Compiz seg faulting on boot
On boot compiz segfaults, leaving me with no desktop. I have to kill the xserver and re-login to get it to work.
p, li { white-space: pre-wrap; }
-- Logs begin at Sat 2016-10-15 19:38:33 BST, end at Thu 2016-11-03 23:28:56 GMT. --
Nov 03 23:21:30 steve-pc systemd-journald[167]: Runtime journal (/run/log/journal/) is 8.0M, max 395.4M, 387.4M free.
Nov 03 23:21:30 steve-pc systemd-journald[167]: System journal (/var/log/journal/) is 376.0M, max 4.0G, 3.6G free.
Nov 03 23:21:36 steve-pc systemd-journald[167]: Time spent on flushing to /var is 5.922775s for 2 entries.
Nov 03 23:21:36 steve-pc kernel: Linux version 4.9.0-4-MANJARO (builduser@manjaro) (gcc version 6.2.1 20160830 (GCC) ) #1 SMP PREEMPT Thu Nov 3 17:31:28 UTC 2016
Nov 03 23:21:37 steve-pc kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9-x86_64 root=UUID=0042e29a-cf37-442b-8b87-fc5e11a9254f rw quiet splash resume=UUID=8882e411-219b-4243-b87a-86d667967b81
Nov 03 23:21:37 steve-pc kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Nov 03 23:21:37 steve-pc kernel: ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
Nov 03 23:21:37 steve-pc kernel: pmd_set_huge: Cannot satisfy [mem 0xf8000000-0xf8200000] with a huge-page mapping due to MTRR override.
Nov 03 23:21:37 steve-pc kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Nov 03 23:21:37 steve-pc kernel: VFS: Disk quotas dquot_6.6.0
Nov 03 23:21:37 steve-pc kernel: Initialise system trusted keyrings
Nov 03 23:21:37 steve-pc kernel: Key type asymmetric registered
Nov 03 23:21:37 steve-pc kernel: Loading compiled-in X.509 certificates
Nov 03 23:21:37 steve-pc kernel: random: systemd-tmpfile: uninitialized urandom read (16 bytes read)
Nov 03 23:21:37 steve-pc kernel: random: systemd-udevd: uninitialized urandom read (16 bytes read)
Nov 03 23:21:37 steve-pc kernel: random: udevadm: uninitialized urandom read (16 bytes read)
Nov 03 23:21:37 steve-pc kernel: SCSI subsystem initialized
Nov 03 23:21:37 steve-pc kernel: scsi 0:0:0:0: CD-ROM            TSSTcorp CDDVDW SN-208FB  SB00 PQ: 0 ANSI: 5
Nov 03 23:21:37 steve-pc kernel: scsi 5:0:0:0: Direct-Access     ATA      ST2000LM003 HN-M 0001 PQ: 0 ANSI: 5
Nov 03 23:21:37 steve-pc kernel: sd 5:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
Nov 03 23:21:37 steve-pc kernel: sd 5:0:0:0: [sda] 4096-byte physical blocks
Nov 03 23:21:37 steve-pc kernel: sd 5:0:0:0: [sda] Write Protect is off
Nov 03 23:21:37 steve-pc kernel: sd 5:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Nov 03 23:21:37 steve-pc kernel: sd 5:0:0:0: [sda] Attached SCSI disk
Nov 03 23:21:37 steve-pc kernel: random: fast init done
Nov 03 23:21:37 steve-pc kernel: random: crng init done
Nov 03 23:21:37 steve-pc kernel: r8168: loading out-of-tree module taints kernel.
Nov 03 23:21:37 steve-pc kernel: r8168 0000:05:00.2: can't disable ASPM; OS doesn't have ASPM control
Nov 03 23:21:37 steve-pc kernel: r8168  Copyright (C) 2015  Realtek NIC software team <nicfae@realtek.com>
                                  This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
                                  This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
Nov 03 23:21:37 steve-pc systemd[1]: tmp.mount: Directory /tmp to mount over is not empty, mounting anyway.
Nov 03 23:21:37 steve-pc kernel: uvcvideo 3-8:1.0: Entity type for entity Extension 4 was not initialized!
Nov 03 23:21:37 steve-pc kernel: uvcvideo 3-8:1.0: Entity type for entity Processing 2 was not initialized!
