Hello, I’m using Manjaro xfce with the karnel 5.10.84-1 LTS and I use pluseaudio (the default audio manager, I think). I tried so many tutorial or topic and nothing as worked.
they frequantly ask the output of inxi -Fazy
Kernel: 5.10.84-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=bb3769b1-aac9-40fe-9674-7876efbc1221 rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: HONOR product: HLYL-WXX9 v: M1100
serial: <superuser required>
Mobo: HONOR model: HLYL-WXX9-PCB v: M1100 serial: <superuser required>
UEFI: HONOR v: 3.06 date: 09/13/2021
ID-1: BAT1 charge: 38.5 Wh (71.7%) condition: 53.7/54.9 Wh (97.7%)
volts: 8.0 min: 7.6 model: Desay HB6181V1ECW-22T type: Li-ion
serial: <filter> status: Discharging cycles: 88
Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600104
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1397 high: 1479 min/max: 1400/3000 boost: disabled
scaling: driver: acpi-cpufreq governor: conservative cores: 1: 1397 2: 1385
3: 1400 4: 1479 5: 1384 6: 1337 7: 1397 8: 1397 9: 1397 10: 1397 11: 1397
12: 1397 bogomips: 71895
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
Device-1: AMD Renoir vendor: QUANTA driver: amdgpu v: kernel bus-ID: 03:00.0
chip-ID: 1002:1636 class-ID: 0300
Device-2: IMC Networks ov9734_azurewave_camera type: USB driver: uvcvideo
bus-ID: 1-4:2 chip-ID: 13d3:56db class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.2 compositor: xfwm4 v: 4.16.1 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 137 size: 355x200mm (14.0x7.9")
diag: 407mm (16")
Device-1: AMD vendor: QUANTA driver: snd_hda_intel v: kernel bus-ID: 03:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: QUANTA driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x
bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: QUANTA driver: snd_hda_intel
v: kernel bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.10.84-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: no
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: & Tele RSH driver: rtw_8822ce v: N/A modules: rtw88_8822ce
port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:c822 class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-4:4 chip-ID: 1358:c123 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 114.16 GiB (23.9%)
model: PC SN730 SDBPNTY-512G-1036 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 11110000 temp: 31.9 C scheme: GPT
ID-1: / raw-size: 131.32 GiB size: 128.2 GiB (97.62%)
used: 114.12 GiB (89.0%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
used: 42.7 MiB (44.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 31.8 C mobo: N/A gpu: amdgpu temp: 31.0 C
Processes: 294 Uptime: 10m wakeups: 1 Memory: 15.07 GiB
used: 1.93 GiB (12.8%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: 1632 note: see --pkg pacman: 1621
lib: 407 flatpak: 4 snap: 7 Shell: Zsh v: 5.8 running-in: xfce4-terminal
inxi: 3.3.11
The output audio works but not the input, it allways take the input audio from my lapotp which is awful (key press or clic on the touchpad are extremly loud)
please help.
