(pamac-manager:20634): Adwaita-WARNING **: 19:55:37.109: Using GtkSettings:gtk-application-prefer-dark-theme with libadwaita is unsupported. Please use AdwStyleManager:color-scheme instead.
** Message: 19:55:37.179: flatpak_plugin.vala:330: refreshing flathub appstream data
a
(pamac-manager:20634): GLib-GIO-ERROR **: 19:55:37.255: Settings schema 'org.gnome.system.proxy' is not installed
zsh: trace trap (core dumped) pamac-manager
error code when running steam from terminal
steam.sh[21904]: Running Steam on manjarolinux 23.0.0 64-bit
steam.sh[21904]: STEAM_RUNTIME is enabled automatically
setup.sh[21978]: Steam runtime environment up-to-date!
steam.sh[21904]: Steam client's requirements are satisfied
[2023-06-17 20:04:05] Startup - updater built Jun 16 2023 01:41:16
[2023-06-17 20:04:05] Startup - Steam Client launched with: '/home/abraham/.local/share/Steam/ubuntu12_32/steam'
06/17 20:04:05 Init: Installing breakpad exception handler for appid(steam)/version(1686880776)/tid(22035)
Looks like steam didn't shutdown cleanly, scheduling immediate update check
[2023-06-17 20:04:05] Loading cached metrics from disk (/home/abraham/.local/share/Steam/package/steam_client_metrics
.bin)
[2023-06-17 20:04:05] Using the following download hosts for Public, Realm steamglobal
[2023-06-17 20:04:05] 1. https://client-update.akamai.steamstatic.com, /, Realm 'steamglobal', weight was 1000, sourc
e = 'update_hosts_cached.vdf'
[2023-06-17 20:04:05] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, source
[2023-06-17 20:04:05] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked
in'
[2023-06-17 20:04:05] Checking for update on startup
[2023-06-17 20:04:05] Checking for available updates...
[2023-06-17 20:04:05] Downloading manifest: https://client-update.akamai.steamstatic.com/steam_client_ubuntu12
[2023-06-17 20:04:05] Manifest download: send request
[2023-06-17 20:04:05] Manifest download: waiting for download to finish
[2023-06-17 20:04:05] Manifest download: finished
[2023-06-17 20:04:05] Download skipped: /steam_client_ubuntu12 version 1686880776, installed version 1686880776, exis
ting pending version 0
[2023-06-17 20:04:05] Nothing to do
[2023-06-17 20:04:05] Verifying installation...
[2023-06-17 20:04:05] Performing checksum verification of executable files
[2023-06-17 20:04:06] Verification complete
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xf2763db0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xf2762500
GetWin32Stats: display was not open yet, good
Loaded SDL version 3.0.0-1735-g2e465ae31
ComputeStartupMode: found registry default startup mode: 0
Switching to desktopui, since -vgui was not specified
steamwebhelper.sh[22091]: Runtime for steamwebhelper: defaulting to /home/abraham/.local/share/Steam/ubuntu12_64/stea
m-runtime-heavy
steamwebhelper.sh[22091]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
CAppInfoCacheReadFromDiskThread took 40 milliseconds to initialize
src/steamUI/steamuisharedjscontroller.cpp (529) : Failed creating offscreen shared JS context
src/steamUI/steamuisharedjscontroller.cpp (529) : Fatal assert; application exiting
06/17 20:04:49 Init: Installing breakpad exception handler for appid(steam)/version(1686880776)/tid(22035)
assert_20230617200449_29.dmp[22221]: Uploading dump (out-of-process)
/tmp/dumps/assert_20230617200449_29.dmp
_ExitOnFatalAssert
