Hi!
I have not succeeded to run a .jnlp file. I have already installed the OpenJDK, Iced Tea and its dependency (rhino). After the installation I have tried to run the file via Konsole using the javaws command or double-clicking the file (what prompts the IcedTea)… but it clashes… I have been google searching the matter and it seems there is not a (easy) solution.
I am a brand new user of Manjaro migrating from a RPM based linux distro. If I do not solve this problem I will need to migrate back because this is the environment I need to home office…
net.sourceforge.jnlp.LaunchException: Fatal: Launch Error: Could not launch JNLP file. The application has not been initialized, for more information execute javaws/browser from the command line and send a bug report.
at net.sourceforge.jnlp.Launcher.launchApplication(Launcher.java:582)
at net.sourceforge.jnlp.Launcher$TgThread.run(Launcher.java:945)
Caused by: java.lang.reflect.InvocationTargetException
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at net.sourceforge.jnlp.Launcher.launchApplication(Launcher.java:576)
... 1 more
Caused by: java.lang.Error: unsupported deployment environment
at hob.jws.a.<init>(Unknown Source)
at hob.jws.AppletLauncher.main(Unknown Source)
... 6 more
You didn’t answer my first question. Without knowing what exactly you’re running, it’s a little hard to help.
It sounds like you’re running an older application that requires an older version of Java. The current OpenJDK version is 15. I would try 8 to be safe.
Hi! Unfortunately it did not work. I am trying to run a remote office app that prompts the HOBjwt… this is my limited knowledge about it once it is a proprietary app. I currently running it in another distro that allows me to download and install the java from Oracle website… my this be a solution in this case?!
Note: I am not a tech guy or programmer… just a Linux enthusiastic using linux distro desktops for the last 13 years.
It is called remote office and it generates a default.jnlp file. The distro is Mageia 7.1 with Java version 8 update 281 downloaded as RPM directly from Oracle website.
The HOBjwt prompts an screen for virtually login in my PC at the office.
Often work applications are designed specifically for a certain OS / framework version and that’s it. If you need something stable and reliable for work, maybe a bleeding edge. rolling release distro isn’t for you.
