Chromium weirdness
This topic may quickly become redundant, depending on when the next Stable Update comes along, and I’ve been hesitant to report these issues with this in mind. However, chromium is a fast-tracked package, and ever since the previous update to chromium itself, I’ve been noticing a few issues with it in Plasma on Wayland…:
  1. chromium will no longer load a URL clicked on from within an email in kmail — I don’t know whether it behaves similarly in other email clients, and I have not tested whether it can open URLs from anywhere other than an already open chromium window.
  2. It is no longer possible to copy a URL directly from the chromium address bar into the clipboard, whether by selecting it with the mouse, by choosing the “Copy” entry in the right-click popup menu, or by way of a keyboard shortcut. The copied entry in the clipboard is always a blank line.
  3. chromium no longer respects the qt color scheme, and although there is a button to use the qt color scheme — see the screenshot below :backhand_index_pointing_down: — clicking this button does not have any effect whatsoever. The buttons for using the gtk color palette or the built-in “Classic” theme do however work.
In terms of the color palette, this is what it used to look like, and what it should normally look like… :backhand_index_pointing_down:
… and this is what it looks like now. :backhand_index_pointing_down:
It also doesn’t appear to use any themes from the Chrome Store. You can install different chromium themes, but it won’t use them, and the section for configuring them in the Preferences will be blank until you remove the theme again and reload the page.
Again, this could all be due to some incompatibility between the two most recent chromium builds — which we take over from Arch verbatim — and the already outdated Plasma and qt versions in the Stable branch, in which case the problem should remedy itself upon the next Stable Update. I don’t have any problem with that, and I can wait — it’s not really a showstopper.
On the other hand, it could also be something with a much deeper underlying cause. And that’s why I’ve now decided to report it. :man_shrugging:
Testing…testing… ( Version 141.0.7390.122 from today ):slight_smile:
  1. I don’t use Kmail. But ctrl clicking a link in Libreoffice works
  2. copying works both ways by me
  3. It switches between classic and gtk by me. QT indeed does not seem to do anything
So, since i am on X11 XFCE and also stable, it has to be something Plasma/Wayland specific. Except the QT button bug
Yes, that is also what I suspect.
Well, Plasma is built upon the qt widget libraries, so… :man_shrugging:
Edit: Opening a link from within a telegram-desktop window does work, and that too is a qt-based application.
“Curiouser and curiouser”, said Alice. :face_with_raised_eyebrow:
Well, I also use Plasma & Wayland, don’t use Chromium, but I do have it installed.
Same here.
I’ve never used KMail and although I’ve checked I don’t have a use for it. (Except, perhaps, if it has some possibly hidden functionality that I am unaware of.) So can’t test anything with that.
sometime back i recall having a issue, wherein if i copied a URL from addressbar (in all manners as you described) and closed the tab before tried pasting the copied URL will go missing from clipboard. the copied item will only exist as far as the tab for where it was copied from existed (from what i figured), and it was surely in plasma/X11.
did a test on google-chrome now, not a issue anymore. will redo the test on chromium later, will let you know.
The 2025.12.08 Stable Update seems to have remedied matters.
