After the new update chromium complains about libilbc.so.2 being missing, checking said package it seems that it got updated to version 3.0.3-1 (libilbc.so.3), so chromium can’t find it.
I have tried reinstalling both.
I would try to re-install chromium:
sudo pacman -Syu chromium
I don’t see that chromium from repos depends on libilbc. Have you installed it from another source?
Chromium doesn’t require libilbc
. In fact, nothing in the repos require it. I would try removing libilbc
Ah, it was ffmpeg-full-git’s fault.
Closed and thanks for the help
