Hello,
When I close my laptop lid, the computer starts overheating, and when I open back up the lid, the computer is frozen and I’m not able to move my cursor anywhere. Anyone have ideas on what I can try to do to solve this issue?
Thanks
Found an old similar topic Laptop Overheating and Freezing When Lid Closed
inxi -Fazy ✔
Kernel: 5.10.59-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=0345865d-abb8-48f7-9675-abae82e788fd rw nouveau.modeset=0 quiet
splash apparmor=1 security=apparmor
resume=UUID=c2dd8d83-e546-4bb0-bc0c-f8c484636876 udev.log_priority=3
Desktop: GNOME 40.3 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Laptop System: ASUSTeK product: ROG Zephyrus G15 GA503QR_GA503QR
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: GA503QR v: 1.0 serial: <filter>
UEFI: American Megatrends LLC. v: GA503QR.408 date: 05/11/2021
ID-1: BAT0 charge: 85.6 Wh (100.0%) condition: 85.6/90.0 Wh (95.1%)
volts: 15.9 min: 15.9 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Not charging
Info: 8-Core model: AMD Ryzen 9 5900HS with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 family: 19 (25) model-id: 50 (80) stepping: 0
microcode: A50000C cache: L2: 4 MiB
bogomips: 105440
Speed: 2583 MHz min/max: 1200/3300 MHz boost: enabled Core speeds (MHz):
1: 2583 2: 2822 3: 1964 4: 1961 5: 1647 6: 1721 7: 2436 8: 1431 9: 2508
10: 2350 11: 2593 12: 2483 13: 1284 14: 2203 15: 1214 16: 1513
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: always-on, RSB filling
Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:249d class-ID: 0300
Device-2: AMD Cezanne vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 07:00.0 chip-ID: 1002:1638 class-ID: 0300
Device-3: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-1.4.1:9 chip-ID: 046d:08e5
class-ID: 0102 serial: <filter>
Display: x11 server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: amdgpu,ati,nvidia unloaded: modesetting,nouveau
alternate: fbdev,nv,vesa resolution: <missing: xdpyinfo>
OpenGL: renderer: NVIDIA GeForce RTX 3070 Laptop GPU/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 07:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: ASUSTeK
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 07:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Kingston HyperX Cloud Flight S type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1.2:6 chip-ID: 0951:16ea
class-ID: 0300 serial: <filter>
Device-5: Logitech HD Pro Webcam C920 type: USB
Sound Server-1: ALSA v: k5.10.59-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: d000
bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:5
Local Storage: total: 1.84 TiB used: 45.95 GiB (2.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 45.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: SK Hynix model: HFM001TD3JX013N
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 41000C20 temp: 39.9 C scheme: GPT
ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%)
used: 45.95 GiB (5.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 64.0 C mobo: N/A
Fan Speeds (RPM): cpu: 600
GPU: device: nvidia screen: :1.0 temp: 52 C device: amdgpu temp: 56.0 C
Processes: 379 Uptime: 9m wakeups: 3 Memory: 38.66 GiB used: 2.74 GiB (7.1%)
Init: systemd v: 248 tool: systemctl Compilers: gcc: 11.1.0 Packages: 1337
pacman: 1326 lib: 319 flatpak: 5 snap: 6 Shell: Zsh v: 5.8
running-in: gnome-terminal inxi: 3.3.06
