Clipgrab, can't find it in Pacman
Where can I download itr, it doesn’t come up when I search for it in Pacman
Hi @Edward78,
You won’t be able to find it with pacman, as it’s not in the repositories. It’s in the AUR:
$ pamac search clipgrab
clipgrab  3.9.10-1        AUR
A video downloader and converter for YouTube, Veoh, DailyMotion, MyVideo, ...
So you can install it with:
pamac build clipgrab
Hope this helps!
Well crap, the one I got from appimage doesn’t seem to want to open.
I also downloaded the .AppImage version just now, VIA this URL:
https://download.clipgrab.org/ClipGrab-3.9.10-x86_64.AppImage
placed it in my ~/Applications/ directory, made it executable:
chmod u=+rwx ~/Applications/ClipGrab-3.9.10-x86_64.AppImage
And executed it:
./Applications/ClipGrab-3.9.10-x86_64.AppImage
All this from my $HOME directory, of course.
The result:
Sorry for the image on the server, my usual method didn’t want to work. Investigating now.
Thanks, I have it, butr it fails to download the vid. :frowning:
Nobody here can help with that, I’m afraid. At least I don’t think so…
I used Clipgrab in the past, but honestly - just using yt-dlp in a terminal is just reliable, accurate and dependable for he most part… and if not, then Clipgrab has nothing to work with either.
I also use yt-dlp, and all I can say is exactly.
I can. :wink:
@Edward78
you need the AppImage - and you need to install openssl-1.1 as well
Arch Linux - openssl-1.1 1.1.1.w-2 (x86_64)
The AppImage relies on that to be present, even though no one tells you that - not even the people who build and distribute the AppImage.
They apparently build this AppImage against this library
but don’t include it as they should.
It will work once this package is present on your system.
sudo pacman -S openssl-1.1
The issue is the same in Debian, Mint, Ubuntu - once this is present, ClipGrab AppImage works.
Well, look at you! Mr. super-helpful!
:wink:
Thanks, by the way!
It took some time to figure it out.
Nice to get presented with an opportunity to share my “hard earned” knowledge. :wink:
clipgrab was available from arch repos (last release Monday 29 January 2024 04:40:03 AM)
still reachable from arch archives; Index of /packages/c/clipgrab/
https://archive.archlinux.org/packages/c/clipgrab/clipgrab-3.9.10-1-x86_64.pkg.tar.zst
EDIT: oops, i must have installed from manjaro repos as well, just when i checked package details, it was packaged by a arch packager, sorreh!!
And for a while, also from the Manjaro repos, but we dropped it when Arch did. :wink:
If you are trying to download a YouTube video, failure to download could also be due to changes currently being implemented by YouTube which affect yt-dlp (a required dependency of clipgrab). I just rebuilt the AUR’s yt-dlp-git (using the command pamac build yt-dlp-git) as there has been another release of yt-dlp today. I keep an eye on new yt-dlp releases via the Release notes from yt-dlp atom feed.
Here’s the new release announcement:
Important changes
  • A stopgap release with a TEMPORARY partial fix for YouTube support
    Some formats may still be unavailable, especially if cookies are passed to yt-dlp. The NEXT release, expected very soon, will require an external JS runtime (e.g. Deno) in order for YouTube downloads to work properly. Read more
Extractor changes
So, yt-dlp will very soon require a separate javascript runtime to download YouTube videos:
The preferred javascript candidate is deno (which is available from the repos):
pamac info deno
Version               : 2.5.4-1
Description           : A secure runtime for JavaScript and TypeScript
URL                   : https://deno.land
Licenses              : MIT
Repository            : extra
Installed Size        : 115.3 MB
Groups                : --
Depends On            : gcc-libs
Optional Dependencies : --
Provides              : --
Replaces              : --
Conflicts With        : --
Packager              : Felix Yan <felixonmars@archlinux.org>
Build Date            : Sat 11 Oct 2025 12:26:43
Validated By          : MD5 Sum  SHA-256 Sum  Signature
Or you can just download and use the precompiled binary to ~/.local/bin/, then you don’t even have to install it. The same with yt-dlp itself.
(That also means the updates are a bit faster than the repositories’.)
…exactly what?
