Hey,
since I’ve made a system upgrade, the vid.stab (official repo) does not work anymore when I use it with ffmpeg (official repo). I receive the following errors:
[vid.stab - serialization @ 0x7ffc6b630b98] Cannot parse localmotion!
Last message repeated 33553466 times
[Parsed_vidstabtransform_2 @ 0x562883cd3780] error while preprocessing transforms
[Parsed_vidstabtransform_2 @ 0x562883cd3780] Failed to configure input pad on Parsed_vidstabtransform_2
Error reinitializing filters!
Failed to inject frame into filter network: Invalid argument
Error while processing the decoded data for stream #0:0
[AVIOContext @ 0x5628827c4780] Statistics: 0 bytes written, 0 seeks, 0 writeouts
Terminating demuxer thread 0
[AVIOContext @ 0x56288278a6c0] Statistics: 131072 bytes read, 0 seeks
Conversion failed!
Currently installed
ffmpeg: 2:6.0-8
vid.stab 1.1.1-1
I don’t know which the last versions were which worked for me, because I did not stablized any videos in the last weeks. When I loopup for the errors I only find some github issue threads from windows users some years ago, that used ffmpeg builds which had trouble to run vid.stab.
I’ve tried to downgrade vid.stab and ffmpeg but I can’t because there are too much dependency issues.
I hope anyone can help as I need do stabilize videos quite often due to my motion sickness.
