After the compositor crashes, it is disabled, and I can continue to use Kdenlive normally without any issues, but, e.g. Krohnkite does not work. I have to re-enable the compositor and reboot to make the compositor work again.
This says something like:
OpenGL compositing (default) as produced the crash of KDE in the past.
This was caused, most probably, by an issue in the driver.
etc.
What can I do to make the compositor not crash? Please tell me which commands do you wish to run and to give the output under this topic.
Thanks!
Kwin should refresh when you click on Reactivează detectarea OpenGL
If i recall correctly you have a Laptop with hybrid intel+nvidia GPU. What is your method of switching graphics and do you use the iGPU or dGPU when opening Kdenlive?
@bogdancovaciu When I click “Reactivează detectarea OpenGL” it does not refresh the compositor. It does change something well but it needs a reboot.
Neofetch shows that I have GPU: NVIDIA GeForce RTX 2060 Mobile
I never switch graphics. I do not know what iGPU or dGPU are.
Thanks.
Let me check if you shared somewhere the complete inxi -Fazy
(it looks like is from when you had the 5.8 kernel)
If you only have the Nvidia GPU aka dGPU = dedicated GPU, then maybe we can tweak the /etc/X11/mhwd.d/nvidia.conf
that you can share here.
The iGPU is a short for integrated GPU.
The current inxi -Fazy
Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=d6a72d1f-3160-46db-80c7-2c374ed21471 rw quiet apparmor=1
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: HP product: OMEN by HP Laptop 17-cb0xxx v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 8603 v: 45.40 serial: <filter> UEFI: AMI v: F.23
date: 02/18/2020
ID-1: BAT1 charge: 65.5 Wh condition: 65.5/70.1 Wh (93%) volts: 17.3/15.4
model: COMPAL PABAS0241231 type: Li-ion serial: <filter> status: Full
Device-1: hidpp_battery_0
model: Logitech G305 Lightspeed Wireless Gaming Mouse serial: <filter>
charge: 100% (should be ignored) rechargeable: yes status: Discharging
Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: DE L2 cache: 12 MiB
bogomips: 62431
Speed: 800 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Type: l1tf
Device-1: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1f11
Device-2: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD
Integrated Webcam
type: USB driver: uvcvideo bus ID: 1-5:4 chip ID: 05c8:03bc
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: nvidia
display ID: :0 screens: 1
Screen-1: 0 s-res: 5760x1200 s-dpi: 128 s-size: 1143x246mm (45.0x9.7")
s-diag: 1169mm (46")
Monitor-1: DP-0 res: 3840x1200 hz: 60 dpi: 93 size: 1052x329mm (41.4x13.0")
diag: 1102mm (43.4")
Monitor-2: DP-2 res: 1920x1080 hz: 144 dpi: 128 size: 382x215mm (15.0x8.5")
diag: 438mm (17.3")
OpenGL: renderer: GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus ID: 00:1f.3 chip ID: 8086:a348
Device-2: NVIDIA TU106 High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:10f9
Device-3: C-Media Audio Adapter type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-3.4:7 chip ID: 0d8c:000c
Sound Server: ALSA v: k5.10.2-2-MANJARO
Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel
bus ID: 00:14.3 chip ID: 8086:a370
IF: wlp0s20f3 state: down mac: <filter>
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus ID: 3c:00.0
chip ID: 10ec:8168
IF: enp60s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-28a5ada02005 state: down mac: <filter>
IF-ID-2: br-471d57f337fe state: down mac: <filter>
IF-ID-3: br-492cf1db5d11 state: down mac: <filter>
IF-ID-4: br-4ed8977b4f26 state: down mac: <filter>
IF-ID-5: br-575437368d89 state: down mac: <filter>
IF-ID-6: br-81ea752696cf state: down mac: <filter>
IF-ID-7: br-8e2f0f583274 state: down mac: <filter>
IF-ID-8: br-a9899d2bfe75 state: down mac: <filter>
IF-ID-9: br-b396320647a9 state: down mac: <filter>
IF-ID-10: br-c561c1409b8e state: down mac: <filter>
