I could not find a Cinnamon specific area for this. Please feel free to move.
After recent updates, the lock screen for Cinnamon will not allow the physical keyboard to gain access 99% of the time. It appears to not like either [Enter] key. Switching keyboards does not change a thing. If I type the password and click on the unlock button it works 100% of the time. If I bring up the virtual keyboard and painfully click through, the return key works on it.
Kernel: 5.15.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0 Desktop: Cinnamon
v: 5.6.5 tk: GTK v: 3.24.36 dm: LightDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: HP product: HP EliteDesk 800 G2 SFF v: N/A serial: <superuser required>
Chassis: type: 4 serial: <superuser required>
Mobo: HP model: 8054 v: KBC Version 05.39 serial: <superuser required> UEFI: HP
v: N01 Ver. 02.59 date: 09/13/2022
Info: quad core model: Intel Core i7-6700 bits: 64 type: MT MCP arch: Skylake-S rev: 3 cache:
L1: 256 KiB L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 2727 high: 2799 min/max: 800/4000 cores: 1: 2799 2: 2718 3: 2700 4: 2700
5: 2700 6: 2700 7: 2725 8: 2776 bogomips: 54417
Device-1: Intel HD Graphics 530 vendor: Hewlett-Packard driver: i915 v: kernel arch: Gen-9 ports:
active: DP-1,DP-2 empty: DP-3,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1912
Display: x11 server: X.Org v: 21.1.6 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96
Monitor-1: DP-1 pos: right model: Lenovo LEN T2224dA res: 1920x1080 dpi: 102
diag: 546mm (21.5")
Monitor-2: DP-2 pos: primary,left model: ViewSonic VG2732 Series res: 1920x1080 dpi: 82
diag: 790mm (31.1")
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
Sound API: ALSA v: k5.15.85-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Intel Ethernet I219-LM vendor: Hewlett-Packard driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:15b7
Local Storage: total: 8.19 TiB used: 2.48 TiB (30.2%)
ID-1: /dev/sda vendor: Samsung model: SSD 860 QVO 1TB size: 931.51 GiB speed: 6.0 Gb/s
serial: <filter>
ID-2: /dev/sdb vendor: Toshiba model: DT01ACA200 size: 1.82 TiB speed: 6.0 Gb/s
serial: <filter>
ID-3: /dev/sdc type: USB vendor: Seagate model: Backup+ Hub BK size: 5.46 TiB serial: <filter>
ID-1: / size: 915.53 GiB used: 44.77 GiB (4.9%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1
System Temperatures: cpu: 59.0 C pch: 46.5 C mobo: N/A
Packages: 1268 pm: pacman pkgs: 1262 pm: flatpak pkgs: 6
1: https: //manjaro.lucassymons.net/stable/$repo/$arch
2: https: //southfront.mm.fcix.net/manjaro/stable/$repo/$arch
3: http: //mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
4: https: //mirror.alpix.eu/manjaro/stable/$repo/$arch
5: https: //mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
6: https: //mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
7: https: //mirror.kamtv.ru/manjaro/stable/$repo/$arch
8: https: //download.nus.edu.sg/mirror/manjaro/stable/$repo/$arch
Processes: 326 Uptime: 1d 1h 22m Memory: 23.36 GiB used: 4.59 GiB (19.7%) Init: systemd v: 252
default: graphical Compilers: gcc: 12.2.0 clang: 14.0.6 Client: Cinnamon v: 5.6.5 inxi: 3.3.24
Moderator edit: Removed useless screenshot
In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
