Hello there!
I am running Manjaro i3 Community edition and have just done my casual sudo pacman -Syu
I should also mention, that I did an yay -Syu
and yay -Yc
afterwards.
After a reboot
- I’ve lost the
mod+return
functionality to my terminal (I swapped the shortcut in i3 config and replaced terminal temporarily with xterm - colors are off…)… - my taskbar icons are different
- mouse-style in various states are different as well
Go-lang is not installed anymoreJust reinstalled with yay -
shortcuts which use i3-exit to reboot and shutdown the system don’t work anymore …i3-exit is not installed anymore…It actually does not come with i3 and can be found here Gitlab manjaro community i3 - i3exit or just reinstalled viasudo pacman -S i3exit
Trying to get my old terminal back to normal - I get this error:
> i3-sensible-terminal
urxvt: unable to load base fontset, please specify a valid one using -fn, aborting
Any clue? How can I rollback?
Here my pacman.log file from today.
You’ll notice in the end, that I tried
- install “terminal” … please overlook
- reinstall rxvt-unicode
- to revert the kernel which didn’t help
pacman.log file
[2021-02-10T10:56:55+0100] [PAMAC] synchronizing package lists
[2021-02-10T13:57:28+0100] [PACMAN] Running ‘pacman -Syu’
[2021-02-10T13:57:28+0100] [PACMAN] synchronizing package lists
[2021-02-10T13:57:28+0100] [PACMAN] starting full system upgrade
[2021-02-10T14:09:42+0100] [ALPM] running ‘60-mkinitcpio-remove.hook’…
[2021-02-10T14:09:42+0100] [ALPM] running ‘firefox-pre.hook’…
[2021-02-10T14:09:42+0100] [ALPM] running ‘ghc-unregister.hook’…
[2021-02-10T14:09:47+0100] [ALPM] running ‘thunderbird-pre.hook’…
[2021-02-10T14:09:47+0100] [ALPM] transaction started
[2021-02-10T14:09:47+0100] [ALPM] upgraded alsa-card-profiles (14.2-1 → 1:0.3.21-1)
[2021-02-10T14:09:47+0100] [ALPM] upgraded linux-api-headers (5.8-1 → 5.10.13-1)
[2021-02-10T14:09:47+0100] [ALPM] upgraded tzdata (2020f-1 → 2021a-1)
[2021-02-10T14:09:47+0100] [ALPM] upgraded filesystem (2020.09-2 → 2021.01.19-1)
[2021-02-10T14:09:47+0100] [ALPM] upgraded glibc (2.32-5 → 2.33-3)
[2021-02-10T14:09:47+0100] [ALPM-SCRIPTLET] Generating locales…
[2021-02-10T14:09:48+0100] [ALPM-SCRIPTLET] en_US.UTF-8… done
[2021-02-10T14:09:49+0100] [ALPM-SCRIPTLET] de_DE.UTF-8… done
[2021-02-10T14:09:49+0100] [ALPM-SCRIPTLET] Generation complete.
[2021-02-10T14:09:50+0100] [ALPM] upgraded gcc-libs (10.2.0-4 → 10.2.0-6)
[2021-02-10T14:09:50+0100] [ALPM] upgraded e2fsprogs (1.45.6-3 → 1.46.0-1)
[2021-02-10T14:09:50+0100] [ALPM] upgraded libldap (2.4.56-1 → 2.4.57-1)
[2021-02-10T14:09:50+0100] [ALPM] upgraded krb5 (1.18.2-1 → 1.18.3-1)
[2021-02-10T14:09:50+0100] [ALPM] upgraded python-setuptools (1:51.1.2-1 → 1:53.0.0-1)
[2021-02-10T14:09:50+0100] [ALPM] upgraded python-jinja (2.11.2-4 → 2.11.3-1)
[2021-02-10T14:09:50+0100] [ALPM] upgraded ansible-base (2.10.4-1 → 2.10.5-1)
[2021-02-10T14:09:53+0100] [ALPM] upgraded ansible (2.10.5-1 → 2.10.6-1)
[2021-02-10T14:09:54+0100] [ALPM] upgraded archlinux-appstream-data (20201223-1 → 20210125-1)
[2021-02-10T14:09:54+0100] [ALPM] upgraded arduino-cli (0.14.0-1 → 0.14.1-1)
[2021-02-10T14:09:54+0100] [ALPM] upgraded libgcrypt (1.8.7-1 → 1.9.1-1)
[2021-02-10T14:09:54+0100] [ALPM] upgraded asciidoc (9.0.4-2 → 9.0.5-1)
[2021-02-10T14:09:54+0100] [ALPM] upgraded audit (2.8.5-9 → 3.0-1)
[2021-02-10T14:09:54+0100] [ALPM] upgraded autoconf (2.69-7 → 2.71-1)
[2021-02-10T14:09:54+0100] [ALPM] upgraded automake (1.16.2-3 → 1.16.3-1)
[2021-02-10T14:09:54+0100] [ALPM] upgraded sqlite (3.34.0-1 → 3.34.1-1)
[2021-02-10T14:09:54+0100] [ALPM] upgraded zstd (1.4.5-1 → 1.4.8-1)
[2021-02-10T14:09:54+0100] [ALPM] upgraded libtiff (4.1.0-2 → 4.2.0-1)
[2021-02-10T14:09:54+0100] [ALPM] upgraded pam (1.5.0-2 → 1.5.1-1)
[2021-02-10T14:09:54+0100] [ALPM] upgraded libcap (2.46-1 → 2.47-1)
[2021-02-10T14:09:54+0100] [ALPM] upgraded systemd-libs (247.2-1 → 247.3-1)
[2021-02-10T14:09:54+0100] [ALPM] upgraded glib2 (2.66.4-2 → 2.66.6-1)
[2021-02-10T14:09:54+0100] [ALPM] upgraded libcups (1:2.3.3op1-1 → 1:2.3.3op2-1)
[2021-02-10T14:09:54+0100] [ALPM] upgraded wayland (1.18.0-2 → 1.19.0-1)
[2021-02-10T14:09:54+0100] [ALPM] upgraded libunwind (1.3.1-2 → 1.4.0-1)
[2021-02-10T14:09:54+0100] [ALPM] upgraded libedit (20191231_3.1-2 → 20191231_3.1-3)
[2021-02-10T14:09:54+0100] [ALPM] upgraded llvm-libs (11.0.1-1 → 11.0.1-2)
[2021-02-10T14:09:54+0100] [ALPM] upgraded findutils (4.7.0-2 → 4.8.0-1)
[2021-02-10T14:09:54+0100] [ALPM] upgraded ca-certificates-mozilla (3.60.1-1 → 3.61-1)
[2021-02-10T14:09:54+0100] [ALPM] upgraded curl (7.74.0-1 → 7.75.0-1)
[2021-02-10T14:09:54+0100] [ALPM] upgraded libnftnl (1.1.8-1 → 1.1.9-1)
[2021-02-10T14:09:54+0100] [ALPM] upgraded iptables (1:1.8.6-1 → 1:1.8.7-1)
[2021-02-10T14:09:54+0100] [ALPM] upgraded systemd (247.2-1 → 247.3-1)
[2021-02-10T14:09:54+0100] [ALPM] upgraded libevdev (1.10.1-1 → 1.11.0-1)
[2021-02-10T14:09:54+0100] [ALPM] upgraded libwacom (1.7-1 → 1.8-1)
[2021-02-10T14:09:55+0100] [ALPM] upgraded nvidia-utils (460.32.03-1 → 460.39-1)
[2021-02-10T14:09:55+0100] [ALPM-SCRIPTLET] e[1;1me[1;32m==>e[1;0me[1;1m If you run into trouble with CUDA not being available, run nvidia-modprobe first.e[1;0m
[2021-02-10T14:09:55+0100] [ALPM] upgraded mesa (20.3.3-1 → 20.3.4-1)
[2021-02-10T14:09:55+0100] [ALPM] upgraded libxt (1.2.0-2 → 1.2.1-1)
[2021-02-10T14:09:55+0100] [ALPM] upgraded python-urllib3 (1.26.1-1 → 1.26.3-1)
[2021-02-10T14:09:55+0100] [ALPM] upgraded bauh (0.9.13-2 → 0.9.14-1)
[2021-02-10T14:09:55+0100] [ALPM] upgraded lmdb (0.9.27-1 → 0.9.28-1)
[2021-02-10T14:09:55+0100] [ALPM] upgraded bind (9.16.10-1 → 9.16.11-1)
[2021-02-10T14:09:55+0100] [ALPM] upgraded binutils (2.35.1-1 → 2.36-3)
[2021-02-10T14:09:55+0100] [ALPM] upgraded bison (3.7.2-1 → 3.7.3-1)
[2021-02-10T14:09:55+0100] [ALPM] upgraded dav1d (0.7.1-1 → 0.8.1-1)
[2021-02-10T14:09:55+0100] [ALPM] upgraded libpulse (14.2-1 → 14.2-2)
[2021-02-10T14:09:55+0100] [ALPM] upgraded libwebp (1.1.0-1 → 1.2.0-1)
[2021-02-10T14:09:55+0100] [ALPM] upgraded libibus (1.5.23+3+gaa558de8-2 → 1.5.23+3+gaa558de8-3)
[2021-02-10T14:09:56+0100] [ALPM] upgraded ffmpeg (2:4.3.1-3 → 2:4.3.1-4)
[2021-02-10T14:09:56+0100] [ALPM] upgraded nss (3.60.1-1 → 3.61-1)
[2021-02-10T14:09:56+0100] [ALPM] upgraded re2 (1:20201101-1 → 1:20210202-1)
[2021-02-10T14:09:56+0100] [ALPM] upgraded pango (1:1.48.0-1 → 1:1.48.1-1)
[2021-02-10T14:09:56+0100] [ALPM] upgraded librsvg (2:2.50.2-1 → 2:2.50.3-1)
[2021-02-10T14:09:56+0100] [ALPM] upgraded gtk-update-icon-cache (1:4.0.1-2 → 1:4.0.2-1)
[2021-02-10T14:09:56+0100] [ALPM] upgraded js78 (78.6.0-1 → 78.7.1-1)
[2021-02-10T14:09:56+0100] [ALPM] upgraded tar (1.32-3 → 1.33-1)
[2021-02-10T14:09:56+0100] [ALPM] upgraded electron9 (9.4.1-1 → 9.4.2-3)
[2021-02-10T14:09:56+0100] [ALPM] upgraded bitwarden (1.23.1-2 → 1.24.6-1)
[2021-02-10T14:09:56+0100] [ALPM] upgraded procps-ng (3.3.16-2 → 3.3.16-3)
[2021-02-10T14:09:56+0100] [ALPM] upgraded brltty (6.1-5 → 6.2-4)
[2021-02-10T14:09:56+0100] [ALPM-SCRIPTLET] Please add your user to the brlapi group.