Nov 03 23:21:37 steve-pc kernel: uvcvideo 3-8:1.0: Entity type for entity Camera 1 was not initialized!
Nov 03 23:21:37 steve-pc systemd-journald[167]: Journal started
Nov 03 23:21:34 steve-pc systemd-udevd[204]: Process '/usr/bin/tlp auto' failed with exit code 4.
Nov 03 23:21:34 steve-pc systemd-udevd[207]: Process '/usr/bin/set-wireless-regdom' failed with exit code 1.
Nov 03 23:21:36 steve-pc systemd-udevd[206]: Process '/usr/bin/alsactl restore 1' failed with exit code 99.
Nov 03 23:21:38 steve-pc dbus[468]: [system] Successfully activated service 'org.freedesktop.systemd1'
Nov 03 23:21:39 steve-pc dbus[468]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
Nov 03 23:21:39 steve-pc bluetoothd[476]: Failed to obtain handles for "Service Changed" characteristic
Nov 03 23:21:39 steve-pc bluetoothd[476]: Sap driver initialization failed.
Nov 03 23:21:39 steve-pc bluetoothd[476]: sap-server: Operation not permitted (1)
Nov 03 23:21:40 steve-pc dbus[468]: [system] Successfully activated service 'org.freedesktop.hostname1'
Nov 03 23:21:41 steve-pc dbus[468]: [system] Activating via systemd: service name='org.freedesktop.Accounts' unit='accounts-daemon.service'
Nov 03 23:21:42 steve-pc dbus[468]: [system] Activating via systemd: service name='org.freedesktop.ColorManager' unit='colord.service'
Nov 03 23:21:45 steve-pc dbus[468]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service'
Nov 03 23:21:47 steve-pc dbus[468]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Nov 03 23:21:48 steve-pc dbus[468]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service'
Nov 03 23:21:48 steve-pc dbus[468]: [system] Activating via systemd: service name='fi.w1.wpa_supplicant1' unit='wpa_supplicant.service'
Nov 03 23:21:50 steve-pc dbus[468]: [system] Successfully activated service 'fi.w1.wpa_supplicant1'
Nov 03 23:21:50 steve-pc polkitd[577]: Loading rules from directory /etc/polkit-1/rules.d
Nov 03 23:21:50 steve-pc polkitd[577]: Loading rules from directory /usr/share/polkit-1/rules.d
Nov 03 23:21:50 steve-pc polkitd[577]: Finished loading, compiling and executing 7 rules
Nov 03 23:21:50 steve-pc dbus[468]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Nov 03 23:21:50 steve-pc polkitd[577]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Nov 03 23:21:50 steve-pc dbus[468]: [system] Successfully activated service 'org.freedesktop.Accounts'
Nov 03 23:21:54 steve-pc NetworkManager[473]: <warn>  [1478215314.7968] dhcp6 (wlp4s0): hostname is not a FQDN, it will be ignored
Nov 03 23:21:58 steve-pc ntpd[804]: ntpd 4.2.8p8@1.3265-o Sat Jun  4 14:58:28 UTC 2016 (1): Starting
Nov 03 23:21:58 steve-pc dbus[468]: [system] Activating via systemd: service name='org.manjaro.pamac' unit='pamac.service'
Nov 03 23:22:00 steve-pc dbus[468]: [system] Successfully activated service 'org.freedesktop.ColorManager'
Nov 03 23:22:00 steve-pc colord[563]: failed to get session [pid 492]: No such device or address
Nov 03 23:22:02 steve-pc dbus[468]: [system] Successfully activated service 'org.manjaro.pamac'
Nov 03 23:22:15 steve-pc dbus[468]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service'
Nov 03 23:22:15 steve-pc dbus[468]: [system] Successfully activated service 'org.freedesktop.RealtimeKit1'
Nov 03 23:22:15 steve-pc polkitd[577]: Registered Authentication Agent for unix-session:c2 (system bus name :1.33 [/usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1], object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_GB.utf8)
Nov 03 23:22:18 steve-pc dbus[468]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service'
Nov 03 23:22:18 steve-pc udisksd[1151]: udisks daemon version 2.1.7 starting
Nov 03 23:22:18 steve-pc dbus[468]: [system] Successfully activated service 'org.freedesktop.UDisks2'
Nov 03 23:22:18 steve-pc udisksd[1151]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Nov 03 23:22:19 steve-pc dbus[468]: [system] Activating via systemd: service name='org.manjaro.pamac' unit='pamac.service'
Nov 03 23:22:19 steve-pc dbus[468]: [system] Successfully activated service 'org.manjaro.pamac'
Nov 03 23:22:20 steve-pc xfce4-notifyd[1228]: Failed to parse css file: gtk.css:10:14not a number
Nov 03 23:22:20 steve-pc dbus[468]: [system] Activating via systemd: service name='org.freedesktop.UPower' unit='upower.service'
Nov 03 23:22:20 steve-pc dbus[468]: [system] Successfully activated service 'org.freedesktop.UPower'
Nov 03 23:22:20 steve-pc upowerd[1232]: energy_full (49.039800) is greater than energy_full_design (48.840000)
Nov 03 23:22:38 steve-pc dbus[468]: [system] Activating service name='org.blueman.Mechanism' (using servicehelper)
Nov 03 23:22:39 steve-pc org.blueman.Mechanism[468]: Unable to init server: Could not connect: Connection refused
Nov 03 23:22:39 steve-pc dbus[468]: [system] Successfully activated service 'org.blueman.Mechanism'
Nov 03 23:22:39 steve-pc blueman-mechani[1285]: gtk_icon_theme_get_for_screen: assertion 'GDK_IS_SCREEN (screen)' failed
Nov 03 23:22:49 steve-pc kwalletd5[971]: Wallet failed to get opened by PAM, error code is -9
Nov 03 23:23:02 steve-pc systemd-coredump[1465]: Process 1001 (compiz) of user 1000 dumped core.
                                                 Stack trace of thread 1001:
                                                 #0  0x00007fd8b975e04f raise (libc.so.6)
