Compiz for pinebook?
Is it possible to install compiz on pinebook with manjaro-arm?
I see pinebook is OpenGL ES2 compatible...
Any tips?
You would have to use the AUR package and edit the PKGBUILD to include aarch64 architecture.
But otherwise, should be possible.
ufff, sounds too complicated ;(
This line:
arch=('i686' 'x86_64')
Just needs to be changed to this line:
arch=('i686' 'x86_64' 'aarch64')
and it should work with a regular makepkg -sci command after that.
I'm reading this, How to install Compiz-Reloaded on Manjaro?
Thanks for info, I'll investigate it XD
This topic was automatically closed after 90 days. New replies are no longer allowed.