[2021-02-10T14:09:56+0100] [ALPM] upgraded btrfs-progs (5.9-3 → 5.10-1)
[2021-02-10T14:09:56+0100] [ALPM] upgraded podofo (0.9.6-3 → 0.9.7-1)
[2021-02-10T14:09:56+0100] [ALPM] upgraded python-markdown (3.3.3-2 → 3.3.3-3)
[2021-02-10T14:09:56+0100] [ALPM] installed python-pycryptodome (3.9.9-3)
[2021-02-10T14:09:56+0100] [ALPM] installed python-py7zr (0.11.3-1)
[2021-02-10T14:09:56+0100] [ALPM] upgraded python-zeroconf (0.28.6-3 → 0.28.8-1)
[2021-02-10T14:09:56+0100] [ALPM] upgraded ttf-droid (20121017-8 → 20121017-9)
[2021-02-10T14:09:57+0100] [ALPM] upgraded qt5-webengine (5.15.2-3 → 5.15.2-5)
[2021-02-10T14:09:57+0100] [ALPM] upgraded parted (3.3-2 → 3.4-1)
[2021-02-10T14:09:57+0100] [ALPM] upgraded libbytesize (2.4-3 → 2.4-4)
[2021-02-10T14:09:57+0100] [ALPM] installed libinih (52-2)
[2021-02-10T14:09:57+0100] [ALPM] upgraded xfsprogs (5.8.0-2 → 5.10.0-1)
[2021-02-10T14:09:57+0100] [ALPM] upgraded gnupg (2.2.26-1 → 2.2.27-1)
[2021-02-10T14:09:57+0100] [ALPM] upgraded libblockdev (2.24-3 → 2.25-1)
[2021-02-10T14:09:57+0100] [ALPM] upgraded calibre (5.9.0-1 → 5.10.1-1)
[2021-02-10T14:09:57+0100] [ALPM] upgraded ccid (1.4.33-1 → 1.4.34-1)
[2021-02-10T14:09:57+0100] [ALPM] upgraded cmake (3.19.3-1 → 3.19.4-1)
[2021-02-10T14:09:58+0100] [ALPM] upgraded cni-plugins (0.9.0-4 → 0.9.0-5)
[2021-02-10T14:09:58+0100] [ALPM] upgraded php (7.4.14-1 → 8.0.2-1)
[2021-02-10T14:09:58+0100] [ALPM] upgraded composer (2.0.8-1 → 2.0.9-1)
[2021-02-10T14:09:58+0100] [ALPM] upgraded conmon (1:2.0.24-1 → 1:2.0.26-1)
[2021-02-10T14:09:58+0100] [ALPM] warning: /etc/containers/seccomp.json installed as /etc/containers/seccomp.json.pacnew
[2021-02-10T14:09:58+0100] [ALPM] upgraded containers-common (0.33.1-1 → 0.34.0-1)
[2021-02-10T14:09:58+0100] [ALPM] upgraded imagemagick (7.0.10.58-1 → 7.0.10.61-1)
[2021-02-10T14:09:58+0100] [ALPM] upgraded poppler (21.01.0-1 → 21.02.0-1)
[2021-02-10T14:09:58+0100] [ALPM] upgraded cups (1:2.3.3op1-1 → 1:2.3.3op2-1)
[2021-02-10T14:09:58+0100] [ALPM] upgraded dnsmasq (2.82-2 → 2.84-1)
[2021-02-10T14:09:58+0100] [ALPM] upgraded runc (1.0.0rc92-1 → 1.0.0rc93-1)
[2021-02-10T14:09:58+0100] [ALPM] upgraded docker (1:20.10.2-1 → 1:20.10.3-1)
[2021-02-10T14:09:58+0100] [ALPM] upgraded python-importlib-metadata (3.3.0-1 → 3.4.0-1)
[2021-02-10T14:09:58+0100] [ALPM] upgraded docker-compose (1.27.4-2 → 1.28.2-1)
[2021-02-10T14:09:59+0100] [ALPM] upgraded electron (11.2.0-1 → 11.2.3-1)
[2021-02-10T14:09:59+0100] [ALPM] upgraded electron6 (6.1.12-3 → 6.1.12-5)
[2021-02-10T14:09:59+0100] [ALPM] upgraded element-web (1.7.16-1 → 1.7.20-1)
[2021-02-10T14:09:59+0100] [ALPM] upgraded element-desktop (1.7.16-1 → 1.7.20-1)
[2021-02-10T14:09:59+0100] [ALPM] upgraded etcher (1.5.114-1 → 1.5.116-1)
[2021-02-10T14:10:00+0100] [ALPM] upgraded firefox (85.0-0.1 → 85.0.1-1)
[2021-02-10T14:10:00+0100] [ALPM] upgraded libinstpatch (1.1.5-1 → 1.1.6-1)
[2021-02-10T14:10:00+0100] [ALPM] upgraded fluidsynth (2.1.6-1 → 2.1.7-1)
[2021-02-10T14:10:00+0100] [ALPM] upgraded fontforge (20200314-5 → 20201107-1)
[2021-02-10T14:10:00+0100] [ALPM] upgraded foomatic-db (3:20200822-1 → 3:20210205-1)
[2021-02-10T14:10:00+0100] [ALPM] upgraded fuse-overlayfs (1.3.0-1 → 1.4.0-1)
[2021-02-10T14:10:00+0100] [ALPM] upgraded fzf (0.25.0-1 → 0.25.1-1)
[2021-02-10T14:10:01+0100] [ALPM] upgraded gcc (10.2.0-4 → 10.2.0-6)
[2021-02-10T14:10:01+0100] [ALPM] upgraded gd (2.3.0-1 → 2.3.1-1)
[2021-02-10T14:10:01+0100] [ALPM] upgraded gitlab-runner (13.7.0-1 → 13.8.0-1)
[2021-02-10T14:10:01+0100] [ALPM] upgraded glibmm (2.64.5-1 → 2.66.0-1)
[2021-02-10T14:10:02+0100] [ALPM] upgraded go (2:1.15.6-1 → 2:1.15.8-1)
[2021-02-10T14:10:02+0100] [ALPM] upgraded pangomm (2.42.2-1 → 2.46.0-1)
[2021-02-10T14:10:02+0100] [ALPM] upgraded gparted (1.1.0-1 → 1.2.0-2)
[2021-02-10T14:10:02+0100] [ALPM] upgraded groff (1.22.4-3 → 1.22.4-4)
[2021-02-10T14:10:02+0100] [ALPM] warning: /etc/default/grub installed as /etc/default/grub.pacnew
[2021-02-10T14:10:03+0100] [ALPM] upgraded grub (2.04-13 → 2.04-15)
[2021-02-10T14:10:03+0100] [ALPM] upgraded gst-plugins-bad-libs (1.18.3-1 → 1.18.3-2)
[2021-02-10T14:10:03+0100] [ALPM] upgraded mjpegtools (2.1.0-5 → 2.2.0beta-1)
[2021-02-10T14:10:03+0100] [ALPM] upgraded zbar (0.23.1-5 → 0.23.1-6)
[2021-02-10T14:10:03+0100] [ALPM] upgraded libshout (1:2.4.4-1 → 1:2.4.5-1)
[2021-02-10T14:10:03+0100] [ALPM] upgraded wavpack (5.3.0-2 → 5.4.0-1)
[2021-02-10T14:10:03+0100] [ALPM] upgraded serd (0.30.8-1 → 0.30.10-1)
[2021-02-10T14:10:03+0100] [ALPM] upgraded gst-plugins-bad (1.18.3-1 → 1.18.3-2)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-hashable (1.3.0.0-69 → 1.3.0.0-86)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-primitive (0.7.1.0-62 → 0.7.1.0-80)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-scientific (0.3.6.2-70 → 0.3.6.2-79)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-attoparsec (0.13.2.4-53 → 0.13.2.4-62)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-base-compat-batteries (0.11.2-43 → 0.11.2-61)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-data-fix (0.3.0-44 → 0.3.0-53)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-dlist (1.0-40 → 1.0-49)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-base-orphans (0.8.4-33 → 0.8.4-50)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-distributive (0.6.2.1-11 → 0.6.2.1-29)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-comonad (5.0.8-10 → 5.0.8-28)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-bifunctors (5.5.9-8 → 5.5.10-13)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-assoc (1.0.2-44 → 1.0.2-53)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-these (1.1.1.1-45 → 1.1.1.1-54)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-strict (0.4.0.1-18 → 0.4.0.1-27)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-time-compat (1.9.5-18 → 1.9.5-27)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-unordered-containers (0.2.13.0-28 → 0.2.13.0-38)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-splitmix (0.1.0.3-38 → 0.1.0.3-56)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-random (1.2.0-108 → 1.2.0-136)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-uuid-types (1.0.3-75 → 1.0.3-84)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-vector (0.12.1.2-103 → 0.12.2.0-10)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-aeson (1.5.5.1-4 → 1.5.5.1-15)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-aeson-pretty (0.8.8-115 → 0.8.8-126)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-colour (2.3.5-108 → 2.3.5-126)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-ansi-terminal (0.11-50 → 0.11-68)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-ansi-wl-pprint (0.6.9-110 → 0.6.9-128)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-hourglass (0.2.12-99 → 0.2.12-108)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-memory (0.15.0-66 → 0.15.0-75)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-asn1-types (0.3.4-54 → 0.3.4-63)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-asn1-encoding (0.9.6-75 → 0.9.6-84)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-asn1-parse (0.9.5-75 → 0.9.5-84)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-async (2.2.2-73 → 2.2.2-90)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-base16-bytestring (1.0.1.0-13 → 1.0.1.0-22)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-base64-bytestring (1.2.0.1-20 → 1.2.0.1-29)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-blaze-builder (0.4.1.0-15 → 0.4.2.1-1)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-blaze-markup (0.8.2.7-44 → 0.8.2.7-54)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-blaze-html (0.9.1.2-74 → 0.9.1.2-84)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-call-stack (0.2.0-84 → 0.3.0-7)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-case-insensitive (1.2.1.0-56 → 1.2.1.0-65)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-text-short (0.1.3-92 → 0.1.3-102)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-cassava (0.5.2.0-88 → 0.5.2.0-98)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-megaparsec (9.0.1-15 → 9.0.1-24)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-cassava-megaparsec (2.0.2-43 → 2.0.2-53)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-data-default-instances-dlist (0.0.1-117 → 0.0.1-126)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-data-default (0.7.1.1-104 → 0.7.1.1-113)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-quickcheck (2.14.2-62 → 2.14.2-87)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-syb (0.7.1-8 → 0.7.2.1-8)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-pandoc-types (1.22-34 → 1.22-45)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-uniplate (1.6.13-21 → 1.6.13-31)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-split (0.2.3.4-98 → 0.2.3.4-107)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-vector-algorithms (0.8.0.4-18 → 0.8.0.4-27)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-mono-traversable (1.0.15.1-93 → 1.0.15.1-103)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-resourcet (1.2.4.2-48 → 1.2.4.2-57)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-conduit (1.3.4-22 → 1.3.4-32)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-network (3.1.2.1-18 → 3.1.2.1-27)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-streaming-commons (0.2.2.1-45 → 0.2.2.1-54)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-typed-process (0.2.6.0-80 → 0.2.6.0-89)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-conduit-extra (1.3.5-89 → 1.3.5-99)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-xml-conduit (1.9.0.0-96 → 1.9.0.0-107)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-citeproc (0.3.0.1-1 → 0.3.0.3-1)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-clock (0.8-8 → 0.8.2-1)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-cmark-gfm (0.2.2-32 → 0.2.2-41)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-commonmark (0.1.1.3-1 → 0.1.1.3-10)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-emojis (0.1-64 → 0.1-73)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-commonmark-extensions (0.2.0.4-19 → 0.2.0.4-28)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-commonmark-pandoc (0.2.0.1-51 → 0.2.0.1-62)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-socks (0.6.1-76 → 0.6.1-85)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-cryptonite (0.27-49 → 0.28-5)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-pem (0.2.4-131 → 0.2.4-140)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-x509 (1.7.5-109 → 1.7.5-119)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-x509-store (1.6.7-108 → 1.6.7-118)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-x509-validation (1.6.11-108 → 1.6.11-118)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-tls (1.5.4-64 → 1.5.4-74)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-x509-system (1.6.6-176 → 1.6.6-186)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-connection (0.3.1-84 → 0.3.1-94)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-decimal (0.5.1-94 → 0.5.1-103)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-doclayout (0.3-62 → 0.3-72)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-hsyaml (0.2.1.0-69 → 0.2.1.0-78)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-text-conversions (0.3.1-34 → 0.3.1-43)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-doctemplates (0.9-1 → 0.9-12)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-extra (1.7.9-15 → 1.7.9-25)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-glob (0.10.1-45 → 0.10.1-54)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-haddock-library (1.9.0-83 → 1.9.0-95)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-hashtables (1.2.4.1-31 → 1.2.4.1-40)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-prettyprinter (1.7.0-47 → 1.7.0-57)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-prettyprinter-ansi-terminal (1.1.2-56 → 1.1.2-66)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-pretty-simple (4.0.0.0-38 → 4.0.0.0-48)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-optparse-applicative (0.16.1.0-38 → 0.16.1.0-56)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-tasty (1.3.1-110 → 1.3.1-129)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-tasty-hunit (0.10.0.3-39 → 0.10.0.3-62)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-utf8-string (1.0.2-3 → 1.0.2-12)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-hledger-lib (1.20.2-11 → 1.20.4-1)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-hslua (1.3.0-22 → 1.3.0-34)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-temporary (1.3-176 → 1.3-196)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-hslua-module-system (0.2.2.1-38 → 0.2.2.1-50)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-hslua-module-text (0.3.0.1-26 → 0.3.0.1-38)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-network-uri (2.6.3.0-220 → 2.6.3.0-232)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-http (4000.3.15-76 → 4000.3.15-93)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-http-types (0.12.3-118 → 0.12.3-128)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-http-client (0.7.4-1 → 0.7.5-2)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-http-client-tls (0.3.5.3-361 → 0.3.5.3-376)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-hxt (9.3.1.18-201 → 9.3.1.18-213)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-ipynb (0.1.0.1-149 → 0.1.0.1-161)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-jira-wiki-markup (1.3.2-44 → 1.3.2-53)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-juicypixels (3.3.5-54 → 3.3.5-63)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-mmorph (1.1.3-10 → 1.1.4-1)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-lucid (2.9.12-80 → 2.9.12-92)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-math-functions (0.3.4.1-75 → 0.3.4.1-97)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-shakespeare (2.0.25-53 → 2.0.25-65)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-skylighting-core (0.10.2-1 → 0.10.2-14)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-skylighting (0.10.2-1 → 0.10.2-14)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-tagsoup (0.14.8-79 → 0.14.8-88)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-texmath (0.12.1-9 → 0.12.1-21)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-unicode-transforms (0.3.7.1-28 → 0.3.7.1-37)
[2021-02-10T14:10:03+0100] [ALPM] upgraded haskell-zip-archive (0.4.1-83 → 0.4.1-92)
[2021-02-10T14:10:03+0100] [ALPM] upgraded hledger (1.20.2-11 → 1.20.4-1)
[2021-02-10T14:10:03+0100] [ALPM] upgraded perl-uri (5.05-1 → 5.07-1)
[2021-02-10T14:10:03+0100] [ALPM] upgraded hwinfo (21.71-1 → 21.72-1)
[2021-02-10T14:10:03+0100] [ALPM] upgraded i3-gaps (4.19-1 → 4.19.1-1)
[2021-02-10T14:10:03+0100] [ALPM] upgraded inxi (3.2.02.2-1 → 3.3.00.1-1)
[2021-02-10T14:10:03+0100] [ALPM] upgraded python-prompt_toolkit (3.0.10-1 → 3.0.14-1)
[2021-02-10T14:10:03+0100] [ALPM] upgraded ipython (7.19.0-4 → 7.19.0-5)
[2021-02-10T14:10:03+0100] [ALPM] upgraded jasper (2.0.19-1 → 2.0.24-1)
[2021-02-10T14:10:04+0100] [ALPM] upgraded jre-openjdk-headless (15.0.1.u9-1 → 15.0.2.u7-1)
[2021-02-10T14:10:04+0100] [ALPM] upgraded jre-openjdk (15.0.1.u9-1 → 15.0.2.u7-1)
[2021-02-10T14:10:04+0100] [ALPM] upgraded jre11-openjdk-headless (11.0.10.u8-2 → 11.0.10.u9-1)
[2021-02-10T14:10:04+0100] [ALPM] upgraded jre11-openjdk (11.0.10.u8-2 → 11.0.10.u9-1)
[2021-02-10T14:10:04+0100] [ALPM] upgraded python-bleach (3.2.1-3 → 3.2.3-1)
[2021-02-10T14:10:04+0100] [ALPM] upgraded python-entrypoints (0.3-5 → 0.3-6)
[2021-02-10T14:10:04+0100] [ALPM] upgraded jupyter-notebook (6.1.6-1 → 6.2.0-1)
[2021-02-10T14:10:04+0100] [ALPM] upgraded jupyter (4.6.3-1 → 4.6.3-2)
[2021-02-10T14:10:04+0100] [ALPM] upgraded libnm (1.28.1dev+7+g3f5df3cdc6-1 → 1.28.1dev+16+gdaad4e2fee-1)
[2021-02-10T14:10:04+0100] [ALPM] upgraded python-numpy (1.19.5-1 → 1.20.0-1)
[2021-02-10T14:10:04+0100] [ALPM] installed libwebsockets (4.1.6-1)
[2021-02-10T14:10:04+0100] [ALPM] upgraded kismet (2020_09_R4-2 → 2020_12_R3-1)
[2021-02-10T14:10:04+0100] [ALPM] upgraded lib32-glibc (2.32-5 → 2.33-3)
[2021-02-10T14:10:04+0100] [ALPM] upgraded lib32-e2fsprogs (1.45.6-1 → 1.46.0-1)
[2021-02-10T14:10:04+0100] [ALPM] upgraded lib32-libldap (2.4.56-1 → 2.4.57-1)
[2021-02-10T14:10:04+0100] [ALPM] upgraded lib32-curl (7.74.0-1 → 7.75.0-1)
[2021-02-10T14:10:05+0100] [ALPM] upgraded lib32-gcc-libs (10.2.0-4 → 10.2.0-6)
[2021-02-10T14:10:05+0100] [ALPM] upgraded lib32-libelf (0.181-1 → 0.182-1)
[2021-02-10T14:10:05+0100] [ALPM] upgraded lib32-wayland (1.18.0-2 → 1.19.0-1)
[2021-02-10T14:10:05+0100] [ALPM] upgraded lib32-llvm-libs (11.0.1-1 → 11.0.1-2)
[2021-02-10T14:10:05+0100] [ALPM] upgraded lib32-mesa (20.3.3-1 → 20.3.4-1)
[2021-02-10T14:10:05+0100] [ALPM] upgraded mhwd-nvidia (460.32.03-1 → 460.39-1)
[2021-02-10T14:10:05+0100] [ALPM] upgraded lib32-nvidia-utils (460.32.03-1 → 460.39-1)
[2021-02-10T14:10:05+0100] [ALPM] upgraded lib32-libva (2.8.0-1 → 2.10.0-1)
[2021-02-10T14:10:05+0100] [ALPM] upgraded lib32-libxt (1.2.0-1 → 1.2.1-1)
[2021-02-10T14:10:05+0100] [ALPM] upgraded lib32-mesa-vdpau (20.3.3-1 → 20.3.4-1)
[2021-02-10T14:10:05+0100] [ALPM] upgraded lib32-vulkan-intel (20.3.3-1 → 20.3.4-1)
[2021-02-10T14:10:05+0100] [ALPM] upgraded lib32-vulkan-radeon (20.3.3-1 → 20.3.4-1)
[2021-02-10T14:10:05+0100] [ALPM] upgraded libcurl-gnutls (7.74.0-1 → 7.75.0-1)
[2021-02-10T14:10:05+0100] [ALPM] upgraded libheif (1.10.0-1 → 1.11.0-1)
[2021-02-10T14:10:05+0100] [ALPM] upgraded libical (3.0.8-3 → 3.0.9-1)
[2021-02-10T14:10:05+0100] [ALPM] upgraded libldm (0.2.4.r20.a856552-1 → 0.2.4.r22.63883d8-1)
[2021-02-10T14:10:05+0100] [ALPM] upgraded libmbim (1.24.4-1 → 1.24.6-1)
[2021-02-10T14:10:05+0100] [ALPM] upgraded libmediainfo (20.08-1 → 20.09-1)
[2021-02-10T14:10:05+0100] [ALPM] upgraded libnumbertext (1.0.6-1 → 1.0.7-1)
[2021-02-10T14:10:05+0100] [ALPM] upgraded libodfgen (0.1.7-2 → 0.1.8-1)
[2021-02-10T14:10:05+0100] [ALPM] upgraded libplacebo (2.72.2-1 → 3.104.0-1)
[2021-02-10T14:10:07+0100] [ALPM] upgraded libreoffice-still (6.4.7-9 → 7.0.4-1)
[2021-02-10T14:10:07+0100] [ALPM] upgraded libsigsegv (2.12-2 → 2.13-1)
[2021-02-10T14:10:07+0100] [ALPM] upgraded libsynctex (2020.54586-9 → 2020.54586-10)
[2021-02-10T14:10:07+0100] [ALPM] upgraded libtorrent-rasterbar (1:1.2.10-7 → 1:1.2.11-1)
[2021-02-10T14:10:07+0100] [ALPM] upgraded liburcu (0.11.0-2 → 0.11.2-1)
[2021-02-10T14:10:07+0100] [ALPM] upgraded libva-mesa-driver (20.3.3-1 → 20.3.4-1)
[2021-02-10T14:10:07+0100] [ALPM] upgraded poppler-glib (21.01.0-1 → 21.02.0-1)
[2021-02-10T14:10:07+0100] [ALPM] upgraded libvips (8.10.2-1 → 8.10.2-2)
[2021-02-10T14:10:07+0100] [ALPM] warning: /etc/libvirt/qemu/networks/default.xml installed as /etc/libvirt/qemu/networks/default.xml.pacnew
[2021-02-10T14:10:07+0100] [ALPM] upgraded libvirt (1:6.5.0-3 → 1:7.0.0-2)
[2021-02-10T14:10:07+0100] [ALPM] upgraded libxnvctrl (460.27.04-1 → 460.39-1)
[2021-02-10T14:10:08+0100] [ALPM] upgraded linux-firmware (20210109.r1812.d528862-1 → 20210119.r1813.0578970-1)
[2021-02-10T14:10:08+0100] [ALPM] upgraded linux414 (4.14.215-1 → 4.14.219-1)
[2021-02-10T14:10:08+0100] [ALPM] upgraded linux414-nvidia (460.32.03-3 → 460.39-3)
[2021-02-10T14:10:13+0100] [ALPM] upgraded linux414-virtualbox-host-modules (6.1.16-13 → 6.1.18-4)
[2021-02-10T14:10:16+0100] [ALPM-SCRIPTLET] In order to use the new version, reload all virtualbox modules manually.
[2021-02-10T14:10:17+0100] [ALPM] upgraded linux510 (5.10.7-3 → 5.10.13-2)
[2021-02-10T14:10:17+0100] [ALPM] upgraded linux510-nvidia (460.32.03-6 → 460.39-7)
[2021-02-10T14:10:22+0100] [ALPM] upgraded linux510-virtualbox-host-modules (6.1.16-19 → 6.1.18-8)
[2021-02-10T14:10:28+0100] [ALPM-SCRIPTLET] In order to use the new version, reload all virtualbox modules manually.
