I have installed Manjaro KDE on my Chuwi GemiBook Pro, but the touchpad does not work. I saw a thread saying that it works with the LTS kernel (5.10.83-1) or 5.15.6-2, but I have 5.15.193-1, 6.12.48-1 and 6.17.1-0 installed. But it doesn’t work with any of them.
Any advice?
inxi -zv8 ✔
Kernel: 6.17.1-0-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.17-x86_64
root=UUID=b6d480d3-9437-4069-a6e2-abb34fafc446 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.18.0
Type: Laptop System: CHUWI Innovation And (ShenZhen)c0.
product: GemiBook Pro v: JS131_V0.15.8 serial: <superuser required>
Mobo: JS131 model: N/A serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: 5.19
date: 08/14/2021
ID-1: BAT0 charge: 38 Wh (100%) condition: 38/38 Wh (100%) volts: 7.6
min: N/A model: Intel SR 1 SR Real Battery type: Unknown serial: <filter>
charging: status: charging cycles: N/A
System RAM: total: 8 GiB available: 7.53 GiB used: 2.57 GiB (34.2%)
Array-1: capacity: 8 GiB slots: 2 modules: 2 EC: None
max-module-size: 4 GiB note: est.
Device-1: Controller0-ChannelA type: LPDDR4 detail: synchronous
size: 4 GiB speed: spec: 3200 MT/s actual: 2933 MT/s volts: note: check
curr: 1 min: 1 max: 1 width (bits): data: 32 total: 32
manufacturer: Micron Technology part-no: 53E1G32D4NQ-046WTE
serial: <filter>
Device-2: Controller0-ChannelB type: LPDDR4 detail: synchronous
serial: <filter>
Info: model: Intel Celeron N5100 bits: 64 type: MCP arch: Alder Lake
level: v2 built: 2021+ process: Intel 7 (10nm ESF) family: 6
model-id: 0x9C (156) stepping: 0 microcode: 0x24000026
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 smt: <unsupported> cache:
L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1.5 MiB desc: 1x1.5 MiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 800 min/max: 800/2800 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 8908
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_capabilities
arch_perfmon art bts cat_l2 cdp_l2 clflush clflushopt clwb cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept ept_ad erms est flexpriority flush_l1d fpu fsgsbase fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri
msr mtrr nonstop_tsc nopl nx pae pat pbe pclmulqdq pdcm pebs pge pln pni
popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep
sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip vme vmx vnmi vpid waitpkg x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
conditional; PBRSB-eIBRS: Not affected; BHI: SW loop, KVM: SW loop
Type: srbds status: Vulnerable: No microcode
Type: vmscape status: Not affected
Device-1: Intel JasperLake [UHD Graphics] driver: i915 v: kernel
arch: Gen-11 process: Intel 10nm built: 2019-21 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:4e61
class-ID: 0300
Device-2: Microdia Webcam Vitade AF driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 0c45:6366
alternate: fbdev,vesa dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: ChiMei InnoLux P140ZKA-BZ1 built: 2019 res:
mode: 2160x1440 hz: 60 scale: 125% (1.25) to: 1728x1152 dpi: 185 gamma: 1.2
chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.149
y: 0.059 white: x: 0.314 y: 0.329 size: 296x197mm (11.65x7.76")
diag: 356mm (14") ratio: 3:2 modes: 2160x1440
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.3-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (JSL)
device-ID: 8086:4e61 memory: 7.35 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.321 layers: 1 device: 0 type: integrated-gpu name: Intel
UHD Graphics (JSL) driver: mesa intel v: 25.2.3-arch1.2
device-ID: 8086:4e61 surfaces: N/A
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Jasper Lake HD Audio vendor: Emdoor Digital
driver: sof-audio-pci-intel-icl alternate: snd_soc_avs,
snd_sof_pci_intel_icl, snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:4dc8
class-ID: 0401
API: ALSA v: k6.17.1-0-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:3165 class-ID: 0280
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:4 chip-ID: 8087:0a2a
class-ID: e001
Local Storage: total: 238.47 GiB used: 12.3 GiB (5.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston
model: RBUSNS8154P3256GJ size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: E8FK11.C temp: 33.9 C scheme: GPT
ID-1: / raw-size: 58.52 GiB size: 57.3 GiB (97.91%) used: 12.3 GiB (21.5%)
fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: b6d480d3-9437-4069-a6e2-abb34fafc446
ID-2: /boot/efi raw-size: 362 MiB size: 361.3 MiB (99.80%)
used: 324 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5 label: EFI2
uuid: 8AE2-008D
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: SYSTEM
uuid: D049-E694
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 178.51 GiB fs: ntfs
label: Local Disk uuid: 1AB44A5FB44A3E0F
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 1000 MiB fs: ntfs
label: Recovery uuid: 06604AFF604AF4C9
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 8 rev: 2.0
Device-1: 1-1:2 info: MosArt Wireless Mouse type: mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 062a:4102 class-ID: 0301
Device-2: 1-6:3 info: Microdia Webcam Vitade AF type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 0c45:6366 class-ID: 0e02
serial: <filter>
Device-3: 1-8:4 info: Intel Bluetooth wireless interface type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:0a2a class-ID: e001
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
System Temperatures: cpu: 65.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1240 libs: 326 tools: pamac,yay pm: flatpak
pkgs: 0
1: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 198
1: cpu: 31.0% command: firefox pid: 1134 mem: 492.4 MiB (6.3%)
2: cpu: 18.8% command: firefox pid: 1367 mem: 268.7 MiB (3.4%)
3: cpu: 18.7% command: firefox pid: 1236 mem: 69.2 MiB (0.8%)
4: cpu: 12.9% command: konsole pid: 1822 mem: 203.8 MiB (2.6%)
5: cpu: 9.9% command: kwin_wayland pid: 615 mem: 199.8 MiB (2.5%)
Memory top: 5 of 198
1: mem: 492.4 MiB (6.3%) command: firefox pid: 1134 cpu: 31.0%
2: mem: 327.8 MiB (4.2%) command: plasmashell pid: 784 cpu: 2.8%
3: mem: 268.7 MiB (3.4%) command: firefox pid: 1367 cpu: 18.8%
4: mem: 264.3 MiB (3.4%) command: firefox pid: 1385 cpu: 7.3%
5: mem: 249.0 MiB (3.2%) command: firefox pid: 1345 cpu: 1.9%
Processes: 198 Power: uptime: 6m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.39
