I’'m using a quite old laptop that, once installed Manjaro, came back to life. Unfortunately, after some months of regular use it became always slower and now it is quite hard to use. I have very little knowledge of Linux and I would like to know if there is something wrong in my settings.
In the future, when providing code/output, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text so that the output looks like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.
Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat.
Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur.
Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
instead of like this:
> Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
(as that makes both our lives much easier)
No need to do anything right now as I’m an editor here on this site and have fixed it for you already. However, in the future I might not see your post so review my edits by pushing the orange pencil above the post I just fixed.
What you see it quite normal:a Core2 Duo with 2GB of RAM and a 5400 RPM HDD is just slow nowadays,
However the specifications for a 2089W7X allow for 8GB maximum RAM so I’d try to find that second hand.
I’d also buy a new 256GB SSD and install that inside the machine and hook up the old HDD with a USB cable and adapter and dd everything over.
That way, you should have a brand new machine that will give you another 3-5 years of for about 150€…
P.S. You will not believe what your machine is still capable of after executing #4 and #5 above!
Hi @Krullino and welcome to the forum!
I’m just here to reinforce what @Fabby wrote.
I have a laptop with a dual core, 6th gen core i3 and it originally came with 4gb of ram and a 500gb HDD.
Almost a year ago I got tired with it just being slow and purchased more RAM and an SDD and I’ll tell you: my life changed!
You can’t imagine how much performance you leave behind when you don’t have enough RAM and your HDD is holding you down.
That said, if your computer has a DVD drive and you don’t use it, there are some pretty cool adapters that allow you to fit a second disk in you pc (at the cost of loosing the DVD drive obviously). This way you can use the HDD as a general storage media and have the OS booting from the SSD.
As for your problem, I experienced a similar issue with an old tablet lately and I ended up just reinstalling, but my advice would be to try and clean you system before recurring to drastic measures: check and clean the pacman cache, look for old and unused programs, maybe give pacman a clean following this article on the wiki!
Idk if this would contribute to any kind of slowness or not (e.g. some packages not playing well with an old kernel), but kernel 5.5 has been EOL (end of life) for a year now. You should swap to kernel 5.4 or 5.10
Other than that, like the others have said, more RAM and an SSD would make it much faster than any kernel change.
Just as an addition to what has already been reported by other companions.
I use an even lighter environment and yet the manjaro is somewhat slow on my machine.
However, I do not blame the system in any way, but my hardware, which is the slowest of history, see:
inxi -SMDm
Host: pccreto Kernel: 5.11.14-1-MANJARO x86_64 bits: 64
Desktop: LXQt 0.16.1 Distro: Manjaro Linux
Type: Laptop System: Positivo Informatica SA product: C14RV01
v: 1.00.05_SIM serial: <superuser required>
Mobo: Positivo Informatica SA model: C14RV01 v: SIM
serial: <superuser required> BIOS: American Megatrends v: 1.00.05
date: 10/03/2012
RAM: total: 3.74 GiB used: 1.26 GiB (33.6%)
RAM Report:
Local Storage: total: 298.09 GiB used: 106.34 GiB (35.7%)
ID-1: /dev/sda vendor: Western Digital model: WD3200BPVT-00JJ5T0
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
