Here is the journalctl
Jul 18 08:56:23 Yamo-Legion5 kwin_x11[84286]: Warning: Setting a new default format with a different version or profile after the global shared context is created may cause issues with context sharing.
Jul 18 08:56:23 Yamo-Legion5 kwin_x11[84286]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 180, resource id: 12582931, major code: 20 (GetProperty), minor code: 0
Jul 18 08:56:23 Yamo-Legion5 kwin_x11[84286]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 181, resource id: 12582931, major code: 20 (GetProperty), minor code: 0
Jul 18 08:56:23 Yamo-Legion5 kwin_x11[84286]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Jul 18 08:56:23 Yamo-Legion5 kwin_x11[84286]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Jul 18 08:56:23 Yamo-Legion5 kwin_x11[84286]: Module 'org.kde.kwin.decoration' does not contain a module identifier directive - it cannot be protected from external registrations.
Jul 18 08:56:24 Yamo-Legion5 kwin_x11[84286]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3466, resource id: 113246212, major code: 18 (ChangeProperty), minor code: 0
Jul 18 08:56:24 Yamo-Legion5 kwin_x11[84286]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3470, resource id: 113246213, major code: 18 (ChangeProperty), minor code: 0
Jul 18 08:56:24 Yamo-Legion5 kwin_x11[84286]: kwin_platform_x11_standalone: Compositing disabled: video driver seems unstable. If you think it's a false positive, please remove "OpenGLIsUnsafe" from [Compositing] in kwinrc and restart kwin.
Jul 18 08:56:24 Yamo-Legion5 kwin_x11[84286]: kwin_core: Compositing is not possible
Jul 18 08:56:24 Yamo-Legion5 kded5[1292]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: Cannot load library /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: (libgps.so.29: cannot open shared object file: No such file or directory)"
Jul 18 08:56:56 Yamo-Legion5 udisksd[1198]: Error cleaning up mount point /run/media/yamo/HiSuite: Error unmounting: Command-line `umount -l '/run/media/yamo/HiSuite'' exited with non-zero exit status 32: umount: /run/media/yamo/HiSuite: not mounted.
Jul 18 08:57:40 Yamo-Legion5 kernel: __report_access: 17 callbacks suppressed
Jul 18 08:57:45 Yamo-Legion5 kernel: __report_access: 300 callbacks suppressed
Jul 18 08:57:53 Yamo-Legion5 kernel: __report_access: 386 callbacks suppressed
Jul 18 08:57:58 Yamo-Legion5 kernel: __report_access: 212 callbacks suppressed
Jul 18 08:58:03 Yamo-Legion5 kernel: __report_access: 314 callbacks suppressed
Jul 18 08:58:08 Yamo-Legion5 kernel: __report_access: 239 callbacks suppressed
Jul 18 08:58:13 Yamo-Legion5 kernel: __report_access: 71 callbacks suppressed
Jul 18 08:58:19 Yamo-Legion5 kernel: __report_access: 131 callbacks suppressed
Jul 18 08:58:24 Yamo-Legion5 kernel: __report_access: 311 callbacks suppressed
Jul 18 08:58:30 Yamo-Legion5 kernel: __report_access: 89 callbacks suppressed
Jul 18 08:58:35 Yamo-Legion5 kernel: __report_access: 155 callbacks suppressed
Jul 18 08:58:52 Yamo-Legion5 org_kde_powerdevil[1355]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
Jul 18 09:00:07 Yamo-Legion5 org_kde_powerdevil[1355]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
Jul 18 09:01:22 Yamo-Legion5 org_kde_powerdevil[1355]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
Jul 18 09:02:40 Yamo-Legion5 kernel: __report_access: 152 callbacks suppressed
Jul 18 09:02:45 Yamo-Legion5 kernel: __report_access: 269 callbacks suppressed
Jul 18 09:02:50 Yamo-Legion5 kernel: __report_access: 371 callbacks suppressed
Jul 18 09:02:55 Yamo-Legion5 kernel: __report_access: 95 callbacks suppressed
