Hi guys… I apologize beforehand because this is more a “1st world problem” than anything else, but at this point I am just more curious than annoyed.
I’ve using Manjaro for a long time now and never had this issue.
I received a new laptop recently so, I removed windows and installed Manjaro Plasma, as always. At his point, all pretty straight forward. But I start to notice some clunkiness when operating the windows (maximize, minimize, drag, move, etc). It’s like the animation stutter and struggle to run smoothly. I started live form a thumb drive and notice the same thing. Seems to be something Plasma related though because I also run a live image with xfce (that I use in older machines) and no problem whatsoever even with transparecy windows and all the whistles and bells.
The weird part is that my other laptop is practically the same, and Plasma works very well , even with dual monitor setup (1080, 2k).
I am going to leave info from both down below in case somebody can spot a relevant difference than may cause this.
Laptop without issues:
Kernel: 6.12.17-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=1478c212-e855-4912-88c8-b9053053133a rw quiet splash
resume=UUID=1f3449c3-b890-4939-a904-0090410b50e9 udev.log_priority=3
Desktop: KDE Plasma v: 6.3.2 tk: Qt v: N/A info: frameworks v: 6.11.0
wm: kwin_x11 with: krunner tools: avail: hypridle,hyprlock vt: 2 dm: SDDM
Type: Laptop System: EXO S.A. product: Smart G12
v: ADL_P_IDL525_S_S3_V0.59.3 serial: <superuser required>
Mobo: EXO S.A. model: EM_IDL525_S_V1.1 serial: <superuser required>
part-nu: 6364 uuid: <superuser required> UEFI: American Megatrends LLC.
v: ADL_P_IDL525_S_S3_V0.59.3 date: 12/28/2022
ID-1: BAT0 charge: 47.3 Wh (100.0%) condition: 47.3/47.3 Wh (100.0%)
volts: 11.4 min: N/A model: Intel SR 1 SR Real Battery type: Unknown
serial: <filter> status: full
System RAM: total: 16 GiB available: 15.37 GiB used: 7.26 GiB (47.2%)
Array-1: capacity: 64 GiB slots: 2 modules: 1 EC: None
Device-1: Controller0-ChannelA-DIMM0 type: no module installed
Device-2: Controller1-ChannelA-DIMM0 type: DDR4 detail: synchronous
size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: 0x0CAB
part-no: B4ASAG53222B serial: <filter>
Info: model: 12th Gen Intel Core i5-1235U bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
microcode: 0x436
Topology: cpus: 1x dies: 1 clusters: 4 cores: 10 threads: 12 mt: 2 tpc: 2
st: 8 smt: enabled cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32
KiB, 8x64 KiB L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 400 min/max: 400/4400:3300 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 59916
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb
pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp
rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
xtopology xtpr
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Alder Lake-UP3 GT2 [UHD Graphics] vendor: nCipher Security
driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
built: 2020-21 ports: active: HDMI-A-1,eDP-1 empty: DP-1, DP-2, HDMI-A-2,
HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:4628 class-ID: 0300
Device-2: Microdia Webcam Vitade AF driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0c45:6366
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.65x15.00")
s-diag: 1245mm (49.01")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: right model: Dell U2711
serial: <filter> built: 2011 res: N/A dpi: 82 gamma: 1.2 chroma: red:
x: 0.678 y: 0.310 green: x: 0.200 y: 0.690 blue: x: 0.149 y: 0.051 white:
x: 0.314 y: 0.329 size: 597x336mm (23.5x13.23") diag: 685mm (27")
ratio: 16:9 modes: 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1280x800,
1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
Monitor-2: eDP-1 pos: primary,left model: ChiMei InnoLux 0x15e7
built: 2016 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2
chroma: red: x: 0.592 y: 0.349 green: x: 0.329 y: 0.557 blue: x: 0.153
y: 0.118 white: x: 0.314 y: 0.329 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: 1920x1080
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:4628 memory: 7.5 GiB unified: yes
API: Vulkan v: 1.4.304 layers: N/A device: 0 type: integrated-gpu
name: Intel Graphics (ADL GT2) driver: N/A device-ID: 8086:4628
surfaces: xcb,xlib
de: kscreen-console,kscreen-doctor wl: nwg-displays,wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Alder Lake PCH-P High Definition Audio
vendor: Emdoor Digital driver: snd_hda_intel v: kernel
alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:51c8 class-ID: 0403
API: ALSA v: k6.12.17-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:6
Local Storage: total: 238.47 GiB used: 113.58 GiB (47.6%)
ID-1: /dev/sda maj-min: 8:0 model: SSD 256GB size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 8A0 scheme: GPT
ID-1: / raw-size: 221.26 GiB size: 216.73 GiB (97.95%)
used: 111.72 GiB (51.5%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 1478c212-e855-4912-88c8-b9053053133a
