Hi,
I’ve just installed codeblocks 20.03-4 on Manjaro. Compilation works fine but running my program gives me an error: Process terminated with status -1
The last thing codeblocks did was: Executing: xterm -T myprogram blah_blah
After a quick check, turns out I don’t have xterm. After installing it, everything works fine.
Isn’t xterm missing from the dependency list of codeblocks?
Worth a try. But if xterm is installed by default on Arch, they won’t like it.
@steanne Actually I didn’t look because codeblocks was a pain to set a default terminal in the past (as far as I remember, it was hardcoded). But you’re right, it’s now easily accessible in the options. Maybe that’s the reason why it’s not a dependency.