                                                 #1  0x00007fd8b975f47a abort (libc.so.6)
                                                 #2  0x00007fd8b979bc50 __libc_message (libc.so.6)
                                                 #3  0x00007fd8b97a1fe6 malloc_printerr (libc.so.6)
                                                 #4  0x00007fd8b97a27de _int_free (libc.so.6)
                                                 #5  0x00007fd8b9009c6d XDestroyRegion (libX11.so.6)
                                                 #6  0x00007fd8b9760cff __cxa_finalize (libc.so.6)
                                                 #7  0x00007fd8ba0b0193 n/a (libcompiz_core.so.ABI-20151010)
Nov 03 23:23:11 steve-pc copyq[1606]: QXcbConnection: XCB error: 3 (BadWindow), sequence: 177, resource id: 12582917, major code: 20 (GetProperty), minor code: 0
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:135:54: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:166:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc org.gtk.vfs.Daemon[1023]: fusermount: failed to access mountpoint /run/user/1000/gvfs: Permission denied
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:176:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:185:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:192:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:200:71: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:209:73: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:218:72: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:430:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:500:72: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:538:72: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:609:75: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:615:77: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:641:73: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:647:75: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:714:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:1285:60: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:1297:62: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:1349:62: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:1362:72: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:1416:54: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:1427:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:1437:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:1446:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:1455:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:1524:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:1578:74: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:1584:76: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:1610:73: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:1616:75: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:2466:9: Not using units is deprecated. Assuming 'px'.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:2466:9: Expected a string.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:3312:53: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:3342:51: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:3345:53: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:3350:53: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:3350:87: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:3538:8: not a number
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:3538:17: Using Pango syntax for the font: style property is deprecated; please use CSS syntax
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:3877:8: not a number
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:3877:20: Using Pango syntax for the font: style property is deprecated; please use CSS syntax
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:3897:54: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:3905:8: not a number
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:3905:22: Using Pango syntax for the font: style property is deprecated; please use CSS syntax
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:3908:8: not a number
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:3908:28: Using Pango syntax for the font: style property is deprecated; please use CSS syntax
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:3911:8: not a number
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:3911:22: Using Pango syntax for the font: style property is deprecated; please use CSS syntax
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:4316:54: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:4325:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Theme parsing error: gtk.css:4335:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:23:16 steve-pc xfce4-notifyd[1637]: Failed to parse css file: gtk.css:10:14not a number
Nov 03 23:23:22 steve-pc dbus[468]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
Nov 03 23:23:23 steve-pc dbus[468]: [system] Successfully activated service 'org.freedesktop.hostname1'
Nov 03 23:24:29 steve-pc org.a11y.atspi.Registry[1095]: XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server ":0"
Nov 03 23:24:29 steve-pc org.a11y.atspi.Registry[1095]:       after 57 requests (57 known processed) with 0 events remaining.