Jul 18 09:03:00 Yamo-Legion5 kernel: __report_access: 224 callbacks suppressed
Jul 18 09:03:05 Yamo-Legion5 kernel: __report_access: 260 callbacks suppressed
Jul 18 09:03:12 Yamo-Legion5 kernel: __report_access: 209 callbacks suppressed
Jul 18 09:03:20 Yamo-Legion5 kernel: __report_access: 182 callbacks suppressed
Jul 18 09:03:22 Yamo-Legion5 org_kde_powerdevil[1355]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
Jul 18 09:03:25 Yamo-Legion5 kernel: __report_access: 290 callbacks suppressed
Jul 18 09:03:31 Yamo-Legion5 kernel: __report_access: 122 callbacks suppressed
Jul 18 09:03:36 Yamo-Legion5 kernel: __report_access: 194 callbacks suppressed
Jul 18 09:07:47 Yamo-Legion5 kernel: __report_access: 89 callbacks suppressed
Jul 18 09:07:52 Yamo-Legion5 kernel: __report_access: 251 callbacks suppressed
Jul 18 09:07:57 Yamo-Legion5 kernel: __report_access: 368 callbacks suppressed
Jul 18 09:08:02 Yamo-Legion5 kernel: __report_access: 113 callbacks suppressed
Jul 18 09:08:07 Yamo-Legion5 kernel: __report_access: 212 callbacks suppressed
Jul 18 09:08:12 Yamo-Legion5 kernel: __report_access: 256 callbacks suppressed
Jul 18 09:08:19 Yamo-Legion5 kernel: __report_access: 231 callbacks suppressed
Jul 18 09:08:27 Yamo-Legion5 kernel: __report_access: 182 callbacks suppressed
Jul 18 09:08:32 Yamo-Legion5 kernel: __report_access: 284 callbacks suppressed
Jul 18 09:08:38 Yamo-Legion5 kernel: __report_access: 128 callbacks suppressed
Jul 18 09:08:43 Yamo-Legion5 kernel: __report_access: 204 callbacks suppressed
Jul 18 09:12:48 Yamo-Legion5 kernel: __report_access: 79 callbacks suppressed
Jul 18 09:12:53 Yamo-Legion5 kernel: __report_access: 262 callbacks suppressed
Jul 18 09:12:58 Yamo-Legion5 kernel: __report_access: 366 callbacks suppressed
Jul 18 09:13:03 Yamo-Legion5 kernel: __report_access: 101 callbacks suppressed
Jul 18 09:13:08 Yamo-Legion5 kernel: __report_access: 217 callbacks suppressed
Jul 18 09:13:13 Yamo-Legion5 kernel: __report_access: 264 callbacks suppressed
Jul 18 09:13:20 Yamo-Legion5 kernel: __report_access: 215 callbacks suppressed
Jul 18 09:13:28 Yamo-Legion5 kernel: __report_access: 182 callbacks suppressed
Jul 18 09:13:33 Yamo-Legion5 kernel: __report_access: 290 callbacks suppressed
Jul 18 09:13:39 Yamo-Legion5 kernel: __report_access: 125 callbacks suppressed
Jul 18 09:13:44 Yamo-Legion5 kernel: __report_access: 194 callbacks suppressed
Jul 18 09:17:55 Yamo-Legion5 kernel: __report_access: 89 callbacks suppressed
Jul 18 09:18:00 Yamo-Legion5 kernel: __report_access: 287 callbacks suppressed
Jul 18 09:18:05 Yamo-Legion5 kernel: __report_access: 389 callbacks suppressed
Jul 18 09:18:10 Yamo-Legion5 kernel: __report_access: 86 callbacks suppressed
Jul 18 09:18:15 Yamo-Legion5 kernel: __report_access: 247 callbacks suppressed
Jul 18 09:18:20 Yamo-Legion5 kernel: __report_access: 234 callbacks suppressed
Jul 18 09:18:27 Yamo-Legion5 kernel: __report_access: 185 callbacks suppressed
Jul 18 09:18:34 Yamo-Legion5 kernel: __report_access: 182 callbacks suppressed
Jul 18 09:18:39 Yamo-Legion5 kernel: __report_access: 284 callbacks suppressed
Jul 18 09:18:46 Yamo-Legion5 kernel: __report_access: 131 callbacks suppressed
Jul 18 09:18:52 Yamo-Legion5 kernel: __report_access: 194 callbacks suppressed
Jul 18 09:22:53 Yamo-Legion5 kernel: __report_access: 89 callbacks suppressed
Jul 18 09:22:58 Yamo-Legion5 kernel: __report_access: 262 callbacks suppressed
Jul 18 09:23:03 Yamo-Legion5 kernel: __report_access: 351 callbacks suppressed
Jul 18 09:23:08 Yamo-Legion5 kernel: __report_access: 107 callbacks suppressed
