So basically I’ve probably slaughtered my new laptop. Cannot access BIOS nor does it start by itself.
But the main problem is that I cannot access the computer normally. I have to ALT F3 to login and start “startx”. Sometimes it tells me that AMDGPU and ACLI didnt load.
Here is my inxit text
Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 81YQ v: IdeaPad 5 15ARE05
serial: <filter> Chassis: type: 10 v: IdeaPad 5 15ARE05 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <filter>
UEFI [Legacy]: LENOVO v: E7CN24WW date: 03/25/2020
ID-1: BAT0 charge: 71.7 Wh condition: 71.7/70.0 Wh (102%) volts: 17.3/15.0
model: SMP L19M4PF1 type: Li-poly serial: <filter> status: Full cycles: 14
Topology: 8-Core model: AMD Ryzen 7 4800U with Radeon Graphics bits: 64
type: MT MCP arch: Zen rev: 1 L2 cache: 4096 KiB
bogomips: 57506
Speed: 1397 MHz min/max: 1400/1800 MHz boost: enabled Core speeds (MHz):
1: 1397 2: 1397 3: 1430 4: 1811 5: 1560 6: 1470 7: 1412 8: 1464 9: 1394
10: 1392 11: 1394 12: 1397 13: 1396 14: 1397 15: 1397 16: 1379
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel
bus ID: 03:00.0 chip ID: 1002:1636
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo
bus ID: 1-3:2 chip ID: 174f:244c serial: <filter>
Display: server: X.org 1.20.9 compositor: gnome-shell driver: amdgpu,ati
unloaded: modesetting,radeon alternate: fbdev,vesa
resolution: <xdpyinfo missing>
OpenGL: renderer: AMD RENOIR (DRM 3.38.0 5.8.11-1-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.8 direct render: Yes
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel
bus ID: 03:00.1 chip ID: 1002:1637
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Lenovo driver: snd_rn_pci_acp3x v: kernel bus ID: 03:00.5
chip ID: 1022:15e2
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 03:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.8.11-1-MANJARO
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus ID: 01:00.0
chip ID: 8086:2723
Local Storage: total: 476.94 GiB used: 7.25 GiB (1.5%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: HFS512GD9TNI-L2A0B
size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 11010C10
scheme: MBR
ID-1: / size: 452.35 GiB used: 7.25 GiB (1.6%) fs: ext4
dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 16.35 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p2
System Temperatures: cpu: 53.4 C mobo: N/A gpu: amdgpu temp: 36 C
Processes: 361 Uptime: 4m Memory: 14.87 GiB used: 1.33 GiB (9.0%)
Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1157 Shell: Zsh
v: 5.8 running in: gnome-terminal inxi: 3.1.05
