Hi,
has someone working GPU acceleration within chromium. Mine says most of it is deactivated. Do I need some more libs?
In chromium “chrome://gpu” says this:
### Graphics Feature Status
* Canvas: Software only, hardware acceleration unavailable
* Flash: Software only. Hardware acceleration disabled
* Flash Stage3D: Software only. Hardware acceleration disabled
* Flash Stage3D Baseline profile: Software only. Hardware acceleration disabled
* Compositing: Software only. Hardware acceleration disabled
* Multiple Raster Threads: Enabled
* Out-of-process Rasterization: Disabled
* OpenGL: Disabled
* Hardware Protected Video Decode: Disabled
* Rasterization: Software only. Hardware acceleration disabled
* Skia Renderer: Enabled
* Video Decode: Software only. Hardware acceleration disabled
* Vulkan: Disabled
* WebGL: Software only, hardware acceleration unavailable
* WebGL2: Software only, hardware acceleration unavailable
### Problems Detected
* Gpu compositing has been disabled, either via blacklist, about:flags or the command line. The browser will fall back to software compositing and hardware acceleration will be unavailable.
*Disabled Features: gpu_compositing*
### Version Information
|Data exported|2020-09-15T07:46:50.805Z|
|Chrome version|Chrome/85.0.4183.83|
|Operating system|Linux 5.8.5-1-MANJARO-ARM|
|Software rendering list URL|https://chromium.googlesource.com/chromium/src/+/94abc2237ae0c9a4cb5f035431c8adfb94324633/gpu/config/software_rendering_list.json|
|Driver bug list URL|https://chromium.googlesource.com/chromium/src/+/94abc2237ae0c9a4cb5f035431c8adfb94324633/gpu/config/gpu_driver_bug_list.json|
|ANGLE commit id|unknown hash|
|2D graphics backend|Skia/85 8ae885386e910cff8c543ae0d952a2c43f46e4ad|
|Command Line|/usr/lib/chromium/chromium --flag-switches-begin --enable-gpu-rasterization --ignore-gpu-blacklist --flag-switches-end|
### Driver Information
|Initialization time|211|
|In-process GPU|false|
|Passthrough Command Decoder|false|
|Sandboxed|true|
|GPU0|VENDOR= 0x0000 [Google Inc.], DEVICE=0x0000 [Google SwiftShader] *ACTIVE*|
|Optimus|false|
|AMD switchable|false|
|Driver vendor||
|Driver version|4.1.0.7|
|GPU CUDA compute capability major version|0|
|Pixel shader version|3.00|
|Vertex shader version|3.00|
|Max. MSAA samples|4|
|Machine model name||
|Machine model version||
|GL_VENDOR|Google Inc.|
|GL_RENDERER|Google SwiftShader|
|GL_VERSION|OpenGL ES 3.0 SwiftShader 4.1.0.7|
|GL_EXTENSIONS|GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth24 GL_OES_depth32 GL_OES_depth_texture GL_OES_depth_texture_cube_map GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_EGL_image_external_essl3 GL_OES_EGL_sync GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_framebuffer_object GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_surfaceless_context GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_texture_3D GL_OES_vertex_array_object GL_OES_vertex_half_float GL_EXT_blend_minmax GL_EXT_color_buffer_float GL_EXT_color_buffer_half_float GL_EXT_draw_buffers GL_EXT_float_blend GL_EXT_instanced_arrays GL_EXT_occlusion_query_boolean GL_EXT_read_format_bgra GL_EXT_texture_compression_dxt1 GL_EXT_texture_filter_anisotropic GL_EXT_texture_format_BGRA8888 GL_EXT_texture_rg GL_ARB_texture_rectangle GL_ANGLE_framebuffer_blit GL_ANGLE_framebuffer_multisample GL_ANGLE_instanced_arrays GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_CHROMIUM_color_buffer_float_rgba GL_CHROMIUM_texture_filtering_hint GL_NV_depth_buffer_float2 GL_NV_fence GL_NV_read_depth GL_NV_read_stencil|
|Disabled Extensions||
|Disabled WebGL Extensions||
|Window system binding vendor|Google Inc.|
|Window system binding version|1.4 SwiftShader 4.1.0.7|