Nov 03 23:24:29 steve-pc unknown[1228]: xfce4-notifyd: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Nov 03 23:24:29 steve-pc systemd[948]: pulseaudio.service: Main process exited, code=exited, status=1/FAILURE
Nov 03 23:24:29 steve-pc systemd[948]: xfce4-notifyd.service: Main process exited, code=exited, status=1/FAILURE
Nov 03 23:24:29 steve-pc polkitd[577]: Unregistered Authentication Agent for unix-session:c2 (system bus name :1.33, object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_GB.utf8) (disconnected from bus)
Nov 03 23:24:29 steve-pc systemd[948]: xfce4-notifyd.service: Unit entered failed state.
Nov 03 23:24:29 steve-pc systemd[948]: xfce4-notifyd.service: Failed with result 'exit-code'.
Nov 03 23:24:29 steve-pc systemd[948]: pulseaudio.service: Unit entered failed state.
Nov 03 23:24:29 steve-pc systemd[948]: pulseaudio.service: Failed with result 'exit-code'.
Nov 03 23:24:29 steve-pc unknown[1637]: xfce4-notifyd: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.0.
Nov 03 23:24:30 steve-pc systemd-coredump[2254]: Process 1036 (kdeconnectd) of user 1000 dumped core.
                                                 Stack trace of thread 1397:
                                                 #0  0x00007f31762b19cf _ZN7QObject10disconnectEPKS_PKcS1_S3_ (libQt5Core.so.5)
                                                 #1  0x00007f3174d57530 n/a (libQt5DBus.so.5)
                                                 #2  0x00007f3174d43f62 n/a (libQt5DBus.so.5)
                                                 #3  0x00007f31760a7d78 n/a (libQt5Core.so.5)
                                                 #4  0x00007f3171e14454 start_thread (libpthread.so.0)
                                                 #5  0x00007f31759bd7df __clone (libc.so.6)
                                                 Stack trace of thread 1401:
                                                 #0  0x00007f31759b448d poll (libc.so.6)
                                                 #1  0x00007f317037f786 n/a (libglib-2.0.so.0)
                                                 #2  0x00007f317037f89c g_main_context_iteration (libglib-2.0.so.0)
                                                 #3  0x00007f31762d670f _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5)
                                                 #4  0x00007f317628023a _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5)
                                                 #5  0x00007f31760a30f3 _ZN7QThread4execEv (libQt5Core.so.5)
                                                 #6  0x00007f31760a7d78 n/a (libQt5Core.so.5)
                                                 #7  0x00007f3171e14454 start_thread (libpthread.so.0)
                                                 #8  0x00007f31759bd7df __clone (libc.so.6)
                                                 Stack trace of thread 1036:
                                                 #0  0x00007f3171e1a10f pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0)
                                                 #1  0x00007f31760a8c2b _ZN14QWaitCondition4waitEP6QMutexm (libQt5Core.so.5)
                                                 #2  0x00007f31760a791e _ZN7QThread4waitEm (libQt5Core.so.5)
                                                 #3  0x00007f3174d43cc6 n/a (libQt5DBus.so.5)
                                                 #4  0x00007f3174d43d59 n/a (libQt5DBus.so.5)
                                                 #5  0x00007f317590a990 __run_exit_handlers (libc.so.6)
                                                 #6  0x00007f317590a9ea exit (libc.so.6)
                                                 #7  0x00007f315659c74f n/a (libgdk-x11-2.0.so.0)
                                                 #8  0x00007f317293b7ae _XIOError (libX11.so.6)
                                                 #9  0x00007f31729397f3 _XReply (libX11.so.6)
                                                 #10 0x00007f317291fc31 XGetSelectionOwner (libX11.so.6)
                                                 #11 0x00007f31565ac4de n/a (libgdk-x11-2.0.so.0)
                                                 #12 0x00007f31565ac881 n/a (libgdk-x11-2.0.so.0)
                                                 #13 0x00007f3156592173 n/a (libgdk-x11-2.0.so.0)
                                                 #14 0x00007f31565926a1 n/a (libgdk-x11-2.0.so.0)
                                                 #15 0x00007f3156593a66 n/a (libgdk-x11-2.0.so.0)
                                                 #16 0x00007f3156595396 n/a (libgdk-x11-2.0.so.0)
                                                 #17 0x00007f315659543e n/a (libgdk-x11-2.0.so.0)
                                                 #18 0x00007f317037f587 g_main_context_dispatch (libglib-2.0.so.0)
                                                 #19 0x00007f317037f7f0 n/a (libglib-2.0.so.0)
                                                 #20 0x00007f317037f89c g_main_context_iteration (libglib-2.0.so.0)
                                                 #21 0x00007f31762d670f _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5)
                                                 #22 0x00007f317628023a _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5)
                                                 #23 0x00007f317628873c _ZN16QCoreApplication4execEv (libQt5Core.so.5)
                                                 #24 0x0000000000401e62 n/a (kdeconnectd)
                                                 #25 0x00007f31758f5291 __libc_start_main (libc.so.6)
                                                 #26 0x0000000000401eca _start (kdeconnectd)