[2021-02-10T14:10:28+0100] [ALPM] upgraded linux54 (5.4.89-1 → 5.4.95-1)
[2021-02-10T14:10:28+0100] [ALPM] upgraded linux54-nvidia (460.32.03-3 → 460.39-4)
[2021-02-10T14:10:34+0100] [ALPM] upgraded linux54-virtualbox-host-modules (6.1.16-17 → 6.1.18-5)
[2021-02-10T14:10:39+0100] [ALPM-SCRIPTLET] In order to use the new version, reload all virtualbox modules manually.
[2021-02-10T14:10:39+0100] [ALPM] upgraded linux59-nvidia (460.32.03-1 → 460.39-1)
[2021-02-10T14:10:46+0100] [ALPM] upgraded linux59-virtualbox-host-modules (6.1.16-14 → 6.1.18-1)
[2021-02-10T14:10:51+0100] [ALPM-SCRIPTLET] In order to use the new version, reload all virtualbox modules manually.
[2021-02-10T14:10:52+0100] [ALPM] upgraded matcha-gtk-theme (20210112-1 → 20210204-1)
[2021-02-10T14:10:52+0100] [ALPM] upgraded mediainfo (20.08-1 → 20.09-1)
[2021-02-10T14:10:52+0100] [ALPM] upgraded mesa-vdpau (20.3.3-1 → 20.3.4-1)
[2021-02-10T14:10:52+0100] [ALPM] upgraded mousepad (0.5.1-1 → 0.5.2-1)
[2021-02-10T14:10:52+0100] [ALPM] upgraded multipath-tools (0.8.5-1 → 0.8.5-2)
[2021-02-10T14:10:52+0100] [ALPM] upgraded mutt (2.0.4-1 → 2.0.5-1)
[2021-02-10T14:10:52+0100] [ALPM] upgraded net-tools (1.60.20181103git-2 → 2.10-1)
[2021-02-10T14:10:52+0100] [ALPM] upgraded nm-connection-editor (1.18.0-1 → 1.20.0-1)
[2021-02-10T14:10:52+0100] [ALPM] upgraded networkmanager (1.28.1dev+7+g3f5df3cdc6-1 → 1.28.1dev+16+gdaad4e2fee-1)
[2021-02-10T14:10:52+0100] [ALPM] upgraded network-manager-applet (1.18.0-1 → 1.20.0-1)
[2021-02-10T14:10:52+0100] [ALPM] upgraded ppp (2.4.7-7 → 2.4.8-1)
[2021-02-10T14:10:52+0100] [ALPM] upgraded networkmanager-pptp (1.2.9dev+10+gb41b0d0-2 → 1.2.9dev+10+gb41b0d0-3)
[2021-02-10T14:10:52+0100] [ALPM] installed qt5-websockets (5.15.2-1)
[2021-02-10T14:10:52+0100] [ALPM] upgraded nextcloud-client (3.1.1-1 → 3.1.2-1)
[2021-02-10T14:10:52+0100] [ALPM] upgraded nodejs (15.6.0-1 → 15.8.0-1)
[2021-02-10T14:10:52+0100] [ALPM] upgraded node-gyp (7.1.1-1 → 7.1.2-1)
[2021-02-10T14:10:52+0100] [ALPM] upgraded opera-ffmpeg-codecs (87.0.4280.141-1 → 88.0.4324.104-1)
[2021-02-10T14:10:52+0100] [ALPM] upgraded p7zip (17.03-1 → 17.03-2)
[2021-02-10T14:10:52+0100] [ALPM] upgraded pandoc (2.11.3-3 → 2.11.3-23)
[2021-02-10T14:10:57+0100] [ALPM] upgraded papirus-icon-theme (20210101-1 → 20210201-1)
[2021-02-10T14:10:57+0100] [ALPM] upgraded python-pikepdf (2.4.0-1 → 2.5.2-1)
[2021-02-10T14:10:57+0100] [ALPM] upgraded pdfarranger (1.6.2-2 → 1.7.0-2)
[2021-02-10T14:10:57+0100] [ALPM] upgraded perl-image-exiftool (12.00-2 → 12.16-1)
[2021-02-10T14:10:57+0100] [ALPM] upgraded poppler-qt5 (21.01.0-1 → 21.02.0-1)
[2021-02-10T14:10:57+0100] [ALPM] upgraded pulseaudio (14.2-1 → 14.2-2)
[2021-02-10T14:10:57+0100] [ALPM] upgraded pulseaudio-bluetooth (14.2-1 → 14.2-2)
[2021-02-10T14:10:57+0100] [ALPM] upgraded pulseaudio-equalizer (14.2-1 → 14.2-2)
[2021-02-10T14:10:57+0100] [ALPM] upgraded python-keyring (21.8.0-1 → 22.0.1-1)
[2021-02-10T14:10:57+0100] [ALPM] upgraded python-levenshtein (0.12.0-10 → 0.12.2-1)
[2021-02-10T14:10:57+0100] [ALPM] upgraded python-mccabe (0.6.1-7 → 0.6.1-8)
[2021-02-10T14:10:57+0100] [ALPM] upgraded python-orjson (3.4.6-1 → 3.4.8-1)
[2021-02-10T14:10:57+0100] [ALPM] upgraded python-pip (20.2.4-1 → 20.3.1-1)
[2021-02-10T14:10:57+0100] [ALPM] upgraded python-pymongo (3.11.2-1 → 3.11.3-1)
[2021-02-10T14:10:57+0100] [ALPM] upgraded python-pytz (2020.5-1 → 2021.1-1)
[2021-02-10T14:10:57+0100] [ALPM] upgraded python-reportlab (3.5.59-1 → 3.5.60-1)
[2021-02-10T14:10:57+0100] [ALPM] upgraded python-setproctitle (1.2.1-1 → 1.2.2-1)
[2021-02-10T14:10:57+0100] [ALPM] upgraded python-shellingham (1.3.1-6 → 1.4.0-1)
[2021-02-10T14:10:57+0100] [ALPM] upgraded python-snowballstemmer (2.0.0-6 → 2.1.0-1)
[2021-02-10T14:10:57+0100] [ALPM] upgraded python-ujson (4.0.1-3 → 4.0.2-1)
[2021-02-10T14:10:57+0100] [ALPM] upgraded python-virtualenv (20.3.0-2 → 20.4.2-1)
[2021-02-10T14:10:57+0100] [ALPM] upgraded python2-gobject2 (2.28.7-6 → 2.28.7-6.1)
[2021-02-10T14:10:57+0100] [ALPM] upgraded qbittorrent (4.3.1-1 → 4.3.3-1)
[2021-02-10T14:10:57+0100] [ALPM] upgraded rclone (1.53.3-1 → 1.54.0-1)
[2021-02-10T14:10:57+0100] [ALPM] upgraded rubygems (3.1.4-1 → 3.2.7-1)
[2021-02-10T14:10:57+0100] [ALPM] upgraded ruby-reline (0.2.0-1 → 0.2.2-1)
[2021-02-10T14:10:57+0100] [ALPM] upgraded scrot (1.4-1 → 1.5-1)
[2021-02-10T14:10:58+0100] [ALPM] upgraded signal-desktop (1.39.5-1 → 1.39.6-1)
[2021-02-10T14:10:58+0100] [ALPM] upgraded talloc (2.3.1-5 → 2.3.2-1)
[2021-02-10T14:10:58+0100] [ALPM] upgraded smbclient (4.13.3-2 → 4.13.4-1)
[2021-02-10T14:10:58+0100] [ALPM] upgraded sudo (1.9.5.p2-0.1 → 1.9.5.p2-1)
[2021-02-10T14:10:58+0100] [ALPM] upgraded systemd-sysvcompat (247.2-1 → 247.3-1)
[2021-02-10T14:10:58+0100] [ALPM] upgraded tailscale (1.2.10-2 → 1.4.2-1)
[2021-02-10T14:10:58+0100] [ALPM] upgraded terraform (0.14.4-1 → 0.14.6-1)
[2021-02-10T14:10:58+0100] [ALPM] upgraded texlive-bin (2020.54586-9 → 2020.54586-10)
[2021-02-10T14:10:58+0100] [ALPM] upgraded thunderbird (78.7.0-0.1 → 78.7.1-0.3)
[2021-02-10T14:10:58+0100] [ALPM] upgraded tlpui (1.3.1.5-1 → 1.3.1.7-1)
[2021-02-10T14:10:59+0100] [ALPM] upgraded vim-runtime (8.2.2347-1 → 8.2.2380-1)
[2021-02-10T14:10:59+0100] [ALPM] upgraded vim (8.2.2347-1 → 8.2.2380-1)
[2021-02-10T14:10:59+0100] [ALPM] upgraded virtualbox (6.1.16-4 → 6.1.18-1)
[2021-02-10T14:10:59+0100] [ALPM] upgraded virtualbox-guest-iso (6.1.16-1 → 6.1.18-1)
[2021-02-10T14:10:59+0100] [ALPM] upgraded vlc (3.0.11.1-6 → 3.0.12-1)
[2021-02-10T14:10:59+0100] [ALPM] upgraded vulkan-intel (20.3.3-1 → 20.3.4-1)
[2021-02-10T14:10:59+0100] [ALPM] upgraded vulkan-radeon (20.3.3-1 → 20.3.4-1)
[2021-02-10T14:10:59+0100] [ALPM] upgraded wireshark-cli (3.4.2-1 → 3.4.3-2)
[2021-02-10T14:10:59+0100] [ALPM] upgraded wireshark-qt (3.4.2-1 → 3.4.3-2)
[2021-02-10T14:10:59+0100] [ALPM] upgraded xarchiver (0.5.4.16-1 → 0.5.4.17-1)
[2021-02-10T14:10:59+0100] [ALPM] upgraded xf86-video-nouveau (1.0.16-2 → 1.0.17-1)
[2021-02-10T14:10:59+0100] [ALPM] upgraded xterm (363-1 → 365-1)
[2021-02-10T14:10:59+0100] [ALPM] upgraded yara (4.0.2-1 → 4.0.4-1)
[2021-02-10T14:10:59+0100] [ALPM] upgraded yay (10.1.2-1 → 10.1.2-2)
[2021-02-10T14:11:00+0100] [ALPM] transaction completed
[2021-02-10T14:11:04+0100] [ALPM] running ‘20-systemd-sysusers.hook’…
[2021-02-10T14:11:04+0100] [ALPM-SCRIPTLET] Creating group brltty with gid 960.
[2021-02-10T14:11:04+0100] [ALPM-SCRIPTLET] Creating user brltty (Braille Device Daemon) with uid 960 and gid 960.
[2021-02-10T14:11:04+0100] [ALPM] running ‘30-systemd-catalog.hook’…
[2021-02-10T14:11:04+0100] [ALPM] running ‘30-systemd-daemon-reload.hook’…
[2021-02-10T14:11:04+0100] [ALPM] running ‘30-systemd-hwdb.hook’…
[2021-02-10T14:11:04+0100] [ALPM] running ‘30-systemd-sysctl.hook’…
[2021-02-10T14:11:04+0100] [ALPM-SCRIPTLET] Not setting net/ipv4/conf/all/rp_filter (explicit setting exists).