|Window system binding extensions|EGL_KHR_create_context EGL_KHR_get_all_proc_addresses EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_fence_sync EGL_KHR_image_base EGL_KHR_surfaceless_context EGL_ANGLE_iosurface_client_buffer EGL_ANDROID_framebuffer_target EGL_ANDROID_recordable|
|Window manager|i3|
|XDG_CURRENT_DESKTOP|i3|
|GDMSESSION|i3|
|Compositing manager|No|
|System visual ID|0|
|RGBA visual ID|0|
|Direct rendering version|unknown|
|Reset notification strategy|0x0000|
|GPU process crash count|0|
|gfx::BufferFormats supported for allocation and texturing|R_8: not supported, R_16: not supported, RG_88: not supported, BGR_565: not supported, RGBA_4444: not supported, RGBX_8888: not supported, RGBA_8888: not supported, BGRX_8888: not supported, BGRA_1010102: not supported, RGBA_1010102: not supported, BGRA_8888: not supported, RGBA_F16: not supported, YVU_420: not supported, YUV_420_BIPLANAR: not supported, P010: not supported|
### Compositor Information
|Tile Update Mode|One-copy|
|Partial Raster|Enabled|
### GpuMemoryBuffers Status
|R_8|Software only|
|R_16|Software only|
|RG_88|Software only|
|BGR_565|Software only|
|RGBA_4444|Software only|
|RGBX_8888|Software only|
|RGBA_8888|Software only|
|BGRX_8888|Software only|
|BGRA_1010102|Software only|
|RGBA_1010102|Software only|
|BGRA_8888|Software only|
|RGBA_F16|Software only|
|YVU_420|Software only|
|YUV_420_BIPLANAR|Software only|
|P010|Software only|
### Display(s) Information
|Info|Display[0] bounds=[0,0 1600x1200], workarea=[0,0 1600x1200], scale=1, rotation=0, panel_rotation=0 external.|
|Color space (all)|{primaries:BT709, transfer:IEC61966_2_1, matrix:RGB, range:FULL}|
|Buffer format (all)|BGRA_8888|
|SDR white level in nits|100|
|Bits per color component|6|
|Bits per pixel|16|
### Video Acceleration Information
### Vulkan Information
### Device Performance Information
### Driver Information for Hardware GPU
|Sandboxed|true|
|Optimus|false|
|Driver vendor||
|Window manager|i3|
|GDMSESSION|i3|
|System visual ID|0|
|RGBA visual ID|0|
### Graphics Feature Status for Hardware GPU
* OpenGL: Disabled
* Vulkan: Disabled
### Problems Detected for Hardware GPU
### Log Messages
* [80412:80412:0915/094640.977876:ERROR:gl_surface_egl.cc(693)] : No suitable EGL configs found.
* [80412:80412:0915/094640.978357:ERROR:gl_surface_egl.cc(741)] : EGL Driver message (Error) eglGetConfigAttrib: Bad config.
* [80412:80412:0915/094640.978571:ERROR:gl_context_egl.cc(85)] : eglGetConfigAttrib failed with error EGL_BAD_CONFIG
* [80412:80412:0915/094640.979730:WARNING:vaapi_wrapper.cc(416)] : VAAPI video acceleration not available for angle
* [80412:80412:0915/094640.980355:ERROR:gl_surface_egl.cc(693)] : No suitable EGL configs found.
* [80412:80412:0915/094640.980620:ERROR:gl_surface_egl.cc(741)] : EGL Driver message (Error) eglCreatePbufferSurface: Bad config.
* [80412:80412:0915/094640.980766:ERROR:gl_surface_egl.cc(2001)] : eglCreatePbufferSurface failed with error EGL_BAD_CONFIG
* [80412:80412:0915/094640.980872:ERROR:gpu_info_collector.cc(63)] : gl::GLContext::CreateOffscreenGLSurface failed
* [80412:80412:0915/094640.980970:ERROR:gpu_info_collector.cc(267)] : Could not create surface for info collection.
* [80412:80412:0915/094640.981073:ERROR:gpu_init.cc(72)] : CollectGraphicsInfo failed.
* [80412:80412:0915/094640.996503:ERROR:viz_main_impl.cc(150)] : Exiting GPU process due to errors during initialization
* GpuProcessHost: The GPU process exited normally. Everything is okay.
* [80485:80485:0915/094641.207286:ERROR:vaapi_wrapper.cc(436)] : vaInitialize failed: unknown libva error
Kernel Version:
Linux warbird 5.8.5-1-MANJARO-ARM #1 SMP PREEMPT Tue Sep 1 16:22:54 CDT 2020 aarch64 GNU/Linux
