Cinnamon - launchers for terminal apps not working
cinnamon
#1
I am currently trying to build Cinnamon 18.0.3 ISOs and noticed that the launcher for manjaro-architect will not do anything while running the exec command from the terminal works fine.
I then tried the launcher for htop in /usr/share/applications. It also does nothing.
So looks like the terminal=true line in the launcher has some kind of a problem.
Ideas anyone?
@Ste74 @Chrysostomus @Thanos_Apostolou @fhdk @philm
Manjaro-Cinnamon 18.0 released
#2
I have noted that anything Gnome based requires the locale to be set.
If locale is not set in locale.conf then terminal will not launch.
#3
Well the terminal does launch fine. Just the launcher files are not working … :thinking:
edit: locale is set anyway btw
#4
Nemo works here and so does the menu but the menu icon disappears still think its a panel problem as it seems random what works and doesn’t work for different setups.
#5
nemo? I am talking about the desktop launcher for manjaro-architect and the launcher for htop in /usr/share/applications …
But hey! manjaro-architect launched from the menu works just fine and so does htop! how’s that possible??
#6
So what is the difference between the launcher on the desktop and the launcher in /usr/share/applications
#7
I just tried this:
opened the menu and launched architect from there. works
deleted the desktop entry for architect and created a fresh one via menu right click > ‘Add to desktop’. Doesn’t work !
Very odd, indeed!
#8
Is Nemo used for the controlling the desktop in Cinnamon?
If so - it could be a regression in Nemo - but I have really no idea.
#9
#10
Yes. Probably a nemo issue … For now I will just remove the architect entry on the new ISO. It can still be launched from the menu or terminal dirctly if needed.
#11
Workaround I found for now is calling gnome-terminal directly from the launcher
Exec=gnome-terminal -- sudo /usr/bin/setup
:sunglasses:
