Clover Bootloader EFI support
#1
Is it possible that in the future we could get a feature that would allow to boot manjaro efi with clover boot loader because I use both OS X and manjaro and I would like to be able to boot manjaro after a fresh install off clover as efi instead of using efi bios. Also I’ve gotten this type of thing to work with Ubuntu but I would like to replace Ubuntu because I prefer manjaro
#2
I suspect the best way of starting this would be to put together a guide to dual-boot macOS and Manjaro.
Specifically supporting a subset of hardware which has its own idiosyncrasies isn’t generally a good use of developer time. Supporting 90% of systems with GRUB is a much better use of time.
#3
Yeah it’s most likely possible to dual boot them together it’s just it’s not explained straight forward how I know for a fact a friend using arch Linux managed to do it so it’s possable
#4
Got it working mark this thread as solved
#5
Please, post how it can be done, so we make a tutorial for general usage.
The solution is not described, so the topic cannot be marked as solved… (stupid Discource!..) :crazy_face:
#6
@Austcool, please do. :slight_smile:
#7
Why hackintosh-ers keep coming here to ask for help ?
#8
Looks like OP wanted help rather than to help.
I’ll close this pending further information.
Because we help. :man_shrugging:
#9