Jul 18 09:23:13 Yamo-Legion5 kernel: __report_access: 203 callbacks suppressed
Jul 18 09:23:18 Yamo-Legion5 kernel: __report_access: 269 callbacks suppressed
Jul 18 09:23:26 Yamo-Legion5 kernel: __report_access: 233 callbacks suppressed
Jul 18 09:23:34 Yamo-Legion5 kernel: __report_access: 182 callbacks suppressed
Jul 18 09:23:39 Yamo-Legion5 kernel: __report_access: 275 callbacks suppressed
Jul 18 09:23:46 Yamo-Legion5 kernel: __report_access: 140 callbacks suppressed
Jul 18 09:23:51 Yamo-Legion5 kernel: __report_access: 194 callbacks suppressed
Jul 18 09:27:57 Yamo-Legion5 kernel: __report_access: 89 callbacks suppressed
Jul 18 09:28:02 Yamo-Legion5 kernel: __report_access: 259 callbacks suppressed
Jul 18 09:28:07 Yamo-Legion5 kernel: __report_access: 337 callbacks suppressed
Jul 18 09:28:12 Yamo-Legion5 kernel: __report_access: 118 callbacks suppressed
Jul 18 09:28:17 Yamo-Legion5 kernel: __report_access: 194 callbacks suppressed
Jul 18 09:28:22 Yamo-Legion5 kernel: __report_access: 281 callbacks suppressed
Jul 18 09:28:30 Yamo-Legion5 kernel: __report_access: 236 callbacks suppressed
Jul 18 09:28:35 Yamo-Legion5 kernel: __report_access: 179 callbacks suppressed
Jul 18 09:28:40 Yamo-Legion5 kernel: __report_access: 86 callbacks suppressed
Jul 18 09:28:45 Yamo-Legion5 kernel: __report_access: 287 callbacks suppressed
Jul 18 09:28:50 Yamo-Legion5 kernel: __report_access: 35 callbacks suppressed
Jul 18 09:28:56 Yamo-Legion5 kernel: __report_access: 194 callbacks suppressed
Jul 18 09:32:57 Yamo-Legion5 kernel: __report_access: 89 callbacks suppressed
Jul 18 09:33:02 Yamo-Legion5 kernel: __report_access: 245 callbacks suppressed
Jul 18 09:33:07 Yamo-Legion5 kernel: __report_access: 335 callbacks suppressed
Jul 18 09:33:12 Yamo-Legion5 kernel: __report_access: 127 callbacks suppressed
Jul 18 09:33:17 Yamo-Legion5 kernel: __report_access: 182 callbacks suppressed
Jul 18 09:33:22 Yamo-Legion5 kernel: __report_access: 294 callbacks suppressed
Jul 18 09:33:27 Yamo-Legion5 kernel: __report_access: 230 callbacks suppressed
Jul 18 09:33:33 Yamo-Legion5 kernel: __report_access: 68 callbacks suppressed
Jul 18 09:33:39 Yamo-Legion5 kernel: __report_access: 119 callbacks suppressed
Jul 18 09:33:44 Yamo-Legion5 kernel: __report_access: 266 callbacks suppressed
Jul 18 09:33:51 Yamo-Legion5 kernel: __report_access: 149 callbacks suppressed
Jul 18 09:33:56 Yamo-Legion5 kernel: __report_access: 194 callbacks suppressed
Jul 18 09:37:59 Yamo-Legion5 kernel: __report_access: 89 callbacks suppressed
Jul 18 09:38:04 Yamo-Legion5 kernel: __report_access: 233 callbacks suppressed
Jul 18 09:38:09 Yamo-Legion5 kernel: __report_access: 329 callbacks suppressed
Jul 18 09:38:14 Yamo-Legion5 kernel: __report_access: 132 callbacks suppressed
Jul 18 09:38:19 Yamo-Legion5 kernel: __report_access: 193 callbacks suppressed
Jul 18 09:38:24 Yamo-Legion5 kernel: __report_access: 287 callbacks suppressed
Jul 18 09:38:29 Yamo-Legion5 kernel: __report_access: 188 callbacks suppressed
Jul 18 09:38:36 Yamo-Legion5 kernel: __report_access: 122 callbacks suppressed
Jul 18 09:38:42 Yamo-Legion5 kernel: __report_access: 119 callbacks suppressed
Jul 18 09:38:47 Yamo-Legion5 kernel: __report_access: 272 callbacks suppressed
Jul 18 09:38:54 Yamo-Legion5 kernel: __report_access: 143 callbacks suppressed
Jul 18 09:39:00 Yamo-Legion5 kernel: __report_access: 194 callbacks suppressed
Jul 18 09:43:01 Yamo-Legion5 kernel: __report_access: 89 callbacks suppressed
Jul 18 09:43:06 Yamo-Legion5 kernel: __report_access: 252 callbacks suppressed
Jul 18 09:43:11 Yamo-Legion5 kernel: __report_access: 326 callbacks suppressed
