Hello,
I tryed to install cockpit on my manjaro i3 but I can’t login on the web panel with my user:pass.
journalctl -u cockpit ✔ FR
Jun 09 18:58:42 klos-allseries systemd[1]: Starting Cockpit Web Service...
Jun 09 18:58:42 klos-allseries cockpit-certificate-ensure[106093]: /usr/lib/cockpit/cockpit-certificate-helper: line 32: sscg: command not fo>
Jun 09 18:58:42 klos-allseries cockpit-certificate-ensure[106094]: Generating a RSA private key
Jun 09 18:58:42 klos-allseries cockpit-certificate-ensure[106094]: ...................+++++
Jun 09 18:58:42 klos-allseries cockpit-certificate-ensure[106094]: ......................+++++
Jun 09 18:58:42 klos-allseries cockpit-certificate-ensure[106094]: writing new private key to '0-self-signed.key'
Jun 09 18:58:42 klos-allseries cockpit-certificate-ensure[106094]: -----
Jun 09 18:58:42 klos-allseries systemd[1]: Started Cockpit Web Service.
Jun 09 19:02:50 klos-allseries systemd[1]: cockpit.service: Deactivated successfully.
Jun 09 19:03:31 klos-allseries systemd[1]: Starting Cockpit Web Service...
Jun 09 19:03:31 klos-allseries systemd[1]: Started Cockpit Web Service.
Jun 09 19:05:36 klos-allseries systemd[1]: cockpit.service: Deactivated successfully.
Jun 09 19:06:44 klos-allseries systemd[1]: Starting Cockpit Web Service...
Jun 09 19:06:44 klos-allseries systemd[1]: Started Cockpit Web Service.
Jun 09 19:09:06 klos-allseries systemd[1]: cockpit.service: Deactivated successfully.
Jun 09 19:09:46 klos-allseries systemd[1]: Starting Cockpit Web Service...
Jun 09 19:09:46 klos-allseries systemd[1]: Started Cockpit Web Service.
Jun 09 19:10:37 klos-allseries cockpit-tls[108523]: cockpit-tls: gnutls_handshake failed: A TLS fatal alert has been received.
Jun 09 19:12:48 klos-allseries systemd[1]: cockpit.service: Deactivated successfully.
Jun 09 19:14:09 klos-allseries systemd[1]: Starting Cockpit Web Service...
Jun 09 19:14:09 klos-allseries systemd[1]: Started Cockpit Web Service.
Jun 09 19:14:57 klos-allseries cockpit-tls[109532]: cockpit-tls: gnutls_handshake failed: A TLS fatal alert has been received.
Jun 09 19:14:59 klos-allseries cockpit-tls[109532]: cockpit-tls: gnutls_handshake failed: A TLS fatal alert has been received.
Jun 09 19:17:06 klos-allseries systemd[1]: cockpit.service: Deactivated successfully.
Jun 09 19:19:53 klos-allseries systemd[1]: Starting Cockpit Web Service...
Jun 09 19:19:53 klos-allseries systemd[1]: Started Cockpit Web Service.
Jun 09 19:22:04 klos-allseries systemd[1]: cockpit.service: Deactivated successfully.
Jun 09 19:23:58 klos-allseries systemd[1]: Starting Cockpit Web Service...
Jun 09 19:23:58 klos-allseries systemd[1]: Started Cockpit Web Service.
Jun 09 19:26:50 klos-allseries systemd[1]: cockpit.service: Deactivated successfully.
Jun 09 19:33:44 klos-allseries systemd[1]: Starting Cockpit Web Service...
Jun 09 19:33:44 klos-allseries systemd[1]: Started Cockpit Web Service.
I tryed to download sscg, but same error.
Thank you for reading
PS : problem solved, I just restarting my computer.
Have a nice day, see you soon