IF-ID-11: br-cfab67bdf823 state: down mac: <filter>
IF-ID-12: br-d7ea6c69f903 state: down mac: <filter>
IF-ID-13: br-e84008fd8c6c state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-14: br-f7aac0d39dcc state: down mac: <filter>
IF-ID-15: docker0 state: down mac: <filter>
IF-ID-16: veth1badc3b state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-17: veth349eeb9 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-18: veth9e4f7c9 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-19: vethc53d68b state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-20: vethd1effcb state: up speed: 10000 Mbps duplex: full mac: <filter>
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 5020 bus ID: 00:17.0 chip ID: 8086.282a rev: 10
Local Storage: total: 1.84 TiB used: 250.21 GiB (13.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB1T0HBLR-000H1
size: 953.87 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: HPS0NEXF temp: 46.9 C
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Samsung model: PSSD T7 Touch
size: 931.51 GiB block size: physical: 512 B logical: 512 B serial: <filter>
ID-1: / raw size: 575.57 GiB size: 566.28 GiB (98.39%)
used: 107.13 GiB (18.9%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /boot/efi raw size: 4.66 GiB size: 4.65 GiB (99.80%)
used: 280 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
ID-1: swap-1 type: partition size: 19.53 GiB used: 1.05 GiB (5.4%)
priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4
System Temperatures: cpu: 47.0 C mobo: 10.0 C gpu: nvidia temp: 42 C
Processes: 362 Uptime: 10h 23m wakeups: 31 Memory: 15.51 GiB
used: 7.09 GiB (45.7%) Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: 1516 pacman: 1511 lib: 433 flatpak: 0 snap: 5 Shell: fish v: 3.1.2
running in: konsole inxi: 3.2.01
The /etc/X11/mhwd.d/nvidia.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 440.82
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
Option "NoLogo" "1"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Extensions"
Option "COMPOSITE" "Enable"
EndSection
Section "InputClass"
Identifier "Keyboard Defaults"
MatchIsKeyboard "yes"
Option "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
Thanks.
Ok, make a backup of the current config:
sudo cp /etc/X11/mhwd.d/nvidia.conf /etc/X11/mhwd.d/nvidia.conf_BCK
then edit the /etc/X11/mhwd.d/nvidia.conf with kate and paste this content in it:
Screen 0 "Screen0"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "type1"
Load "freetype"
Load "glx"
EndSection
Identifier "Mouse0"
Driver "mouse"
EndSection
Driver "kbd"
EndSection
Section "Monitor"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Device"
Driver "nvidia"
Option "TripleBuffer" "On"
Option "metamodes" "nvidia-auto-select +0+0 {ForceCompositionPipeline = On}
EndSection
Section "Screen"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Depth 24
EndSubSection
EndSection
EndSection
EndSection
Open up terminal and run this command:
echo "export KWIN_TRIPLE_BUFFER=1" | sudo tee /etc/profile.d/kwin.sh
then run:
sudo mhwd-gpu --setmod nvidia --setxorg /etc/X11/mhwd.d/nvidia.conf
then reboot your system:
systemctl reboot
In case you end up with some issue, or black screen, you should be able to restore your backup and remove the file /etc/profile.d/kwin.sh
… or maybe you will have to append to it also another two lines, so it will look like this:
export __GL_YIELD=USLEEP
export __GL_MaxFramesAllowed=1
Then set your compositor like this if you still notice some issues:
After systemctl reboot
everything works well and Kdenlive does not break the compositor.
FYI the font size of the titlebar and Plasma task manager is smaller, in Konsole too.
I will try later to adjust with the “Global scale” option in this settings section, if I see the need to change the font size again:
I hope I can get the same clarity of text as before with that setting.
Thanks!
system
closed
February 3, 2021, 10:09am
#8