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: C263-2BFA
ID-3: /home/<filter>/pCloudDrive raw-size: N/A size: 5 TiB
used: 77.3 MiB (0.0%) fs: fuse source: ERR-102
ID-1: swap-1 type: partition size: 16.91 GiB used: 1.79 GiB (10.6%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: 1f3449c3-b890-4939-a904-0090410b50e9
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Hub-2: 1-3:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-5:3 info: Microdia Webcam Vitade AF type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 0c45:6366 class-ID: 0e02
serial: <filter>
Device-2: 1-7:7 info: Trust B.V. Optical Mouse type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1
chip-ID: 15d9:0a33 class-ID: 0301
Device-3: 1-9:5 info: HP Slim Keyboard type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 03f0:304a class-ID: 0300
Device-4: 1-10:6 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 47.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1583 libs: 387 tools: pamac,yay
pm: flatpak pkgs: 0
1: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://mirrors2.manjaro.org/stable/$repo/$arch
3: http://mirror.fcix.net/manjaro/stable/$repo/$arch
4: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
8: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 332
1: cpu: 4.0% command: baloo_file_extractor pid: 1660 mem: 502.2 MiB (3.1%)
2: cpu: 2.3% command: firefox pid: 2788 mem: 660.4 MiB (4.1%)
3: cpu: 2.1% command: dolphin pid: 18320 mem: 242.3 MiB (1.5%)
4: cpu: 1.8% command: teams-for-linux pid: 13575 mem: 547.9 MiB (3.4%)
5: cpu: 1.4% command: thumbnail.so started-by: kioworker pid: 18397
mem: 201.7 MiB (1.2%)
Memory top: 5 of 332
1: mem: 675.1 MiB (4.2%) command: vivaldi-bin pid: 10284 cpu: 0.4%
2: mem: 660.4 MiB (4.1%) command: firefox pid: 2788 cpu: 2.3%
3: mem: 547.9 MiB (3.4%) command: teams-for-linux pid: 13575 cpu: 1.8%
4: mem: 502.2 MiB (3.1%) command: baloo_file_extractor pid: 1660 cpu: 4.0%
5: mem: 498.8 MiB (3.1%) command: plasmashell pid: 999 cpu: 0.3%
Processes: 332 Power: uptime: 4h 41m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 6.13 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.37 running-in: kitty inxi: 3.3.37
Laptop with issues:
root=UUID=aa3a2170-1161-457c-883a-3ac4e51f8498 rw quiet splash
resume=UUID=e607732f-fb23-4b0d-9cee-4eb175ad449e udev.log_priority=3
Type: Laptop System: HP product: HP EliteBook 640 14 inch G9 Notebook PC
v: N/A serial: <superuser required> Chassis: type: 10
Mobo: HP model: 8AA6 v: KBC Version 21.63.00 serial: <superuser required>
part-nu: 978P6EC#ABM uuid: <superuser required> UEFI: HP
v: U86 Ver. 01.08.00 date: 06/26/2023
ID-1: BAT0 charge: 36.9 Wh (87.2%) condition: 42.3/42.8 Wh (99.0%)
power: 6.1 W volts: 12.3 min: 11.4 model: Hewlett-Packard Primary
type: Li-ion serial: <filter> status: discharging cycles: 2
System RAM: total: 16 GiB available: 15.26 GiB used: 1.48 GiB (9.7%)
Device-1: Bottom-Slot 1(left) type: no module installed
Device-2: Bottom-Slot 2(right) type: DDR4 detail: synchronous size: 16 GiB
speed: 3200 MT/s volts: curr: 1 width (bits): data: 64 total: 64
manufacturer: Samsung part-no: M471A2G43CB2-CWE serial: <filter>
Info: model: 12th Gen Intel Core i5-1245U bits: 64 type: MST AMCP
microcode: 0x436
desc: 1x12 MiB
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pconfig pdcm
rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
xtopology xtpr
Device-1: Intel Alder Lake-UP3 GT2 [UHD Graphics] vendor: Hewlett-Packard
built: 2020-21 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4,
HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:4628 class-ID: 0300
Device-2: Luxvisions Innotech HP HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 30c9:006d
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: LG Display 0x0725 built: 2021 res: 1920x1080
dpi: 158 gamma: 1.2 chroma: red: x: 0.596 y: 0.369 green: x: 0.349 y: 0.545
blue: x: 0.149 y: 0.110 white: x: 0.314 y: 0.329
size: 309x174mm (12.17x6.85") diag: 355mm (14") ratio: 16:9
modes: 1920x1080
EDID-Warnings: 1: parse_edid: unknown flag 2
inactive: wayland
device-ID: 8086:4628 memory: 7.45 GiB unified: yes
surfaces: xcb,xlib
vendor: Hewlett-Packard driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel, snd_soc_avs, snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0401
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-2: Intel Ethernet I219-LM vendor: Hewlett-Packard driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1a1e class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0033
class-ID: e001
Local Storage: total: 476.94 GiB used: 13.04 GiB (2.7%)
model: MZVL2512HCJQ-00BH1 size: 476.94 GiB block-size: physical: 512 B
fw-rev: HPS3NGXH temp: 23.9 C scheme: GPT
ID-1: / raw-size: 459.86 GiB size: 451.57 GiB (98.20%)
used: 13.04 GiB (2.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: aa3a2170-1161-457c-883a-3ac4e51f8498
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 376A-EE08
