combine launcher with window list
Hello,
I'm looking for way to combine - group window list under application launcher in xfce panel (similar to budgie). Is there a way to accomplish that?
You mean when you open an application launcher from the panel, to not show a separate icon but to handle minimize actions in the launcher icon itself ?
window grouping.
Exactly like that
You need this: https://aur.archlinux.org/packages/xfce4-taskbar-plugin-git/
Then open Panel Preferences and in Items add the taskbar, remove Window Buttons.
Start Opening apps. Right click on the icons and select Pin this app
Is there maybe a way to open new instance with mouse middle button?
I'm afraid not. The plugin itself does not have any preferences.
There is also this one. I have not used it. You might want to check it out.
