Whenever I play ffxiv with proton my pc freezes whenever anything too intense happens in the game. The freeze is graphical only, as any audio playing prior keeps playing normally without any hiccups of any sort.
inxi output:
System: Kernel: 5.7.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASUSTeK model: PRIME B450M-GAMING/BR v: Rev X.0x serial: <filter> UEFI: American Megatrends
v: 2202 date: 07/14/2020
CPU: Topology: Quad Core model: AMD Ryzen 5 3400G with Radeon Vega Graphics bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 18 (24) stepping: 1 microcode: 8108109 L2 cache: 2048 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 59119
Speed: 2467 MHz min/max: 1400/3700 MHz boost: enabled Core speeds (MHz): 1: 1618 2: 1310 3: 1300 4: 1238 5: 1718
6: 1315 7: 1333 8: 1240
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Picasso vendor: ASUSTeK driver: amdgpu v: kernel bus ID: 09:00.0
chip ID: 1002:15d8
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: amdgpu display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 102 size: 480x270mm (18.9x10.6") diag: 551mm (21.7")
OpenGL: renderer: AMD RAVEN (DRM 3.37.0 5.7.15-1-MANJARO LLVM 10.0.1) v: 4.6 Mesa 20.1.5 direct render: Yes
Journalctl logs:
kernel: [drm:amdgpu_dm_atomic_commit_tail [amdgpu]] *ERROR* Waiting for fences timed out!
kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx timeout, signaled seq=73991, emitted seq=73993
kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process ffxiv_dx11.exe pid 3006 thread ffxiv_dx11:cs0 pid 3021
kernel: AMD-Vi: Completion-Wait loop timed out
kernel: iommu ivhd0: AMD-Vi: Event logged [IOTLB_INV_TIMEOUT device=09:00.0 address=0x40ed89350]
kernel: amdgpu 0000:09:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring kiq_2.1.0 test failed (-110)
