Compositore KDE PLASMA genera problemi.
Buonasera comunità Manjaro :slight_smile:
E da quando ho installato KDE PLASMA mi sono imbattuto con questo problema, potete aiutarmi?
Informazioni sulla gpu:
OpenGL vendor string: X.Org
OpenGL renderer string: AMD TAHITI (DRM 2.50.0, 5.4.18-1-MANJARO, LLVM 9.0.1)
OpenGL core profile version string: 4.5 (Core Profile) Mesa 19.3.4
OpenGL core profile shading language version string: 4.50
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 4.5 (Compatibility Profile) Mesa 19.3.4
OpenGL shading language version string: 4.50
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 19.3.4
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
Ogni commento su come risolvere questo problema è molto apprezzato!
Ragazzi, ho risolto in autonomia. Dopo che sono andato a rimuovere il driver video-linux ed installato video-modesetting il problema viene risolto.
My apologies: my Italian is good enough to read, but not to write.
In the future, it's better to mark the answer that solved your question as "Solution" like this:
Solution
so that your question gets removed from the "unsolved" queue and if anyone else has the same question as you and they look for a solution, they'll find it as well!
We thank you for your cooperation...
:innocent: :wink: :+1:
