Good evening!
I want to buy two monitors to use with my Dell XPS 15 and I’m wondering if a dual monitor setup will be working flawlessly with my device and KDE Plasma. Is there anything to keep in mind before buying?
I won’t need the laptop screen when the two monitors are active/connected - if that should be relevant.
Thanks a lot!
inxi -Fxz
System: Kernel: 5.7.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.19.5
Distro: Manjaro Linux
Machine: Type: Laptop System: Dell product: XPS 15 7590 v: N/A serial: <filter>
Mobo: Dell model: 0VYV0G v: A00 serial: <filter> UEFI: Dell v: 1.7.0 date: 05/11/2020
Battery: ID-1: BAT0 charge: 84.5 Wh condition: 84.5/97.0 Wh (87%) model: SMP DELL GPM0365 status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K360
charge: 100% (should be ignored) status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse charge: 55% (should be ignored)
status: Discharging
CPU: Topology: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Kaby Lake rev: A
L2 cache: 12.0 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 62431
Speed: 900 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 900 2: 900 3: 900 4: 900 5: 900
6: 900 7: 900 8: 900 9: 900 10: 900 11: 900 12: 900
Graphics: Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel bus ID: 00:02.0
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Hewlett-Packard driver: nvidia
v: 450.80.02 bus ID: 01:00.0
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo bus ID: 1-12:5
Display: x11 server: X.Org 1.20.9 driver: modesetting,nvidia resolution: 1: 1920x1080~60Hz
2: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.1.8 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel v: kernel
bus ID: 00:1f.3
Sound Server: ALSA v: k5.7.19-2-MANJARO
Network: Device-1: Intel Wi-Fi 6 AX200 vendor: Bigfoot Networks driver: iwlwifi v: kernel port: 3000
bus ID: 3b:00.0
IF: wlp59s0 state: up mac: <filter>
Drives: Local Storage: total: 476.94 GiB used: 236.93 GiB (49.7%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: KXG60ZNV512G NVMe 512GB size: 476.94 GiB
Partition: ID-1: / size: 451.64 GiB used: 236.93 GiB (52.5%) fs: ext4 dev: /dev/nvme0n1p2
Swap: ID-1: swap-1 type: partition size: 16.79 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 48.0 C mobo: N/A
Info: Processes: 304 Uptime: 4h 35m Memory: 15.26 GiB used: 3.07 GiB (20.1%) Init: systemd Compilers:
gcc: 10.2.0 Packages: 1330 Shell: Bash v: 5.0.18 inxi: 3.1.05
