Any attempt to call wireguard, through zsh or bash, returns (shell): command not found: wireguard
I’m using linux519 kernel, and have wireguard-tools installed.
“modprobe wireguard” returns nothing
I’ve already looked through this. wireguard-tools is installed, wireguard is built into the kenel post 5.6, wg-quick works but calls wireguard and outputs command not found: wireguard, and modprobe finds wireguard already. The issue isn’t wireguard itself, it’s that it can’t be called.
That’s the issue. Wireguard is there, it responds to modprobe and lsmod, but it can’t be called. Either the issue is in the PATH variable, which is unlikely since this is the only command that doesn’t function, or it’s something very obscure. Hopefully, it’s in the PATH and someone can help