ID-1: swap-1 type: partition size: 16.78 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: e607732f-fb23-4b0d-9cee-4eb175ad449e
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-1:2 info: Luxvisions Innotech HP HD Camera type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 30c9:006d class-ID: 0e02
serial: <filter>
Device-2: 3-10:3 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0033 class-ID: e001
System Temperatures: cpu: 20.0 C mobo: N/A
Packages: pm: pacman pkgs: 1202 libs: 327 tools: pamac,yay pm: flatpak
pkgs: 0
1: https://mirrors2.manjaro.org/stable/$repo/$arch
2: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
3: https://mirrors.manjaro.org/repo/stable/$repo/$arch
Processes:
CPU top: 5 of 308
1: cpu: 0.4% command: Xorg pid: 689 mem: 76.6 MiB (0.4%)
2: cpu: 0.4% command: kwin_x11 pid: 877 mem: 197.9 MiB (1.2%)
3: cpu: 0.2% command: plasmashell pid: 908 mem: 392.8 MiB (2.5%)
4: cpu: 0.1% command: [kworker/u48:20-events_unbound] pid: 3154
mem: 0.00 MiB (0.0%)
5: cpu: 0.0% command: init pid: 1 mem: 12.9 MiB (0.0%)
Memory top: 5 of 308
1: mem: 392.8 MiB (2.5%) command: plasmashell pid: 908 cpu: 0.2%
2: mem: 241.1 MiB (1.5%) command: konsole pid: 1636 cpu: 0.0%
3: mem: 197.9 MiB (1.2%) command: kwin_x11 pid: 877 cpu: 0.4%
4: mem: 102.5 MiB (0.6%) command: kded6 pid: 876 cpu: 0.0%
5: mem: 79.4 MiB (0.5%) command: kdeconnectd pid: 1130 cpu: 0.0%
Processes: 308 Power: uptime: 3h 0m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 3 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 6.09 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: N/A Shell: Zsh v: 5.9 default: Bash v: 5.2.37
running-in: konsole inxi: 3.3.37
As they have practically the same specs, both use the same graphic driver:
# no issues
00:02.0 VGA compatible controller: Intel Corporation Alder Lake-UP3 GT2 [UHD Graphics] (rev 0c)
DeviceName: Onboard - Video
Subsystem: nCipher Security Device 2782
Kernel driver in use: i915
Kernel modules: i915, xe
# with issues
DeviceName: Onboard IGD
Subsystem: Hewlett-Packard Company Device 8aa6
Settings in KDE are the same, I checked.
The only difference I noticed, is the mhwd -li output in the laptop with issues I get this:
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-linux 2024.05.06 true PCI
Whereas in the other laptop I get nothing:
Warning: No installed PCI configs!
I am at a loss here.
Any help or suggestion would be welcome!
– Edit 2025-03-17
Today noticed 3 packages on the not performing machine that I didn’t have in the performing machine:
xf86-video-amdgpu, xf86-video-intel, xf86-video-nouveau and xf86-video-ati
So I uninstall them and reboot with no changes.
Then, create this file:
/etc/X11/xorg.conf.d/20-intel.conf
Section “Device”
Identifier “Intel Graphics”
Driver “modesetting”
Option “DRI” “2”
Option “TearFree” “false”
Option “TripleBuffer” “false”
Option “SwapbuffersWait” “false”
EndSection
Even when the working laptop doesn’t have it, just to make sure is not using intel legacy driver, but so far no luck. I am still playing with options here.
In the arch wiki mention something like Option “DRI” “Iris” but when I try that I get a black screen. It also mention that “the Iris Mesa driver is needed” but I don’t know what package has this.
– Edit 2025-03-25
This weekend, I did some additional testing, and install Arch on the same machine just to see what happens. The same problem shows, so at this point I am inclined to think that the hardware implementation of HP is lacking and has some performance issues. Otherwise, I can’t explain why the HP laptop have this problem and not the other laptop that have identical specs, except for the manufacturer. My working laptop works just fine with no additional settings. I don’t even have an Xorg config file.
When I fiddle a little bit with the HP’s configuration and set this:
Option “AccelMethod” “uxa”
Makes the problem disappear but also vanish the “smoth window movement effect”. The windows just pop out.
All this in X11 since in Wayland works OK, pretty similar to X11 in the other one.
– Edit 2025-04-04
Today get some weird results but at least I think I am isolating the problem. I tested a live KDE 6.3.2 and the problem presents itself even in the working laptop (with 5.x works OK). But this is where it gets “weirder”: it only does it in the laptop screen. In the external monitor works flawlessly. I move the same terminal window to the right and everything is smooth. I move it back, and it start stuttering every time I minimize/maximize it. The external monitor is nothing special. A Dell U2711 working at 60hz, same than the laptop. I don’t know what it is, and I don’t know what “improvement” has my current system than when I boot it, it doesn’t lag, but a fresh or live system with kde 6.x, does.
I need help of someone that understand how this work a little better than me and tell me what could cause this.
I leave this open in case somebody thinks of something until I can do more testing.
Thanks in advance.