Jul 18 09:43:16 Yamo-Legion5 kernel: __report_access: 122 callbacks suppressed
Jul 18 09:43:21 Yamo-Legion5 kernel: __report_access: 190 callbacks suppressed
Jul 18 09:43:26 Yamo-Legion5 kernel: __report_access: 287 callbacks suppressed
Jul 18 09:43:31 Yamo-Legion5 kernel: __report_access: 191 callbacks suppressed
Jul 18 09:43:38 Yamo-Legion5 kernel: __report_access: 116 callbacks suppressed
Jul 18 09:43:43 Yamo-Legion5 kernel: __report_access: 119 callbacks suppressed
Jul 18 09:43:48 Yamo-Legion5 kernel: __report_access: 256 callbacks suppressed
Jul 18 09:43:56 Yamo-Legion5 kernel: __report_access: 159 callbacks suppressed
Jul 18 09:44:02 Yamo-Legion5 kernel: __report_access: 194 callbacks suppressed
Jul 18 09:48:02 Yamo-Legion5 kernel: __report_access: 89 callbacks suppressed
Jul 18 09:48:07 Yamo-Legion5 kernel: __report_access: 252 callbacks suppressed
Jul 18 09:48:12 Yamo-Legion5 kernel: __report_access: 314 callbacks suppressed
Jul 18 09:48:17 Yamo-Legion5 kernel: __report_access: 131 callbacks suppressed
Jul 18 09:48:23 Yamo-Legion5 kernel: __report_access: 191 callbacks suppressed
Jul 18 09:48:28 Yamo-Legion5 kernel: __report_access: 287 callbacks suppressed
Jul 18 09:48:33 Yamo-Legion5 kernel: __report_access: 191 callbacks suppressed
Jul 18 09:48:40 Yamo-Legion5 kernel: __report_access: 113 callbacks suppressed
Jul 18 09:48:45 Yamo-Legion5 kernel: __report_access: 119 callbacks suppressed
Jul 18 09:48:51 Yamo-Legion5 kernel: __report_access: 263 callbacks suppressed
Jul 18 09:48:58 Yamo-Legion5 kernel: __report_access: 152 callbacks suppressed
Jul 18 09:49:03 Yamo-Legion5 kernel: __report_access: 197 callbacks suppressed
Jul 18 09:53:03 Yamo-Legion5 kernel: __report_access: 89 callbacks suppressed
Jul 18 09:53:09 Yamo-Legion5 kernel: __report_access: 251 callbacks suppressed
Jul 18 09:53:10 Yamo-Legion5 org_kde_powerdevil[1355]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
Jul 18 09:53:14 Yamo-Legion5 kernel: __report_access: 314 callbacks suppressed
Jul 18 09:53:19 Yamo-Legion5 kernel: __report_access: 125 callbacks suppressed
Jul 18 09:53:24 Yamo-Legion5 kernel: __report_access: 199 callbacks suppressed
Jul 18 09:53:29 Yamo-Legion5 kernel: __report_access: 287 callbacks suppressed
Jul 18 09:53:34 Yamo-Legion5 kernel: __report_access: 179 callbacks suppressed
Jul 18 09:53:39 Yamo-Legion5 kernel: __report_access: 122 callbacks suppressed
Jul 18 09:53:44 Yamo-Legion5 kernel: __report_access: 127 callbacks suppressed
Jul 18 09:53:49 Yamo-Legion5 kernel: __report_access: 66 callbacks suppressed
Jul 18 09:53:54 Yamo-Legion5 kernel: __report_access: 266 callbacks suppressed
Jul 18 09:54:01 Yamo-Legion5 kernel: __report_access: 74 callbacks suppressed
Jul 18 09:54:06 Yamo-Legion5 kernel: __report_access: 197 callbacks suppressed
Jul 18 09:57:36 Yamo-Legion5 org_kde_powerdevil[1355]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
Jul 18 09:58:06 Yamo-Legion5 kernel: __report_access: 89 callbacks suppressed
Jul 18 09:58:11 Yamo-Legion5 kernel: __report_access: 238 callbacks suppressed
Jul 18 09:58:16 Yamo-Legion5 kernel: __report_access: 291 callbacks suppressed
Jul 18 09:58:21 Yamo-Legion5 kernel: __report_access: 146 callbacks suppressed
Jul 18 09:58:27 Yamo-Legion5 kernel: __report_access: 212 callbacks suppressed
Jul 18 09:58:32 Yamo-Legion5 kernel: __report_access: 287 callbacks suppressed
Jul 18 09:58:37 Yamo-Legion5 kernel: __report_access: 185 callbacks suppressed
Jul 18 09:58:45 Yamo-Legion5 kernel: __report_access: 119 callbacks suppressed
Jul 18 09:58:50 Yamo-Legion5 kernel: __report_access: 119 callbacks suppressed
