I have a rather weird issue. Any application run through the terminal, be it ping, traceroute, java, etc. are unable to connect to the internet despite my ethernet connection. They work fine after connecting to a mobile hotspot through WiFi and are also able to connect after leaving the WiFi connection for a brief period, then proceed to be unable to connect. Most GUI applications (such as firefox and steam) are able to use my ethernet as normal.
In regards to the connection working after leaving WiFi, it is a little bit peculiar. I must disconnect from my ethernet connection, connect to wireless, then reconnect to ethernet and disconnect from wireless. Afterwards, everything works as normal for about a minute. I have no idea why.
inxi -Fazy
Kernel: 6.1.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=789b946b-49c3-4fa8-9664-a4df465487ab rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
Type: Desktop System: Micro-Star product: MS-7B22 v: 2.0
serial: <superuser required>
Mobo: Micro-Star model: B360 GAMING PLUS (MS-7B22) v: 2.0
serial: <superuser required> UEFI: American Megatrends v: 2.20
date: 04/09/2018
Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF2
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4377 high: 4393 min/max: 800/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 4384 2: 4385 3: 4344
4: 4386 5: 4390 6: 4393 7: 4384 8: 4382 9: 4371 10: 4364 11: 4376 12: 4374
bogomips: 88824
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU106 [GeForce RTX 2070 Rev. A] vendor: eVga.com.
driver: nvidia v: 535.86.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-07) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f07 class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 110 s-size: 591x352mm (23.27x13.86")
s-diag: 688mm (27.08")
Monitor-1: DP-0 res: 2560x1440 dpi: 109 size: 598x336mm (23.54x13.23")
diag: 686mm (27.01") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.86.05 renderer: NVIDIA GeForce RTX
2070/PCIe/SSE2 direct-render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: eVga.com.
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Logitech Yeti Nano driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-11:5
chip-ID: 046d:0ab1 class-ID: 0300 serial: <filter>
Device-4: Logitech G733 Gaming Headset
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 046d:0ab5 class-ID: 0300
API: ALSA v: k6.1.41-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 0.3.75 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Device-2: Qualcomm Atheros AR93xx Wireless Network Adapter vendor: Fujitsu
driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
chip-ID: 168c:0030 class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Local Storage: total: 931.51 GiB used: 501.15 GiB (53.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QGXA7 temp: 50.9 C
scheme: GPT
ID-1: / raw-size: 614.47 GiB size: 603.75 GiB (98.26%)
used: 499.34 GiB (82.7%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw-size: 350 MiB size: 349.3 MiB (99.80%)
used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: partition size: 9.77 GiB used: 1.82 GiB (18.6%)
priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:7
System Temperatures: cpu: 53.0 C pch: 55.0 C mobo: N/A gpu: nvidia temp: 64 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 49%
Processes: 326 Uptime: 5d 17h 5m wakeups: 1 Memory: total: 32 GiB
available: 31.29 GiB used: 6.68 GiB (21.4%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: 1630 pm: pacman pkgs: 1607 libs: 512 tools: pamac pm: flatpak
pkgs: 23 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.28
inxi -N
Device-1: Intel Ethernet I219-V driver: e1000e
Device-2: Qualcomm Atheros AR93xx Wireless Network Adapter driver: ath9k
Any help would be greatly appreciated!