[2021-02-10T14:11:04+0100] [ALPM-SCRIPTLET] Not setting net/ipv4/conf/default/rp_filter (explicit setting exists).
[2021-02-10T14:11:04+0100] [ALPM-SCRIPTLET] Not setting net/ipv4/conf/all/accept_source_route (explicit setting exists).
[2021-02-10T14:11:04+0100] [ALPM-SCRIPTLET] Not setting net/ipv4/conf/default/accept_source_route (explicit setting exists).
[2021-02-10T14:11:04+0100] [ALPM-SCRIPTLET] Not setting net/ipv4/conf/all/promote_secondaries (explicit setting exists).
[2021-02-10T14:11:04+0100] [ALPM-SCRIPTLET] Not setting net/ipv4/conf/default/promote_secondaries (explicit setting exists).
[2021-02-10T14:11:04+0100] [ALPM] running ‘30-systemd-tmpfiles.hook’…
[2021-02-10T14:11:04+0100] [ALPM] running ‘30-systemd-udev-reload.hook’…
[2021-02-10T14:11:04+0100] [ALPM] running ‘30-systemd-update.hook’…
[2021-02-10T14:11:04+0100] [ALPM] running ‘40-update-ca-trust.hook’…
[2021-02-10T14:11:05+0100] [ALPM] running ‘60-depmod.hook’…
[2021-02-10T14:11:20+0100] [ALPM] running ‘80-cronie.hook’…
[2021-02-10T14:11:20+0100] [ALPM] running ‘90-mkinitcpio-install.hook’…
[2021-02-10T14:11:20+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux414.preset: ‘default’
[2021-02-10T14:11:20+0100] [ALPM-SCRIPTLET] → -k /boot/vmlinuz-4.14-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.14-x86_64.img
[2021-02-10T14:11:20+0100] [ALPM-SCRIPTLET] ==> Starting build: 4.14.219-1-MANJARO
[2021-02-10T14:11:20+0100] [ALPM-SCRIPTLET] → Running build hook: [base]
[2021-02-10T14:11:20+0100] [ALPM-SCRIPTLET] → Running build hook: [udev]
[2021-02-10T14:11:20+0100] [ALPM-SCRIPTLET] → Running build hook: [autodetect]
[2021-02-10T14:11:20+0100] [ALPM-SCRIPTLET] → Running build hook: [modconf]
[2021-02-10T14:11:20+0100] [ALPM-SCRIPTLET] → Running build hook: [block]
[2021-02-10T14:11:20+0100] [ALPM-SCRIPTLET] → Running build hook: [keyboard]
[2021-02-10T14:11:20+0100] [ALPM-SCRIPTLET] → Running build hook: [keymap]
[2021-02-10T14:11:20+0100] [ALPM-SCRIPTLET] → Running build hook: [resume]
[2021-02-10T14:11:20+0100] [ALPM-SCRIPTLET] → Running build hook: [filesystems]
[2021-02-10T14:11:21+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-02-10T14:11:21+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-4.14-x86_64.img
[2021-02-10T14:11:21+0100] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-02-10T14:11:21+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux414.preset: ‘fallback’
[2021-02-10T14:11:21+0100] [ALPM-SCRIPTLET] → -k /boot/vmlinuz-4.14-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.14-x86_64-fallback.img -S autodetect
[2021-02-10T14:11:21+0100] [ALPM-SCRIPTLET] ==> Starting build: 4.14.219-1-MANJARO
[2021-02-10T14:11:21+0100] [ALPM-SCRIPTLET] → Running build hook: [base]
[2021-02-10T14:11:22+0100] [ALPM-SCRIPTLET] → Running build hook: [udev]
[2021-02-10T14:11:22+0100] [ALPM-SCRIPTLET] → Running build hook: [modconf]
[2021-02-10T14:11:22+0100] [ALPM-SCRIPTLET] → Running build hook: [block]
[2021-02-10T14:11:23+0100] [ALPM-SCRIPTLET] → Running build hook: [keyboard]
[2021-02-10T14:11:24+0100] [ALPM-SCRIPTLET] → Running build hook: [keymap]
[2021-02-10T14:11:24+0100] [ALPM-SCRIPTLET] → Running build hook: [resume]
[2021-02-10T14:11:24+0100] [ALPM-SCRIPTLET] → Running build hook: [filesystems]
[2021-02-10T14:11:25+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-02-10T14:11:25+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-4.14-x86_64-fallback.img
[2021-02-10T14:11:28+0100] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-02-10T14:11:28+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: ‘default’
[2021-02-10T14:11:28+0100] [ALPM-SCRIPTLET] → -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
[2021-02-10T14:11:28+0100] [ALPM-SCRIPTLET] ==> Starting build: 5.10.13-2-MANJARO
[2021-02-10T14:11:29+0100] [ALPM-SCRIPTLET] → Running build hook: [base]
[2021-02-10T14:11:29+0100] [ALPM-SCRIPTLET] → Running build hook: [udev]
[2021-02-10T14:11:29+0100] [ALPM-SCRIPTLET] → Running build hook: [autodetect]
[2021-02-10T14:11:29+0100] [ALPM-SCRIPTLET] → Running build hook: [modconf]
[2021-02-10T14:11:29+0100] [ALPM-SCRIPTLET] → Running build hook: [block]
[2021-02-10T14:11:29+0100] [ALPM-SCRIPTLET] → Running build hook: [keyboard]
[2021-02-10T14:11:29+0100] [ALPM-SCRIPTLET] → Running build hook: [keymap]
[2021-02-10T14:11:29+0100] [ALPM-SCRIPTLET] → Running build hook: [resume]
[2021-02-10T14:11:29+0100] [ALPM-SCRIPTLET] → Running build hook: [filesystems]
[2021-02-10T14:11:29+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-02-10T14:11:29+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
[2021-02-10T14:11:30+0100] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-02-10T14:11:30+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: ‘fallback’
[2021-02-10T14:11:30+0100] [ALPM-SCRIPTLET] → -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
[2021-02-10T14:11:30+0100] [ALPM-SCRIPTLET] ==> Starting build: 5.10.13-2-MANJARO
[2021-02-10T14:11:30+0100] [ALPM-SCRIPTLET] → Running build hook: [base]
[2021-02-10T14:11:30+0100] [ALPM-SCRIPTLET] → Running build hook: [udev]
[2021-02-10T14:11:30+0100] [ALPM-SCRIPTLET] → Running build hook: [modconf]
[2021-02-10T14:11:30+0100] [ALPM-SCRIPTLET] → Running build hook: [block]
[2021-02-10T14:11:32+0100] [ALPM-SCRIPTLET] → Running build hook: [keyboard]
[2021-02-10T14:11:33+0100] [ALPM-SCRIPTLET] → Running build hook: [keymap]
[2021-02-10T14:11:33+0100] [ALPM-SCRIPTLET] → Running build hook: [resume]
[2021-02-10T14:11:33+0100] [ALPM-SCRIPTLET] → Running build hook: [filesystems]
[2021-02-10T14:11:35+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-02-10T14:11:35+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
[2021-02-10T14:11:38+0100] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-02-10T14:11:39+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: ‘default’
[2021-02-10T14:11:39+0100] [ALPM-SCRIPTLET] → -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64.img
[2021-02-10T14:11:39+0100] [ALPM-SCRIPTLET] ==> Starting build: 5.4.95-1-MANJARO
[2021-02-10T14:11:39+0100] [ALPM-SCRIPTLET] → Running build hook: [base]
[2021-02-10T14:11:39+0100] [ALPM-SCRIPTLET] → Running build hook: [udev]
[2021-02-10T14:11:39+0100] [ALPM-SCRIPTLET] → Running build hook: [autodetect]
[2021-02-10T14:11:39+0100] [ALPM-SCRIPTLET] → Running build hook: [modconf]
[2021-02-10T14:11:39+0100] [ALPM-SCRIPTLET] → Running build hook: [block]
[2021-02-10T14:11:39+0100] [ALPM-SCRIPTLET] → Running build hook: [keyboard]
[2021-02-10T14:11:39+0100] [ALPM-SCRIPTLET] → Running build hook: [keymap]
[2021-02-10T14:11:39+0100] [ALPM-SCRIPTLET] → Running build hook: [resume]
[2021-02-10T14:11:39+0100] [ALPM-SCRIPTLET] → Running build hook: [filesystems]
[2021-02-10T14:11:39+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-02-10T14:11:39+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64.img
[2021-02-10T14:11:40+0100] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-02-10T14:11:40+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: ‘fallback’
[2021-02-10T14:11:40+0100] [ALPM-SCRIPTLET] → -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64-fallback.img -S autodetect
[2021-02-10T14:11:40+0100] [ALPM-SCRIPTLET] ==> Starting build: 5.4.95-1-MANJARO
[2021-02-10T14:11:40+0100] [ALPM-SCRIPTLET] → Running build hook: [base]
[2021-02-10T14:11:41+0100] [ALPM-SCRIPTLET] → Running build hook: [udev]
[2021-02-10T14:11:41+0100] [ALPM-SCRIPTLET] → Running build hook: [modconf]
[2021-02-10T14:11:41+0100] [ALPM-SCRIPTLET] → Running build hook: [block]
[2021-02-10T14:11:43+0100] [ALPM-SCRIPTLET] → Running build hook: [keyboard]
[2021-02-10T14:11:43+0100] [ALPM-SCRIPTLET] → Running build hook: [keymap]
[2021-02-10T14:11:43+0100] [ALPM-SCRIPTLET] → Running build hook: [resume]
[2021-02-10T14:11:43+0100] [ALPM-SCRIPTLET] → Running build hook: [filesystems]
[2021-02-10T14:11:45+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-02-10T14:11:45+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64-fallback.img
[2021-02-10T14:11:50+0100] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-02-10T14:11:50+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: ‘default’
[2021-02-10T14:11:50+0100] [ALPM-SCRIPTLET] → -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64.img
[2021-02-10T14:11:50+0100] [ALPM-SCRIPTLET] ==> Starting build: 5.9.16-1-MANJARO
[2021-02-10T14:11:50+0100] [ALPM-SCRIPTLET] → Running build hook: [base]
[2021-02-10T14:11:50+0100] [ALPM-SCRIPTLET] → Running build hook: [udev]
[2021-02-10T14:11:50+0100] [ALPM-SCRIPTLET] → Running build hook: [autodetect]
[2021-02-10T14:11:50+0100] [ALPM-SCRIPTLET] → Running build hook: [modconf]
[2021-02-10T14:11:50+0100] [ALPM-SCRIPTLET] → Running build hook: [block]
[2021-02-10T14:11:50+0100] [ALPM-SCRIPTLET] → Running build hook: [keyboard]
[2021-02-10T14:11:50+0100] [ALPM-SCRIPTLET] → Running build hook: [keymap]
[2021-02-10T14:11:50+0100] [ALPM-SCRIPTLET] → Running build hook: [resume]
[2021-02-10T14:11:50+0100] [ALPM-SCRIPTLET] → Running build hook: [filesystems]
[2021-02-10T14:11:51+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-02-10T14:11:51+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64.img
[2021-02-10T14:11:51+0100] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-02-10T14:11:51+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: ‘fallback’
[2021-02-10T14:11:51+0100] [ALPM-SCRIPTLET] → -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64-fallback.img -S autodetect
[2021-02-10T14:11:51+0100] [ALPM-SCRIPTLET] ==> Starting build: 5.9.16-1-MANJARO
[2021-02-10T14:11:51+0100] [ALPM-SCRIPTLET] → Running build hook: [base]
[2021-02-10T14:11:52+0100] [ALPM-SCRIPTLET] → Running build hook: [udev]
[2021-02-10T14:11:52+0100] [ALPM-SCRIPTLET] → Running build hook: [modconf]
[2021-02-10T14:11:52+0100] [ALPM-SCRIPTLET] → Running build hook: [block]
[2021-02-10T14:11:54+0100] [ALPM-SCRIPTLET] → Running build hook: [keyboard]
[2021-02-10T14:11:55+0100] [ALPM-SCRIPTLET] → Running build hook: [keymap]
[2021-02-10T14:11:55+0100] [ALPM-SCRIPTLET] → Running build hook: [resume]
[2021-02-10T14:11:55+0100] [ALPM-SCRIPTLET] → Running build hook: [filesystems]
[2021-02-10T14:11:56+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-02-10T14:11:56+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64-fallback.img
[2021-02-10T14:12:00+0100] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-02-10T14:12:00+0100] [ALPM] running ‘90-nvidia-utils.hook’…
[2021-02-10T14:12:00+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux414.preset: ‘default’
[2021-02-10T14:12:00+0100] [ALPM-SCRIPTLET] → -k /boot/vmlinuz-4.14-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.14-x86_64.img
[2021-02-10T14:12:00+0100] [ALPM-SCRIPTLET] ==> Starting build: 4.14.219-1-MANJARO