Nov 03 23:24:34 steve-pc kwalletd5[2381]: Wallet failed to get opened by PAM, error code is -9
Nov 03 23:24:34 steve-pc xfce4-notifyd[2492]: Failed to parse css file: gtk.css:10:14not a number
Nov 03 23:24:34 steve-pc dbus[468]: [system] Activating via systemd: service name='org.manjaro.pamac' unit='pamac.service'
Nov 03 23:24:34 steve-pc polkitd[577]: Registered Authentication Agent for unix-session:c4 (system bus name :1.76 [/usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1], object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_GB.utf8)
Nov 03 23:24:34 steve-pc dbus[468]: [system] Successfully activated service 'org.manjaro.pamac'
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:135:54: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:166:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:176:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:185:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:192:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:200:71: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:209:73: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:218:72: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:430:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:500:72: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:538:72: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:609:75: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:615:77: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:641:73: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:647:75: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:714:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:1285:60: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:1297:62: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:1349:62: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:1362:72: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:1416:54: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:1427:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:1437:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:1446:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:1455:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:1524:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:1578:74: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:1584:76: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:1610:73: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:1616:75: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:2466:9: Not using units is deprecated. Assuming 'px'.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:2466:9: Expected a string.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:3312:53: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:3342:51: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:3345:53: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:3350:53: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:3350:87: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:3538:8: not a number
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:3538:17: Using Pango syntax for the font: style property is deprecated; please use CSS syntax
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:3877:8: not a number
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:3877:20: Using Pango syntax for the font: style property is deprecated; please use CSS syntax
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:3897:54: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:3905:8: not a number
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:3905:22: Using Pango syntax for the font: style property is deprecated; please use CSS syntax
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:3908:8: not a number
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:3908:28: Using Pango syntax for the font: style property is deprecated; please use CSS syntax
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:3911:8: not a number
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:3911:22: Using Pango syntax for the font: style property is deprecated; please use CSS syntax
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:4316:54: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:4325:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Theme parsing error: gtk.css:4335:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:34 steve-pc cinnamon-screen[2498]: Couldn't get presence status: The name org.gnome.SessionManager was not provided by any .service files
Nov 03 23:24:36 steve-pc dbus[468]: [system] Activating service name='org.blueman.Mechanism' (using servicehelper)
Nov 03 23:24:36 steve-pc org.blueman.Mechanism[468]: Unable to init server: Could not connect: Connection refused
Nov 03 23:24:36 steve-pc dbus[468]: [system] Successfully activated service 'org.blueman.Mechanism'
Nov 03 23:24:36 steve-pc blueman-mechani[3007]: gtk_icon_theme_get_for_screen: assertion 'GDK_IS_SCREEN (screen)' failed
Nov 03 23:24:37 steve-pc copyq[2438]: QXcbWindow: Unhandled client message: "WM_S0"
Nov 03 23:24:37 steve-pc copyq[2438]: QXcbWindow: Unhandled client message: "_NET_WM_CM_S0"
Nov 03 23:24:37 steve-pc copyq[2438]: QXcbWindow: Unhandled client message: "COMPOSITING_MANAGER"
Nov 03 23:24:37 steve-pc copyq[2438]: QXcbWindow: Unhandled client message: "XFWM4_COMPOSITING_MANAGER"
Nov 03 23:24:37 steve-pc dbus[468]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
Nov 03 23:24:37 steve-pc dbus[468]: [system] Successfully activated service 'org.freedesktop.hostname1'
Nov 03 23:24:37 steve-pc systemd-coredump[3014]: Process 2414 (compiz) of user 1000 dumped core.
