Good morning community.
Yesterday I installed manjaro 21.2.5 with kde plasma.
Right after updating the system, I installed clamav and ran a full system scansion using
And the file is - kind of - important to the Add Remove Software app - it will be fetched again on next run.
Linux != Windows - and unless you are being reckless - like running a virus scanner with sudo priviliges or any other apps for that matter - your system is safe.
Linux is not a major target for malware - but in the unlikely case you should be hit by a malware - it would only have write access to the files for which your user have write access.
So never run apps/scripts with sudo permissions - unless strictly required to modify system files.
