Hello, I recently switched from Gnome to KDE Plasma and having tons of trouble getting the keyboard rgb working. I think I’ve searched, read and attempted more things than I remember for the backlights.
Does anyone happen to know where to find, or could help with some instructions that an amateur could follow? I would definitely appreciate it!
inxi:
inxi -Fazy
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=c47d8e98-62ed-41b1-89f1-b80ae491152b ro quiet apparmor=1
security=apparmor resume=UUID=41e353b4-a42a-4875-88b4-6e1eb4a20f2c
udev.log_priority=3
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Manjaro Linux
Type: Laptop System: Notebook product: N85_N87,HJ,HJ1,HK1 v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Notebook model: N85_N87,HJ,HJ1,HK1 serial: <filter>
UEFI: American Megatrends v: 1.05.22RLS1 date: 03/27/2018
ID-1: BAT0 charge: 34.6 Wh condition: 34.6/59.9 Wh (58%) volts: 12.7/11.1
model: Notebook BAT type: Li-ion serial: <filter> status: Full
Info: Quad Core model: Intel Core i7-7700HQ bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: 9 microcode: DE
L2 cache: 6 MiB
bogomips: 44817
Speed: 900 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900 5: 900 6: 908 7: 900 8: 900
Type: l1tf
Device-1: Intel HD Graphics 630 vendor: CLEVO/KAPOK driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:591b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: CLEVO/KAPOK
driver: nvidia v: 460.32.03 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1c8c
Device-3: Chicony Chicony USB 2.0 Camera type: USB driver: uvcvideo
bus ID: 1-2:2 chip ID: 04f2:b5a7
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 20.3.3
direct render: Yes
Device-1: Intel CM238 HD Audio vendor: CLEVO/KAPOK driver: snd_hda_intel
v: kernel bus ID: 00:1f.3 chip ID: 8086:a171
Sound Server: ALSA v: k5.9.16-1-MANJARO
vendor: CLEVO/KAPOK driver: r8169 v: kernel port: d000 bus ID: 03:00.1
chip ID: 10ec:8168
IF: enp3s0f1 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: d000
bus ID: 04:00.0 chip ID: 8086:24fd
IF: wlp4s0 state: up mac: <filter>
Local Storage: total: 238.47 GiB used: 76.6 GiB (32.1%)
model: WDS256G1X0C-00ENX0 size: 238.47 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: B35900WD
temp: 61.9 C
ID-1: / raw size: 221.09 GiB size: 216.62 GiB (97.98%)
used: 76.6 GiB (35.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 17.08 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 61.0 C mobo: N/A
Processes: 253 Uptime: 19h 58m wakeups: 2 Memory: 15.53 GiB
used: 3.52 GiB (22.6%) Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.0.1 Packages: pacman: 1335 lib: 393 flatpak: 0 Shell: Bash
v: 5.1.0 running in: konsole inxi: 3.2.02
ls -l /sys/class/leds:
ls -l /sys/class/leds/
total 0
lrwxrwxrwx 1 root root 0 1 feb 15.39 input15::capslock -> ../../devices/pci0000:00/0000:00:14.0/usb1/1-11/1-11:1.0/0003:062A:5918.0001/input/input15/input15::capslock
lrwxrwxrwx 1 root root 0 1 feb 15.39 input15::numlock -> ../../devices/pci0000:00/0000:00:14.0/usb1/1-11/1-11:1.0/0003:062A:5918.0001/input/input15/input15::numlock
lrwxrwxrwx 1 root root 0 1 feb 15.39 input15::scrolllock -> ../../devices/pci0000:00/0000:00:14.0/usb1/1-11/1-11:1.0/0003:062A:5918.0001/input/input15/input15::scrolllock
lrwxrwxrwx 1 root root 0 1 feb 15.39 input4::capslock -> ../../devices/platform/i8042/serio0/input/input4/input4::capslock
lrwxrwxrwx 1 root root 0 1 feb 15.39 input4::numlock -> ../../devices/platform/i8042/serio0/input/input4/input4::numlock
lrwxrwxrwx 1 root root 0 1 feb 15.39 input4::scrolllock -> ../../devices/platform/i8042/serio0/input/input4/input4::scrolllock
lrwxrwxrwx 1 root root 0 1 feb 15.39 phy0-led -> ../../devices/pci0000:00/0000:00:1c.6/0000:04:00.0/leds/phy0-led