Jul 18 09:58:51 Yamo-Legion5 org_kde_powerdevil[1355]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
Jul 18 09:58:55 Yamo-Legion5 kernel: __report_access: 257 callbacks suppressed
Jul 18 09:59:03 Yamo-Legion5 kernel: __report_access: 158 callbacks suppressed
Jul 18 09:59:09 Yamo-Legion5 kernel: __report_access: 197 callbacks suppressed
Jul 18 10:00:06 Yamo-Legion5 org_kde_powerdevil[1355]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
Jul 18 10:02:06 Yamo-Legion5 org_kde_powerdevil[1355]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
Jul 18 10:03:09 Yamo-Legion5 kernel: __report_access: 89 callbacks suppressed
Jul 18 10:03:14 Yamo-Legion5 kernel: __report_access: 221 callbacks suppressed
Jul 18 10:03:19 Yamo-Legion5 kernel: __report_access: 275 callbacks suppressed
Jul 18 10:03:25 Yamo-Legion5 kernel: __report_access: 179 callbacks suppressed
Jul 18 10:03:31 Yamo-Legion5 kernel: __report_access: 212 callbacks suppressed
Jul 18 10:03:36 Yamo-Legion5 kernel: __report_access: 284 callbacks suppressed
Jul 18 10:03:42 Yamo-Legion5 kernel: __report_access: 176 callbacks suppressed
Jul 18 10:03:47 Yamo-Legion5 kernel: __report_access: 113 callbacks suppressed
Jul 18 10:03:52 Yamo-Legion5 kernel: __report_access: 125 callbacks suppressed
Jul 18 10:03:57 Yamo-Legion5 kernel: __report_access: 56 callbacks suppressed
Jul 18 10:04:02 Yamo-Legion5 kernel: __report_access: 287 callbacks suppressed
Jul 18 10:04:08 Yamo-Legion5 kernel: __report_access: 83 callbacks suppressed
Jul 18 10:04:14 Yamo-Legion5 kernel: __report_access: 197 callbacks suppressed
Jul 18 10:07:32 Yamo-Legion5 org_kde_powerdevil[1355]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
Jul 18 10:08:10 Yamo-Legion5 kernel: __report_access: 89 callbacks suppressed
Jul 18 10:08:15 Yamo-Legion5 kernel: __report_access: 233 callbacks suppressed
Jul 18 10:08:20 Yamo-Legion5 kernel: __report_access: 275 callbacks suppressed
Jul 18 10:08:26 Yamo-Legion5 kernel: __report_access: 167 callbacks suppressed
Jul 18 10:08:32 Yamo-Legion5 kernel: __report_access: 212 callbacks suppressed
Jul 18 10:08:37 Yamo-Legion5 kernel: __report_access: 284 callbacks suppressed
Jul 18 10:08:42 Yamo-Legion5 kernel: __report_access: 175 callbacks suppressed
Jul 18 10:08:47 Yamo-Legion5 kernel: __report_access: 105 callbacks suppressed
Jul 18 10:08:52 Yamo-Legion5 kernel: __report_access: 125 callbacks suppressed
Jul 18 10:08:58 Yamo-Legion5 kernel: __report_access: 59 callbacks suppressed
Jul 18 10:09:03 Yamo-Legion5 kernel: __report_access: 287 callbacks suppressed
Jul 18 10:09:09 Yamo-Legion5 kernel: __report_access: 83 callbacks suppressed
Jul 18 10:09:15 Yamo-Legion5 kernel: __report_access: 197 callbacks suppressed
Jul 18 10:10:06 Yamo-Legion5 org_kde_powerdevil[1355]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
Jul 18 10:11:21 Yamo-Legion5 org_kde_powerdevil[1355]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
Jul 18 10:12:36 Yamo-Legion5 org_kde_powerdevil[1355]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
Jul 18 10:13:13 Yamo-Legion5 kernel: __report_access: 89 callbacks suppressed
Jul 18 10:13:18 Yamo-Legion5 kernel: __report_access: 220 callbacks suppressed
Jul 18 10:13:23 Yamo-Legion5 kernel: __report_access: 257 callbacks suppressed
Jul 18 10:13:29 Yamo-Legion5 kernel: __report_access: 198 callbacks suppressed
Jul 18 10:13:36 Yamo-Legion5 kernel: __report_access: 213 callbacks suppressed
Jul 18 10:13:41 Yamo-Legion5 kernel: __report_access: 281 callbacks suppressed
Jul 18 10:13:46 Yamo-Legion5 kernel: __report_access: 170 callbacks suppressed
