3066 17: 3599 18: 2879 19: 2878
    20: 2879 21: 4122 22: 2880 23: 2880 24: 2880 25: 3599 26: 2880 27: 2879
    28: 2881 29: 4162 30: 2880 31: 2200 32: 3275 bogomips: 217671
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: ASUSTeK driver: nvidia
    v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
    (as of 2022-08) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16
    bus-ID: 0b:00.0 chip-ID: 10de:2484 class-ID: 0300
  Device-2: AMD Cape Verde PRO [Radeon HD 7750/8740 / R7 250E]
    vendor: VISIONTEK driver: radeon v: kernel alternate: amdgpu arch: GCN-1
    code: Southern Islands process: TSMC 28nm built: 2011-20 pcie: gen: 3
    speed: 8 GT/s lanes: 8 link-max: lanes: 16 ports: active: DP-3,DP-4
    empty: DP-1, DP-2, DP-5, DP-6 bus-ID: 0c:00.0 chip-ID: 1002:683f
    class-ID: 0300
  Device-3: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo
    bus-ID: 5-3:4 chip-ID: 0c45:6367 class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
    compositor: kwin_x11 driver: X: loaded: modesetting,nvidia gpu: radeon
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 5760x2160 s-dpi: 80 s-size: 1829x686mm (72.01x27.01")
    s-diag: 1953mm (76.91")
  Monitor-1: DP-1 pos: 1-2 res: 1920x1080 dpi: 93
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
  Monitor-2: DP-1-3 pos: primary,1-1 res: 1920x1080 dpi: 93
  Monitor-3: DP-1-4 pos: 2-1 res: 1920x1080 dpi: 82
    size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
  Monitor-4: DP-3 pos: primary,2-2 res: 1920x1080 dpi: 82
  Monitor-5: DP-4 pos: 2-3 res: 1920x1080 dpi: 82
  Monitor-6: HDMI-0 pos: 1-4 res: 1920x1080 dpi: 93
  OpenGL: renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2 v: 4.6.0 NVIDIA
    515.65.01 direct render: Yes
  Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel bus-ID: 5-1:2 v: kernel pcie: chip-ID: 0c76:120b
    gen: 4 class-ID: 0300 speed: 16 GT/s serial: <filter> lanes: 8 link-max:
    lanes: 16 bus-ID: 0b:00.1 chip-ID: 10de:228b class-ID: 0403
  Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
    Series] vendor: VISIONTEK driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 0c:00.1
    chip-ID: 1002:aab0 class-ID: 0403
  Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
    bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-4: JMTek LLC. Plugable USB Audio Device type: USB
    driver: hid-generic,snd-usb-audio,usbhid
  Device-5: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo
  Device-6: ASUSTek ASUS AI Noise-Cancelling Mic Adapter type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-4:6 chip-ID: 0b05:194e
    class-ID: 0300 serial: <filter>
  Device-7: Schiit Audio Unison Universal Dac type: USB
    driver: snd-usb-audio bus-ID: 9-1:2 chip-ID: 30be:1019 class-ID: 0102
  Sound Server-1: ALSA v: k5.19.1-3-MANJARO running: yes
  Sound Server-3: JACK v: 1.9.21 running: no
  Sound Server-4: PulseAudio v: 16.1 running: yes
  Sound Server-5: PipeWire v: 0.3.56 running: no
  Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0
  IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
    driver: btusb v: 0.8 bus-ID: 5-5.3:12 chip-ID: 0a12:0001 class-ID: e001
  Device-1: luks-c847cf9f-c6b5-4624-a25e-4531e318851a maj-min: 254:2
    type: LUKS dm: dm-2 size: 3.64 TiB
  Components:
  p-1: sda1 maj-min: 8:1 size: 3.64 TiB
  Device-2: luks-swap maj-min: 254:1 type: LUKS dm: dm-1 size: 12 GiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 12 GiB
  Device-3: luks-disk maj-min: 254:0 type: LUKS dm: dm-0 size: 919.01 GiB
  Components:
  p-1: nvme0n1p3 maj-min: 259:3 size: 919.01 GiB
  Local Storage: total: 9.13 TiB used: 3.4 TiB (37.3%)
    model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
    rev: 111110WD temp: 52.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Western Digital
    model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
    rev: 211070WD temp: 46.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD4005FZBX-00K5WB0 size: 3.64 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
    rev: 1A01 scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
  ID-5: /dev/sdc maj-min: 8:32 type: USB vendor: ASolid model: USB
    size: 29.3 GiB block-size: physical: 512 B logical: 512 B type: N/A
    serial: <filter> rev: 0000 scheme: MBR
  ID-1: / raw-size: 919.01 GiB size: 919.01 GiB (100.00%) used: 606.37 GiB
    (66.0%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0 mapped: luks-disk