                                                 Stack trace of thread 2414:
                                                 #0  0x00007fee9d9a704f raise (libc.so.6)
                                                 #1  0x00007fee9d9a847a abort (libc.so.6)
                                                 #2  0x00007fee9d9e4c50 __libc_message (libc.so.6)
                                                 #3  0x00007fee9d9eafe6 malloc_printerr (libc.so.6)
                                                 #4  0x00007fee9d9eb7de _int_free (libc.so.6)
                                                 #5  0x00007fee9d252c75 XDestroyRegion (libX11.so.6)
                                                 #6  0x00007fee9d9a9cff __cxa_finalize (libc.so.6)
                                                 #7  0x00007fee9e2f9193 n/a (libcompiz_core.so.ABI-20151010)
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:135:54: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:166:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc org.gtk.vfs.Daemon[2448]: fusermount: failed to access mountpoint /run/user/1000/gvfs: Permission denied
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:176:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:185:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:192:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc org.a11y.Bus[2448]: Activating service name='org.a11y.atspi.Registry'
Nov 03 23:24:38 steve-pc org.a11y.Bus[2448]: Successfully activated service 'org.a11y.atspi.Registry'
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:200:71: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:209:73: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:218:72: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:430:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:500:72: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:538:72: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:609:75: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:615:77: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:641:73: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:647:75: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:714:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:1285:60: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:1297:62: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:1349:62: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:1362:72: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:1416:54: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:1427:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:1437:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:1446:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:1455:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:1524:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:1578:74: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:1584:76: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:1610:73: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:1616:75: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:2466:9: Not using units is deprecated. Assuming 'px'.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:2466:9: Expected a string.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:3312:53: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:3342:51: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:3345:53: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:3350:53: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:3350:87: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:3538:8: not a number
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:3538:17: Using Pango syntax for the font: style property is deprecated; please use CSS syntax
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:3877:8: not a number
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:3877:20: Using Pango syntax for the font: style property is deprecated; please use CSS syntax
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:3897:54: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:3905:8: not a number
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:3905:22: Using Pango syntax for the font: style property is deprecated; please use CSS syntax
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:3908:8: not a number
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:3908:28: Using Pango syntax for the font: style property is deprecated; please use CSS syntax
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:3911:8: not a number
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:3911:22: Using Pango syntax for the font: style property is deprecated; please use CSS syntax
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:4316:54: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:4325:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Theme parsing error: gtk.css:4335:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:24:38 steve-pc xfce4-notifyd[3106]: Failed to parse css file: gtk.css:10:14not a number
Nov 03 23:28:34 steve-pc sudo[3864]:    steve : TTY=pts/1 ; PWD=/home/steve ; USER=root ; COMMAND=/usr/bin/systemctl restart NetworkManager
Nov 03 23:28:34 steve-pc dbus[468]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service'
Nov 03 23:28:34 steve-pc dbus[468]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Nov 03 23:28:34 steve-pc ntpd[829]: ntpd exiting on signal 15 (Terminated)
Nov 03 23:28:35 steve-pc dbus[468]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
Nov 03 23:28:35 steve-pc dbus[468]: [system] Successfully activated service 'org.freedesktop.hostname1'
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:135:54: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:166:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:176:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:185:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:192:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:200:71: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:209:73: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:218:72: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:430:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:500:72: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:538:72: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:609:75: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:615:77: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:641:73: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:647:75: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:714:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:1285:60: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:1297:62: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:1349:62: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:1362:72: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:1416:54: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:1427:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:1437:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:1446:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:1455:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:1524:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:1578:74: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:1584:76: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:1610:73: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:1616:75: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:2466:9: Not using units is deprecated. Assuming 'px'.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:2466:9: Expected a string.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:3312:53: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:3342:51: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:3345:53: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:3350:53: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:3350:87: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:3538:8: not a number
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:3538:17: Using Pango syntax for the font: style property is deprecated; please use CSS syntax
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:3877:8: not a number
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:3877:20: Using Pango syntax for the font: style property is deprecated; please use CSS syntax
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:3897:54: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:3905:8: not a number
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:3905:22: Using Pango syntax for the font: style property is deprecated; please use CSS syntax
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:3908:8: not a number
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:3908:28: Using Pango syntax for the font: style property is deprecated; please use CSS syntax
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:3911:8: not a number
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:3911:22: Using Pango syntax for the font: style property is deprecated; please use CSS syntax
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:4316:54: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:4325:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:35 steve-pc xfce4-notifyd[2492]: Theme parsing error: gtk.css:4335:56: Using one color stop with linear-gradient() is deprecated.
