I’ve noticed on two laptops that after login cinnamon is no longer starting.
After typing the password, I can see my background shortly which then turns black and the folders on the desktop show up.
Using right-click, I can open a terminal, and using cinnamon --replace & I can get cinnamon to start properly.
Thanks for that hint!
With a new user, it works flawlessly - is there any config file I could diff in order to understand what’s going wrong?
Or can I “just” reset some setting - I’m not even sure if it’s cinnamon-related or due to the display manager?
Even though that wasn’t the solution, looking at dot-files was a great point in the right direction! Thanks for your replies!
Looking at .xsession-errors told me the following:
[cinnamon-settings-daemon-smartcard] Failed to start: no suitable smartcard driver could be found
File "/usr/bin/cinnamon-launcher", line 13, in <module>
import gi
File "/home/${whoami}/.local/lib/python3.9/site-packages/gi/__init__.py", line 40, in <module>
from . import _gi
ImportError: libffi.so.7: cannot open shared object file: No such file or directory
and so on…
Deleting /home/${whoami}/.local/lib/python3.9/site-packages/gi which I can’t recall “updating” manually did the trick.
Later on, checking for missing dependencies among my python package base revealed no issues so deleting that package should have done no harm.