    label: N/A uuid: N/A
  ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 14.3 MiB
    (2.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: EFI
    uuid: 8922-E04D
  ID-3: /home raw-size: 919.01 GiB size: 919.01 GiB (100.00%) used: 606.37
    GiB (66.0%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0 mapped: luks-disk
  ID-4: /run/media/sarah/ConvergentRefuge raw-size: 3.64 TiB size: 3.64 TiB
    (100.00%) used: 2.53 TiB (69.4%) fs: btrfs dev: /dev/dm-2 maj-min: 254:2
    mapped: luks-c847cf9f-c6b5-4624-a25e-4531e318851a label: ConvergentRefuge
    uuid: 7d295e73-4143-4eb1-9d22-75a06b1d2984
  ID-5: /run/media/sarah/MSS_EXtended raw-size: 731.51 GiB size: 731.16 GiB
    (99.95%) used: 290.46 GiB (39.7%) fs: xfs dev: /dev/nvme1n1p1
    maj-min: 259:5 label: MSS EXtended
    uuid: 20339e0b-8343-433e-9209-ac67e31d9d73
  ID-6: /run/user/1000/keybase/kbfs raw-size: N/A size: 250 GiB used: 0 KiB
    (0.0%) fs: fuse dev: /dev/fuse label: N/A uuid: N/A
  ID-1: swap-1 type: partition size: 12 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/dm-1 maj-min: 254:1 mapped: luks-swap label: SWAP
    uuid: c8991364-85a7-4e6c-8380-49cd5bd7a873
  ID-1: /dev/nvme1n1p2 maj-min: 259:6 size: 16 MiB fs: <superuser required>
  ID-2: /dev/nvme1n1p3 maj-min: 259:7 size: 199.98 GiB fs: ntfs label: N/A
    uuid: E658FD3258FD025B
  ID-3: /dev/sdb1 maj-min: 8:17 size: 3.64 TiB fs: ntfs
    label: JerichoVariance uuid: 1AB22D5664889CBD
  ID-4: /dev/sdc1 maj-min: 8:33 size: 3.32 GiB fs: iso9660
  ID-5: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: C80E-8B3F
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-2: 1-2:2 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s
    chip-ID: 045b:0209 class-ID: 0900
  Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  Hub-4: 2-2:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s
    chip-ID: 045b:0210 class-ID: 0900
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-6: 3-1:2 info: VIA Labs Hub ports: 4 rev: 2.1 speed: 480 Mb/s
    power: 100mA chip-ID: 2109:3431 class-ID: 0900
  Hub-7: 3-1.2:3 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
    chip-ID: 2109:2813 class-ID: 0900
  Device-1: 3-1.3:4 info: Microsoft Xbox One Controller (Firmware 2015)
    type: <vendor specific> driver: usbfs interfaces: 3 rev: 2.0 speed: 12 Mb/s
    power: 500mA chip-ID: 045e:02dd class-ID: ff00 serial: <filter>
  Hub-8: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  Hub-9: 4-2:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
    chip-ID: 2109:0813 class-ID: 0900
  Hub-10: 5-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 5-1:2 info: JMTek LLC. Plugable USB Audio Device type: Audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
    speed: 12 Mb/s power: 100mA chip-ID: 0c76:120b class-ID: 0300
    serial: <filter>
  Hub-11: 5-2:3 info: Terminus FE 2.1 7-port Hub ports: 7 rev: 2.0
    speed: 480 Mb/s power: 100mA chip-ID: 1a40:0201 class-ID: 0900
  Device-1: 5-2.1:5 info: Sunplus Innovation Gaming mouse [Philips SPK9304]
    type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    speed: 1.5 Mb/s power: 98mA chip-ID: 1bcf:08a0 class-ID: 0301
  Device-2: 5-2.5:7 info: Microdia Backlit Gaming Keyboard
    type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s power: 400mA chip-ID: 0c45:652f class-ID: 0301
  Device-3: 5-2.6:8 info: HUION H420 type: Mouse,HID driver: uclogic,usbhid
    interfaces: 3 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 256c:006e
    class-ID: 0300
  Hub-12: 5-2.7:10 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
    power: 100mA chip-ID: 1a40:0101 class-ID: 0900
  Device-1: 5-2.7.4:13 info: Texas Instruments TI-Nspire Calculator
    type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
    power: 500mA chip-ID: 0451:e012 class-ID: 0000
  Device-2: 5-3:4 info: Microdia USB 2.0 Camera type: Video,Audio
    power: 500mA chip-ID: 0c45:6367 class-ID: 0102 serial: <filter>
  Device-3: 5-4:6 info: ASUSTek ASUS AI Noise-Cancelling Mic Adapter
    type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
    rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0b05:194e class-ID: 0300
    serial: <filter>
  Hub-13: 5-5:9 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Device-1: 5-5.3:12 info: Cambridge Silicon Radio Bluetooth Dongle (HCI
    mode) type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 0a12:0001 class-ID: e001