[2021-02-10T14:12:00+0100] [ALPM-SCRIPTLET] → Running build hook: [base]
[2021-02-10T14:12:00+0100] [ALPM-SCRIPTLET] → Running build hook: [udev]
[2021-02-10T14:12:00+0100] [ALPM-SCRIPTLET] → Running build hook: [autodetect]
[2021-02-10T14:12:00+0100] [ALPM-SCRIPTLET] → Running build hook: [modconf]
[2021-02-10T14:12:00+0100] [ALPM-SCRIPTLET] → Running build hook: [block]
[2021-02-10T14:12:01+0100] [ALPM-SCRIPTLET] → Running build hook: [keyboard]
[2021-02-10T14:12:01+0100] [ALPM-SCRIPTLET] → Running build hook: [keymap]
[2021-02-10T14:12:01+0100] [ALPM-SCRIPTLET] → Running build hook: [resume]
[2021-02-10T14:12:01+0100] [ALPM-SCRIPTLET] → Running build hook: [filesystems]
[2021-02-10T14:12:01+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-02-10T14:12:01+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-4.14-x86_64.img
[2021-02-10T14:12:02+0100] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-02-10T14:12:02+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux414.preset: ‘fallback’
[2021-02-10T14:12:02+0100] [ALPM-SCRIPTLET] → -k /boot/vmlinuz-4.14-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.14-x86_64-fallback.img -S autodetect
[2021-02-10T14:12:02+0100] [ALPM-SCRIPTLET] ==> Starting build: 4.14.219-1-MANJARO
[2021-02-10T14:12:02+0100] [ALPM-SCRIPTLET] → Running build hook: [base]
[2021-02-10T14:12:02+0100] [ALPM-SCRIPTLET] → Running build hook: [udev]
[2021-02-10T14:12:02+0100] [ALPM-SCRIPTLET] → Running build hook: [modconf]
[2021-02-10T14:12:02+0100] [ALPM-SCRIPTLET] → Running build hook: [block]
[2021-02-10T14:12:04+0100] [ALPM-SCRIPTLET] → Running build hook: [keyboard]
[2021-02-10T14:12:04+0100] [ALPM-SCRIPTLET] → Running build hook: [keymap]
[2021-02-10T14:12:04+0100] [ALPM-SCRIPTLET] → Running build hook: [resume]
[2021-02-10T14:12:04+0100] [ALPM-SCRIPTLET] → Running build hook: [filesystems]
[2021-02-10T14:12:06+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-02-10T14:12:06+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-4.14-x86_64-fallback.img
[2021-02-10T14:12:09+0100] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-02-10T14:12:09+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: ‘default’
[2021-02-10T14:12:09+0100] [ALPM-SCRIPTLET] → -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
[2021-02-10T14:12:09+0100] [ALPM-SCRIPTLET] ==> Starting build: 5.10.13-2-MANJARO
[2021-02-10T14:12:09+0100] [ALPM-SCRIPTLET] → Running build hook: [base]
[2021-02-10T14:12:09+0100] [ALPM-SCRIPTLET] → Running build hook: [udev]
[2021-02-10T14:12:09+0100] [ALPM-SCRIPTLET] → Running build hook: [autodetect]
[2021-02-10T14:12:09+0100] [ALPM-SCRIPTLET] → Running build hook: [modconf]
[2021-02-10T14:12:09+0100] [ALPM-SCRIPTLET] → Running build hook: [block]
[2021-02-10T14:12:10+0100] [ALPM-SCRIPTLET] → Running build hook: [keyboard]
[2021-02-10T14:12:10+0100] [ALPM-SCRIPTLET] → Running build hook: [keymap]
[2021-02-10T14:12:10+0100] [ALPM-SCRIPTLET] → Running build hook: [resume]
[2021-02-10T14:12:10+0100] [ALPM-SCRIPTLET] → Running build hook: [filesystems]
[2021-02-10T14:12:10+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-02-10T14:12:10+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
[2021-02-10T14:12:11+0100] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-02-10T14:12:11+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: ‘fallback’
[2021-02-10T14:12:11+0100] [ALPM-SCRIPTLET] → -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
[2021-02-10T14:12:11+0100] [ALPM-SCRIPTLET] ==> Starting build: 5.10.13-2-MANJARO
[2021-02-10T14:12:11+0100] [ALPM-SCRIPTLET] → Running build hook: [base]
[2021-02-10T14:12:11+0100] [ALPM-SCRIPTLET] → Running build hook: [udev]
[2021-02-10T14:12:11+0100] [ALPM-SCRIPTLET] → Running build hook: [modconf]
[2021-02-10T14:12:11+0100] [ALPM-SCRIPTLET] → Running build hook: [block]
[2021-02-10T14:12:13+0100] [ALPM-SCRIPTLET] → Running build hook: [keyboard]
[2021-02-10T14:12:14+0100] [ALPM-SCRIPTLET] → Running build hook: [keymap]
[2021-02-10T14:12:14+0100] [ALPM-SCRIPTLET] → Running build hook: [resume]
[2021-02-10T14:12:14+0100] [ALPM-SCRIPTLET] → Running build hook: [filesystems]
[2021-02-10T14:12:16+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-02-10T14:12:16+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
[2021-02-10T14:12:19+0100] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-02-10T14:12:19+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: ‘default’
[2021-02-10T14:12:19+0100] [ALPM-SCRIPTLET] → -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64.img
[2021-02-10T14:12:19+0100] [ALPM-SCRIPTLET] ==> Starting build: 5.4.95-1-MANJARO
[2021-02-10T14:12:19+0100] [ALPM-SCRIPTLET] → Running build hook: [base]
[2021-02-10T14:12:19+0100] [ALPM-SCRIPTLET] → Running build hook: [udev]
[2021-02-10T14:12:19+0100] [ALPM-SCRIPTLET] → Running build hook: [autodetect]
[2021-02-10T14:12:20+0100] [ALPM-SCRIPTLET] → Running build hook: [modconf]
[2021-02-10T14:12:20+0100] [ALPM-SCRIPTLET] → Running build hook: [block]
[2021-02-10T14:12:20+0100] [ALPM-SCRIPTLET] → Running build hook: [keyboard]
[2021-02-10T14:12:20+0100] [ALPM-SCRIPTLET] → Running build hook: [keymap]
[2021-02-10T14:12:20+0100] [ALPM-SCRIPTLET] → Running build hook: [resume]
[2021-02-10T14:12:20+0100] [ALPM-SCRIPTLET] → Running build hook: [filesystems]
[2021-02-10T14:12:20+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-02-10T14:12:20+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64.img
[2021-02-10T14:12:21+0100] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-02-10T14:12:21+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: ‘fallback’
[2021-02-10T14:12:21+0100] [ALPM-SCRIPTLET] → -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64-fallback.img -S autodetect
[2021-02-10T14:12:21+0100] [ALPM-SCRIPTLET] ==> Starting build: 5.4.95-1-MANJARO
[2021-02-10T14:12:21+0100] [ALPM-SCRIPTLET] → Running build hook: [base]
[2021-02-10T14:12:21+0100] [ALPM-SCRIPTLET] → Running build hook: [udev]
[2021-02-10T14:12:21+0100] [ALPM-SCRIPTLET] → Running build hook: [modconf]
[2021-02-10T14:12:21+0100] [ALPM-SCRIPTLET] → Running build hook: [block]
[2021-02-10T14:12:23+0100] [ALPM-SCRIPTLET] → Running build hook: [keyboard]
[2021-02-10T14:12:24+0100] [ALPM-SCRIPTLET] → Running build hook: [keymap]
[2021-02-10T14:12:24+0100] [ALPM-SCRIPTLET] → Running build hook: [resume]
[2021-02-10T14:12:24+0100] [ALPM-SCRIPTLET] → Running build hook: [filesystems]
[2021-02-10T14:12:26+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-02-10T14:12:26+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64-fallback.img
[2021-02-10T14:12:29+0100] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-02-10T14:12:29+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: ‘default’
[2021-02-10T14:12:29+0100] [ALPM-SCRIPTLET] → -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64.img
[2021-02-10T14:12:29+0100] [ALPM-SCRIPTLET] ==> Starting build: 5.9.16-1-MANJARO
[2021-02-10T14:12:30+0100] [ALPM-SCRIPTLET] → Running build hook: [base]
[2021-02-10T14:12:30+0100] [ALPM-SCRIPTLET] → Running build hook: [udev]
[2021-02-10T14:12:30+0100] [ALPM-SCRIPTLET] → Running build hook: [autodetect]
[2021-02-10T14:12:30+0100] [ALPM-SCRIPTLET] → Running build hook: [modconf]
[2021-02-10T14:12:30+0100] [ALPM-SCRIPTLET] → Running build hook: [block]
[2021-02-10T14:12:30+0100] [ALPM-SCRIPTLET] → Running build hook: [keyboard]
[2021-02-10T14:12:30+0100] [ALPM-SCRIPTLET] → Running build hook: [keymap]
[2021-02-10T14:12:30+0100] [ALPM-SCRIPTLET] → Running build hook: [resume]
[2021-02-10T14:12:30+0100] [ALPM-SCRIPTLET] → Running build hook: [filesystems]
[2021-02-10T14:12:30+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-02-10T14:12:30+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64.img
[2021-02-10T14:12:32+0100] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-02-10T14:12:32+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: ‘fallback’
[2021-02-10T14:12:32+0100] [ALPM-SCRIPTLET] → -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64-fallback.img -S autodetect
[2021-02-10T14:12:32+0100] [ALPM-SCRIPTLET] ==> Starting build: 5.9.16-1-MANJARO
[2021-02-10T14:12:32+0100] [ALPM-SCRIPTLET] → Running build hook: [base]
[2021-02-10T14:12:32+0100] [ALPM-SCRIPTLET] → Running build hook: [udev]
[2021-02-10T14:12:32+0100] [ALPM-SCRIPTLET] → Running build hook: [modconf]
[2021-02-10T14:12:32+0100] [ALPM-SCRIPTLET] → Running build hook: [block]
[2021-02-10T14:12:34+0100] [ALPM-SCRIPTLET] → Running build hook: [keyboard]
[2021-02-10T14:12:35+0100] [ALPM-SCRIPTLET] → Running build hook: [keymap]
[2021-02-10T14:12:35+0100] [ALPM-SCRIPTLET] → Running build hook: [resume]
[2021-02-10T14:12:35+0100] [ALPM-SCRIPTLET] → Running build hook: [filesystems]
[2021-02-10T14:12:37+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-02-10T14:12:37+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64-fallback.img
[2021-02-10T14:12:40+0100] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-02-10T14:12:40+0100] [ALPM] running ‘99-grub.hook’…
[2021-02-10T14:12:42+0100] [ALPM-SCRIPTLET] Generating grub configuration file …
[2021-02-10T14:12:42+0100] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/manjaro/theme.txt
[2021-02-10T14:12:43+0100] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.10-x86_64
[2021-02-10T14:12:43+0100] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
[2021-02-10T14:12:43+0100] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
[2021-02-10T14:12:43+0100] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.9-x86_64
[2021-02-10T14:12:43+0100] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.9-x86_64.img
[2021-02-10T14:12:43+0100] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.9-x86_64-fallback.img
[2021-02-10T14:12:43+0100] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.4-x86_64
[2021-02-10T14:12:43+0100] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.4-x86_64.img
[2021-02-10T14:12:43+0100] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.4-x86_64-fallback.img
[2021-02-10T14:12:43+0100] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-4.14-x86_64
[2021-02-10T14:12:43+0100] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-4.14-x86_64.img
[2021-02-10T14:12:43+0100] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-4.14-x86_64-fallback.img
[2021-02-10T14:12:45+0100] [ALPM-SCRIPTLET] Found Windows Boot Manager on /dev/nvme1n1p2@/efi/Microsoft/Boot/bootmgfw.efi
[2021-02-10T14:12:45+0100] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings …
[2021-02-10T14:12:45+0100] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2021-02-10T14:12:45+0100] [ALPM-SCRIPTLET] /usr/bin/grub-probe: warning: unknown device type nvme0n1.