Nov 03 23:28:36 steve-pc ntpd[4118]: ntpd 4.2.8p8@1.3265-o Sat Jun  4 14:58:28 UTC 2016 (1): Starting
Nov 03 23:28:36 steve-pc ntpd[4120]: bind(21) AF_INET6 fe80::691d:1376:a585:a041%3#123 flags 0x11 failed: Cannot assign requested address
Nov 03 23:28:36 steve-pc ntpd[4120]: unable to create socket on wlp4s0 (5) for fe80::691d:1376:a585:a041%3#123
Nov 03 23:28:36 steve-pc dbus[468]: [system] Activating via systemd: service name='org.manjaro.pamac' unit='pamac.service'
Nov 03 23:28:36 steve-pc dbus[468]: [system] Successfully activated service 'org.manjaro.pamac'
Nov 03 23:28:37 steve-pc ntpd[4120]: bind(24) AF_INET6 fe80::691d:1376:a585:a041%3#123 flags 0x11 failed: Cannot assign requested address
Nov 03 23:28:37 steve-pc ntpd[4120]: unable to create socket on wlp4s0 (6) for fe80::691d:1376:a585:a041%3#123
Nov 03 23:28:37 steve-pc NetworkManager[3959]: <warn>  [1478215717.6100] dhcp6 (wlp4s0): hostname is not a FQDN, it will be ignored
Nov 03 23:28:38 steve-pc dbus[468]: [system] Activating via systemd: service name='org.manjaro.pamac' unit='pamac.service'
Nov 03 23:28:38 steve-pc dbus[468]: [system] Successfully activated service 'org.manjaro.pamac'
Nov 03 23:28:42 steve-pc sudo[4269]:    steve : TTY=pts/1 ; PWD=/home/steve ; USER=root ; COMMAND=/usr/bin/systemctl restart NetworkManager
Nov 03 23:28:42 steve-pc ntpd[4120]: ntpd exiting on signal 15 (Terminated)
Nov 03 23:28:43 steve-pc ntpd[4506]: ntpd 4.2.8p8@1.3265-o Sat Jun  4 14:58:28 UTC 2016 (1): Starting
Nov 03 23:28:43 steve-pc ntpd[4508]: bind(21) AF_INET6 fe80::691d:1376:a585:a041%3#123 flags 0x11 failed: Cannot assign requested address
Nov 03 23:28:43 steve-pc ntpd[4508]: unable to create socket on wlp4s0 (5) for fe80::691d:1376:a585:a041%3#123
Nov 03 23:28:43 steve-pc dbus[468]: [system] Activating via systemd: service name='org.manjaro.pamac' unit='pamac.service'
Nov 03 23:28:43 steve-pc dbus[468]: [system] Successfully activated service 'org.manjaro.pamac'
Nov 03 23:28:44 steve-pc ntpd[4508]: bind(24) AF_INET6 fe80::691d:1376:a585:a041%3#123 flags 0x11 failed: Cannot assign requested address
Nov 03 23:28:44 steve-pc ntpd[4508]: unable to create socket on wlp4s0 (6) for fe80::691d:1376:a585:a041%3#123
Nov 03 23:28:45 steve-pc dbus[468]: [system] Activating via systemd: service name='org.manjaro.pamac' unit='pamac.service'
Nov 03 23:28:45 steve-pc dbus[468]: [system] Successfully activated service 'org.manjaro.pamac'
Nov 03 23:28:45 steve-pc NetworkManager[4357]: <warn>  [1478215725.5981] dhcp6 (wlp4s0): hostname is not a FQDN, it will be ignored
Nov 03 23:28:49 steve-pc sudo[4659]:    steve : TTY=pts/1 ; PWD=/home/steve ; USER=root ; COMMAND=/usr/bin/systemctl restart NetworkManager
