/etc/default/grub
GRUB_DEFAULT=saved
GRUB_TIMEOUT=10
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet cryptdevice=UUID=033cd263-32fc-4a40-96ff-8b199aa4502f:luks-033cd263-32fc-4a40-96ff-8b199aa4502f root=/dev/mapper/luks-033cd263-32fc-4a40-96ff-8b199aa4502f resume=/dev/mapper/luks-033cd263-32fc-4a40-96ff-8b199aa4502f apparmor=1 security=apparmor udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
GRUB_DISABLE_OS_PROBER=false
/etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=2343-BC39 /boot/efi vfat umask=0077 0 2
/dev/mapper/luks-033cd263-32fc-4a40-96ff-8b199aa4502f / ext4 defaults,noatime 0 1
# /dev/mapper/luks-9bd2fcd4-1711-415f-a7e1-4a7c712d7b61 swap swap defaults,noatime 0 2
/swapfile none swap defaults 0 0
/etc/mkinitcpio.conf
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run. Advanced users may wish to specify all system modules
# in this array. For instance:
# MODULES=(piix ide_disk reiserfs)
MODULES=""
# BINARIES
# This setting includes any additional binaries a given user may
# wish into the CPIO image. This is run last, so it may be used to
# override the actual binaries included by a given hook
# BINARIES are dependency parsed, so you may safely ignore libraries
BINARIES=()
# FILES
# This setting is similar to BINARIES above, however, files are added
# as-is and are not parsed in any way. This is useful for config files.
FILES="/crypto_keyfile.bin"
# HOOKS
# This is the most important setting in this file. The HOOKS control the
# modules and scripts added to the image, and what happens at boot time.
# Order is important, and it is recommended that you do not change the
# order in which HOOKS are added. Run 'mkinitcpio -H <hook name>' for
# help on a given hook.
# 'base' is _required_ unless you know precisely what you are doing.
# 'udev' is _required_ in order to automatically load modules
# 'filesystems' is _required_ unless you specify your fs modules in MODULES
# Examples:
## This setup specifies all modules in the MODULES setting above.
## No raid, lvm2, or encrypted root is needed.
# HOOKS=(base)
## This setup will autodetect all modules for your system and should
## work as a sane default
# HOOKS=(base udev autodetect block filesystems)
## This setup will generate a 'full' image which supports most systems.
## No autodetection is done.
# HOOKS=(base udev block filesystems)
## This setup assembles a pata mdadm array with an encrypted root FS.
## Note: See 'mkinitcpio -H mdadm' for more information on raid devices.
# HOOKS=(base udev block mdadm encrypt filesystems)
## This setup loads an lvm2 volume group on a usb device.
# HOOKS=(base udev block lvm2 filesystems)
## NOTE: If you have /usr on a separate partition, you MUST include the
# usr, fsck and shutdown hooks.
HOOKS="base udev autodetect modconf block keyboard keymap encrypt openswap resume filesystems"
# COMPRESSION
# Use this to compress the initramfs image. By default, gzip compression
# is used. Use 'cat' to create an uncompressed image.
#COMPRESSION="gzip"
#COMPRESSION="bzip2"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
# COMPRESSION_OPTIONS
# Additional options for the compressor
#COMPRESSION_OPTIONS=()
fdisk -l
Disk /dev/nvme0n1: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: Samsung SSD 980 1TB
I/O size (minimum/optimal): 16384 bytes / 131072 bytes
Disklabel type: gpt
Disk identifier: C8AC9BB9-D616-4544-BAF9-D21AF414F973
Device Start End Sectors Size Type
/dev/nvme0n1p1 4096 618495 614400 300M EFI System
/dev/nvme0n1p2 618496 1953521663 1952903168 931.2G Linux filesystem
Disk /dev/sda: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: CT1000MX500SSD1
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 42529F72-61A6-1A4B-B6F3-A664BC535CF4
/dev/sda1 2048 1953519615 1953517568 931.5G Linux filesystem
Disk /dev/mapper/luks-033cd263-32fc-4a40-96ff-8b199aa4502f: 931.21 GiB, 999884324864 bytes, 1952899072 sectors
Disk /dev/loop0: 55.45 MiB, 58142720 bytes, 113560 sectors
Disk /dev/loop1: 307.58 MiB, 322523136 bytes, 629928 sectors
~~snipped some loop drives~~~
Disk /dev/loop39: 287.32 MiB, 301281280 bytes, 588440 sectors
Disk /dev/mapper/luks-5680c03e-3b5a-4c42-a291-cab5e452dc5a: 931.51 GiB, 1000198897664 bytes, 1953513472 sectors
Disk /dev/sdb: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: Portable SSD T5
I/O size (minimum/optimal): 512 bytes / 33553920 bytes
Disklabel type: dos
Disk identifier: 0x443f523e
Device Boot Start End Sectors Size Id Type
/dev/sdb1 2048 1953522112 1953520065 931.5G 7 HPFS/NTFS/exFAT
blkid
/dev/nvme0n1p1: UUID="2343-BC39" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="b17054e9-ad00-4a89-b674-c784c0dd3187"
/dev/nvme0n1p2: UUID="033cd263-32fc-4a40-96ff-8b199aa4502f" TYPE="crypto_LUKS" PARTUUID="2be654ce-5c5b-4d0e-ae67-19662af07b88"
/dev/sda1: UUID="5680c03e-3b5a-4c42-a291-cab5e452dc5a" TYPE="crypto_LUKS" PARTUUID="b4a44a48-0aa4-da48-85f7-8eb285fa4440"
/dev/mapper/luks-033cd263-32fc-4a40-96ff-8b199aa4502f: UUID="1bf5bf1e-eabc-4e6e-9410-6cc92ea3c86f" BLOCK_SIZE="4096" TYPE="ext4"
/dev/loop0: TYPE="squashfs"
~~~ snipped some loop drives~~~
/dev/loop39: TYPE="squashfs"
/dev/mapper/luks-5680c03e-3b5a-4c42-a291-cab5e452dc5a: UUID="40ad8326-09e7-4155-8473-7c3c588a0e02" BLOCK_SIZE="4096" TYPE="ext4"
/dev/sdb1: LABEL="Samsung_T5" UUID="4E7E-D879" BLOCK_SIZE="512" TYPE="exfat" PARTUUID="443f523e-01
I have commented out the places where the old swap partition was (9bd2fcd4-1711-415f-a7e1-4a7c712d7b61). Grepping the rest of /etc for that uuid i come up empty handed.
