[CLOSED] Command-not-found : using older shared library
#1
Hi all
This only happens to me when tmux is running.
I’m on zsh, so…
┌─[spiros@HOME] - [~] - [Πεμ Οκτ 18, 09:36]
└─[$] <> not-a-command
cnf-lookup: error while loading shared libraries: libboost_system.so.1.67.0: cannot open shared object file: No such file or directory
zsh: not-a-command: command not found
About cnf-lookup:
┌─[spiros@HOME] - [~] - [Πεμ Οκτ 18, 09:37]
└─[$] <> pacman -Qo cnf-lookup
/usr/bin/cnf-lookup is owned by command-not-found 0.6.2-2
┌─[spiros@HOME] - [~] - [Πεμ Οκτ 18, 09:45]
└─[$] <> LANG=en_US pacman -Qi command-not-found
Version : 0.6.2-2
Description : In case a command could not be found this utility searches for packages containing this or a similar command (bash,zsh).
Architecture : x86_64
URL : http://github.com/metti/command-not-found
Licenses : GPL
Groups : None
Provides : None
Depends On : boost-libs libarchive tdb wget
Optional Deps : None
Required By : None
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 606.00 KiB
Packager : Bernhard Landauer oberon@manjaro.org
Build Date : Fri Jul 13 13:55:55 2018
Install Date : Wed Oct 17 19:04:16 2018
Install Reason : Explicitly installed
Install Script : Yes
Validated By : Signature
And here is the library:
└─[$] <> pacman -Qs boost
local/boost 1.68.0-1
    Free peer-reviewed portable C++ source libraries - development headers
local/boost-libs 1.68.0-1
    Free peer-reviewed portable C++ source libraries - runtime libraries
└─[$] <> pacman -Ql boost-libs|grep system
boost-libs /usr/lib/libboost_filesystem.so
boost-libs /usr/lib/libboost_filesystem.so.1.68.0
boost-libs /usr/lib/libboost_system.so
boost-libs /usr/lib/libboost_system.so.1.68.0
I have tried re-installing command-no-found, but no luck
Now, I know I could probably be able to “fix” it by linking the library, but it would be nice to have it right…
Sounds like command-not-found needs a rebuild, @oberon :slight_smile:
I’ve rebuilt it, look for 0.6.2-2.0 (and -2.1 in unstable).
Yes!
Thank you very much
Closed
closed #5
This topic was automatically closed 180 days after the last reply. New replies are no longer allowed.
