Compositor slow/laggy after kernel 6.6.32 upgrade
I upgraded from 5.15 to 6.6 LTS and I noticed the compositor is slow and laggy when starting apps and minimizing/maximizing. The right click context menu is also slow (appears slow, and hover effects are slow as well).
Regarding the window transitions - they’re only slow when I’m looking at my desktop and opening/maximizing/minimizing a window. If I do the same on top of another window it’s all fine.
  Kernel: 6.6.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    root=UUID=7badc200-b109-4774-965d-ef67cc249f1c rw text udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
    wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: Gigabyte model: Z690 AORUS ELITE DDR4 v: x.x
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: F4 date: 11/10/2021
  Info: model: 12th Gen Intel Core i5-12600K bits: 64 type: MST AMCP
    arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 2
    microcode: 0x35
  Topology: cpus: 1x cores: 10 mt: 6 tpc: 2 st: 4 threads: 16 smt: enabled
    cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32 KiB, 4x64 KiB
    L2: 9.5 MiB desc: 6x1.2 MiB, 1x2 MiB L3: 20 MiB desc: 1x20 MiB
  Speed (MHz): avg: 800 high: 801 min/max: 800/4900:3600 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
    5: 801 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
    15: 800 16: 800 bogomips: 118000
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel AlderLake-S GT1 vendor: Gigabyte driver: i915 v: kernel
    ports: active: none empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:4680 class-ID: 0380
  Device-2: NVIDIA GA104 [GeForce RTX 3070 Lite Hash Rate] vendor: ASUSTeK
    driver: nvidia v: 550.78 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2488 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: i915,nvidia
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 5120x1440 s-dpi: 120 s-size: 1084x305mm (42.68x12.01")
    s-diag: 1126mm (44.33")
  Monitor-1: DP-4 pos: primary,right res: 2560x1440 hz: 60 dpi: 109
    size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
  Monitor-2: HDMI-0 pos: left res: 2560x1440 hz: 60 dpi: 109
    drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: kms_swrast
    surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
    memory: 7.81 GiB
  API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 3070 driver: nvidia v: 550.78 device-ID: 10de:2488
    surfaces: xcb,xlib device: 1 type: integrated-gpu name: Intel UHD Graphics
    770 (ADL-S GT1) driver: mesa intel v: 24.0.8-manjaro1.1
    device-ID: 8086:4680 surfaces: xcb,xlib
  Device-1: Intel Alder Lake-S HD Audio vendor: Gigabyte driver: snd_hda_intel
    v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7ad0
    class-ID: 0403
  Device-2: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
    bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
  API: ALSA v: k6.6.32-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.7 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Server-3: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
  Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 05:00.0
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: wg0-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
  Device-1: TP-Link TP-Jmn+ UB500 Adapter driver: btusb v: 0.8 type: USB
    rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:2 chip-ID: 2357:0604
  Local Storage: total: 4.32 TiB used: 245.88 GiB (5.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 1B4QFXO7 temp: 39.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 QVO 4TB
    size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
  ID-1: / raw-size: 97.17 GiB size: 95.08 GiB (97.85%) used: 34.71 GiB (36.5%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
    used: 27.2 MiB (5.5%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
  ID-3: /home raw-size: 368.1 GiB size: 361.26 GiB (98.14%)
    used: 211.15 GiB (58.4%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 41.0 C mobo: 34.0 C
  Fan Speeds (rpm): N/A
  Memory: total: 16 GiB note: est. available: 15.4 GiB used: 6.6 GiB (42.9%)
  Processes: 387 Power: uptime: 2h 43m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.15 GiB services: org_kde_powerdevil,upowerd
    Init: systemd v: 255 default: graphical tool: systemctl
  Packages: 1877 pm: pacman pkgs: 1869 libs: 509 tools: pamac pm: flatpak
    pkgs: 8 Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: Zsh v: 5.9
    running-in: yakuake inxi: 3.3.34
You might consider allocating some swap space.