[2021-02-10T14:12:45+0100] [ALPM-SCRIPTLET] done
[2021-02-10T14:12:45+0100] [ALPM] running ‘dbus-reload.hook’…
[2021-02-10T14:12:45+0100] [ALPM] running ‘detect-old-perl-modules.hook’…
[2021-02-10T14:12:45+0100] [ALPM] running ‘firefox-post.hook’…
[2021-02-10T14:12:45+0100] [ALPM] running ‘fontconfig.hook’…
[2021-02-10T14:12:45+0100] [ALPM] running ‘gdk-pixbuf-query-loaders.hook’…
[2021-02-10T14:12:45+0100] [ALPM] running ‘ghc-register.hook’…
[2021-02-10T14:12:50+0100] [ALPM] running ‘glib-compile-schemas.hook’…
[2021-02-10T14:12:50+0100] [ALPM] running ‘gtk-update-icon-cache.hook’…
[2021-02-10T14:12:53+0100] [ALPM] running ‘manjaro-printer.hook’…
[2021-02-10T14:12:53+0100] [ALPM] running ‘texinfo-install.hook’…
[2021-02-10T14:12:55+0100] [ALPM] running ‘texlive-fmtutil.hook’…
[2021-02-10T14:13:21+0100] [ALPM] running ‘texlive-updmap.hook’…
[2021-02-10T14:13:24+0100] [ALPM] running ‘thunderbird-post.hook’…
[2021-02-10T14:13:24+0100] [ALPM] running ‘update-desktop-database.hook’…
[2021-02-10T14:13:24+0100] [ALPM] running ‘update-mime-database.hook’…
[2021-02-10T14:13:24+0100] [ALPM] running ‘update-vlc-plugin-cache.hook’…
[2021-02-10T14:13:25+0100] [ALPM] running ‘vimdoc.hook’…
[2021-02-10T14:13:25+0100] [ALPM] running ‘xorg-mkfontscale.hook’…
[2021-02-10T14:13:41+0100] [PACMAN] Running ‘pacman -S -y -u --config /etc/pacman.conf --’
[2021-02-10T14:13:41+0100] [PACMAN] synchronizing package lists
[2021-02-10T14:13:42+0100] [PACMAN] starting full system upgrade
[2021-02-10T14:15:48+0100] [PACMAN] Running ‘pacman -S -u -y --config /etc/pacman.conf --’
[2021-02-10T14:15:48+0100] [PACMAN] synchronizing package lists
[2021-02-10T14:15:49+0100] [PACMAN] starting full system upgrade
[2021-02-10T14:16:54+0100] [PACMAN] Running ‘pacman -R --config /etc/pacman.conf – alsa-card-profiles brandr celt0.5.1 cmark-gfm conky conky-i3 cracklib dunst dunstify electron6 electron7 gconf gendesk go gperftools gtest guile2.0 gulp haskell-base-noprelude haskell-bitarray haskell-cmark-gfm haskell-regex-pcre i3-help i3-scripts i3-scrot i3exit jemalloc js60 js68 lib32-alsa-oss lib32-alsa-plugins lib32-lz4 libcurl-gnutls libvncserver libxnvctrl links linux-latest linux-latest-virtualbox-host-modules lv2 manjaro-base-skel mhwd-nvidia-340xx node-prune opera-ffmpeg-codecs otf-crimson-text papirus-icon-theme papirus-maia-icon-theme python-jade-application-kit python-more-itertools python-pew python-pymongo python-pytoml python2-apsw python2-backports python2-backports.functools_lru_cache python2-beautifulsoup4 python2-chardet python2-css-parser python2-cssselect python2-dateutil python2-dbus python2-dnspython python2-enum34 python2-feedparser python2-html2text python2-html5-parser python2-html5lib python2-ipaddress python2-lxml python2-markdown python2-mechanize python2-msgpack python2-netifaces python2-pillow python2-psutil python2-pychm python2-pyqt5 python2-pyqtwebengine python2-regex python2-sip-pyqt5 python2-soupsieve python2-unrardll python2-webencodings scons sip4 skopeo software-center-web-jak ttf-webhostinghub-glyphs urxvt-perls xcursor-breeze xmlto xorg-bdftopcf xorg-font-util xorg-font-utils xorg-fonts-alias-misc xorg-fonts-misc xorg-mkfontscale xsel yarn’
[2021-02-10T14:16:56+0100] [ALPM] running ‘ghc-unregister.hook’…
[2021-02-10T14:16:56+0100] [ALPM] transaction started
[2021-02-10T14:16:56+0100] [ALPM] removed yarn (1.22.10-1)
[2021-02-10T14:16:56+0100] [ALPM] removed xorg-fonts-misc (1.0.3-10)
[2021-02-10T14:16:56+0100] [ALPM] removed xorg-fonts-alias-misc (1.0.4-1)
[2021-02-10T14:16:56+0100] [ALPM] removed xorg-font-utils (7.6-6)
[2021-02-10T14:16:56+0100] [ALPM] removed xorg-mkfontscale (1.2.1-2)
[2021-02-10T14:16:56+0100] [ALPM] removed xorg-font-util (1.3.2-2)
[2021-02-10T14:16:56+0100] [ALPM] removed xorg-bdftopcf (1.1-2)
[2021-02-10T14:16:56+0100] [ALPM] removed xmlto (0.0.28-4)
[2021-02-10T14:16:56+0100] [ALPM] removed xcursor-breeze (5.11.5-1)
[2021-02-10T14:16:56+0100] [ALPM] removed urxvt-perls (2.3-1)
[2021-02-10T14:16:56+0100] [ALPM] removed xsel (1.2.0.20190821-1)
[2021-02-10T14:16:56+0100] [ALPM] removed ttf-webhostinghub-glyphs (1.0-8)
[2021-02-10T14:16:56+0100] [ALPM] removed software-center-web-jak (1.0.2-1)
[2021-02-10T14:16:56+0100] [ALPM] removed skopeo (1.2.1-1)
[2021-02-10T14:16:56+0100] [ALPM] removed sip4 (4.19.24-1)
[2021-02-10T14:16:56+0100] [ALPM] removed scons (3.1.2-4)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-unrardll (0.1.4-2)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-regex (2020.7.14-1)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-pyqtwebengine (5.15.0-2)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-pyqt5 (5.15.0-3)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-sip-pyqt5 (4.19.24-1)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-pychm (0.8.6-1)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-psutil (5.8.0-1)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-pillow (6.2.1-3)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-netifaces (0.10.9-3)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-msgpack (0.6.2-4)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-mechanize (1:0.4.5-1)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-markdown (3.1.1-5)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-ipaddress (1.0.23-2)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-html5lib (1.1-5)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-webencodings (0.5.1-6)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-html5-parser (0.4.9-2)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-lxml (4.6.2-1)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-html2text (2019.8.11-4)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-feedparser (5.2.1-9)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-enum34 (1.1.9-1)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-dnspython (1.16.0-3)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-dbus (1.2.16-3)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-dateutil (2.8.1-5)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-cssselect (1.1.0-6)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-css-parser (1.0.4-3)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-chardet (3.0.4-7)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-beautifulsoup4 (4.9.3-3)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-soupsieve (1.9.6-2)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-backports.functools_lru_cache (1.6.1-2)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-backports (1.0-3)
[2021-02-10T14:16:56+0100] [ALPM] removed python2-apsw (3.33.0-3)
[2021-02-10T14:16:56+0100] [ALPM] removed python-pytoml (0.1.21-6)
[2021-02-10T14:16:56+0100] [ALPM] removed python-pymongo (3.11.3-1)
[2021-02-10T14:16:57+0100] [ALPM] removed python-pew (1.2.0-5)
[2021-02-10T14:16:57+0100] [ALPM] removed python-more-itertools (8.6.0-3)
[2021-02-10T14:16:57+0100] [ALPM] removed python-jade-application-kit (3.5.6-3)
[2021-02-10T14:16:57+0100] [ALPM] removed papirus-maia-icon-theme (20200702-1)
[2021-02-10T14:16:58+0100] [ALPM] removed papirus-icon-theme (20210201-1)
[2021-02-10T14:16:58+0100] [ALPM] removed otf-crimson-text (1:2019.07-2)
[2021-02-10T14:16:58+0100] [ALPM] removed opera-ffmpeg-codecs (88.0.4324.104-1)
[2021-02-10T14:16:58+0100] [ALPM] removed node-prune (1.1.0-2)
[2021-02-10T14:16:58+0100] [ALPM] removed mhwd-nvidia-340xx (340.108-1)
[2021-02-10T14:16:58+0100] [ALPM] removed manjaro-base-skel (20171029-3)
[2021-02-10T14:16:58+0100] [ALPM] removed lv2 (1.18.2-1)
[2021-02-10T14:16:58+0100] [ALPM] removed linux-latest-virtualbox-host-modules (5.10-1)
[2021-02-10T14:16:58+0100] [ALPM] removed linux-latest (5.10-1)
[2021-02-10T14:16:58+0100] [ALPM] removed links (2.21-1)
[2021-02-10T14:16:58+0100] [ALPM] removed libvncserver (0.9.13-1)
[2021-02-10T14:16:58+0100] [ALPM] removed libcurl-gnutls (7.75.0-1)
[2021-02-10T14:16:58+0100] [ALPM] removed lib32-lz4 (1.9.3-1)
[2021-02-10T14:16:58+0100] [ALPM] removed lib32-alsa-plugins (1.2.2-1)
[2021-02-10T14:16:58+0100] [ALPM] removed lib32-alsa-oss (1.1.8-2)
[2021-02-10T14:16:58+0100] [ALPM] removed js68 (68.12.0-1)
[2021-02-10T14:16:58+0100] [ALPM] removed js60 (60.9.0-2)
[2021-02-10T14:16:58+0100] [ALPM] removed jemalloc (1:5.2.1-3)
