Downgraded to systemd v253.09
. Audio stopped working with systemd v253.10
. Using Linux kernel v6.5.1
. HW is an ASUS motherboard with integrated audio.
Could you please give us more information about your system with this command?:
inxi --full --admin --filter --width
and
journalctl -b -p err
Hmm, there was only one revert done with those: Comparing v253.9...v253.10 · systemd/systemd-stable · GitHub
Yes, that is weird. I don’t know what happened. I have updated to systemd 254.3-1
and audio working fine.
inixi’s ouput:
Kernel: 6.5.2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=fb733bb1-dfa2-4cde-9e9b-3e874ba4a2d1 rw quiet splash
resume=UUID=02d44c38-1a15-4dc7-a38a-9eefbb949f04 udev.log_priority=3
amd_pstate.shared_mem=1 amd_pstate=passive mitigations=off
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
Mobo: ASUSTeK model: ROG CROSSHAIR X670E GENE v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1415
date: 05/16/2023
Device-1: hidpp_battery_0 model: Logitech MX Ergo Multi-Device Trackball
status: discharging
Info: model: AMD Ryzen 9 7950X bits: 64 type: MT MCP arch: Zen 4 gen: 5
level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
model-id: 0x61 (97) stepping: 2 microcode: 0xA601203
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 16 MiB desc: 16x1024 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3223 high: 5881 min/max: 400/5881 boost: enabled scaling:
driver: amd-pstate governor: schedutil cores: 1: 5029 2: 2769 3: 3011 4: 3011
5: 2974 6: 3011 7: 2777 8: 3011 9: 3011 10: 3011 11: 3011 12: 5475 13: 3011
14: 3011 15: 3011 16: 3011 17: 2986 18: 3011 19: 3011 20: 3011 21: 3011
22: 3011 23: 3011 24: 3011 25: 3011 26: 3011 27: 3011 28: 5881 29: 3011
30: 3011 31: 3011 32: 3011 bogomips: 288115
Type: spec_rstack_overflow status: Vulnerable, no microcode
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled,
PBRSB-eIBRS: Not affected
Device-1: AMD Raphael vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2
code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-2 empty: DP-1,DP-3
bus-ID: 69:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 44.0 C
Device-2: Elgato Systems GmbH Facecam driver: hid-generic,usbhid,uvcvideo
type: USB rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 10-2:2
chip-ID: 0fd9:0078 class-ID: 0300 serial: <filter>
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.0
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 126 s-size: 774x435mm (30.47x17.13")
s-diag: 888mm (34.96")
Monitor-1: DP-2 mapped: DisplayPort-1 model: Gigabyte M32U serial: <filter>
built: 2022 res: 3840x2160 dpi: 140 gamma: 1.2 size: 697x392mm (27.44x15.43")
diag: 800mm (31.5") ratio: 16:9 modes: max: 3840x2160 min: 720x400
API: OpenGL v: 4.6 Mesa 23.1.7-1 renderer: AMD Radeon Graphics
(raphael_mendocino LLVM 16.0.6 DRM 3.54 6.5.2-1-MANJARO) direct-render: Yes
Device-1: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
bus-ID: 69:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-2: Medeli AudioPro X5 Microphone
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-3:2 chip-ID: 0a67:c003 class-ID: 0300
serial: <filter>
Device-3: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-6:3
chip-ID: 0b05:1a52 class-ID: 0300
API: ALSA v: k6.5.2-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.79 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0 chip-ID: 8086:15f3
class-ID: 0200
Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2725
class-ID: 0280
IF: wlp7s0 state: up mac: <filter>
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-7:8 chip-ID: 8087:0032
class-ID: e001
Local Storage: total: 9.1 TiB used: 6.2 TiB (68.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 34.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST6000VN0033-2EE110
size: 5.46 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: SC60 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
ID-1: / raw-size: 1.81 TiB size: 1.78 TiB (98.37%) used: 875.52 GiB (48.0%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: partition size: 8.02 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 51.8 C mobo: N/A gpu: amdgpu temp: 44.0 C
Fan Speeds (rpm): N/A
Processes: 606 Uptime: 24m wakeups: 2 Memory: total: 64 GiB
available: 61.94 GiB used: 8.05 GiB (13.0%) Init: systemd v: 253
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1718 libs: 298
tools: pamac,paru,yay pm: rpm pkgs: 0 pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
running-in: tmux: inxi: 3.3.29
journactl’s output:
Sep 11 08:22:28 jetm-rog-x670e-gene kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP7.UP00.DP40.UP00.DP68], AE_NOT_FOUND (20230331/dswload2-162)
Sep 11 08:22:28 jetm-rog-x670e-gene kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20230331/psobject-220)
Sep 11 08:22:28 jetm-rog-x670e-gene kernel: i2c i2c-0: Failed to register i2c client ITE8853:00 at 0x4e (-16)
Sep 11 08:22:28 jetm-rog-x670e-gene kernel: hub 12-0:1.0: config failed, hub doesn't have any ports! (err -19)
Sep 11 08:22:28 jetm-rog-x670e-gene (udev-worker)[644]: event8: Failed to call EVIOCSKEYCODE with scan code 0x7c, and key code 190: Invalid argument
Sep 11 08:22:37 jetm-rog-x670e-gene kernel: iwlwifi 0000:07:00.0: WRT: Invalid buffer destination
Sep 11 08:22:38 jetm-rog-x670e-gene kernel: iwlwifi 0000:07:00.0: WRT: Invalid buffer destination
Motherboard has a firmware update for audio codec ALC4080
ROG CROSSHAIR X670E GENE - BIOS & Firmware
Thank you. I will update the Mobo.