Nov 03 23:28:49 steve-pc ntpd[4508]: ntpd exiting on signal 15 (Terminated)
Nov 03 23:28:50 steve-pc ntpd[4895]: ntpd 4.2.8p8@1.3265-o Sat Jun  4 14:58:28 UTC 2016 (1): Starting
Nov 03 23:28:50 steve-pc ntpd[4897]: bind(21) AF_INET6 fe80::691d:1376:a585:a041%3#123 flags 0x11 failed: Cannot assign requested address
Nov 03 23:28:50 steve-pc ntpd[4897]: unable to create socket on wlp4s0 (5) for fe80::691d:1376:a585:a041%3#123
Nov 03 23:28:50 steve-pc dbus[468]: [system] Activating via systemd: service name='org.manjaro.pamac' unit='pamac.service'
Nov 03 23:28:50 steve-pc dbus[468]: [system] Successfully activated service 'org.manjaro.pamac'
Nov 03 23:28:51 steve-pc ntpd[4897]: bind(24) AF_INET6 fe80::691d:1376:a585:a041%3#123 flags 0x11 failed: Cannot assign requested address
Nov 03 23:28:51 steve-pc ntpd[4897]: unable to create socket on wlp4s0 (6) for fe80::691d:1376:a585:a041%3#123
Nov 03 23:28:52 steve-pc dbus[468]: [system] Activating via systemd: service name='org.manjaro.pamac' unit='pamac.service'
Nov 03 23:28:52 steve-pc dbus[468]: [system] Successfully activated service 'org.manjaro.pamac'
Nov 03 23:28:53 steve-pc sudo[5048]:    steve : TTY=pts/1 ; PWD=/home/steve ; USER=root ; COMMAND=/usr/bin/systemctl restart NetworkManager
Nov 03 23:28:54 steve-pc ntpd[4897]: ntpd exiting on signal 15 (Terminated)
Nov 03 23:28:55 steve-pc ntpd[5248]: ntpd 4.2.8p8@1.3265-o Sat Jun  4 14:58:28 UTC 2016 (1): Starting
Nov 03 23:28:55 steve-pc ntpd[5250]: bind(21) AF_INET6 fe80::691d:1376:a585:a041%3#123 flags 0x11 failed: Cannot assign requested address
Nov 03 23:28:55 steve-pc ntpd[5250]: unable to create socket on wlp4s0 (5) for fe80::691d:1376:a585:a041%3#123
Nov 03 23:28:55 steve-pc dbus[468]: [system] Activating via systemd: service name='org.manjaro.pamac' unit='pamac.service'
Nov 03 23:28:55 steve-pc dbus[468]: [system] Successfully activated service 'org.manjaro.pamac'
Nov 03 23:28:56 steve-pc ntpd[5250]: bind(24) AF_INET6 fe80::691d:1376:a585:a041%3#123 flags 0x11 failed: Cannot assign requested address
Nov 03 23:28:56 steve-pc ntpd[5250]: unable to create socket on wlp4s0 (6) for fe80::691d:1376:a585:a041%3#123
Nov 03 23:28:56 steve-pc NetworkManager[5098]: <warn>  [1478215736.6564] dhcp6 (wlp4s0): hostname is not a FQDN, it will be ignored
Nov 03 23:28:56 steve-pc dbus[468]: [system] Activating via systemd: service name='org.manjaro.pamac' unit='pamac.service'
Nov 03 23:28:56 steve-pc dbus[468]: [system] Successfully activated service 'org.manjaro.pamac'
Only happened since last compiz update.
Then downgrade compiz.
J.
I have.
