It’s a new dual boot with windows system. After I was AFK manjaro locked the computer and it wouldn’t let me in for some reason (i didn’t set up any password, just hitting enter said it failed to unlock). I hard rebooted. Now when i try to boot into Manjaro after the GRUB most of the time it’s just a black screen (and one time there was “failed to start pkg database update” error). Ctrl+Alt+f2 worked so I updated and the system and then launched startx, here’re the log file contents:
> [ 8.538] (--) Log file renamed from "/var/log/Xorg.pid-977.log" to "/var/log/Xorg.0.log"
> [ 8.539]
> [X.Org](https://X.Org) X Server 1.20.10
> X Protocol Version 11, Revision 0
> [ 8.539] Build Operating System: Linux Manjaro Linux
> [ 8.539] Current Operating System: Linux tvvoty-ms7a38 5.9.16-1-MANJARO #1 SMP PREEMPT Mon Dec 21 22:00:46 UTC 2020 x86_64
> [ 8.539] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=12f5e12e-8787-4e13-8c73-b8daf351f23d ro quiet apparmor=1 security=apparmor udev.log_priority=3
> [ 8.540] Build Date: 16 December 2020 10:33:32PM
> [ 8.540]
> [ 8.540] Current version of pixman: 0.40.0
> [ 8.540] Before reporting problems, check http://wiki.x.org
> to make sure that you have the latest version.
> [ 8.540] Markers: (--) probed, (**) from config file, (==) default setting,
> (++) from command line, (!!) notice, (II) informational,
> (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
> [ 8.540] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Jan 11 04:04:44 2021
> [ 8.540] (==) Using config directory: "/etc/X11/xorg.conf.d"
> [ 8.540] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
> [ 8.540] (==) ServerLayout "layout"
> [ 8.540] (==) No screen section available. Using defaults.
> [ 8.540] (**) |-->Screen "Default Screen Section" (0)
> [ 8.540] (**) | |-->Monitor "<default monitor>"
> [ 8.541] (==) No device specified for screen "Default Screen Section".
> Using the first device section listed.
> [ 8.541] (**) | |-->Device "Device0"
> [ 8.541] (==) No monitor specified for screen "Default Screen Section".
> Using a default monitor configuration.
> [ 8.541] (==) Automatically adding devices
> [ 8.541] (==) Automatically enabling devices
> [ 8.541] (==) Automatically adding GPU devices
> [ 8.541] (==) Automatically binding GPU devices
> [ 8.541] (==) Max clients allowed: 256, resource mask: 0x1fffff
> [ 8.541] (WW) The directory "/usr/share/fonts/OTF" does not exist.
> [ 8.541] Entry deleted from font path.
> [ 8.541] (WW) The directory "/usr/share/fonts/Type1" does not exist.
> [ 8.541] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
> [ 8.541] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
> [ 8.541] (==) FontPath set to:
> /usr/share/fonts/misc,
> /usr/share/fonts/TTF
> [ 8.541] (==) ModulePath set to "/usr/lib/xorg/modules"
> [ 8.541] (**) Extension "Composite" is enabled
> [ 8.541] (**) Extension "RENDER" is enabled
> [ 8.541] (II) The server relies on udev to provide the list of input devices.
> If no devices become available, reconfigure udev or disable AutoAddDevices.
> [ 8.541] (II) Module ABI versions:
> [ 8.541] [X.Org](https://X.Org) ANSI C Emulation: 0.4
> [ 8.541] [X.Org](https://X.Org) Video Driver: 24.1
> [ 8.541] [X.Org](https://X.Org) XInput driver : 24.1
> [ 8.541] [X.Org](https://X.Org) Server Extension : 10.0
> [ 8.542] (++) using VT number 1
> [ 8.542] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
> [ 8.543] (II) xfree86: Adding drm device (/dev/dri/card0)
> [ 8.553] (--) PCI:*(41@0:0:0) 1002:15d8:1462:7a38 rev 200, Mem @ 0xe0000000/268435456, 0xf0000000/2097152, 0xfcc00000/524288, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
> [ 8.553] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
> [ 8.553] (II) LoadModule: "glx"
> [ 8.553] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
> [ 8.555] (II) Module glx: vendor="[X.Org](https://X.Org) Foundation"
> [ 8.555] compiled for 1.20.10, module version = 1.0.0
> [ 8.555] ABI class: [X.Org](https://X.Org) Server Extension, version 10.0
> [ 8.555] (II) LoadModule: "vesa"
> [ 8.555] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
> [ 8.555] (II) Module vesa: vendor="[X.Org](https://X.Org) Foundation"
> [ 8.555] compiled for 1.20.9, module version = 2.5.0
> [ 8.555] Module class: [X.Org](https://X.Org) Video Driver
> [ 8.555] ABI class: [X.Org](https://X.Org) Video Driver, version 24.1
> [ 8.555] (II) VESA: driver for VESA chipsets: vesa
> [ 8.556] vesa: Refusing to run on UEFI
> [ 8.556] (EE) No devices detected.
> [ 8.556] (EE)
> Fatal server error:
> [ 8.556] (EE) no screens found(EE)
> [ 8.556] (EE)
> Please consult the The [X.Org](https://X.Org) Foundation support
> at http://wiki.x.org
> for help.
> [ 8.556] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
> [ 8.556] (EE)
> [ 8.556] (EE) Server terminated with error (1). Closing log file.
I guess the problem’s in the video driver? ( I’m using Ryzen5 3400g integrated graphics)