Jul 18 10:13:51 Yamo-Legion5 kernel: __report_access: 100 callbacks suppressed
Jul 18 10:13:56 Yamo-Legion5 kernel: __report_access: 135 callbacks suppressed
Jul 18 10:14:01 Yamo-Legion5 kernel: __report_access: 35 callbacks suppressed
Jul 18 10:14:06 Yamo-Legion5 kernel: __report_access: 293 callbacks suppressed
Jul 18 10:14:13 Yamo-Legion5 kernel: __report_access: 104 callbacks suppressed
Jul 18 10:14:18 Yamo-Legion5 kernel: __report_access: 197 callbacks suppressed
Jul 18 10:14:36 Yamo-Legion5 org_kde_powerdevil[1355]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
Jul 18 10:18:15 Yamo-Legion5 kernel: __report_access: 89 callbacks suppressed
Jul 18 10:18:20 Yamo-Legion5 kernel: __report_access: 236 callbacks suppressed
Jul 18 10:18:25 Yamo-Legion5 kernel: __report_access: 283 callbacks suppressed
Jul 18 10:18:31 Yamo-Legion5 kernel: __report_access: 156 callbacks suppressed
Jul 18 10:18:36 Yamo-Legion5 kernel: __report_access: 194 callbacks suppressed
Jul 18 10:18:41 Yamo-Legion5 kernel: __report_access: 257 callbacks suppressed
Jul 18 10:18:47 Yamo-Legion5 kernel: __report_access: 128 callbacks suppressed
Jul 18 10:18:53 Yamo-Legion5 kernel: __report_access: 167 callbacks suppressed
Jul 18 10:18:58 Yamo-Legion5 kernel: __report_access: 135 callbacks suppressed
Jul 18 10:19:04 Yamo-Legion5 kernel: __report_access: 49 callbacks suppressed
Jul 18 10:19:09 Yamo-Legion5 kernel: __report_access: 283 callbacks suppressed
Jul 18 10:19:16 Yamo-Legion5 kernel: __report_access: 120 callbacks suppressed
Jul 18 10:19:21 Yamo-Legion5 kernel: __report_access: 197 callbacks suppressed
Jul 18 10:23:21 Yamo-Legion5 kernel: __report_access: 89 callbacks suppressed
Jul 18 10:23:26 Yamo-Legion5 kernel: __report_access: 224 callbacks suppressed
Jul 18 10:23:31 Yamo-Legion5 kernel: __report_access: 260 callbacks suppressed
Jul 18 10:23:37 Yamo-Legion5 kernel: __report_access: 191 callbacks suppressed
Jul 18 10:23:42 Yamo-Legion5 kernel: __report_access: 200 callbacks suppressed
Jul 18 10:23:47 Yamo-Legion5 kernel: __report_access: 233 callbacks suppressed
Jul 18 10:23:53 Yamo-Legion5 kernel: __report_access: 146 callbacks suppressed
Jul 18 10:24:00 Yamo-Legion5 kernel: __report_access: 167 callbacks suppressed
Jul 18 10:24:05 Yamo-Legion5 kernel: __report_access: 140 callbacks suppressed
Jul 18 10:24:10 Yamo-Legion5 kernel: __report_access: 47 callbacks suppressed
Jul 18 10:24:15 Yamo-Legion5 kernel: __report_access: 287 callbacks suppressed
Jul 18 10:24:22 Yamo-Legion5 kernel: __report_access: 110 callbacks suppressed
Jul 18 10:24:28 Yamo-Legion5 kernel: __report_access: 197 callbacks suppressed
Jul 18 10:25:33 Yamo-Legion5 tlp[2008969]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Jul 18 10:25:33 Yamo-Legion5 tlp[2008973]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Jul 18 10:25:33 Yamo-Legion5 tlp[2008973]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Jul 18 10:25:33 Yamo-Legion5 tlp[2008969]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Jul 18 10:25:33 Yamo-Legion5 tlp[2008969]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Jul 18 10:25:33 Yamo-Legion5 tlp[2008973]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Jul 18 10:25:33 Yamo-Legion5 tlp[2008969]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Jul 18 10:25:33 Yamo-Legion5 tlp[2008973]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Jul 18 10:25:33 Yamo-Legion5 tlp[2009064]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Jul 18 10:25:33 Yamo-Legion5 tlp[2009064]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Jul 18 10:25:33 Yamo-Legion5 tlp[2009064]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Jul 18 10:25:33 Yamo-Legion5 tlp[2009064]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Jul 18 10:25:33 Yamo-Legion5 org_kde_powerdevil[1355]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