[2021-02-10T14:16:58+0100] [ALPM] removed i3exit (20201126-1)
[2021-02-10T14:16:58+0100] [ALPM] removed i3-scrot (2.1-1)
[2021-02-10T14:16:58+0100] [ALPM] removed i3-scripts (20200804-1)
[2021-02-10T14:16:58+0100] [ALPM] removed i3-help (20180110-1)
[2021-02-10T14:16:58+0100] [ALPM] removed haskell-regex-pcre (0.95.0.0-7)
[2021-02-10T14:16:58+0100] [ALPM] removed haskell-cmark-gfm (0.2.2-41)
[2021-02-10T14:16:58+0100] [ALPM] removed haskell-bitarray (0.0.1.1-19)
[2021-02-10T14:16:58+0100] [ALPM] removed haskell-base-noprelude (4.13.0.0-1)
[2021-02-10T14:16:58+0100] [ALPM] removed gulp (4.0.2-3)
[2021-02-10T14:16:58+0100] [ALPM] removed guile2.0 (2.0.14-4)
[2021-02-10T14:16:58+0100] [ALPM] removed gtest (1.10.0-3)
[2021-02-10T14:16:58+0100] [ALPM] removed gperftools (2.8.1-1)
[2021-02-10T14:16:59+0100] [ALPM] removed go (2:1.15.8-1)
[2021-02-10T14:16:59+0100] [ALPM] removed gendesk (1.0.6-1)
[2021-02-10T14:16:59+0100] [ALPM] removed gconf (3.2.6+11+g07808097-7)
[2021-02-10T14:16:59+0100] [ALPM] removed electron7 (7.1.14-7)
[2021-02-10T14:16:59+0100] [ALPM] removed electron6 (6.1.12-5)
[2021-02-10T14:16:59+0100] [ALPM] removed dunst (1.5.0-1.0)
[2021-02-10T14:16:59+0100] [ALPM] removed dunstify (1.5.0-1.0)
[2021-02-10T14:16:59+0100] [ALPM] removed cracklib (2.9.7-2)
[2021-02-10T14:16:59+0100] [ALPM] removed conky-i3 (20180507-1)
[2021-02-10T14:16:59+0100] [ALPM] removed conky (1.11.6-1)
[2021-02-10T14:16:59+0100] [ALPM] removed libxnvctrl (460.39-1)
[2021-02-10T14:16:59+0100] [ALPM] removed cmark-gfm (0.29.0.gfm.0-2)
[2021-02-10T14:16:59+0100] [ALPM] removed celt0.5.1 (0.5.1.3-5)
[2021-02-10T14:16:59+0100] [ALPM] removed brandr (0.2-3)
[2021-02-10T14:16:59+0100] [ALPM] removed alsa-card-profiles (1:0.3.21-1)
[2021-02-10T14:16:59+0100] [ALPM] transaction completed
[2021-02-10T14:17:00+0100] [ALPM] running ‘30-systemd-udev-reload.hook’…
[2021-02-10T14:17:00+0100] [ALPM] running ‘30-systemd-update.hook’…
[2021-02-10T14:17:00+0100] [ALPM] running ‘dbus-reload.hook’…
[2021-02-10T14:17:00+0100] [ALPM] running ‘fontconfig.hook’…
[2021-02-10T14:17:00+0100] [ALPM] running ‘gio-querymodules.hook’…
[2021-02-10T14:17:00+0100] [ALPM] running ‘gtk-update-icon-cache.hook’…
[2021-02-10T14:17:00+0100] [ALPM] running ‘update-desktop-database.hook’…
[2021-02-10T14:19:51+0100] [PACMAN] Running ‘pacman -U --noconfirm --config /etc/pacman.conf – /home/leander/.cache/yay/zoom/zoom-5.5.2-1-x86_64.pkg.tar.xz’
[2021-02-10T14:19:51+0100] [ALPM] transaction started
[2021-02-10T14:19:55+0100] [ALPM] upgraded zoom (5.4.57862.0110-1 → 5.5.2-1)
[2021-02-10T14:19:55+0100] [ALPM] transaction completed
[2021-02-10T14:19:55+0100] [ALPM] running ‘30-systemd-update.hook’…
[2021-02-10T14:19:55+0100] [ALPM] running ‘update-desktop-database.hook’…
[2021-02-10T14:19:55+0100] [ALPM] running ‘update-mime-database.hook’…
[2021-02-10T14:21:23+0100] [PACMAN] Running ‘pacman -U --noconfirm --config /etc/pacman.conf – /home/leander/.cache/yay/google-chrome/google-chrome-88.0.4324.150-1-x86_64.pkg.tar.xz’
[2021-02-10T14:21:23+0100] [ALPM] transaction started
[2021-02-10T14:21:27+0100] [ALPM] upgraded google-chrome (88.0.4324.96-1 → 88.0.4324.150-1)
[2021-02-10T14:21:27+0100] [ALPM-SCRIPTLET] e[me(Be[1me[38;5;4m==>e[me(Be[1me[38;5;3m NOTE:e[me(Be[1m Custom flags should be put directly in: ~/.config/chrome-flags.confe[me(B
[2021-02-10T14:21:27+0100] [ALPM-SCRIPTLET] e[me(Be[1me[38;5;4m==>e[me(Be[1me[38;5;3m NOTE:e[me(Be[1m The launcher is called: 'google-chrome-stable’e[me(B
[2021-02-10T14:21:27+0100] [ALPM] transaction completed
[2021-02-10T14:21:27+0100] [ALPM] running ‘30-systemd-update.hook’…
[2021-02-10T14:21:27+0100] [ALPM] running ‘gtk-update-icon-cache.hook’…
[2021-02-10T14:21:27+0100] [ALPM] running ‘update-desktop-database.hook’…
[2021-02-10T14:43:25+0100] [PACMAN] Running ‘pacman -S terminal’
[2021-02-10T14:44:15+0100] [PACMAN] Running ‘pacman -S rxvt-unicode’
[2021-02-10T14:44:17+0100] [ALPM] transaction started
[2021-02-10T14:44:17+0100] [ALPM] reinstalled rxvt-unicode (9.22-10)
[2021-02-10T14:44:17+0100] [ALPM] transaction completed
[2021-02-10T14:44:17+0100] [ALPM] running ‘30-systemd-update.hook’…
[2021-02-10T14:44:17+0100] [ALPM] running ‘update-desktop-database.hook’…
[2021-02-10T15:06:52+0100] [PACMAN] Running ‘pacman -U /var/cache/pacman/pkg/linux-latest-5.9-2-any.pkg.tar.zst’
[2021-02-10T15:06:55+0100] [ALPM] transaction started
[2021-02-10T15:06:55+0100] [ALPM] installed linux-latest (5.9-2)
[2021-02-10T15:06:55+0100] [ALPM] transaction completed
[2021-02-10T15:56:14+0100] [PAMAC] synchronizing package lists
[2021-02-10T15:56:28+0100] [ALPM] transaction started
[2021-02-10T15:56:28+0100] [ALPM] upgraded linux-latest (5.9-2 → 5.10-1)
[2021-02-10T15:56:29+0100] [ALPM] transaction completed
[2021-02-10T16:07:06+0100] [PACMAN] Running ‘pacman -Syu’
[2021-02-10T16:07:06+0100] [PACMAN] synchronizing package lists
[2021-02-10T16:07:07+0100] [PACMAN] starting full system upgrade
[2021-02-10T16:07:11+0100] [PACMAN] Running ‘pacman -Syyu’
[2021-02-10T16:07:11+0100] [PACMAN] synchronizing package lists
[2021-02-10T16:07:15+0100] [PACMAN] starting full system upgrade
I noticed this:
[2021-02-10T14:16:54+0100] [PACMAN] Running 'pacman -R --config /etc/pacman.conf -- alsa-card-profiles brandr celt0.5.1 cmark-gfm conky conky-i3 cracklib dunst dunstify electron6 electron7 gconf gendesk go gperftools gtest guile2.0 gulp haskell-base-noprelude haskell-bitarray haskell-cmark-gfm haskell-regex-pcre i3-help i3-scripts i3-scrot i3exit jemalloc js60 js68 lib32-alsa-oss lib32-alsa-plugins lib32-lz4 libcurl-gnutls libvncserver libxnvctrl links linux-latest linux-latest-virtualbox-host-modules lv2 manjaro-base-skel mhwd-nvidia-340xx node-prune opera-ffmpeg-codecs otf-crimson-text papirus-icon-theme papirus-maia-icon-theme python-jade-application-kit python-more-itertools python-pew python-pymongo python-pytoml python2-apsw python2-backports python2-backports.functools_lru_cache python2-beautifulsoup4 python2-chardet python2-css-parser python2-cssselect python2-dateutil python2-dbus python2-dnspython python2-enum34 python2-feedparser python2-html2text python2-html5-parser python2-html5lib python2-ipaddress python2-lxml python2-markdown python2-mechanize python2-msgpack python2-netifaces python2-pillow python2-psutil python2-pychm python2-pyqt5 python2-pyqtwebengine python2-regex python2-sip-pyqt5 python2-soupsieve python2-unrardll python2-webencodings scons sip4 skopeo software-center-web-jak ttf-webhostinghub-glyphs urxvt-perls xcursor-breeze xmlto xorg-bdftopcf xorg-font-util xorg-font-utils xorg-fonts-alias-misc xorg-fonts-misc xorg-mkfontscale xsel yarn'
Where the accedently “unneeded dependencies” deleted with yay -Yc
? Shoud I just run pacman -S --config /etc/pacman.conf -- alsa-card-profiles brandr celt0.5.1 cmark-gfm conky conky-i3 cracklib dunst ...
EDIT: I just tried that and got
error: target not found: electron7
error: target not found: haskell-base-noprelude
error: target not found: js60
warning: linux-latest-5.10-1 is up to date -- reinstalling
error: target not found: mhwd-nvidia-340xx
error: target not found: node-prune
error: target not found: otf-crimson-text
error: target not found: python2-apsw
error: target not found: python2-css-parser
error: target not found: python2-html2text
error: target not found: python2-html5-parser
error: target not found: python2-markdown
error: target not found: python2-mechanize
error: target not found: python2-netifaces
error: target not found: python2-pychm
error: target not found: python2-pyqt5
error: target not found: python2-pyqtwebengine
error: target not found: python2-regex
error: target not found: python2-sip-pyqt5
error: target not found: python2-unrardll
error: target not found: ttf-webhostinghub-glyphs
error: target not found: xorg-font-utils
Targets where not found? Might there be an compability issue with the newest Kernel verison?
EDIT 2:
I looked into the thread gnome-terminal-wont-open-after-update
But I do not have
- locale.gen file
- sudo local-gen was not found
- local.conf has different content:
LANG=en_US.UTF-8
LC_ADDRESS=de_DE.UTF-8
LC_IDENTIFICATION=de_DE.UTF-8
LC_MEASUREMENT=de_DE.UTF-8
LC_MONETARY=de_DE.UTF-8
LC_NAME=de_DE.UTF-8
LC_NUMERIC=de_DE.UTF-8
LC_PAPER=de_DE.UTF-8
LC_TELEPHONE=de_DE.UTF-8
LC_TIME=de_DE.UTF-8
=> I guess its not an error with the locals
