$ pamac info grub
Version : 2:2.16-4
Description : GNU GRand Unified Bootloader (2)
Packager : Mark Wagie <mark@manjaro.org>
Build Date : Wed 28 Oct 2026 16:00:12 GMT
Install Date : Fri 30 Oct 2026 14:49:44 GMT
$ ls -l /usr/share/info/grub*
-rw-r--r-- 1 root root 39941 Oct 28 16:00 /usr/share/info/grub-dev.info.gz
-rw-r--r-- 1 root root 81660 Oct 28 16:00 /usr/share/info/grub.info-1.gz
-rw-r--r-- 1 root root 70270 Oct 28 16:00 /usr/share/info/grub.info-2.gz
-rw-r--r-- 1 root root 6836 Oct 28 16:00 /usr/share/info/grub.info.gz
There’s also manjaro-pacnew-checker in the official repo that works very well when pacnew files are installed.One can check the diffs and if confused on what to merge that’s what the forum is for to ask.
According to my pacman.loggrub-2.16-3 was the first 2.16 grub to hit testing branch; and that one has the relevant sections in the info pages, and for posterity sake so does the grub-2.16-1 package.
I always forget that info is there. It (generally) contains vast amounts of information and history. Being an archaeology nerd I see no problems with either of those things, but I wish that the info system had a bit of “memory” so it would remember where you left off if you open the same section again; especially for something as large as the grub info docs.
For example like Okular does when it saves metadata files in its settings directory, so if you open the same PDF file once, scroll down a bit and later re-opening the same file, you will find that it shows you the page where you left off. At least for as long as the PDF is still named as it once was.
It’s very useful, but could be a security hazard also. As far as I know, it doesn’t distinguish between harmless kids’ storybooks and company secrets, where the mere fact that you have evidence of a file having been stored on your computer might be considered a security flaw.