  Hub-14: 5-6:11 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Hub-15: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-16: 7-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 7-4:2 info: ASUSTek AURA LED Controller type: HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
    chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
  Hub-17: 8-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Device-1: 8-1:2 info: ASolid USB_0114 type: Mass Storage
    driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 144mA
    chip-ID: 24a9:205a class-ID: 0806 serial: <filter>
  Hub-18: 9-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 9-1:2 info: Schiit Audio Unison Universal Dac type: Audio
    driver: snd-usb-audio interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA
  Hub-19: 10-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 58.0 C mobo: 41.0 C
  Fan Speeds (RPM): fan-1: 1695 fan-2: 1109 fan-3: 1127 fan-4: 1131
    fan-5: 3276 fan-6: 0 fan-7: 0
  GPU: device: nvidia screen: :0.0 temp: 49 C fan: 0% device: radeon
    temp: 54.0 C
  Processes: 797 Uptime: 1h 44m wakeups: 0 Init: systemd v: 251
  default: graphical tool: systemctl Compilers: gcc: 12.1.1 alt: 10
  clang: 14.0.6 Packages: 2473 pm: pacman pkgs: 2443 libs: 516
  tools: pamac,yay pm: flatpak pkgs: 14 pm: snap pkgs: 16 Shell: Bash
  v: 5.1.16 running-in: yakuake inxi: 3.3.21
How can I pin down the number of causes of this? It’s not kernel related as I have tried the the LTS one and it still happens on it.
Hint:
I suggest researching the messages provided in your dmesg log. :wink:
The message may be interpreted using the following logic - but I am guessing - I have no idea what I am commenting on.
on cpu 19 - a machine check returned 0 = false on bank 5 with address baa0000000090150
which cause an incident on processor 2:a20f10 at 11-09-2022 21:18:21 reference socket 0 (incase of more than one processor) - the rest is likely identifiers of some sort.
The reference to bank 5 could point to a specific memory address not containing the expected value which may indicate a failing memory stick.
I converted the timestamp to human readable universal timestamp
date -ud @1662931101
It’s a significant bug in Manjaro that it does not manage to alert us by email when it is preparing to crash. I’d certainly fill out the form and claim a refund or replacement. Still, I did enjoy your title.
However, in the event that the staff of Manjaro might not agree with this approach, we should turn to our ‘Search Engine’.
From Searxng I got this: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 6: ee2000000040110 / Kernel & Hardware / Arch Linux Forums
I doubt if it’s a software issue, but I’d boot from USB and see how that goes. Make sure it IS a hardware issue - and then possibly start rebuilding the machine.
Can you post some hardware info?
The rest of the hardware (PSU,…).
I saw that it was a machine-check exception, I was more looking for confirmation before purchasing another processor lol.
Not that it was some side-software error or something.
That would be funny though.
Like there is going to be a scheduled crash today or something lol.
I knwo that it was a machine check exception and I researched it ahead of the post, but I was just verifying it before potentially getting another processor.
It happens occasionally, and kind of makes me wonder if the CPU is failing. It was one of the earliest production runs of the 5950x, so I wonder if it was of a poorer quality. :woman_shrugging:
Then why didn’t you say so to begin with?
Your post title infers that you expected there to be warning…or something.
If you had been more clear and concise in your topic title and first post, you would have received the same courtesy in the responses by others. :wink:
Can you run inxi -Fza as root ?
I’m curious if you get the same issue with anything else - stick another ISO on your Ventoy and boot that, see how it goes.
I guess I’ve been lucky - my i3-4130 lasted forever until my old PSU died, so now I’m on a Ryzen 5600G and expect (as it survived 3 months already) if it survives more than 6 months, it should survive until it’s obsolete.
I knew this random issue in the past, that would be related to AMD CPU and RAM
Try to enable DOCP or XMP in BIOS, it solved the issue for me. CPU and RAM should be in good balance.
