I’ve downloaded the Cinnamon ISO 3 times, direct and torrent, and keep getting the same mismatch sha256. The sig file also fails it’s check. I’m wondering if there is an error on the download page. Can someone please provide a sha256 from the actual image, not what is posted on the download page. Thank you
Could you provide a link or reference to the .ISO you downloaded, so we know which one? e.g. the one(s) from @DeLinuxCo or @sbk …?
Cheers. ![]()
Presumably you downloaded from manjaro.org. Please notice, the 3 ISOs listed under community images are not officially supported, and they were not updated. I think regardless of checksums it would be better to download a Cinnamon ISO from
The direct image on the main Manjaro downloads page links this iso to the direct download and the torrent:
manjaro-cinnamon-25.0.3-250609-linux612.iso
Here’s the link to the sha256: https://download.manjaro.org/cinnamon/25.0.3/manjaro-cinnamon-25.0.3-250609-linux612.iso.sha512
Aha, a bit of confusion there. You mention sha256 but the link is for the sha512. Not the same thing. ![]()
Ahh, it literally does not tell you what the checksum is, just the number. I could only assume sha256. The sha512 is correct!! Thank you for pointing out my ignorance (again!!) haha. Solved
The Cinnamon & i3 ISOs on the website are from well over a year ago, I recommend using the newer ISOs here:
