Hi all.
I’m trying to figure out a way to compile a reverse enginering driver created fot this capture card.
I’m aware of the riscs and warning about how this IS a bad ideia and etc. But I aprecciate all help.
I don’t have too much experience with linux and none with compiling anything else from AUR with YAY or similar helper.
Like a noob, I’ve followed the basic ideia of a git “regular installation”:
git clone https://github.com/stoth68000/sc0710
cd sc0710
make
make install
A childsh hope of a miraculous solution, but it doesn’t work.
[EDITED: forgot to comment about SUDO]
SUDO MAKE or MAKE output:
make -C /lib/modules/5.18.6-1-MANJARO/build M=/home/gits/sc0710 modules
make[1]: Entrando no diretório '/usr/lib/modules/5.18.6-1-MANJARO/build'
CC [M] /home/gits/sc0710/sc0710-cards.o
CC [M] /home/gits/sc0710/sc0710-core.o
CC [M] /home/gits/sc0710/sc0710-i2c.o
/home/gits/sc0710/sc0710-i2c.c: In function ‘sc0710_i2c_read_hdmi_status’:
/home/gits/sc0710/sc0710-i2c.c:177:13: warning: unused variable ‘i’ [-Wunused-variable]
177 | int i;
CC [M] /home/gits/sc0710/sc0710-dma-channel.o
/home/gits/sc0710/sc0710-dma-channel.c: In function ‘sc0710_dma_channel_alloc’:
/home/gits/sc0710/sc0710-dma-channel.c:428:22: error: implicit declaration of function ‘pci_alloc_consistent’ [-Werror=implicit-function-declaration]
428 | ch->pt_cpu = pci_alloc_consistent(dev->pci, ch->pt_size, &ch->pt_dma);
/home/gits/sc0710/sc0710-dma-channel.c:428:20: warning: assignment to ‘u64 *’ {aka ‘long long unsigned int *’} from ‘int’ makes pointer from integer without a cast [-Wint-conversion]
/home/gits/sc0710/sc0710-dma-channel.c: In function ‘sc0710_dma_channel_resize’:
/home/gits/sc0710/sc0710-dma-channel.c:532:20: warning: assignment to ‘u64 *’ {aka ‘long long unsigned int *’} from ‘int’ makes pointer from integer without a cast [-Wint-conversion]
532 | ch->pt_cpu = pci_alloc_consistent(dev->pci, ch->pt_size, &ch->pt_dma);
cc1: some warnings being treated as errors
make[2]: *** [scripts/Makefile.build:288: /home/gits/sc0710/sc0710-dma-channel.o] Erro 1
make[1]: *** [Makefile:1838: /home/gits/sc0710] Erro 2
make[1]: Saindo do diretório '/usr/lib/modules/5.18.6-1-MANJARO/build'
make: *** [Makefile:14: all] Erro 2
SUDO MAKE INSTALL or MAKE INSTALL outup:
make: *** no rule to process the target 'install' . Stop
(this is a translated output, since my system doens’t run in english).
PCI card is installed on PCI port, but no ideia if is listened or not.
MHWD -LA output:
> All PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-prime 2021.12.18 false PCI
video-nvidia-470xx 2021.12.18 false PCI
video-vesa 2017.03.12 true PCI
video-rendition 2020.01.18 true PCI
video-openchrome 2020.01.18 true PCI
video-virtualmachine 2021.07.26 true PCI
video-voodoo 2017.03.12 true PCI
video-s3 2020.01.18 true PCI
video-nvidia-390xx 2021.12.18 false PCI
video-hybrid-amd-nvidia-470xx-prime 2021.12.18 false PCI
video-hybrid-amd-nvidia-prime 2021.12.18 false PCI
video-nvidia 2021.12.18 false PCI
video-hybrid-intel-nvidia-470xx-prime 2021.12.18 false PCI
video-modesetting 2020.01.13 true PCI
video-sisusb 2020.01.18 true PCI
video-hybrid-intel-nvidia-390xx-bumblebee 2021.12.18 false PCI
network-rt3562sta 2013.12.07 true PCI
network-slmodem 2013.12.07 true PCI
network-broadcom-wl 2018.10.07 false PCI
network-r8168 2016.04.20 true PCI
Warning: No USB configs found!
Any help is welcome, and of course, if this is the wrong way to compile a driver, I’ll accept instructions.
TY.