Jul 18 10:25:33 Yamo-Legion5 plasmashell[1356]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55d047c08580) QQmlContext(0x55d046638690) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Jul 18 10:25:33 Yamo-Legion5 plasmashell[1356]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Jul 18 10:25:33 Yamo-Legion5 plasmashell[1356]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Jul 18 10:25:33 Yamo-Legion5 plasmashell[1356]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:37:27: QML ScrollBar: Binding loop detected for property "visible"
Jul 18 10:25:33 Yamo-Legion5 plasmashell[1356]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:38:5: QML TextArea: Binding loop detected for property "implicitHeight"
Jul 18 10:26:03 Yamo-Legion5 plasmashell[1356]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x7f3f5409b2c0) QQmlContext(0x55d046638690) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Jul 18 10:26:03 Yamo-Legion5 plasmashell[1356]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Jul 18 10:26:03 Yamo-Legion5 plasmashell[1356]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Jul 18 10:26:03 Yamo-Legion5 plasmashell[1356]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:37:27: QML ScrollBar: Binding loop detected for property "visible"
Jul 18 10:26:03 Yamo-Legion5 plasmashell[1356]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:38:5: QML TextArea: Binding loop detected for property "implicitHeight"
Jul 18 10:28:20 Yamo-Legion5 kernel: __report_access: 89 callbacks suppressed
Jul 18 10:28:25 Yamo-Legion5 kernel: __report_access: 224 callbacks suppressed
Jul 18 10:28:30 Yamo-Legion5 kernel: __report_access: 269 callbacks suppressed
Jul 18 10:28:36 Yamo-Legion5 kernel: __report_access: 188 callbacks suppressed
Jul 18 10:28:43 Yamo-Legion5 kernel: __report_access: 212 callbacks suppressed
Jul 18 10:28:48 Yamo-Legion5 kernel: __report_access: 260 callbacks suppressed
Jul 18 10:28:53 Yamo-Legion5 kernel: __report_access: 131 callbacks suppressed
Jul 18 10:28:54 Yamo-Legion5 sddm[759]: Authentication error: "Process crashed"
Jul 18 10:28:54 Yamo-Legion5 sddm[759]: Auth: sddm-helper crashed (exit code 15)
Jul 18 10:28:54 Yamo-Legion5 sddm[759]: Auth: sddm-helper exited with 15
Jul 18 10:28:54 Yamo-Legion5 kglobalaccel5[1347]: The X11 connection broke (error 1). Did the X11 server die?
Jul 18 10:28:54 Yamo-Legion5 kglobalaccel5[1347]: The X11 connection broke: I/O error (code 1)
Jul 18 10:28:54 Yamo-Legion5 kactivitymanagerd[1389]: The X11 connection broke (error 1). Did the X11 server die?
Jul 18 10:28:54 Yamo-Legion5 msm_kde_notifier[1382]: The X11 connection broke (error 1). Did the X11 server die?
Jul 18 10:28:54 Yamo-Legion5 pamac-tray-plasma[1420]: The X11 connection broke (error 1). Did the X11 server die?
Jul 18 10:28:54 Yamo-Legion5 yakuake[1459]: The X11 connection broke (error 1). Did the X11 server die?
Jul 18 10:28:54 Yamo-Legion5 yakuake[1459]: Had queued notifications on destruction. Was the eventloop running?
Jul 18 10:28:54 Yamo-Legion5 kscreen_backend_launcher[1543]: The X11 connection broke (error 1). Did the X11 server die?
Jul 18 10:28:54 Yamo-Legion5 baloorunner[66192]: The X11 connection broke (error 1). Did the X11 server die?
Jul 18 10:28:54 Yamo-Legion5 kalendarac[1538]: The X11 connection broke (error 1). Did the X11 server die?
