[Hi!! I hope someone can help me.
I have installed Manjaro Gnome for the first time on a new laptop: Medion Akoya E15415 Intel Core i5-10210U/8GB/256GB SSD
Everything is working fine apart from the microphone, which isn’t being recognized by the os.
I’ve been searching for various possible solutions but nothing I tried has worked.
Here is the output of a couple of commands that might be useful for understanding the problem, I hope this can help you in helping me!
Thank you so much in advance!!
arecord -l
**** List of CAPTURE Hardware Devices ****
card 0: sofessx8336 [sof-essx8336], device 0: ES8336 (*) []
Subdevices: 1/1
Subdevice #0: subdevice #0
pactl list cards
Card #42
Driver: alsa
Owner Module: n/a
Properties:
device.enum.api = "udev"
device.api = "alsa"
media.class = "Audio/Device"
api.alsa.path = "hw:0"
api.alsa.card = "0"
api.alsa.card.name = "sof-essx8336"
api.alsa.card.longname = "MEDION-E15415-NONE-NP1xCM"
device.plugged.usec = "4529968"
device.bus_path = "pci-0000:00:1f.3-platform-sof-essx8336"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sof-essx8336/sound/card0"
device.bus = "pci"
device.subsystem = "sound"
device.vendor.id = "0x8086"
device.product.id = "0x02c8"
device.product.name = "Comet Lake PCH-LP cAVS"
device.name = "alsa_card.pci-0000_00_1f.3-platform-sof-essx8336"
device.description = "Comet Lake PCH-LP cAVS"
device.nick = "sof-essx8336"
device.icon_name = "audio-card-pci"
api.alsa.use-acp = "true"
api.acp.auto-port = "false"
factory.id = "14"
client.id = "31"
object.id = "42"
object.serial = "42"
object.path = "alsa:pcm:0"
alsa.card = "0"
alsa.card_name = "sof-essx8336"
alsa.long_card_name = "MEDION-E15415-NONE-NP1xCM"
alsa.driver_name = "snd_soc_sof_es8336"
device.string = "0"
Profiles:
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
output:stereo-fallback+input:stereo-fallback: Stereo Output + Stereo Input (sinks: 1, sources: 1, priority: 5151, available: yes)
output:stereo-fallback: Stereo Output (sinks: 1, sources: 0, priority: 5100, available: yes)
input:stereo-fallback: Stereo Input (sinks: 0, sources: 1, priority: 51, available: no)
pro-audio: Pro Audio (sinks: 4, sources: 1, priority: 1, available: yes)
Active Profile: output:stereo-fallback+input:stereo-fallback
Ports:
analog-input-headset-mic: Headset Microphone (type: Headset, priority: 8800, latency offset: 0 usec, availability group: Legacy 1, not available)
Properties:
port.type = "headset"
port.availability-group = "Legacy 1"
card.profile.port = "0"
Part of profile(s): input:stereo-fallback, output:stereo-fallback+input:stereo-fallback
analog-output-speaker: Speakers (type: Speaker, priority: 10000, latency offset: 0 usec, availability unknown)
Properties:
port.type = "speaker"
card.profile.port = "1"
Part of profile(s): output:stereo-fallback, output:stereo-fallback+input:stereo-fallback
analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, availability group: Legacy 1, not available)
Properties:
port.type = "headphones"
card.profile.port = "2"
Part of profile(s): output:stereo-fallback, output:stereo-fallback+input:stereo-fallback](https://)
Hi and welcome to the Forum
If the OS doesn’t recognize it (eg detect it) how were you able to provide info about it using the commands you show?
Maybe the application you want to use for recording has not been configured properly to use it as input?
PS:
Edit your post acording to the info in below thread, it will make it easier for the rest to read the output
Difficulty: ★☆☆☆☆
Formatting differences
Discourse – this forum’s engine – uses Markdown to format its posts, and removes “unnecessary” whitespace.
Terminal commands often produce output formatted so that they are better readable by the user, taking advantage of the monospaced font used.
Programming code often rely on indentation to make it more readable.
Using preformatting in Markdown
Markdown includes a pattern to provide preformatting when necessary.
You only need to put the part to f…
Sorry, what I meant to say is that the system app of the os doesn’t detect any mic and when I try to use Skype or Google Meet the same thing happens.
done! thanks for the tip
more info that could be helpful
sudo alsa-info.sh --upload
http://alsa-project.org/db/?f=0ba9c312de89b355cdb8644264dc769903549972
Community Assistant EDIT: show inactive link in preformatted text
Just to be safe, have you tried a couple of different kernels? If not, that can sometimes solve such issues. I always go for open-source drivers & have had few issues with sound etc, on multiple machines. Hopefully you find a solution soon…
Yeah, I tried updating to the latest kernel version and rebooting, sadly, it didn’t change a thing.
I’ll try installing open-source drivers and see if one of them fixes the mic problem!
Tried what @ruziel suggested and the problem still continues, plus now my camera isnt working either
Do you have Timeshift installed? If not, that’s always good to have in situations where an update breaks something. I hope you find a solution soon. R
Because you are able to post hardware info about your microphone input, it is already detected by the “system”, eg. kernel…
If it doesn’t show up in your application(s), it is a misconfiguration of said app(s) or the sound system you are using pipewire going by the tag on the topic…
Unfortunately im unable to assist with audio issues, because i lack the knowledge about that.
PS:
I changed the topic title, to prevent misguiding interested readers.
I do have timeshift installed and I was able to go back to the version where the camera was working.
No advances with the mic problem tho
Ah okay. Hopefully you find a solution soon. All the best with this one…
cscs
19 April 2023 10:35
12
If you run
sudo mkinitcpio -P
Do you get any ‘possibly missing firmware’ messages?
it does! this is the output I got:
~ sudo mkinitcpio -P ✔ 48s
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'default'
-> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64.img --microcode /boot/intel-ucode.img
==> Starting build: '6.1.23-1-MANJARO'
-> Running build hook: [base]
-> Running build hook: [udev]
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [plymouth]
-> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.1-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'fallback'
-> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64-fallback.img -S autodetect --microcode /boot/intel-ucode.img
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.1-x86_64-fallback.img'
cscs
20 April 2023 18:56
14
Those are only warnings and can be safely ignored. You most likely do not need any of them. Reference the Arch Wiki article in the post above for more info.
cscs
20 April 2023 20:36
16
You can safely ignore the warnings, if you know that you do not use the affected hardware .
(emphasis mine)
Of course OP can choose to ignore them … but as the thread is about non-functioning hardware … its not out of the realm of possibiities that this is related.
Specifically this firmware is to do with USB host.
Try installing sof-firmware
and reboot.
I installed all of the “possibly missing firmware” packages and sof-firmware. After rebooting I double checked and the issue continues.
