During use of Libre Office Writer on many occasions, there are keyboard issues. At one point, the keyboard began typing repeated the same key ‘h’ and continued filling other text boxes, such as when attempting to use the terminal to kill the program. (the mouse worked and was able to click into the Manjaro’s menu but the text box within was affected.) A reboot proved that the keyboard issue was not mechanical. After changing a setting in Manjaro for how text is typed in- someplace in the settings, Libra OfficeWriter after a certain point of text entry, stutters. Doing a save helps with the first occurrence but there after, after perhaps another page of text is typed, the keyboard stops working. The mouse still works but the keyboard remains non-working and unavailable to the system or any other application–such as the Logout, Login- type password feature. Rebooting resolves the issue. The issue is not present in a different Debian based OS on another partition. The system run on an HP Pavilion laptop, g-series with (EDIT: STRIKE 8 Gig. ) 4 Gig of RAM and a SWAP partition of 16 Gig.
Kernel: 5.16.14-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=46588cb5-04db-479e-b013-ff344795af33 rw quiet apparmor=1
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Hewlett-Packard product: HP Pavilion g7 Notebook PC
v: 058F100014204610000620100 serial: <filter> Chassis: type: 10 serial: N/A
Mobo: Hewlett-Packard model: 166A v: 08.38 serial: <filter> BIOS: Insyde
v: F.63 date: 03/22/2012
RAM: total: 3.63 GiB used: 1.91 GiB (52.5%)
Array-1: capacity: 8 GiB slots: 2 EC: None max-module-size: 4 GiB
note: est.
Device-1: Bottom - Slot 1 size: No Module Installed
Device-2: Bottom - Slot 2 size: 4 GiB speed: 1067 MT/s type: DDR3
detail: synchronous bus-width: 64 bits total: 64 bits manufacturer: Samsung
part-no: M471B5273DH0-CH9 serial: <filter>
Info: model: Intel Core i3 M 380 bits: 64 type: MT MCP arch: Westmere
family: 6 model-id: 0x25 (37) stepping: 5 microcode: 0x7
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 933 min/max: 933/2533 base/boost: 2533/2533 scaling:
driver: acpi-cpufreq governor: schedutil volts: 0.0 V ext-clock: 1066 MHz
cores: 1: 933 2: 933 3: 933 4: 933 bogomips: 20225
Flags: acpi aperfmperf apic arat arch_perfmon bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts est flush_l1d fpu
fxsr ht ibpb ibrs lahf_lm lm mca mce mmx monitor msr mtrr nonstop_tsc nopl
nx pae pat pbe pcid pdcm pebs pge pni popcnt pse pse36 pti rdtscp rep_good
sep ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc vme
xtopology xtpr
Type: itlb_multihit status: KVM: VMX unsupported
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
Device-1: Intel Core Processor Integrated Graphics vendor: Hewlett-Packard
driver: i915 v: kernel ports: active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0046 class-ID: 0300
Device-2: Chicony HP Webcam-101 type: USB driver: uvcvideo bus-ID: 2-1.5:3
chip-ID: 04f2:b293 class-ID: 0e02 serial: <filter>
Display: server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
s-diag: 485mm (19.11")
Monitor-1: LVDS-1 model: LG Display 0x027a built: 2009 res: 1600x900
hz: 60 dpi: 106 gamma: 1.2 size: 382x215mm (15.04x8.46") diag: 438mm (17.3")
ratio: 16:9 modes: 1600x900
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel 5 Series/3400 Series High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:3b56 class-ID: 0403
Sound Server-1: ALSA v: k5.16.14-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
Device-1: Realtek RTL8188CE 802.11b/g/n WiFi Adapter vendor: Hewlett-Packard
driver: rtl8192ce v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000
bus-ID: 02:00.0 chip-ID: 10ec:8176 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200
Local Storage: total: 465.76 GiB used: 23.64 GiB (5.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD5000BPKX-22HPJT0 family: Black Mobile size: 465.76 GiB block-size:
physical: 4096 B logical: 512 B sata: 3.0 speed: 3.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: 1A01 temp: 41 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 4y 318d 14h cycles: 94
Optical-1: /dev/sr0 vendor: hp model: DVD RW AD-7711H rev: 1.81
dev-links: cdrom
ID-1: / raw-size: 302.09 GiB size: 296.28 GiB (98.08%)
used: 23.64 GiB (8.0%) fs: ext4 block-size: 4096 B dev: /dev/sda3
maj-min: 8:3 label: N/A uuid: 46588cb5-04db-479e-b013-ff344795af33
ID-1: swap-1 type: partition size: 15.23 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: a5ade7db-8e54-4739-ba69-55a274ec42ce
ID-1: /dev/sda2 maj-min: 8:2 size: 148.44 GiB fs: reiserfs label: N/A
uuid: 18ea01c6-7a08-4414-b83f-fb54f90e58d3
Hub-1: 1-0:1 info: Full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0020 class-ID: 0900
Device-1: 1-1.1:3 info: Pixart Imaging Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 093a:2510 class-ID: 0301
Hub-3: 2-0:1 info: Full speed or root hub ports: 3 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.5:3 info: Chicony HP Webcam-101 type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b293
System Temperatures: cpu: 56.0 C mobo: N/A
Processes: 184 Uptime: 53m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1495 lib: 367
flatpak: 0 Shell: Bash (sudo) v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.14
AMENDMENT:
Yesterday while writing to the forum (and during a chat on another webpage based customer support) using Chromium, the keyboard stopped typing 5-6x and required reboot. So my bad: Libre happened to be where I’d typed the most- I can get about 2 pages typed b4 kb quits. The error seemed character limited but later the keyboard stuttered entering a search term. There was no text output.
Mouse clicking my way to shutdown, meant to close an open terminal but opened a new terminal by mistake. The new terminal loaded slower and a bit of flicker to it So I typed a key and the KB functioned! On Return to the browser, the KB worked, too. But not long after it stopped again. My new terminal “trick” did not work and I had to shutdown. Just “Restart” (but not POWER OFF COMPLETE Shutdown) does not work always. “Logout” “Login” does not work.
I thought maybe a timed malicious code- or cron job but didn’t know how to see crontabs in Manjaro.
I thot there was something with an hourly amror (I don’t recall the spelling) running, that I saw (i forget where). Unless I have top running I can’t get to it after the malfunction. I’ve tried different kernels. This was all I could come up with to see if any job was occurring:
systemctl status cronie
● cronie.service - Periodic Command Scheduler
Loaded: loaded (/usr/lib/systemd/system/cronie.service; enabled; vendor pr>
Active: active (running) since Thu 2022-04-07 11:07:37 EDT; 55min ago
Main PID: 450 (crond)
Tasks: 1 (limit: 4441)
Memory: 580.0K
CPU: 34ms
CGroup: /system.slice/cronie.service
└─450 /usr/bin/crond -n
Apr 07 11:07:37 nobody systemd[1]: Started Periodic Command Scheduler.
Apr 07 11:07:37 nobody crond[450]: (CRON) STARTUP (1.5.7)
Apr 07 11:07:37 nobody crond[450]: (CRON) INFO (Syslog will be used instead of >
Apr 07 11:07:37 nobody crond[450]: (CRON) INFO (RANDOM_DELAY will be scaled wit>
Apr 07 11:07:37 nobody crond[450]: (CRON) INFO (running with inotify support)
Apr 07 12:01:01 nobody CROND[6961]: (root) CMD (run-parts /etc/cron.hourly)
Apr 07 12:01:01 nobody CROND[6960]: (root) CMDEND (run-parts /etc/cron.hourly)
lines 1-17/17 (END)