Jul 18 10:28:54 Yamo-Legion5 pulseaudio[1379]: X11 I/O error handler called
Jul 18 10:28:54 Yamo-Legion5 pulseaudio[1379]: X11 I/O error exit handler called, preparing to tear down X11 modules
Jul 18 10:28:54 Yamo-Legion5 xdg-desktop-portal-kde[1936]: The X11 connection broke (error 1). Did the X11 server die?
Jul 18 10:28:54 Yamo-Legion5 konsole[1597]: The X11 connection broke (error 1). Did the X11 server die?
Jul 18 10:28:54 Yamo-Legion5 konsole[68318]: The X11 connection broke (error 1). Did the X11 server die?
Jul 18 10:28:54 Yamo-Legion5 konsole[68318]: Had queued notifications on destruction. Was the eventloop running?
Jul 18 10:28:54 Yamo-Legion5 kwin_x11[84286]: The X11 connection broke: I/O error (code 1)
Jul 18 10:28:54 Yamo-Legion5 kded5[1292]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Jul 18 10:28:55 Yamo-Legion5 at-spi2-registr[2088049]: Could not open X display
Jul 18 10:28:55 Yamo-Legion5 at-spi2-registr[2088049]: AT-SPI: Cannot open default display
Jul 18 10:28:55 Yamo-Legion5 at-spi2-registr[2088145]: Could not open X display
Jul 18 10:28:55 Yamo-Legion5 at-spi2-registr[2088145]: AT-SPI: Cannot open default display
Jul 18 10:28:55 Yamo-Legion5 at-spi2-registr[2088147]: Could not open X display
Jul 18 10:28:55 Yamo-Legion5 at-spi2-registr[2088147]: AT-SPI: Cannot open default display
Jul 18 10:28:55 Yamo-Legion5 at-spi2-registr[2088149]: Could not open X display
Jul 18 10:28:55 Yamo-Legion5 at-spi2-registr[2088149]: AT-SPI: Cannot open default display
Jul 18 10:28:55 Yamo-Legion5 at-spi2-registr[2088151]: Could not open X display
Jul 18 10:28:55 Yamo-Legion5 at-spi2-registr[2088151]: AT-SPI: Cannot open default display
Jul 18 10:28:55 Yamo-Legion5 at-spi2-registr[2088153]: Could not open X display
Jul 18 10:28:55 Yamo-Legion5 at-spi2-registr[2088153]: AT-SPI: Cannot open default display
Jul 18 10:28:55 Yamo-Legion5 okular[1615]: The X11 connection broke (error 1). Did the X11 server die?
Jul 18 10:28:55 Yamo-Legion5 at-spi2-registr[2088155]: Could not open X display
Jul 18 10:28:55 Yamo-Legion5 at-spi2-registr[2088155]: AT-SPI: Cannot open default display
Jul 18 10:28:55 Yamo-Legion5 dolphin[1581]: The X11 connection broke (error 1). Did the X11 server die?
Jul 18 10:28:55 Yamo-Legion5 systemd-coredump[2088161]: Failed to connect to coredump service: Connection refused
Jul 18 10:28:57 Yamo-Legion5 kded5[2088160]: qt.qpa.xcb: could not connect to display :0
Jul 18 10:28:57 Yamo-Legion5 kded5[2088160]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
Jul 18 10:28:57 Yamo-Legion5 systemd-coredump[2088191]: Failed to connect to coredump service: Connection refused
Jul 18 10:28:57 Yamo-Legion5 sddm[759]: Signal received: SIGTERM
Jul 18 10:28:57 Yamo-Legion5 org.freedesktop.secrets[1955]: discover_other_daemon: 1
Jul 18 10:28:58 Yamo-Legion5 sddm[759]: QProcess: Destroyed while process ("/usr/lib/sddm/sddm-helper") is still running.
Jul 18 10:30:27 Yamo-Legion5 systemd[1235]: app-visual\x2dstudio\x2dcode-4fadaa543cdd4f749c68f4d33e63a7f3.scope: Stopping timed out. Killing.
Jul 18 10:30:27 Yamo-Legion5 systemd[1235]: app-visual\x2dstudio\x2dcode-4fadaa543cdd4f749c68f4d33e63a7f3.scope: Failed with result 'timeout'.
Jul 18 10:30:27 Yamo-Legion5 kernel: kauditd_printk_skb: 24 callbacks suppressed
Jul 18 10:30:28 Yamo-Legion5 kernel: ACPI: \: failed to evaluate _DSM (0x1001)
